DATA SHEET
CURRENT SENSOR - LOW TCR
AUTOMOTIVE GRADE
PE_L series
5%, 1%, 0.5%
sizes
0201/0402/ 0603/ 0805/ 1206/ 2010/ 2512
Product specification – November 28, 2016 V.5
RoHS compliant & Halogen free
Chip Resistor Surface Mount
SERIES
PE_L
0201 /0402/ 0603/ 0805/ 1206/ 2010/ 2512
2
12
SCOPE
ORDERING INFORMATION - GLOBAL PART NUMBER
This specification describes PE
series current sensor - low TCR
with lead-free terminations made by
metal foil with ceramic substrate.
Global part numbers are identified by the series, size, tolerance, packing
type, temperature coefficient, taping reel and resistance value.
GLOBAL PART NUMBER
PE XXXX X X X XX XXXX L
(1)
APPLICATIONS
Consumer goods
Computer
Telecom / Datacom
Industrial / Power supply
Automotive
Alternative Energy
FEATURES
AEC-Q200 qualified
Halogen-free Epoxy
RoHS compliant
Products with lead-free
terminations meet RoHS
requirements
Pb-glass contained in electrodes,
resistor element and glass are
exempted by RoHS
Reduce environmentally
hazardous wastes
High component and
equipment reliability
None forbidden-materials used
in products/production
(2) (3) (4)
(5)
(6)
(7)
(1) SIZE
0201/ 0402/ 0603/ 0805/ 1206/ 2010/ 2512
(2) TOLERANCE
D = ± 0.5% (>10mΩ)
F = ± 1%
J = ± 5%
(3) PACKAGING TYPE
R = Paper/ PE taping reel
K = Embossed taping reel
(4) TEMPERATURE COEFFICIENT OF RESISTANCE
E = ± 50 ppm/°C
M = ± 75 ppm/°C
F = ± 100 ppm/°C
J = ± 350 ppm/°C
(5) TAPING REEL
07 / 7W / 7T / 47 / 57= 7 inch dia. Reel and specific rated power.
Detailed power rating are shown in the Table 2.
(6) RESISTANCE VALUE
5 mΩ to 910 mΩ
There are 3~5 digits indicated the resistance value. Letter R is decimal point.
Detailed coding rules of resistance are shown in the table of “Resistance rule of
global part number”.
(7) DEFAULT CODE
Letter L is the system default code for ordering only. (Note)
Low resistances applied to
current sensing
Resistance rule of global part
number
Resistance code rule
Example
0R001 = 1 mΩ
0RXXX
(1 to 910 mΩ)
0R1 = 100 mΩ
0R91 = 910 mΩ
ORDERING EXAMPLE
The ordering code of a PE2512
1W chip resistor, value 0.006 Ω
with ± 1% tolerance, supplied in 7inch tape reel is:
PE2512FKM070R006L
NOTE
1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions
"Lead-Free Process"
www.yageo.com
Nov. 28, 2016 V.5
PE_L
SERIES
3
12
MARKING
PE0201 / PE0402
No marking
YNSC123_1
Fig. 1
PE0603
5mΩ ≦ R≦ 50mΩ
51mΩ ≦ R≦ 910mΩ
10
51
Fig. 2 Value = 10 mΩ
2 digits
Value =51 mΩ
PE0805
5mΩ ≦ R≦ 50mΩ
010
Fig. 3 Value = 10 mΩ
51mΩ ≦ R≦ 910mΩ
051
3 digits
Value =51 mΩ
PE1206
5mΩ ≦ R≦ 50mΩ
51mΩ ≦ R≦ 910mΩ
R010
R051
Fig. 4 Value = 10 mΩ
Value = 51 mΩ
4 digits
The “R” is used as a decimal point; the other 3 digits are
significant.
PE2010 / PE2512
5mΩ ≦ R≦ 100mΩ
R010
Fig. 5 Value = 10 mΩ
4 digits
significant.
