Power Inductors
Specification for Approval
立创
Customer:
Customer P/N:
Power Inductors
Product Name:
Coilank P/N:
New Released,
Approved by
APW12A80 Series
Revised]
Checked by
Prepared by
Jean.lin
Bruce.lan
Coilank Technology Co.,Ltd
ADD: No.39,Chingao Rd.,(305)Hsinpu,Hs inchu Hsien Taiwan,R.O.C
TEL : 00886-3-5894523 FAX : 00886-3-5894415
ADD: Unit D, 16/F Cheuk Nang Plaze 250 Hennessy Road, Wanchai HongKong
TEL : 00852-31135161 FAX : 00852-31121631
SZ Office TEL : 0755-29452870/3 FAX : 0755-61658369
HTTP : www.coilank.com
E-mail : sales@coilank.com
【For Customer approval Only】
Qualification Status:
Approved By
Date:
Full
Restricted
Verified By
Checked By
Comments:
Http://www.coilank.com
E-mail:sales@coilank.com
Rejected
Power Inductors
Change Note
Version
Comtent
Draw
Check
1
New Design
Lijun.lan
Emie.luo
2
Upgrade the Coilank P/N:APW-B to
APW-A
Bruce.lan
Jean.lin
Approval
Date
James.huang 2018.10.31
Jean.lin
2019.03.29
Coding
S02
S153
Power Inductors
1. External Dimensions (Unit:m/m)
TYPE
A
B
C
D
E
F
G
H
Q’TY/Reel
APW12A80
12.5Max
12.5Max
8.0Max
5.0Ref
7.6Ref
12.6Ref
5.4Ref
7.0Ref
500
2. Part Number Code
APW
A
A:
B:
C:
D:
E:
F:
12
B
A
C
80
D
M
E
Series Name
Dimensions(mm)
Materials
Thickness(mm)
Tolerance
Inductance
1R5
F
Power Inductors
12:12.5x12.5 Max
NO use
80:8.0 Max
M:±20%
1R5=1.5uH
3. Electrical Characteristics
Part Number
Inductance
(uH)
Test Frequency
(KHz)
DC Resistance
(mΩ)Max.
Saturation Current
(A)Max.
APW12A80M1R5
1.5
100KHz/0.25V
10.0
15.0
APW12A80M2R2
2.2
100KHz/0.25V
11.5
8.0
APW12A80M3R3
3.3
100KHz/0.25V
15.0
7.5
APW12A80M4R7
4.7
100KHz/0.25V
10.45
6.8
APW12A80M6R8
6.8
100KHz/0.25V
24.0
6.0
APW12A80M100
10.0
100KHz/0.25V
30.0
8.0
APW12A80M150
15.0
100KHz/0.25V
27.0
7.5
APW12A80M220
22.0
100KHz/0.25V
43.0
3.6
APW12A80M330
33.0
100KHz/0.25V
68.4
5.0
APW12A80M470
47.0
100KHz/0.25V
85.0
4.3
APW12A80M101
100.0
100KHz/0.25V
150.0
2.8
Power Inductors
Notes:
1)AEC-Q200 qualified.
2)All test data is referenced to 25℃ ambient.
3)Operating temperature range -40℃ to +125℃.
4)Isat: DC current(A) that will cause lo to drop approximately 35%.
5)The part temperature(ambient + temp rise)should not exceed 125℃ under worst case operating
conditions. circuit design,component placement, PWB trace size and thickness,airflow and other
cooling provisions all affect the part temperature,part temperature should be verified in the end
application.
4. Test Data
ELECTRICAL CHARCTERISTIC
MECHANICAL DIMENSIONS
SPEC
L(uH)
DCR(mΩ)
Isat(uH)
A(mm)
B(mm)
C(mm)
D(mm)
TOL
1.5
10.0
12.5
12.5
8.0
5.0
NO
±20%
Max
Max
Max
Max
Ref
1
1.53
5.26
15.0A
(L0A-L15.0A)
/L0A≤35%
1.43
12.01
11.96
7.53
OK
2
1.52
5.35
1.42
11.93
12.03
7.59
OK
3
1.49
5.56
1.39
11.96
12.02
7.58
OK
4
1.53
5.52
1.42
12.03
11.95
7.55
OK
5
1.56
5.46
1.45
12.02
12.02
7.52
OK
6
1.49
5.36
1.38
11.95
12.03
7.59
OK
7
1.48
5.46
1.38
11.95
11.94
7.58
OK
8
1.52
5.46
1.46
12.01
12.02
7.53
OK
9
1.47
5.46
1.37
11.99
11.95
7.51
OK
10
1.52
5.62
1.43
12.03
11.94
7.54
OK
Test Equipmets: IM3536,VR126,VR7210,Calipers
5. Test and Measurement Procedures
5.1 Test Conditions
5.1.1 Unless otherwise specified, the standard atmospheric conditions for measurement/test as:
a. Ambient Temperature: 20±15℃
b. Relative Humidity: 65%±20%
c. Air Pressure: 86KPa to 106KPa
5.1.2 If any doubt on the results, measurements/tests should be made within the following limits:
a. Ambient Temperature: 20±2℃
b. Relative Humidity: 65%±5%
c. Air Pressure: 86KPa to 106Kpa
5.2 Visual Examination
a. Inspection Equipment: 10X magnifier
Power Inductors
5.3 Electrical Test
5.3.1 Inductance (L)
a. Refer to the third item.
b. Test equipment: IM3536 LCR meter or equivalent.
c. Test Frequency and Voltage: Refer to the third item.
