SX25Y026000B31T-10.5
    TKD(泰晶)
    SMD2520_4P
    无源晶振 SMD2520_4P
SX25Y026000B31T-10.5 数据手册
STANDARD SPECIFICATION  产品规格书   Customer: Customer Part NO.: Type & Freq: SX-2520 26.000MHZ TKD Part NO.: SX25Y026000B31T-10.5 10.5PF ±10PPM Customer Approval : (PLEASE RETURN A COPY WITH APPOVAL) HUBEITKD ELECTRONICS TECHNOLOGY CO.,LTD. 湖北泰晶电子科技股份有限公司  SUIZHOU TAIWARD ELECTRONIC TECHNOLOGY CO.,LTD 随州泰华电子科技有限公司   APPROVED  CHECK  DESIGNER  J.T Wang Y Yang B Yang 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 1 REVISION Rev Date 00 2017-09-13 NO. Description of Revision History 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 New Publication Page 2 Spec Sheet Contents NO. Content Page 1 QUARTZ CRYSTAL UNIT SPECIFICATION 4 2 DIMENSIONS & MARKING 5 3 INSIDE STRUCTURE 6 4 EQUIVALENT CIRCUIT 6 5 RELIABILITY SPECIFICATION 6 PACKING 9 7 FLOW CHART 10 8 HARMFUL SUBSTANCE CONTENT STATEMENT 11 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 7-8 Page 3 ※ 1. QUARTZ CRYSTAL UNIT SPECIFICATION 1. Frequency: 26.000000MHz 2. Holder type : SX-2520 3. Oscillation Mode: Fundamental 4. Cutting Mode AT cut 5. Measurement Instrument S&A 250B(Measured FL) 6. Frequency Tolerance: ±10ppm at 25℃± 3℃ 7. Equivalent Series Resistance: 60ΩMax. 8. Storage Temperature Range: -40℃ ~ +85℃ 9. Operating Temperature -20℃ ~ +75℃ 10.Frequency Stability: Refer to Operating Temperature ±10PPM -20℃ ~ +75℃ 11. Drive Level: 100uW/Max 12. Load Capacitance(CL): 10.5pF 13. Shunt Capacitance: 3.0pF 14. Insulation resistance : 500MΩ min /DC 100V 15. Aging: ±3ppm / Year 16. PACKING: 3000PCS / Reel MAX 17. NOTE: 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 4 ※ 2.DIMENSIONS & MARKING 2.1 DIMENSIONS: 2.2 MARKING: Frequency (MHz) eg. 26.0=26.000000MHz 26.0 T YM Y: Year code M:Month code TKD Year : 1 2 3 4 5 6 7 8 9 0 Month : 1 2 3 4 5 6 7 8 9 10 11 12 Code: A B C D E F G H J K L M 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 5 ※ 3. INSIDE STRUCTURE No. COMPONENTS MATERIALS 1 Package Ceramic (AI2O3) 2 LID KV(Fe/Co/Ni) 3 Crystal blank SiO2 4 Electrode Noble Metal(Ag) 5 Adhesive Resin、Ag ※ 4. EQUIVALENT CIRCUIT 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 6 ※ 5. RELIABILITY SPECIFICATION NO. JIS C 6701 REFER ITEM 1 FREE FALL 2 VIBRATION CONDITIONS BASIS OF VERDICT FREE DROPPING FROM 75 cm HEIGHT 3 TIMES ON A HARD FREQUENCY:10〜55Hz, AMPLITUDE (TOTAL EXCURSION):1.5mm±15%, SWEEP TIME:1MIN, 3 DIRECTION(X, Y, Z) EACH F±5ppm CI±15% or 5Ω F±5ppm CI±15% or 5Ω FOR 2 Hrs. THE CRYSTAL UNIT SHALL BE SUBJECTED TO 100 SUCCESSIVE