Outlines
For dimensions, please refer to Table 1
5mΩ ≦ R≦ 50mΩ
R010
51mΩ ≦ R≦ 910mΩ
R051
YNSC143
Fig. 5 Chip resistor outlines
www.yageo.com
Nov. 28, 2016 V.5
PE_L
SERIES
4
12
DIMENSION
Table 1 For outlines, please refer to Fig. 4
TYPE
RESISTANCE RANGE
L (mm)
W (mm)
H (mm)
I1 (mm)
PE0201
50 mΩ ≦ R ≦ 200 mΩ
0.60± 0.03
0.31± 0.04
0.27± 0.04
0.14± 0.06
PE0402
10 mΩ ≦ R ≦ 910 mΩ
1.00+0.10/-0.15
0.50+0.10/-0.15
0.35± 0.15
0.25± 0.10
5 mΩ , 10 mΩ , 15mΩ , 20 mΩ ≦ R ≦ 50 mΩ
1.60± 0.20
0.76± 0.25
0.35± 0.25
0.38± 0.25
51 mΩ ≦ R ≦ 910 mΩ
1.52± 0.25
0.76± 0.25
0.45± 0.10
0.38± 0.25
2.03± 0.25
1.27± 0.25
0.35± 0.25
0.38± 0.25
51 mΩ ≦ R ≦ 910 mΩ
2.03± 0.25
1.27± 0.25
0.55± 0.10
0.35± 0.20
5 mΩ
3.20± 0.25
1.60± 0.25
0.64± 0.25
0.64± 0.25
6 mΩ ≦ R ≦ 910 mΩ
3.20± 0.25
1.60± 0.25
0.64± 0.25
0.51± 0.25
5 mΩ ≦ R ≦ 6 mΩ
5.08± 0.25
2.54± 0.25
0.64± 0.25
1.47± 0.25
7 mΩ ≦ R ≦ 100 mΩ
5.08± 0.25
2.54± 0.25
0.64± 0.25
0.51± 0.25
6 mΩ ≦ R ≦ 100 mΩ
6.35± 0.25
3.18± 0.25
0.64± 0.25
0.76± 0.25
PE0603
PE0805
PE1206
PE2010
PE2512
Note:
1. For relevant physical dimensions, please refer to construction outlines.
2. Please contact with sales offices, distributors and representatives in your region before ordering.
www.yageo.com
Nov. 28, 2016 V.5
PE_L
SERIES
5
12
ELECTRICAL CHARACTERISTICS
Table 2
SERIES SIZE
0201
Fig. 4
PE
POWER RATING (1)
07
7W
1/20W 1/10W
TOLERANCE RESISTANCE RANGE
7T
47
57
50 mΩ ≦ R ≦ 200mΩ
10 mΩ ≦ R ≦ 910 mΩ
0402
1/16W 1/8W 1/6W 1/4W
0603
1/10W 1/5W 1/3W 2/5W 1/2W ± 0.5%(>10 mΩ )
0805
1/8W
1/4W 1/3W 1/2W
± 1%
20 mΩ ≦ R ≦ 910 mΩ
1206
1/4W
1/2W
1W
± 5%
5 mΩ ≦ R ≦ 910 mΩ
2010
1/2W
1W
5mΩ ≦ R≦ 100mΩ
2512
1W
2W
6mΩ ≦ R≦ 100mΩ
OF RESISTANCE
20mΩ ≦ R≦ 70mΩ ± 350ppm/℃
70mΩ
很抱歉,暂时无法提供与“PE2512FKM070R1L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.279401+0.63754
- 10+3.7038810+0.44728
- 25+3.1676425+0.38253
- 50+2.7556650+0.33278
- 100+2.15782100+0.26058
- 250+1.97419250+0.23841
- 500+1.60702500+0.19407
- 1000+1.274581000+0.15392
- 国内价格
- 5+0.82022
- 50+0.66877
- 150+0.59304
- 500+0.53625
- 2500+0.49082
