HP221M400N310A
HP221M400N310A
    CAPXON(台湾丰宾)
    AEC_D25X31MM_TM
    贴片铝电解电容 AEC_D25X31MM_TM
HP221M400N310A 数据手册
HP Series HP Series Snap-in Type 105℃ Features ◆ Highly reliable capacitors that with high ripple current. ◆ Terminal spacing fixed at 10 mm for printed circuit board plug in. ◆ Aluminum case designed explosion-proof vent. ◆ Best for switching power supplies. ◆ For detail specifications, please refer to Engineering Bulletion No. E107 ◆ RoHS Compliant Specifications Item Performance Characteristics Operating Temperature Range Rated Voltage Range Capacitance Range Capacitance Tolerance Leakage Current (+20℃,max.) -40 to +105℃ 10 to 100 VDC 330 to 68000μF -25 to +105℃ 160 to 450 VDC 33 to 2200μF ±20% (120Hz, +20℃) I ≦ 0.02CV After 5 minutes with rated working voltage applied. Less than the value under table (%) μF VDC 47~390 470~3900 4700~8200 10000~22000 27000~47000 56000~68000 Dissipation Factor (tanδ,at 20℃,120Hz) 10~16 — 25 35 40 45 50 25~35 — 20 30 35 40 45 50~63 — 20 30 30 35 — 80~100 15 20 25 — — — 160~250 15 15 — — — — 315~450 20 20 — — — — 160 200~250 4 4 — — 400~450 8 — Impedance ratio max. Low Temperature Characteristics (at 120Hz) Load Life Shelf Life Rated voltage(V) Z - 25℃ Z+20℃ Z - 40℃ Z+20℃ 10 5 15 16 5 15 25 4 15 35 4 12 50 4 12 63 4 12 100 4 12 Test conditions Duration time :2000 Hrs Ambient temperature :+105℃ Applied voltage :Rated DC working voltage After test requirement at +20℃ Capacitance change :≦ ±20% of the initial measured value Dissipation factor :≦ 200% of the initial specified value Leakage current :≦ The initial specified value Test conditions Duration time :1000 Hrs Ambient temperature :+105℃ :None Applied voltage After test requirement at +20℃ : Same limits as Load life. Pre-treatment for measurements shall be conducted after application of DC working voltage for 30 minutes. Multiplier for Ripple Current vs. Frequency CAP(μF) Frequency(Hz) 50(60) 120 0.8 1 10<CAP≦100 0.8 1 100<CAP≦1000 0.8 1 1000<CAP 400 1.23 1.16 1.11 1K 1.36 1.25 1.17 10K 50K-100K 1.48 1.53 1.35 1.38 1.25 1.28 Diagram of Dimensions:(unit:mm) 182 HP Series Case Size φDxL(mm) 4700 6800 8200 10000 12000 15000 18000 22000 27000 Size 22 Ripple 22x26 1.24 22x26 22x26 22x31 1.56 2.04 2.20 22x31 22x36 22x36 2.34 2.49 2.76 22x36 22x41 2.94 3.12 22x46 3.48 33000 39000 47000 56000 68000 WV(SV) Cap φD (μF) 1500 2200 3300 3900 4700 5600 6800 8200 10000 12000 15000 22 Size Ripple 10 (13) Size 25 Ripple 25x26 25x26 25x26 1.56 2.04 2.20 25x26 25x26 25x31 25x31 25x36 2.40 2.60 2.76 2.94 3.12 25x36 25x46 3.48 3.72 25x51 4.10 Size 30 Ripple 30x26 30x26 2.80 30x26 30x31 30x31 30x36 3.08 3.30 3.48 3.72 30x41 30x46 30x51 4.10 4.38 4.64 25 (32) 25 30 Size Ripple Size Ripple 1.03 22x26 1.48 25x26 1.48 22x26 22x31 22x31 