O705032768MEEA4SC
O705032768MEEA4SC
    YXC(扬兴科技)
    SMD7050_4P
    有源晶振 SMD7050_4P
O705032768MEEA4SC 数据手册
Crystal OscillatorsSMD CMOS Output 7.0 x 5.0 x 1.3 mm YSO751SR S eries Features . Small SMD seam sealed clock crystal oscillator units. 000 X . 5 X 1 2 XX C Y X .High precision characteristic covering up to wide frequency range. .Designed for automatic mounting and reflow soldering. .Tri-State function available. .Supply voltage range : 1.8 V ~ 5 V. .High stability, low jitter, low power consumption. .Main application : wireless communication, PC, and LCDM. .RoHS Compliant / Pb Free. Electrical Specifications Item / Type YSO751SR Output Type CMOS Output Load 15 pF, or specify Oscillation Mode Fundamental / 3rd Overtone Supply Voltage 1.8~5V Frequency Range 1 ~ 200 MHz Frequency Stability ± 10 ppm ~ ± 50 ppm Operating Temperature Range - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ Storage Temperature Range - 40 ~ + 85 ℃ , - 55 ~ + 125 ℃ Voltage Vol ( Max. ) / Voh ( Min. ) 90%Vdd min./10%Vdd max Rise ( Tr ) / Fall ( Tf ) Time 8 ns Max. Supply Current See Below Symmetry 40 ~ 60 % Standard Start-up Time 10 ms Max. Aging ( at 25 ℃ ) ± 3 ppm / year Max. Dimensions 125.000 .YXC XXXX Units: mm 1/2 ★ PART NUMBER GUIDE 部件号示例 Quartz Crystal Oscillator Dimensions Frequency Supply voltage (Hz) (V) O 12M 26M 7050 Definition YSX531SL YSO 7 51SR==7 5 .0.0×5.0 SMD SEAM TYPE e.g. O 7 05012MEEA4 SC Frequency Stability output Overall (ppm) E 4 Definition D:±20ppm E :±25ppm H :±50ppm S C C Description B:±10ppm Frequency Stability 频率稳定度 Material Operating Temp. Range A E Description Pin Operating Temp. 工作温度 C:-20~+70℃ I :-40~+85℃ X :Customer specified ★ INPUT CURRENT 工作电流 Vdc=1.8 ~ 3.3V Vdc=5.0V 15pF only 15pF only 1.0 ~ 35.999 MHz 25 mA max 1.0 ~ 35.999 MHz 20mA max 36.0 ~ 69.999 MHz 60mA max 36.0 ~ 69.999 MHz 40mA max 70.0 ~ 150 MHz 80mA max 70.0 ~ 150 MHz 60mA max ★ TAPING SPECIFICATION (Unit: mm) 编带规格 φ1.31 4.0 1.02 12 0° φ13 2.0 C B D G F E OSC-SMD7050 A A B 178±2.0 16.0±0.3 C D 8.40±0.15 5.80±0.15 E F G 7.88±0.1 1.90±0.1 58.0±1.0 1000 pcs per reel ★ REFLOW SOLDERING PROFILE 回流焊特性 Temperature (℃) 260℃ max ★ Test Circuit(测试电路) 220℃ 180℃ Frequency Counter +Vs A ③ Oscillator 4 3 + Vs Power Supply 1 V 0.1μF 2 ① ② Oscilloscope 15pF * Times (S) Pb free reflow A 2/2 ① Preheat ② Primary heat 220℃ 60sec. max ③ Peak 10sec. max. 160~180℃ 260℃ 120sec. max
O705032768MEEA4SC 价格&库存
很抱歉,暂时无法提供与“O705032768MEEA4SC”相匹配的价格&库存,您可以联系我们找货
