CS0805-5N6J-S
CS0805-5N6J-S
    CHILISIN(奇力新)
    固定电感器
CS0805-5N6J-S 数据手册
SMD Wire Wound Ceramic Chip Inductors - CS Series CS Series Due to technical expertise of accurately wounding skill, these chip inductors are designed as filtering, impedance matching, resonance and choke circuits for RF designer. The stand series as well as customer design to meet your needs of telecom & wireless products. Features Applications  RoHS Compliant RF products for cellular phone, GPS receiver, Base Station, Repeater,  Ceramic body and wire wound construction provide high SRFs. Wireless LAN/ Mouse/ Keyboard/ earphone, remote control, security  These ultra – compact inductors provided exceptional Q values, system and other RF modules. even at high frequencies.  Their ceramic construction delivers the highest possible SRFs as well as excellent Q values.  The non-magnetic coil form also assures the utmost in thermal stability, predictability and batch consistency.  CS series is standard parts for RF designers. Product Identification Shapes and Dimensions / Recommended Pattern CS0402 CS0603/0805/1008 Dimensions CS0402 CS0805 CS1008 CS0603 A Max B Max C Max D E F G H I J inch 0.047 0.028 0.026 0.010 0.020 0.009 0.022 0.026 0.014 0.018 mm 1.19 0.70 0.66 0.25 0.51 0.23 0.56 0.66 0.36 0.46 inch 0.093 0.068 0.06 0.028 0.050 0.020 0.040 0.070 0.040 0.030 mm 2.35 1.73 1.52 0.71 1.27 0.51 1.02 1.78 1.02 0.76 inch 0.115 0.110 0.083 0.046 0.080 0.020 0.060 0.100 0.040 0.050 mm 2.92 2.79 2.1 1.16 2.03 0.51 1.52 2.54 1.02 1.27 A B C D E F G H I J mm +0.2 1.02±0.1 0.51 0.76 0.33 0.86 1.02 0.64 0.64 1.6 -0.1 0.82 +0.2 -0.1 SMD Wire Wound Ceramic Chip Inductors - CS Series Electrical Characteristics Inductance (nH) Tolerance (±%) Q Min L Typ Q Typ L Typ Q Typ SRF (GHz) Min Rdc (Ω) Max Irms (mA) Max CS0402-1N0□-S 1.0 10 / 5 16 1.02 77 1.02 69 12.70 0.045 1360 Part Number 900MHz 1.7GHz CS0402-1N9□-S 1.9 10 / 5 16 1.72 68 1.74 82 11.30 0.070 1040 CS0402-2N0□-S 2.0 10 / 5 16 1.93 54 1.93 75 11.10 0.070 1040 CS0402-2N2□-S 2.2 10 / 5 19 2.19 59 2.23 100 10.80 0.070 960 790 CS0402-2N4□-S 2.4 10 / 5 15 2.24 51 2.27 68 10.50 0.068 CS0402-2N7□-S 2.7 10 / 5 16 2.58 42 2.60 61 10.40 0.120 640 CS0402-3N3□-S 3.3 10 / 5 19 3.10 65 3.12 87 7.00 0.066 840 CS0402-3N6□-S 3.6 10 / 5 19 3.56 45 3.62 71 6.80 0.066 840 CS0402-3N9□-S 3.9 10 / 5 19 3.89 50 4.00 75 6.00 0.066 840 CS0402-4N3□-S 4.3 10 / 5 18 4.19 47 4.30 71 6.00 0.091 700 640 CS0402-4N7□-S 4.7 10 / 5 15 4.55 48 4.68 68 4.77 0.130 CS0402-5N1□-S 5.1 10 / 5 20 5.15 56 5.25 82 4.80 0.083 800 CS0402-5N6□-S 5.6 10 / 5 20 5.16 54 5.28 81 4.80 0.083 