■ Thick Film Chip Resistor — CR Series
■ Application
■ Features
─ Consumer electrical
─ Small size and light weight
─ Home Appliance: Air conditioner, Refrigerator
─ Reliability, high quality
─ Computer & relative products: Main board
─ Communication equipment: Cell phone, Fax machine
─ Power equipment: Power supply,lllumination equipment
─ Measuring instrument: Electric meter, Navigation equipment
■ Type Dimension
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
CR0201
0.60 ± 0.03
0.30 ± 0.03
0.23 ± 0.05
0.15 ± 0.05
0.15 ± 0.05
CR0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.15 ± 0.10
0.20 ± 0.10
CR0603
1.60 ± 0.20
0.80 ± 0.15
0.40 ± 0.10
0.30 ± 0.20
0.30 ± 0.10
CR0805
2.00 ± 0.20
1.25 ± 0.15
0.50 ± 0.15
0.30 ± 0.15
0.40 ± 0.15
CR1206
3.05 ± 0.10
1.60 ± 0.20
0.55 ± 0.15
0.40 ± 0.20
0.50 ± 0.20
CR1210
3.05 ± 0.10
2.50 ± 0.20
0.55 ± 0.15
0.50 ± 0.20
0.50 ± 0.20
CR1812
4.50 ± 0.10
3.10 ± 0.20
0.55 ± 0.05
0.55 ± 0.20
0.70 ± 0.20
CR2010
5.00 ± 0.20
2.50 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
CR2512
6.30 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
TEL: 886-7-8116611
FAX: 886-7-8115533
E-mail: service@everohms.com
http://www.everohms.com
■ Standard Electrical Specifications
Item
Type
CR0201
Rated Power Max Working
at 70℃
Voltage
0.05 W
CR0402
0.063 W
CR0603
0.1 W
CR0805
0.125 W
CR1206
Max Overload
Voltage
25V
T.C.R.
(PPM/℃)
50V
100V
75V
150V
150V
300V
0.5 W
1Ω~9.9Ω
±200
10Ω~10MΩ
±400
1Ω~9.9Ω
±300
10Ω~990Ω
±200
10Ω~1MΩ
1KΩ~10MΩ
±400
1Ω~9.9Ω
±200
10Ω~10MΩ
±100
10Ω~1MΩ
10Ω~10MΩ
±400
±200
10Ω~10MΩ
±100
10Ω~1MΩ
10Ω~10MΩ
±300
±200
200V
400V
0.75 W
1W
10.2Ω~1MΩ 10.2Ω~10MΩ
1Ω~10Ω
±200
10.2Ω~10MΩ
±300
±200
1Ω~10Ω
10.2Ω~10MΩ
±300
±200
1Ω~10Ω
10.2Ω~10MΩ
±300
±200
±100
10.2Ω~10MΩ
1Ω~10Ω
±100
CR2512
1Ω~10Ω
±100
CR2010
1Ω~9.9Ω
±300
±100
0.75 W
J(±5%)
-200/+400
±100
CR1812
Resistance Range
F(±1%)
G(±2%)
50V
0.25 W
CR1210
B(±0.1%)
D(±0.5%)
1Ω~10Ω
10.2Ω~10MΩ
For non-standard parts, please contact our sales dept.
Operating Temperature Range :−55℃〜+155℃.
Type CR1210/1812/2010/2512 :1Ω~10Ω(Alloy Film)
Type CR1210/1812/2010/2512 :>10Ω(Thick Film)
Type
0201
0402
0603
Jumper Resistance Value
Jumper Rated Current
TEL: 886-7-8116611
0805
1206
1210
1812
2010
2512
50mΩMax
0.5A
FAX: 886-7-8115533
1A
2A
● Low Ohm Chip Resistor
Item
Resistance Range
(mΩ)
Rated Power
at 70℃
Rated Voltage
Range
Max Overload
Voltage
T.C.R.
(PPM/℃)
CR0402
0.063 W
0.17~0.25V
0.624 V
±800
470~990
CR0603
0.1 W
0.1~0.31V
0.775 V
±800
100~330
±600
331~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
F(±1%)、J±(5%)
Type
CR0805
CR1206
CR1210
CR1812
CR2010
0.125 W
0.25 W
0.5 W
0.75 W
0.75 W
CR2512
1W
0.04~0.35V
0.875 V
0.05~0.5V
1.25 V
0.07~0.7V
1.75 V
0.08~0.8V
2.15 V
0.08~0.8V
2.15 V
0.1~0.99V
2.475V
● For non-standard parts, please contact our sales dept.
● Operating Temperature Range :−55℃〜+155℃.
