36 Donghuan Road,Jitigang Village,Huangjiang,Dongguan,Guangdong Province,P.R.China
TEL :+86(0)769-38879888 Fax :+86(0)769-38879889 E-mail : yl@dgylec.com
PRODUCT SPECIFICATION SHEET
CUSTOMER
PRODUCT TYPE
: SMD X'TAL 2.5*2.0(4PAD)
NOMINAL FREQ.
: 24.000000 MHz
FL P/N
: 2S24000091
PREPARE
REVISION
: A2
CUSTOMER P/N
CUSTOMER'S APPROVAL&DATE
PREPPR
P PREP
QA
QA QA
PREP
QAQA
QA
APPROVED
PREP
FL CORPORATION
APPROVED
Jay Lee
CHECKED
QA
DESIGNED
QA
QA
APPROVED
QA
APPROVED
PREP
PREP
QA
QA
QA
QA
QA
QA Chen XuanRu
Jin QA
Qi
RoHS Compliant
2S24000091
TEL : +86(0)769-38879888 FL P/N:
FAX : 86(0)769-38879889
VER:
CONTENTS
A2
PAGE
‧ SPECIFICATION REVISION RECORD SHEET
2
‧ ELECTRICAL SPECIFICATIONS
3
‧ DIMENSIONS & MARKING
4
‧ STRUCTURE ILLUSTRATION
5
‧ RELIABILITY TEST SPECIFICATIONS
6
‧ PACKAGING REQUIREMENT
7/8
‧ SPECIFICATION OF THE ENVIRONMENT-RELATED SUBSTANCES
9
ATTACHMENT(optional)
‧ ELECTRICAL CHARACTERISTICS TEST
A
YES
NO
‧ TEMPERATURE CHARACTERISTICS TEST
B
YES
NO
PAGE:
1/9
VER:
2S24000091
A2
PAGE:
2/9
Rev.
Revise page
A0
N/A
A1
P.5、P.8
A2
P.9
Revise Contents
Date
Ref. No.
Reviser
Initial released
18-Sep-19
N/A
Chen XuanRu
P.5 change Electrode;P.8
change Bar Code Label
18-Sep-19
N/A
Chen XuanRu
change Specification of the
environment-related substances
23-Sep-19
N/A
Chen XuanRu
2S24000091
YL P/N:
A2
VER:
PAGE:
PRODUCT DESCRIPION
Standard atmospheric conditions
Unless otherwise specified. The standard range of atmospheric conditions for making measurement
and tests are as follow:
25±2℃
Ambient temperature :
40%~70%
Relative humidity :
If there is no doubt the results, measurement shall be made within the following limits:
25±2℃
40%~70%
Relative humidity :
Measure equipment
Electrical characteristics measured by S&A250B or equivalent.
Crystal cutting type
The crystal is using AT CUT (thickness shear mode)
Electrical Spec.
No.
Items
Remarks
Symbol
1 Nominal Frequency
Min
Typ
Max
Units
FL
24.000000
MHz
Fundamental
CL
8.0
pF
4 Frequency Tolerance
±30
ppm
at 25±2℃
5 Frequency Stability
±30
ppm
at -40~+95℃
(reference 25℃)
6 Shunt Capacitance
C0
2 Oscillation Mode
3 Load Capacitance
7 Aging (/1 year)
8 Operating Temperature
-40
9 Storage Temperature
3
ppm/year
at 25±2℃
95
-40
95
ESR
60
ohms
11 Insulation Resistance
IR
500
M-ohms
at DC 100V
12 Drive Level
DL
100
uW
10 Equivalent series resistance
±3
pF
3/9
VER:
DIMENSIONS unit:mm
2S24000091
A2
PAGE:
CONNECTION DIAGRAM (TOP VIEW)
#4
#3
#3
#4
#1
#2
#2
#1
Pin
#1
#2
#3
#4
Function
Xtal terminal (Input)
GND terminal
Xtal terminal (Output)
GND terminal
LAND PATTERN unit:mm
MARKING
Frequency
EX: 24.000MHz = 240
SUGGESTED REFLOW PROFILE
Temp.
Total time : 360 sec. Max.
Solder melting point :225 oC
10 sec. Max.
260 5
220
60 sec. Max.
180
150
120 sec. Max.
