Aluminum Electrolytic Type / Surface Mount Type
Capacitors
Surface
Mount Type
CE-KX
RoHS compliance
Low Impedance
Series
CE-ZX
(P.50)
10 to 20% less impedance than CE-AX series at hight frequencies.
● 105℃ 1,000 to 2,000hours
● Solvent proof (within 2 minutes)
CE-LX
(P.52)
Low ESR
Long Life
CE-KX
Low Impedance
CE-AX
(P.46)
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
6.3
10
16
25
35
50
63
80
100
CE-BE
Surge voltage
(V)
Room temperature
8.0
13
44
63
79
100
125
CE-BD
Category temperature range (℃)
CE-BS
Capacitance tolerance (%)
120Hz/20℃
CE-BSS
CE-FE
CE-LD
CE-FSS
CE-FS
CE-FS(High Voltage)
CE-FH
Dissipation Factor(tan δ)
Leakage current
(LC)
CE-ZX
M : ±20
φ4 to φ6.3
0.24
0.20
φ8 to φ16
0.28
0.24
0.14
0.12
0.12
0.10
0.08
0.07
0.20
0.16
0.14
0.14
0.12
0.10
0.08
The greater value of either 0.01CV or 3
Impedance ratio at
Iow temperature
Based on the value at −40℃ Z/Z20℃
120Hz, +20℃ −55℃ Z/Z20℃
Endurance
105℃
rated voltage applied
(With the rated
ripple current)
CE-ZC
0.16
Exceeding 1,000μF, +0.02 every 1,000μF
μA/after 2minutes (max)
CE-AX
CE-KX
tanδ
(max)
120Hz/20℃
−55 to +105
3
2
2
2
2
2
2
2
2
5
4
4
3
3
3
3
3
3
Test
CE-LX
φ4 to φ6.3 : 1,000hours, φ8 to φ16 : 2,000hours
△C/C
Within ±25% of the initial value
tanδ
Less than 200% of the specified value
LC
Less than the specified value
CE-GA
CE-LS
CE-PH
Polarity
(Cathode)
8D
470
16 K
CE-PS
CE-PF
CE-TH
CE-JX
CE-NP
CE-FN
48
0.3max
W
Lot No.
Rated Capacitance
Series Symbol
Rated Voltage(6.3V→6)
[ φD≥12.5 ]
Polarity
(Cathode)
8DT
3300
16 K
(Unit : mm)
C
CE-LF
CE-PC
[ φD≤10 ]
(P)
CE-LL
■ Marking, Dimensions
H
CE-LH(High Voltage)
φD
CE-LH
Lot No.
Indicated Only φD=16
Rated Capacitance
Series Symbol
L
R (+)
A pressure relief vent is provided
for φD=8 or bigger
(P)reference size
D±0.5
L±0.3
W±0.2
H±0.2
C±0.2
R
P
4
6.0
4.3
4.3
5.0
0.5 to 0.8
1.0
5
6.0
5.3
5.3
6.0
0.5 to 0.8
1.4
6.3
6.0
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
7.7
6.6
6.6
7.3
0.5 to 0.8
2.2
8
10.2
8.3
8.3
9.0
0.7 to 1.0
3.2
10
10.2
10.3
10.3
11.0
1.0 to 1.4
4.6
12.5
13.5±0.5
12.8
12.8
13.5
1.0 to 1.4
4.6
16
16.5±0.5
16.3
16.3
17.3
1.7 to 2.1
7.0
RoHS compliance
■ Size, Impedance, Rated Ripple Current
10
16
25
35
10
15
22
4×6.0
27
33
1.45
90
47
5×6.0
0.70
170
56
5×6.0
0.70
170
4×6.0
1.45
90
5×6.0
0.70
170
1.45
90
4×6.0
1.45
90
5×6.0
0.70
170
4×6.0
1.45
90
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
