HHXB250ARA221MHA0G
HHXB250ARA221MHA0G
    NCC(贵弥功)
    SMD,D8xL10mm
    贴片铝电解电容 AEC_D8X10MM_SM
HHXB250ARA221MHA0G 数据手册
CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXB Series ・High reliability and high voltage are realized by hybrid electrolyte ・Endurance with ripple current : 5,000 hours at 105℃ ・For high reliability applications. (Automotive equipment, Base station equipment, etc.) ・RoHS2 Compliant ・Halogen Free ・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information. HXA Higher temperature HXB ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Range Capacitance Tolerance Leakage Current -55 to +105℃ 16 to 80Vdc ±20% (M) I=0.01CV Where, I : Max. leakage current (μA) , C: Nominal capacitance(μF), V : Rated voltage(V) Rated voltage(Vdc) 16V 25V 35V 50V 63V 80V tanδ 0.16 0.14 0.12 0.10 0.08 0.08 (Max.) Dissipation Factor (tanδ) Low Temperature Characteristics (Max. Impedance Ratio) Endurance (at 20℃, 120Hz) (at 20℃ after 2 minutes) (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.5 Z(-55℃)/Z(+20℃)≦2.0 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated ripple current is applied (the peak voltage shall not exceed the rated voltage) for 5,000 hours at 105 ℃. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours at 105 ℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by applying voltage according to item 4.1 of JIS C 5101-4. Capacitance change ≦±30% of the initial value D.F. (tanδ) ≦ 200% of the initial specified value ESR ≦ 200% of the initial specified value Leakage current ≦ The initial specified value Shelf Life ◆DIMENSIONS [mm] ● Terminal ● Terminal ● Size Code : A code : F61 to JA0 ● Size Code : G(Vibration resistant structure) code : HA0 and JA0 Vent for JA0 Vent for JA0 0.3max. W 0.3max. L±0.3 (Note) L±0.5 A±0.2 Note : L±0.5 for HA0 and JA0 2 3 4 H HXB 5 6 7 8 9 10 RA 11 12 φD 6.3 L 5.8 A 6.6 B 6.6 C 7.2 W 0.5 to 0.8 P 1.9 F80 HA0 JA0 6.3 8 10 7.7 10.0 10.0 6.6 8.3 10.3 6.6 8.3 10.3 7.2 9.0 11.0 0.5 to 0.8 0.7 to 1.1 0.7 to 1.1 1.9 3.1 4.5 A±0.2 : Dummy terminals ◆MARKING ◆PART NUMBERING SYSTEM 1 Size Code F61 P C±0.2 B±0.2 φD±0.5 P C±0.2 B±0.2 φD±0.5 W 13 14 M 15 16 17 18 G Supplement code Size code Capacitance tolerance code Capacitance code (ex. 47µF:470, 100µF:101) Taping code Terminal code Voltage code (ex. 35V:350, 50V:500) Series code Category EX) 35V47µF 26A 47 V HB ●Rated voltage symbol Rated voltage (Vdc) 16 25 35 50 63 80 Symbol C E V H J K Please refer to "Product code guide (conductive polymer hybrid type)" Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001S CONDUCTIVE POLYMER HYBRID ALUMINUM ELECTROLYTIC CAPACITORS Surface Mount HXBSeries ◆STANDARD RATINGS WV (Vdc) 16 25 35 50 63 80 Cap (µF) Size code ESR (mΩmax./20℃, 100kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. 82 150 270 470 47 56 68 100 150 220 270 330 27 47 47 68 100 150 150 270 10 15 22 33 33 47 56 68 100 6.8 10 10 22 22 33 33 56 22 39 F61 F80 HA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 JA0 F61 F80 F61 F80 HA0 HA0 JA0 HA0 JA0 F61 F61 F80 F80 HA0 HA0 JA0 JA0 HA0 JA0 45 27 22 18 50 50 30 30 27 27 20 20 60 60 35 35 27 27 20 20 80 40 80 40 30 30 25 30 25 120 120 80 80 40 40 30 30 45 35 1,600 2,200 2,500 2,600 1,300 1,300 2,000 2,000 2,300 2,300 2,500 2,500 1,300 1,300 2,000 2,000 2,300 2,300 2,500 2,500 1,100 1,600 1,100 1,600 1,800 1,800 2,000 1,800 2,000 1,000 1,000 1,500 1,500 1,600 1,600 1,800 1,800 1,600 1,700 HHXB160ARA820MF61G HHXB160ARA151MF80G HHXB160□RA271MHA0G HHXB160□RA471MJA0G HHXB250ARA470MF61G HHXB250ARA560MF61G HHXB250ARA680MF80G HHXB250ARA101MF80G HHXB250□RA151MHA0G HHXB250□RA221MHA0G HHXB250□RA271MJA0G HHXB250□RA331MJA0G HHXB350ARA270MF61G HHXB350ARA470MF61G HHXB350ARA470MF80G HHXB350ARA680MF80G HHXB350□RA101MHA0G HHXB350□RA151MHA0G HHXB350□RA151MJA0G HHXB350□RA271MJA0G HHXB500ARA100MF61G HHXB500ARA150MF80G HHXB500ARA220MF61G HHXB500ARA330MF80G HHXB500□RA330MHA0G HHXB500□RA470MHA0G HHXB500□RA560MJA0G HHXB500□RA680MHA0G HHXB500□RA101MJA0G HHXB630ARA6R8MF61G HHXB630ARA100MF61G HHXB630ARA100MF80G HHXB630ARA220MF80G HHXB630□RA220MHA0G HHXB630□RA330MHA0G HHXB630□RA330MJA0G HHXB630□RA560MJA0G HHXB800□RA220MHA0G HHXB800□RA390MJA0G □ : Enter the appropriate terminal code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Capacitance(µF) to 15 to 39 to 220 to Frequency(Hz) 10 33 150 470 120 0.03 0.07 0.10 0.13 1k 0.30 0.30 0.40 0.45 5k 0.50 0.50 0.60 0.65 10k 0.60 0.60 0.70 0.75 20k 0.70 0.70 0.80 0.85 30k 0.75 0.75 0.80 0.85 100k to 500k 1.00 1.00 1.00 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001S
HHXB250ARA221MHA0G 价格&库存
很抱歉,暂时无法提供与“HHXB250ARA221MHA0G”相匹配的价格&库存,您可以联系我们找货