● High Ohm Chip Resistor
■Standard Electrical Specifications
Item
Rated Power
at 70℃
Max Working
Voltage
Max Overload
Voltage
CR0402
0.063 W
50V
100V
CR0603
0.1 W
75V
150V
CR0805
0.125 W
150V
300V
CR1206
0.25 W
CR1210
0.5 W
Type
±200
200V
CR2010
0.75 W
CR2512
1W
T.C.R.
(PPM/℃)
400V
Resistance Range
F(±1%)
J(±5%)
10.1 MΩ
10.1 MΩ
54 MΩ
100 MΩ
TEL: 886-7-8116611
FAX: 886-7-8115533
● Trimmable Chip Resistor – TCR series
Item
Rated Power
at 70℃
Max Working
Voltage
Max Overload
Voltage
TCR0402
0.063 W
50V
100V
TCR0603
0.1 W
75V
150V
TCR0805
0.125 W
150V
300V
TCR1206
0.25 W
TCR1210
0.5 W
TCR1812
0.75 W
Type
0.75 W
TCR1218
1W
TCR2512
1W
Resistance
Tolerance
Resistance
Range
±15%
±200
200V
TCR2010
T.C.R.
(PPM/℃)
±20%
10Ω~1MΩ
±30%
400V
■ Parts Number Explanation
■ Example:
CR
0603
J
10R
P
05
Product Type
Size(Inch)
Resistor
Tolerance
Resistors
Value
Package
Quantity
CR
TCR
0201
0402
0603
0805
1206
1210
1812
2010
2512
TEL: 886-7-8116611
B:±0.1%
D:±0.5%
F:±1%
G:±2%
J:±5%
K:±10%
L:±15%
M:±20%
N:±30%
FAX: 886-7-8115533
P、Q:Paper Taping
E:Embossed Taping
D:Packed in a Bag
Optional
04:4000PCS
05:5000PCS
10:10000PCS
40:40000PCS
50:50000PCS
■ Appendix For SMD Chip Resistor
● Packaging Information
■ Dimension
Unit: mm
TYPE
SIZE
A
ψB
ψC
ψD
W
ψM
0201/0402
7”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
0402
13”
40K/50K Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
0603/0805/1206/
1210
7”
5K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
10”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
254±2.0
13”
20K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
7”
4K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
16.0±2.0
178±2.0
0603/0805
/1206
2010/2512/1812
■ Tapping Specification
■ Dimension
Unit: mm
Packaging Type
A
B
W
E
F
G
H
T
0201 0.45±0.1 0.75±0.1
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.35±0.1
0402 0.70±0.1 1.20±0.1
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.45±0.1
0603 1.05±0.2 1.80±0.2
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.60±0.1
0805 1.55±0.2 2.30±0.2
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.75±0.1
1206 1.90±0.2 3.50±0.2
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.75±0.1
1210 2.85±0.2 3.50±0.2
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
2.0±0.05 0.75±0.1
ψD
P
2.0±0.1
Paper Type
4.0±0.1
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Dimension
Unit: mm
Packaging Type
Embossed
Type
A
B
W
E
F
G
H
T
ψD
ψD1
T1
P
2010
2.80±0.2 5.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1
1.50±0.1 0.85±0.15
2512
3.40±0.2 6.70±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1
1.50±0.1 0.85±0.15 4.0±0.1
1812
3.30±0.2 4.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1
1.50±0.1 0.85±0.15
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Packing Material Data / Storage Data
■ Front & Back Lead Dimension
■ Top Adhesive Peel Off Strength:10~70g
■ Package
External Box Size
Contain Length Width Height
(Kpcs)
(mm)
(mm) (mm)
Inner Box Size
Reel Size H(mm)
1
13
2
24
3
36
5
60
10
113
25K
180
180
60
50K
180
180
110
150K
430
200
200
300K
400
400
200
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
TEL: 886-7-8116611
FAX: 886-7-8115533
● Reliability Test and Requirement
Test Item
Test Method
Temperature
Coefficient of
Resistance (T.C.R)
JIS C 5201-1
clause 4.8
-55℃ or +155℃, 25℃ is the reference temperature
Refer to Ratings
Short Time
Overload
JIS C 5201-1
clause 4.13
General:2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
±1:±(1.0%+0.05Ω)
±5:±(2.0%+0.1Ω)
Value 95% Coverage
Soldering Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
±1:±(0.5%+0.05Ω)
±5:±(1.0%+0.05Ω)
Value
很抱歉,暂时无法提供与“CR2010F910KE04Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10422
- 500+0.08306
- 1500+0.07139
