SCDS5D28T-1R0M-S-N
SCDS5D28T-1R0M-S-N
    CHILISIN(奇力新)
    SMD,5.7x5.7mm
    功率电感 SMD
SCDS5D28T-1R0M-S-N 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BPSC Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Shielded Power Inductors - SCDS Series SCDS Series Features Applications  RoHS, Halogen Free and REACH Compliance  Magnetic shielded  Various package size and wide inductance range       AP Routers STBs LCD TVs and monitors Game consoles LED lightings DC/DC converters Product Identification  T : Packaging: Tape and Reel  CEC Internal No.: S: Base type terminals SCDS 3D16T-XXXX-S-N Shape and Dimensions Recommended Pattern Dimensions in mm TYPE SCDS3D16 Dimension in mm A B C D E TYPE A B C D 4+0 4+0 1.8+0 5.2 +0 1.0 SCDS3D16 4.6 1.6 1.4 4.6 SCDS 4D18 ~ 6D38 Shape and Dimensions Recommended Pattern Dimension in TYPE mm Dimension in A B C +0 E TYPE A B C +0 1.9 1.5 5.3 1.9 1.5 5.3 D SCDS4D18 4.7 ± 0.3 4.7 ± 0.3 2.0 6.9 1.5 SCDS4D18 SCDS4D28 4.7 ± 0.3 4.7 ± 0.3 3.0+0 6.9+0 1.5 SCDS4D28 +0 +0 mm SCDS4D40 4.7 ± 0.3 4.7 ± 0.3 6.9 1.5 SCDS4D40 1.9 1.5 5.3 SCDS5D18 5.7 ± 0.3 5.7 ± 0.3 2.0+0 8.2+0 2.0 SCDS5D18 2.15 2.0 6.3 5.7 ± 0.3 5.7 ± 0.3 +0 +0 2.0 SCDS5D28 2.15 2.0 6.3 +0 9.5 2.0 SCDS6D28 2.65 2.0 7.3 9.5+0 2.0 SCDS6D38 2.65 2.0 7.3 SCDS5D28 SCDS6D28 SCDS6D38 6.7 ± 0.3 6.7 ± 0.3 7+0 7+0 4 3.0 +0 3.0 4+0 8.2 SMD Shielded Power Inductors - SCDS Series Standard Specifications Stamp Inductance (H) RDC (mΩ) Max Rated Current (A) SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS SCDS 3D16 4D18 4D28 4D40 45 5D18 5D28 6D28 38 15 24 6D38 3D16 4D18 4D28 4D40 1.72 5D18 5D28 6D28 2.80 3.50 3.50 2.50 3.00 3.40 2.60 3.00 1R0 1.0 1R2 1.2 1R5 1.5 1R8 1.8 2R0 2.0 2R2 2.2 2R5 2.5 2R6 2.6 2R7 2.7 3R0 3.0 3R3 3.3 85 3R6 3.6 90 3R9 3.9 4R1 4.1 4R2 4.2 31 2.20 4R3 4.3 41 2.5Typ 4R7 4.7 38 31 22 5R0 5.0 38 31 24 5R3 5.3 38 5R4 5.4 5R6 5.6 6R0 6.0 6R2 6.2 6R3 6.3 6R8 6.8 7R3 7.3 7R4 7.4 8R2 8.2 8R6 8.6 8R7 8.7 8R9 8.9 100 10 120 12 150 15 180 18 220 22 270 330 390 23.6 52 2.56 60 70 38 75 15 19.5 1.55 27.5 31.3 1.50 1.35 29.0 72 45 22 48 2.20 2.10 18 35 18 1.20 1.32 2.04 2.50 4.6 1.90 18 43.3 110 49.2 2.40 20 33 56 24 24 27 25 20 1.10 1.28 1.60 1.04 1.57 0.88 1.44 3.60 3.4 1.90 2.40 3.00 2.10 3.00 64.8 27 2.60 57 162 72.0 44 76 1.95 0.90 0.84 1.32 2.8 170 1.60 1.90 2.40 3.10 1.90 2.40 2.90 1.90 76 1.60 100.9 27 0.80 1.17 2.50 35 96 45 51 2.25 27 180 170 200 1.40 1.80 2.40 2.50 1.35 1.65 2.15 2.30 0.78 108.9 46 100 50 50 31 0.73 0.76 1.12 2.6 54 2.10 31 245 117.5 2.30 53 0.68 1.04 1.60 58 1.85 34 2.20 116 210 280 128.3 320 131.6 360 149.0 400 166.0 430 480 235.0 27 620 570 33 675 694 39 470 65 65 38 153 76 70 53 196 103 84 57 210 110 95 92 290 122 128 96 261.0 330 175 142 331.3 386 189 165 800 383.7 520 212 210 47 950 587.0 595 250 560 56 1080 624.5 665 680 68 1300 699.0 