5.3.2 Direct Current Resistance (DCR)
b. Test equipment: VR126 or equivalent.
5.3.3 Current
b. Test equipment (see Fig.5.3.3-1): Electric Power, Electric current meter, Thermometer.
c. Measurement method (see Fig. 5.3.3-1):
1. Set test current to be 0 mA.
2. Measure initial temperature of chip surface.
3. Gradually increase voltage and measure chip temperature for corresponding current.
d. Definition of Temperature rise current: DC current that causes the temperature rise (△T
=40°C)from 20°C ambient (see Fig. 5.3.3-2).
Fig.5.3.3-1
Fig.5.3.3-2
5.4 Reliability Test
Item
Specifications
Test conditions
Temperature: 125±2℃.
Duration:1000hrs.
Measured at room temperature after
placing for 24±4 hrs.
5.4.1
High temperature storage
test
5.4.2
Temperature cycling test
No visible mechanical damage.
Inductance change: Within ±10%.
Condition for 1 cycle.
Step1:-40±2℃ 30min Min.
Step2:125±2℃, transition time 1min Max.
Step3:125±2℃ 30min Min.
Step4:Low temp, transition time 1min Max.
Number of cycles:1000.
Measured at room temperature after placing for 24±4
hrs.
Power Inductors
Item
Specifications
Test conditions
5.4.3
Biased humidity test
Humidity :85﹪±3 RH.
Temperature:85℃±2℃.
Duration : 1000hrs.
placing for24±4 hrs.
5.4.4
Operational life test
Temperature:105±2℃.
Duration :1000hrs.
5.4.5
Resistance to solvent test
Add aqueous wash chemical - OKEM
clean or equivalent.
Oscillation Frequency: 10~2K~10Hz for
20 minute.
Total Amplitude:1.52mm±10%.
Testing Time : 12 hours(20 minutes, 12
cycles each of 3 orientations).
5.4.6
Vibration test
Temperature (°C): 260 ±5 (solder temp).
Time (s): 10 ±1.
ramp/immersion and emersion rate:
25mm/s ±6 mm/s.
Number of heat cycles:1.
5.4.7
Resistance to soldering
heat test
Steam Aging: 8 hours ± 15 min.
Preheat: 150℃,60sec.
Solder: Sn99.5%-Cu0. 5%.
Temperature: 245±5℃.
Flux for lead free: Rosin. 9.5%.
Dip time: 4±1sec.
Depth: completely cover the termination.
5.4.8
Solderability test
5.4.9
Terminal strength (SMD) test
More than 95% of the terminal
electrode should be covered with
solder.
With the component mounted on a PCB
with the device to be tested,apply a 17.7
N (1.8 Kg) force to the side of a device
being tested. This force shall be applied
for 60 +1 seconds. Also the force shall be
applied radually as not to apply a shock
to the component being tested.
Power Inductors
6. Packaging, Storage
6.1 Tape and Reel Packaging Dimensions
6.1.1 Taping Dimensions (Unit: mm)
Please refer to Fig. 6.1.1-1
6.1.1-1
TYPE
APW12A80
A0
B0
W
E
F
P0
P
P1
12.7±0.1 12.7±0.1 24.0±0.3 1.75±0.1 11.5±0.1 4.0±0.1 16.0±0.1 2.0±0.1
D0
T0
K0
1.5±0.1
0.4±0.1
8.2±0.1
6.1.2 Reel Dimensions (Unit: mm)
Please refer to Fig. 6.1.2-1.
Fig. 6.1.2-1.
TYPE
A
B
C
D
APW12A80
24.5±2.0
330.0±2.0
100.0±2.0
28.5±2.0
Power Inductors
6.2 Packaging
6.2.1 The inner box specification: 350*340*40MM
Packing quantity: 500PCS/ box
Bubble bag:37*45CM
Job description: putting the air bubble bag products placed
inside the box, sealed with scotch tape
6.2.2 The outside box specification: 370*360*165MM
Packing quantity: 1500PCS/ box
Job description: will be outside the box bottom
sealed, inner box into the box.
a. With transparent tape sealed box at the top
b. The specified location with a box labels in the outer box.
c. If the mantissa box under a FCL with inner box or filling full
6.3 Storage
a.To maintain the solderability of terminal electrodes and to keep the packing material in good
condition, temperature and humidity in the storage area should be controlled.
b. Recommended conditions: -10℃~40℃, 70%RH (Max.)
c.The ambient temperature must be kept below 30℃.Even under ideal storage conditions,
solderability of products electrodes may decrease as time passes. For this reason, product should
be used with one year from the time of delivery.
d. In case of storage over 6 months, solderability shall be checked before actual usage.
Power Inductors
7. Recommended Soldering Technologies
7.1 Re-flowing Profile:
△ Preheat condition: 150~200℃/60~120sec.
△ Allowed time above 217℃: 60~90sec.
△ Max temp: 260℃
△ Max time at max temp: 5sec.
△ Solder paste: Sn/3.0Ag/0.5Cu
△ Allowed Reflow time: 2x max
7.2 Iron Soldering Profile:
△ Iron soldering power: Max.30W
△ Pre-heating: 150℃/60sec.
△ Soldering Tip temperature: 350℃Max.
△ Soldering time: 3sec Max.
△ Max.1 times for iron soldering
[Note: Take care not to apply the tip of the
soldering iron to the]
很抱歉,暂时无法提供与“APW12A80M2R2”相匹配的价格&库存,您可以联系我们找货