760 CS0402-6N2□-S 6.2 10 / 5 20 6.16 52 6.37 76 4.80 0.083 760 CS0402-6N8□-S 6.8 10 / 5 20 6.56 63 6.93 78 4.80 0.083 680 CS0402-7N5□-S 7.5 10 / 5 22 7.91 60 8.22 88 4.80 0.10 680 CS0402-8N2□-S 8.2 10 / 5 22 8.50 57 8.85 84 4.40 0.10 680 CS0402-8N7□-S 8.7 10 / 5 18 8.78 54 9.21 73 4.10 0.20 480 CS0402-9N0□-S 9.0 10 / 5 22 9.07 62 9.53 78 4.16 0.10 680 CS0402-9N5□-S 9.5 10 / 5 18 9.42 54 9.98 69 4.00 0.20 480 CS0402-10N□-S 10 10 / 5 21 9.8 50 10.10 67 3.90 0.20 480 CS0402-11N□-S 11 10 / 5 24 10.7 52 11.20 78 3.68 0.12 640 CS0402-12N□-S 12 10 / 5 24 11.9 53 12.70 71 3.60 0.12 640 CS0402-13N□-S 13 10 / 5 24 13.4 51 14.63 57 3.45 0.21 440 CS0402-15N□-S 15 10 / 5 24 14.6 55 15.50 77 3.28 0.17 560 CS0402-16N□-S 16 10 / 5 24 16.6 46 18.86 47 3.10 0.22 560 CS0402-18N□-S 18 10 / 5 25 18.3 57 20.28 62 3.10 0.23 420 CS0402-19N□-S 19 10 / 5 24 19.1 50 21.10 67 3.04 0.20 480 CS0402-20N□-S 20 10 / 5 25 20.7 52 23.66 53 3.00 0.25 420 CS0402-22N□-S 22 10 / 5 25 23.2 53 26.75 53 2.80 0.30 400 CS0402-23N□-S 23 10 / 5 22 23.8 49 26.90 64 2.72 0.30 400 CS0402-24N□-S 24 10 / 5 25 25.1 51 29.50 50 2.70 0.30 400 CS0402-27N□-S 27 10 / 5 24 28.7 49 33.50 63 2.48 0.30 400 CS0402-30N□-S 30 10 / 5 25 31.1 46 38.50 39 2.35 0.35 400 CS0402-33N□-S 33 10 / 5 24 34.9 31 41.74 32 2.35 0.40 400 CS0402-36N□-S 36 10 / 5 24 39.5 44 48.40 53 2.32 0.44 320 CS0402-39N□-S 39 10 / 5 25 41.7 47 50.23 45 2.10 0.55 200 CS0402-40N□-S 40 10 / 5 24 39.0 44 47.40 33 2.24 0.65 320 CS0402-43N□-S 43 10 / 5 25 45.8 46 61.55 34 2.03 0.81 100 CS0402-47N□-S 47 10 / 5 20 50.0 38 - - 2.10 0.83 150 CS0402-51N□-S 51 10 / 5 25 56.6 40 - - 1.75 0.82 100 CS0402-56N□-S 56 10 / 5 22 62.8 42 - - 1.76 0.97 100 100 CS0402-68N□-S 68 10 / 5 22 78.2 36 - - 1.62 1.12 CS0402-82N□-S 82 10 / 5 20 - - - - 1.26 1.55 50 CS0402-R10□-S 100 10 / 5 20 - - - - 1.16 2.00 30       When ordering, please specify tolerance and packaging codes. Tolerance : J = ±5% , K = ±10% L , Q : Agilent/HP4291A+Agilent/HP16197A @250MHz SRF : Agilent/HP8753D / Agilent/HP8722ES Rdc : CH502BC/HP4338B Irms for a 15℃ rise above 25℃ ambient. SMD Wire Wound Ceramic Chip Inductors – CS Series Electrical Characteristics Part Number Test Inductance Tolerance Frequency (nH) (±%) (MHz) Q Min SRF (MHz) Min Rdc (Ω) Max 900 MHz 1.7 GHz Irms (mA) Max L Typ Q Typ L Typ Q Typ Color CS0603-1N6-S 1.6 250 10 / 5 24 12500 0.030 700 1.67 49 1.65 63 Red CS0603-1N8-S 1.8 250 10 / 5 16 12500 0.045 700 1.63 35 1.66 50 Black CS0603-3N6-S 3.6 250 10 / 5 22 5900 0.063 700 3.72 53 3.71 65 Red CS0603-3N9-S 3.9 250 10 / 5 22 6900 0.080 700 3.95 49 3.96 67 Brown CS0603-4N3-S 4.3 250 