BCRH2D18/HP-2R2N-NL
BCRH2D18/HP-2R2N-NL
    BC(台湾诚阳)
    SMD
    功率电感 SMD
BCRH2D18/HP-2R2N-NL 数据手册
ROH S Compliant 承 認 書 SPECIFICATION FOR APPROVAL CUSTOMER: CUSTOMER P/N PART NO: DESCRIPTION: PRODUCTS NO: PRODUCTS REV: DATE: SMD POWER INDUCTORS BCRH2D18/HP-2R2N 01 2018-6-11 PURCHASER CONFIRMED. APPROVAL BY CHECK BY DRAWN BY REMARK PROVIDER ENGINEER DEPT. APPROVAL BY CHECK BY chenlinli 誠 陽 實 業 有 限 公 司 TAIPEI OFF ICE TAIWAN CHENG YANG COMPONENT CORP 2F-1, NO. 176, Chine-Yi Road., Zhonghe District, New Taipei City, TAIWAN(R.O.C) 新北市中和區建一路 176 號 2 樓之一 POSTAL CODE: 23500 TEL NO.:+886-2- 8228-0930 FAX NO.:+886-2-8228-0929 E-mail:h21803@ms29.hinet.net 寶 誠 電 子 有 限 公 司 CHINA FACTORY ZHUHAI BAO CHENG ELECTRONICSCO.,LTD Guan Tang Industrial Park, Tang Jia Wan Town, Zhuhai City, Guangdong Province, CHINA 中國廣東省珠海市塘家灣鎮官塘工業區 POSTAL CODE: 519085 TEL NO:86-756-3383187 FAX NO:86-756-3380704 E-mail: baocheng@baocheng.biz 昆 山 誠 陽 電 子 有 限 公 司 CHINA FACTORY KUNSHAN CHENG YANG ELECTRONICSCO.,LTDP Qiang-An Road., High-Tech. Industrial Park, Kunshan City, Jiangsu Province, China 江蘇省昆山市高科技工業園區強安路 35 號 POSTAL CODE: 215300 TEL NO:86-512-57823500 FAX NO:86-512-57823503 E-mail: kscy@taiwan-chengyang.com.tw ROHS Compliant TEST DATA DIMENSION&ELECTRIC CHARACTER CUSTOMER: PART NO.: DESCRIPTION: SMD INDUCTOR SERIES NO: BCRH2D18/HP-2R2N 1.MECHANICAL DIMENSION UNIT:mm 2R2 2.RECOMMEND LAND PATTERN DIMENSIONS A 3.2MAX B 3.2MAX C 2.0MAX D 1.0REF E F G H I 3.SEPCIFICATIONS Part Number BCRH2D18/HP-2R2N L(0A) Rdc (mOHM) Inductance Typical Max 2.2uH±30% @100KHZ 0.25V 2.20 50.90 60.0 Heat Rating Current DC Amps.Idc(A) Saturation Current DC Amps.ldc(A) Typical Typical 1.60 1.60 (1). All test data is referenced to 25℃ ambient. (2). Operating Tenperature Rangr-30℃ to +100℃. (3). DC current(1.6A)that will cause an approximate△T of 40℃. (4). DC current(1.6A)that will cause Lo to drop approximately 35%. (5). The part temperature(ambient+temp rise)should not exceed 100℃ under worst case operating conditions.Circuit design,component placement,PWB trace size and thickness,airflow and other cooling provisions all affect the part temperature part temperature should be verified in the end appliation. 