6.3×6.0
0.39
250
6.3×6.0
0.39
250
250
6.3×6.0
0.39
250
6.3×6.0
0.39
250
6.3×6.0
0.39
250
6.3×7.7
6.3×6.0
0.39
250
6.3×6.0
0.39
250
0.30
300
CE-BE
6.3×6.0
0.39
250
6.3×7.7
0.30
300
8×10.2 0.15
600
CE-BD
250
6.3×7.7
0.30
300
8×10.2 0.15
600
8×10.2 0.15
600
CE-BS
0.30
300
6.3×7.7
0.30
300
8×10.2 0.15
600
8×10.2 0.15
600
CE-BSS
300
8×10.2 0.15
600
8×10.2 0.15
600
8×10.2 0.15
600
10×10.2 0.080
850
CE-FE
8×10.2 0.15
600
8×10.2 0.15
600
8×10.2 0.15
600
10×10.2 0.080
850
12.5×13.5 0.058 1150
CE-LD
680
8×10.2 0.15
600
10×10.2 0.080
850
CE-FSS
1000
8×10.2 0.15
600
1500
10×10.2 0.080
850
6.3×6.0
100
6.3×6.0
0.39
250
150
6.3×6.0
0.39
250
6.3×6.0
0.39
220
6.3×6.0
0.39
250
6.3×7.7
330
6.3×7.7
0.30
470
10×10.2 0.080
250
0.39
6.3×6.0
68
0.39
4×6.0
850
3300
16×16.5 0.035 1800
CE-FS
16×16.5 0.035 1800
CE-FS
(High Voltage)
16×16.5 0.035 1800
2200
16×16.5 0.035 1800
CE-KX
16×16.5 0.035 1800
6800
CE-FH
CE-AX
16×16.5 0.035 1800
4700
Surface
Mount Type
6.3
4.7
Capacitors
V
μF
CE-ZX
CE-ZC
CE-LX
V
μF
50
63
80
CE-GA
100
2.2
6.3×6.0
2.70
42
3.3
6.3×6.0
2.40
45
45
6.3×6.0
2.40
45
6.3×7.7
4×6.0
2.55
64
5×6.0
2.00
10
6.3×6.0
0.52
215
6.3×6.0
22
6.3×6.0
0.52
215
6.3×7.7
33
6.3×7.7
0.44
47
6.3×7.7
0.44
4.7
55
6.3×6.0
2.40
1.00
90
6.3×7.7
2.00
65
2.00
65
0.80
135
8×10.2 0.90
140
8×10.2 0.90
140
243
8×10.2 0.35
280
8×10.2 0.90
140
10×10.2 0.50
220
243
8×10.2 0.35
280
10×10.2 0.50
220
12.5×13.5 0.24
500
8×10.2 0.35
280
12.5×13.5 0.24
500
12.5×13.5 0.24
500
10×10.2 0.20
480
12.5×13.5 0.24
500
16×16.5 0.14
800
12.5×13.5 0.24
500
16×16.5 0.14
800
16×16.5 0.14
800
68
100
8×10.2 0.22
400
150
220
10×10.2 0.13
585
330
12.5×13.5 0.10
800
800
CE-LH
CE-LH
(High Voltage)
CE-LL
CE-LF
CE-PC
CE-PH
CE-PS
CE-PF
CE-TH
CE-JX
CE-NP
CE-FN
16×16.5 0.065 1410
470
1000
12.5×13.5 0.14
CE-LS
16×16.5 0.060 1610
→Please use the higher voltage model in the next.
Please refer to page 14 for
ripple current frequency coefficients.
■ Part number KX
Case size:φDxL(mm)
16×16.5:CE-KXT
Rated ripple current
mArms(100kHz, 105℃)
Impedance(Ω)
max at 100kHz, 20℃
KXT
16 CE 3300 KX T
16 CE 470 KX
Series code
Rated capacitance
Type code
Rated voltage
Sn plating terminal option
Series code
Rated capacitance
Type code
Rated voltage
49
很抱歉,暂时无法提供与“63CE470KXT+D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.01560
- 10+5.89680
- 30+5.82120
- 100+5.73480