10 / 5 22 5900 0.063 700 4.32 50 4.33 70 Orange CS0603-4N7-S 4.7 250 10 / 5 20 5800 0.116 700 4.72 47 4.75 57 Violet CS0603-5N1-S 5.1 250 10 / 5 20 5700 0.140 700 4.93 47 4.95 56 Green CS0603-5N6-S 5.6 250 10 / 5 20 5800 0.170 700 5.53 56 5.86 77 Yellow White CS0603-6N3-S 6.3 250 10 / 5 20 5700 0.140 700 5.50 47 6.10 60 CS0603-6N8-S 6.8 250 10 / 5 27 5800 0.110 700 6.75 60 7.10 81 Red CS0603-7N5-S 7.5 250 10 / 5 28 4800 0.106 700 7.70 60 7.82 65 Brown CS0603-8N2-S 8.2 250 10 / 5 28 4700 0.109 700 8.30 60 8.50 60 White CS0603-8N7-S 8.7 250 10 / 5 28 4600 0.109 700 8.86 62 9.32 58 Yellow CS0603-9N5-S 9.5 250 10 / 5 28 5400 0.135 700 9.70 59 9.92 61 Blue CS0603-10N-S 10 250 10 / 5 / 2 31 4800 0.130 700 10.0 66 10.6 83 Orange CS0603-11N-S 11 250 10 / 5 / 2 33 4000 0.086 700 11.0 53 11.5 56 Gray CS0603-12N-S 12 250 10 / 5 / 2 35 4000 0.130 700 12.3 72 13.5 83 Yellow CS0603-15N-S 15 250 10 / 5 / 2 35 4000 0.170 700 15.4 64 16.8 89 Green CS0603-16N-S 16 250 10 / 5 / 2 34 3300 0.104 700 16.2 55 17.3 52 White CS0603-18N-S 18 250 10 / 5 / 2 35 3100 0.170 700 18.7 70 21.4 69 Blue CS0603-22N-S 22 250 10 / 5 / 2 38 3000 0.190 700 22.8 73 26.1 71 Violet CS0603-24N-S 24 250 10 / 5 / 2 37 2650 0.135 700 24.5 45 28.7 39 Black CS0603-27N-S 27 250 10 / 5 / 2 40 2800 0.220 600 29.2 74 34.6 65 Gray CS0603-30N-S 30 250 10 / 5 / 2 37 2250 0.144 600 31.4 47 39.9 28 Brown White CS0603-33N-S 33 250 10 / 5 / 2 40 2300 0.220 600 36 67 49.5 42 CS0603-36N-S 36 250 10 / 5 / 2 38 2080 0.250 600 39.4 47 52.7 24 Red CS0603-39N-S 39 250 10 / 5 / 2 40 2200 0.250 600 42.7 60 60.2 40 Black CS0603-43N-S 43 250 10 / 5 / 2 39 2000 0.280 600 47 44 64.9 21 Orange CS0603-47N-S 47 200 10 / 5 / 2 38 2000 0.280 600 52.2 62 77.2 35 Brown CS0603-56N-S 56 200 10 / 5 / 2 38 1900 0.310 600 62.5 56 97 26 Red CS0603-68N-S 68 200 10 / 5 / 2 37 1700 0.340 600 80.5 54 168 21 Orange CS0603-72N-S 72 150 10 / 5 / 2 34 1700 0.490 400 82 53 135 20 Yellow Green CS0603-82N-S 82 150 10 / 5 / 2 34 1700 0.540 400 96.2 54 177 21 CS0603-R10-S 100 150 10 / 5 / 2 34 1400 0.580 400 124 49 - - Blue CS0603-R11-S 110 150 10 / 5 / 2 32 1350 0.610 300 138 43 - - Violet CS0603-R12-S 120 150 10 / 5 / 2 32 1300 0.750 300 166 39 - - Gray CS0603-R15-S 150 150 10 / 5 / 2 28 990 0.920 280 250 25 - - White CS0603-R18-S 180 100 10 / 5 / 2 25 990 1.250 240 305 22 - - Black Brown CS0603-R22-S 220 100 10 / 5 / 2 25 900 2.100 200 - - - - CS0603-R27-S 270 100 10 / 5 / 2 24 900 2.800 170 - - - - Red CS0603-R33-S 330 100 10 / 5 / 2 25 900 3.890 100 - - - - Orange CS0603-R39-S 390 100 10 / 5 / 2 25 900 4.350 100 - - - - Yellow  When ordering, please specify tolerance and packaging codes.       