SSR024000I3CH
SSR024000I3CH
    HELE(加高电子)
    SMD7050_4P
    有源晶振 24MHz 3V~3.6V-10℃~+70℃
SSR024000I3CH 数据手册
1. Type Name: HSO751S 2. Output Frequency: 24.000000MHz 3. Absolute Maximum Ratings: Item Symbol Vdd terminal voltage Vdd Input terminal voltage Vcont Output terminal voltage Vout Output terminal current Iout Storage temp. range Tstr 4. Value -0.5 ~ 7.0 -0.5 ~ Vdd+0.5 -0.5 ~ Vdd+0.5 25 -55 ~ 125 Electric Specifications: Item Symbol Frequency tolerance Operating temp. range Supply voltage Current consumption 1 (#1 pin: open or "H") Current consumption 2 (#1 pin: "L" level) Symmetry Low level output voltage High level output voltage Rise & Fall time Pin #1 options Output load Low level input current High Level input current Low level input voltage High level input voltage Output disable time Output enable time Aging Δf/F Topr Vdd Min -50 -10 3.0 Idd1 Idd2 3.3 - - 25 mA - - 0.02 mA 2012/02/16 F. S. TSAI Check -10~70 ℃ Fig1,2 3.3V 60 % 0.1xVdd V V 10 ns YES C-MOS CL =30 pF (Idd1, Idd2 test at No Load) μA -100 μA 100 0.3xVdd V Fig3 3.3V 0.7xVdd V 100 ns 5 ms -5 5 ppm/year 25±3℃ 50 - Prepare C. H. WENG U. F. CHEN HARMONY Etc ppm ℃ V Condition Vdd Temp 3.3+/0.3V HSO751S SPECIFICATION Confirm Unit Max +50 +70 3.6 Duty 40 Vol Voh 0.9xVdd Tr & Tf - Iil Iih Vil Vih Tplz Tpzl - Value Typ - F :Output Frequency Δf =Oscillation Frequency – F Frequency Stability is inclusive of 25℃ Tolerance, operating temperature range, input voltage change, Load chang, first of aging , shock and vibration. Tittle Country of origin Date Unit V V V mA ℃ TAIWAN FACTORY SHEN ZHEN FACTORY Rev. Page SSR024000I3CH ELECTRONICS 25±3℃ CORP. 0 1 Fig. 1) Measurement Circuit : CL = Include jig & probe capacitance (Refer to 4) Switch H Open L Out term. Oscillation out Oscillation out High Z Fig. 2) Output Wave Form: Fig. 3) Input Output Condition: Tittle Country of origin HSO751S SPECIFICATION Date Confirm 2012/02/16 F. S. TSAI Check Prepare C. H. WENG U. F. CHEN HARMONY TAIWAN FACTORY SHEN ZHEN FACTORY Rev. Page SSR024000I3CH ELECTRONICS CORP. 0 2 5. Dimensions: Lot No.: Year : Last digit of the year Year Code 2000 2010 0 2001 2011 1 2002 2012 2 2003 2013 3 2004 2014 4 2005 2015 5 2006 2016 6 2007 2017 7 2008 2018 8 2009 2019 9 Month : Alphabet assign below Month Code 1 A 2 B 3 C 4 D 5 E 6 F 7 G 8 H 9 J 10 K 11 L 12 M Marking : Laser marking or Ink marking. Tittle Country of origin HSO751S SPECIFICATION Date Confirm 2012/02/16 F. S. TSAI Check Prepare C. H. WENG U. F. CHEN HARMONY Spec. No. TAIWAN FACTORY SHEN ZHEN FACTORY Rev. Page SSR024000I3CH ELECTRONICS CORP. 0 3
SSR024000I3CH 价格&库存
很抱歉,暂时无法提供与“SSR024000I3CH”相匹配的价格&库存,您可以联系我们找货
SSR024000I3CH
    • 1+4.56840
    • 10+4.46040
    • 30+4.38480
    库存:10