CHANGE OF TEMPERATURE CYCLES +85+4/-0℃ 3 TEMPERATURE CYCLE 30±3min +25±2℃ F±5ppm CI±15% or 5Ω -40+0/-6℃ 30±3min 1 Cycle 4 FINE LEAK HELIUM BOMBING 5.0〜5.5 Kgf / cm²,FOR 2 HOURS. PEAK:260℃ ± 10℃ ≤1×10-9Pa.m3/s Time:15±5 sec 15±5sec 260±10℃ 5 RESISTANCE TO SOLDERING HEAT 217℃以上 150~200℃ 90±30sec 6 SOLDERABILITY 7 HIGH TEMP. & HUMIDITY HIGH 8 TEMPERATURE STORAGE F±5ppm CI±15% or 5Ω 105±45sec THE LEAD IS IMMERSED IN A 260±5℃ SOLDER BATH WITHIN 2±0.6 SECONDS. STORED AT 60±2℃ AND HUMIDITY 90〜95% FOR 500±12 H. more than 95% of lead shall be covered by new solder F±5ppm CI±15% or 5Ω STORED AT 85±2℃ FOR 720±12H. ( If Customer's temperature request is higher than the standard,Temperature test must be done for customer F±5ppm CI±15% or 5Ω requirements. ) 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 7 LOW 9 TEMPERATURE STORAGE STORED AT –40±2℃ FOR 500±12H. ( If Customer's temperature request is lower than the standard,Temperature test must be done for customer F±5ppm CI±15% or 5Ω requirements. ) SHALL BE PRESSURIZED AT A SPEED OF APPROX.0.5mm/sec IN THE DIRECTION INDICATED BY THE ARROW UNTIL THE 10 TERMINAL STRENGTH BENDING WIDTH REACHES 3mm AND HELD FOR 5 SECONDS. F±5ppm CI±15% or 5Ω A R0.5 JIG SHALL BE USED TO APPLY A 10N DEAD LOAD IN THE DIRECTION INDICATED BY THE ARROW TO THE ELEMENT AND RETAIN IT FOR 10 SECONDS. 11 F±5ppm CI±15% or 5Ω STICKING TENDENCY A R0.5 PRESSURIZED BAR SHALL BE USED TO APPLY A 10N LOAD IN THE CENTER OF ELEMENT AND RETAIN ELEMENT 12 ASSEMBLY IT FOR 10 SECONDS. STRENGTH 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 F±5ppm CI±15% or 5Ω Page 8 ※ 6. PACKING 6.1 CARRIER TYPE(unit:mm) Marking Marking A B C D E F G H J K t 2.25 2.75 8.0 3.5 1.75 4.0 2.0 4.0 1.55 1.05 0.25 6.2 REEL(unit:mm) M N P Q R S U 178.0 60.2 11.5 8.0 2.5 11.0 13.0 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 9 ※ 7. FLOW CHART 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 10 ※ 8. HARMFUL SUBSTANCE CONTENT STATEMENT 随州泰华电子科技有限公司 SX-2520 产品 有毒有害物质或元素的名称及含量表 有毒有害物质或元素 材料名称 铅(Pb) 汞(Hg) 镉(Cd) 六价铬 (Cr(VI)) 多溴联苯 (PBB) 多溴二苯醚 (PBDE) BLANK ND ND ND ND ND ND Package ND ND ND ND ND ND LID ND ND ND ND ND ND Electrode Adhesive ND ND ND ND ND ND ND ND ND ND ND ND 备注 … … … … … … … … … … 拆分部件 n ○:表示该有毒有害物质在该部件所有均质材料中的含量均在 SJ/T11363-2006 规定的限量要求以下 ×:表示该有毒有害物质至少在该部件的某一均质材料中的含量超出SJ/T11363-2006 规定的限量要求。 (供应商应将其原材料按要求进行拆分,并按照此表格进行详细标注,对不能满足标准要求的零部件进行具体 的原因描述) 地址:湖北省随州市经济开发区深圳工业园泰华科技 TEL:0722-7509016 FAX:0722-7509036 Page 11
SX25Y026000B31T-10.5 价格&库存
很抱歉,暂时无法提供与“SX25Y026000B31T-10.5”相匹配的价格&库存,您可以联系我们找货