Tolerance : G = ±2% , J = ±5% , K = ±10% Packaging: Clear tape and reel {standard}. L /Q: Agilent/HP4291A+ Agilent/HP16197A SRF: HP8753D/ HP4291A RDC: CH502BC/HP4338B Irms for a 15℃ rise above 25℃ ambient.  Operating temperature range from -40℃ to 125℃. (Including self - temperature rise) SMD Wire Wound Ceramic Chip Inductors – CS Series Electrical Characteristics Part Number Inductance (nH) Test Frequency (MHz) Tolerance Q (±%) Min Test Frequency (MHz) SRF Rdc Irms (MHz) Min (Ω) Max (mA) Max Color CS0805-2N8-S 2.8 250 10 / 5 80 1500 7900 0.06 800 Gray CS0805-3N0-S 3.0 250 10 / 5 65 1500 7900 0.06 800 White CS0805-3N3-S 3.3 250 10 / 5 50 1500 7900 0.08 600 Black CS0805-5N6-S 5.6 250 10 / 5 65 1000 5500 0.08 600 Orange CS0805-6N8-S 6.8 250 10 / 5 50 1000 5500 0.11 600 Brown CS0805-7N5-S 7.5 250 10 / 5 50 1000 4500 0.14 600 Green CS0805-8N2-S 8.2 250 10 / 5 50 1000 4700 0.12 600 Red CS0805-10N-S 10 250 10 / 5 / 2 60 500 4200 0.10 600 Blue CS0805-12N-S 12 250 10 / 5 / 2 50 500 4000 0.15 600 Orange CS0805-15N-S 15 250 10 / 5 / 2 50 500 3400 0.17 600 Yellow Green CS0805-18N-S 18 250 10 / 5 / 2 50 500 3300 0.20 600 CS0805-22N-S 22 250 10 / 5 / 2 55 500 2600 0.22 500 Blue CS0805-24N-S 24 250 10 / 5 / 2 50 500 2000 0.22 500 Gray Violet CS0805-27N-S 27 250 10 / 5 / 2 55 500 2500 0.25 500 CS0805-33N-S 33 250 10 / 5 / 2 60 500 2050 0.27 500 Gray CS0805-36N-S 36 250 10 / 5 / 2 55 500 1700 0.27 500 Orange CS0805-39N-S 39 250 10 / 5 / 2 60 500 2000 0.29 500 White CS0805-43N-S 43 200 10 / 5 / 2 60 500 1650 0.34 500 Yellow CS0805-47N-S 47 200 10 / 5 / 2 60 500 1650 0.31 500 Black CS0805-56N-S 56 200 10 / 5 / 2 60 500 1550 0.34 500 Brown CS0805-68N-S 68 200 10 / 5 / 2 60 500 1450 0.38 500 Red CS0805-82N-S 82 150 10 / 5 / 2 65 500 1300 0.42 400 Orange CS0805-91N-S 91 150 10 / 5 / 2 65 500 1200 0.48 400 Black CS0805-R10-S 100 150 10 / 5 / 2 65 500 1200 0.46 400 Yellow CS0805-R11-S 110 150 10 / 5 / 2 50 250 1000 0.48 400 Brown CS0805-R12-S 120 150 10 / 5 / 2 50 250 1100 0.51 400 Green CS0805-R15-S 150 100 10 / 5 / 2 50 250 920 0.56 400 Blue CS0805-R18-S 180 100 10 / 5 / 2 50 250 870 0.64 400 Violet CS0805-R20-S 200 100 10 / 5 / 2 50 250 860 0.68 400 Red CS0805-R22-S 220 100 10 / 5 / 2 50 250 850 0.70 400 Gray CS0805-R24-S 240 100 10 / 5 / 2 44 250 690 1.00 350 Red CS0805-R25-S 250 100 10 / 5 / 2 45 250 660 1.20 350 Yellow White CS0805-R27-S 270 100 10 / 5 / 2 48 250 650 1.00 350 CS0805-R33-S 330 100 10 / 5 / 2 48 250 600 1.40 310 Black CS0805-R39-S 390 100 10 / 5 / 2 48 250 560 1.50 290 Brown CS0805-R47-S 470 50 10 / 