22x31 1.88 1.92 2.25 2.60 25x26 1.90 30x26 1.92 25x26 2.60 30x26 2.60 22x36 22x41 3.14 3.50 25x31 25x36 3.14 3.50 30x26 30x31 3.14 3.50 22x46 4.02 25x41 25x46 25x51 4.02 4.58 4.82 30x31 30x36 30x41 4.02 4.58 4.82 30x46 5.12 22000 27000 33000 WV(SV) 22 Cap φD Size Ripple (μF) 680 1000 22x26 0.84 1200 22x26 1.10 1500 22x31 1.12 22x26 1.50 1800 22x331 1.62 2200 22x31 1.65 22x31 1.85 2700 22x36 1.97 22x36 2.24 3300 3900 4700 5600 6800 8200 10000 12000 15000 50 (63) 25 30 Size Ripple Size Ripple 25x26 1.12 25x26 25x26 25x31 25x31 1.65 1.85 1.98 2.24 22x41 2.54 25x36 2.54 22x46 2.95 22x51 3.10 25x36 25x41 25x41 25x46 25x46 25x51 2.80 3.01 3.02 3.15 3.23 3.35 35 Ripple 2.20 22x26 18000 Size 35x27 3.20 35x27 35x27 35x32 35x32 35x37 35x42 35x52 3.48 3.65 3.85 4.10 4.38 4.64 4.80 35 Size Ripple 35x27 3.50 35x27 35x32 35x32 35x37 35x37 35x42 35x47 35x52 4.02 4.58 4.79 4.82 5.12 5.30 5.47 6.09 35 Size Ripple 22 Size Ripple 22x26 1.17 22x26 1.53 22x31 1.65 22x31 2.02 22x31 2.20 22x31 2.79 22x36 2.97 22x36 3.06 22x41 3.24 22x51 3.51 16 (20) Size 25 Ripple Size 30 Ripple Size 35 Ripple 25x26 1.55 25x26 2.02 30x26 2.02 25x26 25x31 25x31 2.79 2.97 3.06 30x26 2.81 30x26 3.06 25x36 25x41 25x46 25x46 25x51 25x51 3.24 3.42 3.51 4.08 4.25 4.30 30x26 3.24 35x32 3.24 30x36 30x36 3.51 4.08 35x32 35x32 3.54 4.08 30x41 30x46 4.30 4.83 35x32 35x37 4.30 4.83 30x51 5.78 35x42 35x47 35x52 5.78 6.32 7.05 35 (44) 22 25 30 35 Size Ripple Size Ripple Size Ripple Size Ripple 22x26 1.26 22x26 1.35 25x26 1.45 22x31 1.45 22x26 1.80 25x26 1.90 30x26 1.92 22x31 1.90 22x31 2.23 22x36 2.42 25x26 2.30 30x26 2.54 25x31 2.44 22x36 2.89 25x31 2.89 30x26 2.89 22x41 3.24 25x36 3.24 30x26 3.21 35x27 3.24 30x31 3.43 22x51 3.57 25x41 3.57 30x31 3.57 35x27 3.57 25x46 3.96 30x36 3.96 35x27 3.75 35x32 4.00 25x51 4.21 30x41 4.21 35x32 4.21 30x46 4.69 35x37 4.69 35x42 5.07 35x52 63 (79) 22 25 30 Size Ripple Size Ripple Size Ripple 22x26 0.70 22x26 0.85 25x26 0.85 22x26 0.98 22x26 1.10 25x26 1.12 30x26 1.14 22x31 1.15 22x31 1.40 25x26 1.40 Size 5.50 35 Ripple 30x26 1.65 22x36 22x41 1.65 2.07 25x31 25x36 1.65 2.07 30x26 30x26 1.65 2.07 30x26 2.24 2.48 30x36 3.05 35x27 3.05 2.95 2.40 2.54 2.92 3.07 3.43 35x27 35x27 25x36 25x41 25x41 25x46 25x51 2.48 2.49 2.66 2.95 2.46 2.55 30x31 30x26 30x31 30x31 22x46 22x51 30x41 3.43 35x32 3.43 30x36 30x41 30x41 3.14 3.20 3.26 35x27 35x32 35x32 3.10 3.20 3.26 30x46 3.86 35x37 3.86 30x51 4.64 35x42 4.64 30x46 30x51 3.58 4.11 35x37 35x42 35x47 35x52 3.58 4.11 4.62 5.05 35x47 35x52 5.05 5.75 183 Ripple Current ( A, rms ) at 105℃ 120Hz Snap-in WV(SV) Cap φD (μF) 3300 HP Series φDxL(mm) WV(SV) Cap φD (μF) 330 470 560 680 820 1000 1200 1500 1800 2200 Size 22 Ripple 22x26 0.63 22x26 22x31 22x26 22x31 22x31 0.70 0.75 0.81 0.87 1.02 