4.PACKAGING INFORMATION parts are packaged on 7"reels 1000 per reel,7000within each box,14000 per carton A0= 3.25mm B0=3.25mm 2R2 K0=2.3mm APPROVED BY: Zhu jinbai CHECKED BY: Carl Zhao BC019S0004 DRAWN BY:Peter Zhu ZYX.W Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: CUSTOMER P/N: CUSTOMER REV: TEST DATE:2018-6-11 PART NAME: SMD INDUCTOR BC PART NO:BCRH2D18/HP-2R2N BC REV: QUANTITY:5PCS TEST ITEM A B C SPEC. 3.20 3.20 2.00 MAX MAX MAX 01 3.00 3.03 1.87 02 3.02 2.98 1.89 03 3.04 3.01 1.90 04 3.06 3.02 1.89 05 3.04 3.02 1.91 X 3.03 3.01 1.89 σ 0.020 0.017 0.013 Cpk 2.75 3.64 2.71 D E F G H I J 06 07 08 09 10 11 12 13 14 15 APPROVED BY CHECKED BY PREPARED BY chenlinli TEST DATA NO:BWIEG0002-6A BC019S0004 K Rohs Compliant ZHUHAI BAOCHENG ELECTRONICS CO.,LTD TEST DATA FOR PREPRODUCTION SAMPLE CUSTOMER: CUSTOMER P/N: CUSTOMER REV: TEST DATE:2018-6-11 PART NAME: SMD INDUCTOR BC PART NO:BCRH2D18/HP-2R2N BC REV: QUANTITY:5PCS TEST ITEM L(0A) L(1.6A)/L(0A)·100% DCR(S-F) TEST 100KHZ 0.25V CONDITION SPEC. 2.2uH ±30% ≥65% AT DC 1.6A 01 1.93 98% 60mΩ MAX 50.2 02 1.97 98% 50.9 03 2.00 98% 52.2 04 1.99 99% 51.1 05 2.03 98% 50.1 06 07 08 09 10 11 12 13 14 15 X 1.98 50.90 σ 0.033 0.756 Cpk 4.45 4.01 1. TEST INSTRUMENTS: □HP-4285A METER □WK3260B METER □HP-4191A METER □CH-3200 METER □CH-310 METER □CH-3305 METER ■CD1068+CD1320 METER ■WK3260B+WK3265B METER □VR562 METER ■CH-502B DCR METER 2.CONDITION TEMPERATURE: 25℃ HUMIDITY: 65%RH TEST DATA NO:BWIEG0002-7A APPROVED BY CHECKED BY PREPARED BY chenlinli BC019S0004 ROHS Compliant ELECTRONICS CHARACTER TEST CHART CUSTOMER: PART NAME: SMD INDUCTOR TEMPERATURE RISE CURRENT DC:1.6A CUSTOMER P/N: TEST DATE:2018-6-11 BC PN:BCRH2D18/HP-2R2N SAMPLE CO: VR712+VR113 METER TEST INSTRUMENTS 80.0 3.5 64.0 2.8 48.0 2.1 32.0 1.4 16.0 0.7 0.0 INDUCTORS(uH) TEMPERATURE(℃) 0min 2.09 28.1 3min 1.99 52.1 100KHZ 0.25V TEST TERM: 2.INDUCTCMCE VS CURRENT 6min 1.98 53.9 9min 1.97 54.6 12min 1.96 55.1 15min 1.95 55.6 18min 1.94 55.9 TEST INSTRUMENTS: 20min 1.95 56.1 TIME VR116+VR7220 METER INDUCTORS(uH) 3.50 ● Saturated Current point 2.80 2.10 ■DTL=-35% 1.40 ▲DTL=-50% 0.70 0.00 INDUCTORS 0A 2.07 0.32A 2.06 0.25V TEST TERM: 3.INDUCTCMCE VS FREQUENCUY INDUCTORS(uH) 0.0 INDUCTORS(uH) TEMPERATURE (℃) 1.CURVES OF TEMPERATURE AND INDUCTAME VARIED WITH TP CARRENT 0.64A 2.06 0.96A 2.05 1.28A 2.04 1.6A 2.03 TEST INSTRUMENTS: 2.3A 1.37 2.36A 1.02 CURRENT (A) HP-4285A METER 3.50 2.80 2.10 1.40 0.70 0.00 INDUCTORS FREQUENCY(Hz) 1KHz 10KHz 50KHz 100KHz 300KHz 500KHZ 800KHZ 1MHZ 2.00 2.00 1.99 1.97 1.96 1.96 1.94 1.93 1.TEST CONDITION TEMPERATURE: 25℃ HUMIDITY: ≦ 65% RH APPROVED BY CHECKED BY PREPARED BY chenlinli
BCRH2D18/HP-2R2N-NL 价格&库存
很抱歉,暂时无法提供与“BCRH2D18/HP-2R2N-NL”相匹配的价格&库存,您可以联系我们找货