5 / 2 33 100 375 1.76 250 Violet CS0805-R56-S 560 25 10 / 5 / 2 23 50 340 1.90 230 Orange CS0805-R62-S 620 25 10 / 5 / 2 23 50 220 2.20 210 Yellow CS0805-R68-S 680 25 10 / 5 / 2 23 50 188 2.20 190 Green CS0805-R82-S 820 25 10 / 5 / 2 23 50 215 2.35 180 Blue CS0805-1R0-S 1000 25 10 / 5 / 2 20 50 100 2.50 170 Gray CS0805-1R2-S 1200 7.9 10 / 5 / 2 18 25 100 2.50 170 White  When ordering, please specify tolerance and packaging codes.  Tolerance : G = ±2% , J = ±5% , K = ±10%  L/Q: Agilent/HP4291A+Agilent/HP16197A  SRF: Agilent/HP8753D / Agilent/HP4291A  RDC: CH502BC/HP4338B  Irms for a 15℃ rise above 25℃ ambient.  Operating temperature range from -40℃ to 125℃. (Including self - temperature rise) SMD Wire Wound Ceramic Chip Inductors – CS Series Electrical Characteristics Part Number CS1008-10N-S CS1008-12N-S Test Tolerance Inductance Frequency (±%) (nH) (MHz) 10 12 50 50 10 / 5 / 2 10 / 5 / 2 Q Min 50 50 Test SRF Frequency (MHz) Min (MHz) 500 500 4100 3300 Color Coding Rdc (Ω) Max Irms (mA) Max 1 2ND 3RD 0.08 0.09 1000 1000 Brown Brown Black Red Black Black ST CS1008-15N-S 15 50 10 / 5 / 2 50 500 2500 0.10 1000 Brown Green Black CS1008-18N-S 18 50 10 / 5 / 2 50 350 2500 0.11 1000 Brown Gray Black CS1008-22N-S 22 50 10 / 5 / 2 55 350 2400 0.12 1000 Red Red Black CS1008-27N-S 27 50 10 / 5 / 2 55 350 1600 0.13 1000 Red Violet Black CS1008-33N-S 33 50 10 / 5 / 2 60 350 1600 0.14 1000 Orange Orange Black CS1008-39N-S 39 50 10 / 5 / 2 60 350 1500 0.15 1000 Orange White Black CS1008-47N-S 47 50 10 / 5 / 2 65 350 1500 0.16 1000 Yellow Violet Black CS1008-56N-S 56 50 10 / 5 / 2 65 350 1300 0.18 1000 Green Blue Black CS1008-68N-S 68 50 10 / 5 / 2 65 350 1300 0.20 1000 Blue Gray Black CS1008-82N-S 82 50 10 / 5 / 2 60 350 1000 0.22 1000 Gray Red Black CS1008-R10-S 100 25 10 / 5 / 2 60 350 1000 0.56 650 Brown Black Brown CS1008-R12-S 120 25 10 / 5 / 2 60 350 950 0.63 650 Brown Red Brown CS1008-R15-S 150 25 10 / 5 / 2 45 100 850 0.70 580 Brown Green Brown CS1008-R18-S 180 25 10 / 5 / 2 45 100 750 0.77 620 Brown Gray Brown CS1008-R22-S 220 25 10 / 5 / 2 45 100 700 0.84 500 Red Red Brown Red Violet Brown CS1008-R27-S 270 25 10 / 5 / 2 45 100 600 0.91 500 CS1008-R33-S 330 25 10 / 5 / 2 45 100 570 1.05 450 Orange Orange Brown CS1008-R39-S 390 25 10 / 5 / 2 45 100 500 1.12 470 Orange White Brown CS1008-R47-S 470 25 10 / 5 / 2 45 100 450 1.19 470 Yellow Violet Brown CS1008-R56-S 560 25 10 / 5 / 2 45 100 415 1.33 400 Green Blue Brown Brown CS1008-R62-S 620 25 10 / 5 / 2 45 100 375 1.40 300 Blue Red CS1008-R68-S 680 25 10 / 5 / 2 45 100 375 1.47 400 Blue Gray Brown CS1008-R75-S 