820 82 914.8 101 100 1020 121 120 151 150 181 180 221 220 331 1700 2000 150 1.25 124 295 210 270 0.55 0.61 1.00 0.56 0.84 1.20 1.30 1.70 2.00 1.10 1.20 1.55 0.50 0.76 1.70 0.97 1.10 1.40 0.48 0.72 1.60 0.85 1.00 1.32 0.40 0.41 0.70 1.50 0.80 0.90 1.20 1.30 109 0.35 0.35 124 0.32 0.32 0.58 0.75 0.85 1.05 1.20 0.56 0.65 0.75 0.97 138 1.10 0.30 0.50 0.57 0.70 0.86 238 1.00 150 0.28 0.48 0.54 0.62 0.80 305 0.95 277 202 0.26 0.41 0.50 0.58 0.73 0.85 840 978 355 304 234 0.24 0.35 0.43 0.52 0.65 0.75 463 390 324 0.32 0.41 0.46 0.60 1200 0.70 520 535 358 0.29 0.36 0.42 0.54 0.65 0.45 0.18 0.20 1270 2840 1.8 1.6 1.4 0.27 1350 0.15 1540 1050 2000 1200 330 3400 391 390 3560 471 470 2500 561 560 3200 5500 3.50 0.95 155 105 3.80 2.60 22 105 6D38 0.24 0.22 0.29 0.20 0.28 1700 0.19 0.19 1800 0.18 0.18 0.08 0.15 1800 681 680 5200 0.10 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without advance notice. Please contact our sales department before ordering. 0.12 0.22 SMD Shielded Power Inductors - SCDS Series Note: When ordering, please specify tolerance code. Tolerance: M=±20% , T=±30% , N = +40-20%  Operating temperature range-30℃~100℃(Including self - temperature rise)  Rated Current:DC current that will cause L drop approximately 35% over its nominal value or DC current cause the temperature rising approximately △t=40℃, whichever is lower  Measure Equipment: Test Freq L:SCDS 3D16(100kHz/ 0.1V) , 4D28/ 4D40 (100kHz/ 1V) , SCDS 5D18/ 5D28/ 6D28/ 6D38 (10kHz/ 1V) SCDS 4D18: 1.0~8.2H (7.96MHz/ 1V), 10~150H (100kHz/ 1V) L:Agilent/ E4980 or HP4284A RDC:Chroma 16502 Rated Current: HP4284+42841A or WK3260B+WK3265B Tolerance Of Inductors  SCDS 3D16 1.5 ~ 220H ± 30%  SCDS 5D18 1.0 ~ 100H ± 30%  SCDS 4D18 1.0 ~ 150H ± 30%  SCDS 5D28 1.0 ~ 560H ± 30%  SCDS 4D28 1.2 ~ 680H ± 30%  SCDS 6D28 1.0 ~ 100H ± 30%  SCDS 4D40 2.2 ~ 22H ± 30%  SCDS 6D38 2.2 ~ 560uH ± 30%  Tolerance: M = ±20% , T = ±30% , N = +40-20% Packaging Specifications Tape Dimensions Reel Dimensions Dimensions in mm TYPE Tape Dimensions Reel Dimensions Quantity A0 B0 K0 D E W P P0 P2 A B C D PCS / REEL SCDS 3D16 4.1 4.1 2.0 1.5 1.75 12 8 4 2 178 60 13 13.2 1000 SCDS 4D18 5.3 5.3 2.4 1.5 1.75 12 8 4 2 330 100 13 13.4 2000 SCDS 4D28 5.3 5.3 3.4 1.5 1.75 12 8 4 2 330 100 13 13.4 2000 SCDS 4D40 5.35 5.35 4.1 1.55 1.75 12 8 4 2 330 100 13 13.4 1000 SCDS 5D18 6.2 6.2 2.2 1.5 1.75 12 8 4 2 330 100 13 13.4 2000 SCDS 5D28 6.2 6.2 3.2 1.5 1.75 12 8 4 2 330 100 13 13.4 2000 SCDS 6D28 7.25 7.25 3.35 1.55 1.75 16 12 4 2 330 100 13 16.0 1500 SCDS 6D38 7.1 7.1 4.1 1.55 1.75 16 12 4 2 330 100 13 16.0 1000 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without advance notice. Please contact our sales department before ordering.
SCDS5D28T-1R0M-S-N 价格&库存
很抱歉,暂时无法提供与“SCDS5D28T-1R0M-S-N”相匹配的价格&库存,您可以联系我们找货
SCDS5D28T-1R0M-S-N
库存:6104