Time
4/9
VER:
2S24000091
A2
PAGE:
NO
COMPONENTS
MATERIALS
QTY
FINISH/SPECIFICATIONS
1
Cap(Lid)
Kovar(Fe+Co+Ni)
1
Ni plating
2
Base(Package)
Almina Ceramics (AI2O3)
1
3
Pad(Package)
Ni + Au
4
Ni+Au plating
4
Crystal blank
SiO2
1
5
Conductive adhesive
Ag
2
Silicone resin
6
Electrode
Noble metal
2
5/9
VER:
2S24000091
A2
PAGE:
6/9
RELIABILITY SPECIFICATIONS
1.MECHANICAL ENDURANCE
Test Item
Test Methods
No.
1 Drop Test
150 cm height, fall freely onto stainless plate 3 times.
2 Shock Test
3 Mechanical Shock
4 Vibration
5 Gross Leak
6 Fine Leak
7 Solderability
8
Resistance To
Soldering Heat
150g/150cm Height,3times in the direction of ±x, ±y, ±z on
concrete floor
JIS C6701
IEC-68-02-27
Device are shocked to half sine wave ( 1000 G ) three mutually
MIL-STD-202F
pendicular axes each 3 times. 1.0m sec. duration time
Frequency range
10 ~ 55 Hz
Amplitude
1.52 mm
MIL-STD-883E
Pendicular axes each test time 2 hours(x,y,z Axis)
Total test time 6 hours
Standard Sample For Automatic Gross Leak Detector Test
Pressure 2kg/cm2
Helium Bombing 4.5kgf/cm2 for 2 hr
MIL-STD-883E
MIL-STD-883E
o
o
Temperature
Immersing depth
Immersion time
Flux
215 C +/- 5 C
0.5 mm minimum
10 +/- 0.5 seconds
Rosin resin methyl alcohol
solvent ( 1 : 4 )
Pre-heat temperature
Pre-heat time
Test temperature
Test time
125 oC
60 ~ 120 sec.
260 +/- 5 oC
5 +/- 1 sec.
2.ENVIRONMENTAL ENDURANCE
Test Item
Test Methods
No.
o
o
9 High Temp. Storage
+ 125 C +/- 3 C for 500 +/- 12 hours
10 Low Temp. Storage
- 40 oC +/- 3 oC for 500 +/- 12 hours
MIL-STD-883E
MIL-STD-202F
MIL-STD-883E
Total 100 cycles of the following temperature cycle
1 cycle
o
125+/- 3 C
25 oC
11 Thermal Shock
-55+/- 3
o
MIL-STD-883E
C
30 min.
30 min.
10 min. max.
12 High Temp&Homidity
13
Pressure Cooker
Storage
85℃±3℃, RH 85%,500Hrs
JIS C5023
o
120 +/- 3 C, RH100%, 2 bar, for 240 hours
JIS C6701
VER:
2S24000091
A2
PAGE:
PACKING : (EIA-481-2)
16
2S1600F001
Dimension
PKG Type
2520(8mm)
A0
B0
K0
Unit : mm
T
W
E
F
2.25±0.1
2.70±0.1
0.75±0.1
0.25±0.05
8±0.3
1.75±0.1
3.50±0.1
P1
P2
D1
D0
P0
4±0.1
2±0.1
1±0.1
1.55±0.05
4±0.1
Standard Reel Quantity is 3,000
pcs per reel.
THE INSPECTION FOR TAPE TENSION
REMARK : NA
7/9
YL P/N:
VER:
2S24000091
A2
PAGE:
8/9
SMD PRODUCT PACKING STANDARD
Out-going packing instruction
Reel Packing
Inner Packing
standard:diameter 18cm
standard:L19.0xW19.0xH2.5cm
material:plastics
material:B corrugated paper
Carton
standard:L34.0xW22.0xH22.0cm
material:AB corrugated paper(10
boxes enter)
L1
L1
L1
The label instruction
Label Drawing
Mark Name of Article
Spec.
L1 条码标签
1.Date Code
Bar Code
2.Lot No.
Label
3.Part No.
(Chintz Paper) 4.Freq
5.Q'ty
Size
Printing
75x35mm White
Remark
Specifications on the label is for the use of templates with different product specifications may vary.
If customer specified requirements for labels packaging. please provide the operation procedure.
Range
Banned Substances
Products
Maximum
concentration
ppm(mg/kg)
Packing Material
Maximum
concentration
ppm(mg/kg)
5
5
40
100
5
5
10
10
5
5
5
5
40
100
40
100
40
100
40
100
No detect
No detect
N/A
很抱歉,暂时无法提供与“2S24000091”相匹配的价格&库存,您可以联系我们找货