750 25 10 / 5 / 2 45 100 360 1.54 360 Violet Green Brown CS1008-R82-S 820 25 10 / 5 / 2 45 100 350 1.61 400 Gray Red Brown CS1008-R91-S 910 25 10 / 5 / 2 35 50 320 1.68 380 White Brown Brown CS1008-1R0-S 1000 25 10 / 5 / 2 35 50 290 1.75 370 Brown Black Red Red CS1008-1R2-S 1200 7.9 10 / 5 / 2 35 50 250 2.0 310 Brown Red CS1008-1R5-S 1500 7.9 10 / 5 / 2 28 50 200 2.3 330 Brown Green Red CS1008-1R8-S 1800 7.9 10 / 5 / 2 28 50 160 2.6 300 Brown Gray Red CS1008-2R2-S 2200 7.9 10 / 5 / 2 28 50 160 2.8 280 Red Red Red CS1008-2R7-S 2700 7.9 10 / 5 / 2 22 25 140 3.2 290 Red Violet Red CS1008-3R3-S 3300 7.9 10 / 5 / 2 22 25 110 3.4 290 Orange Orange Red CS1008-3R9-S 3900 7.9 10 / 5 / 2 20 25 100 3.6 260 Orange White Red CS1008-4R7-S 4700 7.9 10 / 5 / 2 20 25 90 4.0 260 Yellow Violet Red CS1008-5R6-S 5600 7.9 10 / 5 / 2 18 7.9 45 4.0 240 Green Blue Red CS1008-6R8-S 6800 7.9 10 / 5 / 2 18 7.9 40 4.9 200 Blue Gray Red CS1008-8R2-S 8200 7.9 10 / 5 / 2 18 7.9 25 6.0 170 Gray Red Red CS1008-100-S 10000 2.52 10 / 5 / 2 18 7.9 25 8.0 150 Brown Black Orange  When ordering, please specify tolerance and packaging codes.  Tolerance : G = ±2% , J = ±5% , K = ±10%  Packaging: Clear tape and reel {standard}  L/Q: Agilent/HP4291A+ Agilent/HP16197A  SRF: Agilent/HP8753D / Agilent/HP4291A  RDC: CH502BC/HP4338B  Irms for a 15℃ rise above 25℃ ambient.  Operating temperature range from -40℃ to 125℃. (Including self - temperature rise)  Inductance would be correct Chilisin standard piece. 1st Code 3rd Code 2nd Code COLOR CODING SMD Wire Wound Ceramic Chip Inductors - CS Series Packaging Specifications Tape Dimensions Tape Dimensions Figure 1 Figure 2 Reel Dimensions Dimensions in mm TYPE Tape Dimensions Fig. Reel Dimensions Quantity A B T W P F K A B C D PCS / Reel CS0402 1 0.75 1.23 0.53 8 2 3.5 - 178 60 12 1.5 4000 CS0603 1 1.16 1.85 0.95 8 4 3.5 - 178 60 12 1.5 4000 CS0805 2 1.85 2.45 0.23 8 4 3.5 1.45 178 60 12 1.5 2000 CS1008 2 2.80 2.95 0.23 8 4 3.5 2.20 178 60 12 1.5 2000
CS0805-5N6J-S
物料型号:SMD Wire Wound Ceramic Chip Inductors - CS Series
器件简介:CS系列是符合RoHS标准的SMD线绕陶瓷芯片电感器。它们具有高自谐频率(SRF),即使在高频下也提供出色的Q值。这些超紧凑的电感器因其精确绕线技术而设计用于射频设计师的滤波、阻抗匹配、谐振和扼流电路。
引脚分配:文档中提供了不同尺寸的电感器的尺寸代码和推荐布局垫尺寸,例如CS0402、CS0603/0805/1008。
参数特性:电感器的电气特性包括标称电感值、公差、最小Q值、自谐频率(SRF)、最大直流电阻(Rdc)和最大直流电流(Irms)。
功能详解:CS系列电感器适用于射频产品,包括手机、GPS接收器、基站、中继器、无线局域网/鼠标/键盘/耳机、遥控器、安全系统等其他RF模块。
应用信息:适用于电信和无线产品,满足不同客户的设计需求。
封装信息:提供了不同型号的电感器的尺寸和封装规格,以及胶带尺寸和卷轴尺寸。
CS0805-5N6J-S 价格&库存
很抱歉,暂时无法提供与“CS0805-5N6J-S”相匹配的价格&库存,您可以联系我们找货
CS0805-5N6J-S
  • 50+0.02950
  • 500+0.02530
  • 1500+0.02220
  • 5000+0.01870
  • 25000+0.01780
库存:54