22x31 22x36 22x36 80 (100) Size 25 Ripple 25x26 0.86 1.11 1.18 1.46 25x26 25x31 25x31 1.02 1.09 1.16 25x31 1.46 22x41 1.74 25x36 1.74 22x46 1.95 22x51 2.25 25x36 25x41 25x41 25x46 25x46 25x51 25x51 25x56 1.89 1.99 2.20 2.31 2.58 2.70 3.30 3.45 2700 3300 3900 4700 5600 6800 WV(SV) Cap φD (μF) 100 150 220 270 330 390 470 560 680 22 Size Ripple Size 30 Ripple 1.38 30x26 30x31 30x26 30x31 30x31 1.46 1.56 1.70 1.82 1.95 22x41 1.65 25x36 1.65 30x31 1.65 22x46 1.83 25x41 1.83 30x31 1.83 35x27 1.83 30x31 30x36 30x36 30x41 30x41 30x46 30x46 30x51 30x51 2.20 2.31 2.58 2.72 3.30 3.50 3.73 3.90 4.29 560 680 820 1000 1200 1500 1800 1.95 25x41 2.52 30x36 2.52 35x32 2.52 35x27 35x32 35x32 35x37 35x37 35x42 35x37 35x42 35x42 35x47 35x52 2.25 2.40 2.68 2.85 3.30 3.50 3.73 3.93 4.29 5.10 5.66 25x51 3.03 30x41 3.03 35x32 3.03 30x46 4.10 35x37 4.10 30x56 4.59 35x47 4.59 35x47 4.98 35x52 5.43 35 Size Ripple 30x26 1.21 22x41 1.40 25x36 1.40 30x31 1.40 35x27 1.40 22x46 1.64 25x36 25x41 25x41 25x46 25x51 1.58 1.67 1.76 1.85 2.15 30x31 30x36 30x36 1.65 1.75 1.85 35x27 35x32 35x32 1.71 1.80 1.85 30x41 2.15 35x32 2.15 25x56 2.46 30x46 30x51 2.46 2.80 35x37 35x42 2.46 2.80 30x51 3.13 35x42 35x52 35x57 3.13 3.26 3.39 2200 470 35x27 1.21 22x46 1.35 22x51 22x56 1.60 1.70 220 (270) 25 30 Size Ripple Size Ripple 25x26 25x26 25x26 25x26 25x31 25x31 25x36 25x36 25x41 25x46 25x51 25x56 0.50 0.60 0.85 1.05 1.15 1.20 1.28 1.31 1.38 1.60 1.75 2.00 1.32 30x26 25x31 0.50 0.60 0.85 1.05 1.15 1.25 30x26 1.38 1.00 1.10 22x26 22x26 22x31 22x31 22x36 22x41 1.26 25x31 30x26 30x26 22 Size Ripple 25x26 1.38 0.98 1.10 1800 1.26 35 Ripple 22x36 160 (200) 25 30 Size Ripple Size Ripple 1500 22x31 Size 1.16 25x26 25x31 1200 22 25 30 Size Ripple Size Ripple Size Ripple 22x26 0.54 22x26 0.79 25x26 0.81 22x31 0.85 22x26 0.90 25x26 0.95 22x31 0.97 22x31 1.02 25x26 1.02 30x26 1.14 30x26 0.37 0.42 0.74 0.98 1.09 1.15 1.21 1000 390 35 Ripple 22x26 22x26 22x26 22x31 22x31 22x36 22x36 820 WV(SV) Cap φD (μF) 68 100 150 180 220 270 330 Size 100 (125) 30x26 30x26 30x26 30x26 30x31 30x31 0.85 1.05 1.15 1.25 1.33 1.35 30x36 30x41 30x46 30x51 1.60 1.75 2.00 2.30 35 Size Ripple 35x27 1.35 35x27 35x32 35x37 35x42 35x47 35x52 35x56 1.60 1.75 2.00 2.30 2.35 2.40 2.50 184 22 Size Ripple 22x26 0.38 22x26 0.54 22x31 0.92 22x31 1.03 22x36 1.21 22x36 1.33 22x41 1.41 22x41 1.57 22x46 1.65 22x46 1.81 22x51 1.90 22x51 2.04 22x56 2.12 22 Size Ripple 22x26 0.27 22x31 0.44 22x31 0.60 22x31 0.69 22x36 1.00 22x41 1.16 22x46 1.28 22x46 1.48 200 (250) 25 30 Size Ripple Size Ripple 25x26 25x26 25x26 25x31 25x31 25x36 25x36 25x41 25x41 25x46 25x46 25x51 25x51 25x56 0.54 0.92 1.03 1.21 1.34 1.43 1.59 1.68 1.85 1.94 2.07 2.17 2.30 2.40 0.44 0.60 0.69 1.00 1.16 1.28 1.48 25x41 25x46 25x51 1.76 1.85 