X5H027000DA1H-W
X5H027000DA1H-W
    HELE(加高电子)
    SMD5032_2P
    无源晶振 SMD5032_2P
X5H027000DA1H-W 数据手册
CRYSTAL RESONATOR Glass Sealing Package HSX530G Series Features: ■High precision and reliability with excellent heat resistance. ■Suitable for various applications. ■Ideal solution for product design less sensitive to space constraints. ■Primary solution for DIP type clock design looking to consider a switch to SMD type production. Dimension (mm): Internal Connections 5.0±0.2 12.000 H.ELE. YM 1.4 Max. 3.2±0.2 Frequency Recommended Land Pattern (mm) 2.6 1.6 2.4 2.0 0.8 1.1 3.8 Standard Specification: ITEM TYPE Frequency Range Mode Frequency Tolerance Frequency Stability over Operating Temperature Range Operating Temperature Load Capacitance Drive Level Equivalent Series Resistance Storage Temp. Range HSX530G 8 ~ 10 MHz 10 ~ 20 MHz 20 ~ 27 MHz Fundamental ±30ppm , ±50ppm (at. 25℃ ) 27 ~ 50 MHz ±30ppm, ±50ppm, or Specify 150Ω Max. -10 ~ +60 ℃ , or Specify Series, 8pF, 10pF, 12pF, or Specify 10μW (300μW Max.) 100Ω Max. 80Ω Max. ℃ -40 ~ +125 50Ω Max. *Packing Unit: 1,000pcs/Reel. HARMONY ELECTRONICS CORP. http://www.hele.com.tw
X5H027000DA1H-W 价格&库存
很抱歉,暂时无法提供与“X5H027000DA1H-W”相匹配的价格&库存,您可以联系我们找货