1.93 35 Ripple 30x26 30x26 30x26 30x31 0.92 1.05 1.21 1.45 30x31 1.65 35x27 1.65 30x31 30x36 30x31 30x36 30x36 30x41 30x41 30x46 30x51 1.85 1.94 2.04 2.17 2.30 2.40 2.62 2.75 3.00 35x27 1.85 35x32 2.17 35x37 2.31 35x37 35x42 35x42 35x47 35x52 35x52 2.62 2.75 3.00 3.28 3.46 4.01 250 (300) 25 30 Size Ripple Size Ripple 25x26 25x26 25x26 25x31 25x36 25x36 25x36 Size Size 35 Ripple 30x26 30x26 30x26 30x31 30x31 30x31 0.60 0.69 1.00 1.16 1.28 1.48 35x27 35x27 1.28 1.48 30x36 1.76 35x32 1.76 30x41 30x46 30x51 1.93 2.22 2.48 35x32 35x37 35x42 35x47 35x52 1.93 2.22 2.48 2.80 3.17 Ripple Current ( A, rms ) at 105℃ 120Hz HP Series φDxL(mm) 220 270 330 400 (450) Size 25 Ripple Size 30 Ripple 220 270 330 390 30 Ripple 0.72 0.82 30x26 30x26 0.72 0.85 22x31 22x31 0.64 0.75 25x26 25x31 0.64 0.75 30x26 30x26 0.64 0.75 25x31 25x31 25x36 25x41 0.82 0.90 0.98 1.14 30x26 30x26 30x31 30x36 0.82 0.90 0.95 1.14 22x36 22x36 22x41 22x46 0.78 0.84 0.97 1.02 25x31 25x36 25x36 25x41 0.78 1.84 0.97 1.02 30x26 30x26 30x31 30x36 0.78 0.84 0.97 1.02 25x46 1.21 30x41 30x46 30x51 1.21 1.40 1.57 25x46 1.22 30x41 30x46 30x51 1.22 1.5 1.68 WV(SV) 450 (500) 22 25 30 φD Cap Size Ripple Size Ripple Size Ripple (μF) 33 22x26 0.24 47 22x31 0.35 25x26 0.35 22x31 0.41 25x26 0.41 56 180 Size 25x26 25x31 560 100 120 150 22 25 Size Ripple Size Ripple 22x26 0.32 22x26 0.45 25x26 0.45 22x26 0.52 25x26 0.52 0.56 0.68 470 82 35 Ripple 25x26 25x26 390 68 Size 420 (470) 22x36 22x36 0.55 0.64 25x31 25x31 0.55 0.64 30x26 30x26 0.55 0.64 22x41 22x46 22x51 0.74 0.82 0.96 25x31 25x36 25x41 25x46 0.74 0.82 0.96 1.14 30x31 30x31 30x36 30x36 30x41 30x41 30x51 0.74 0.82 0.96 1.10 1.16 1.24 1.48 35x27 35x32 0.95 1.14 35x32 35x37 35x42 35x42 35x47 35x47 35x52 35x52 1.21 1.40 1.57 1.71 1.79 1.94 2.03 2.23 Size Size 35 Ripple 35x27 1.02 35x32 35x37 35x42 35x47 1.22 1.5 1.68 1.76 35x52 1.87 35 Ripple 35x27 35x32 0.96 1.14 35x37 35x42 35x47 35x52 1.24 1.48 1.64 1.86 470 560 Ripple Current ( A, rms ) at 105℃ 120Hz 185 Snap-in WV(SV) 22 φD Cap Size Ripple (μF) 33 22x26 0.39 47 22x26 0.56 22x26 0.63 56 22x31 0.68 68 22x31 0.72 22x31 0.77 82 22x36 0.82 100 22x36 0.82 22x36 0.90 120 150 22x41 0.98 22x46 1.14 180
HP221M400N310A
物料型号:CapXon HP Series
器件简介:CapXon HP系列是高可靠性的电容器,具有高纹波电流,适用于105℃环境,适用于开关电源。
引脚分配:端子间距固定为10mm,适用于印刷电路板插入。
参数特性: - 工作温度范围:-40到+105°C - 额定电压范围:10至100VDC和160至450VDC - 电容范围:330至68000μF - 电容公差:±20%(120Hz, +20°C) - 漏电流:在额定工作电压下,+20°C时最大值为0.02CV,5分钟后 - 耗散因数(tanδ):20°C 120Hz时小于表中的值
功能详解:电容器设计用于开关电源,具有防爆铝制外壳和防爆通风口。
应用信息:最佳适用于开关电源,详细规格请参阅工程通报E107。
封装信息:提供了详细的尺寸图表和安全装置、安装孔和PCB端子的符号说明。
HP221M400N310A 价格&库存
很抱歉,暂时无法提供与“HP221M400N310A”相匹配的价格&库存,您可以联系我们找货
HP221M400N310A
  • 5+31.80880
  • 20+18.97500
  • 40+13.28250
  • 100+9.48750
  • 200+9.01310
  • 1000+8.34900
库存:89
