SMD Aluminum Electrolytic Capacitors
VUA
Features
‧ 6.3 ~ 18φ, 125℃, 1,000 ~ 2,000 hours assured
‧ Chip type high temperature range, for +125℃ use
‧ For automobile modules and other high temperature applications
‧ RoHS Compliance
Marking color: Black
SPECIFICATIONS
Items
Category Temperature Range
Capacitance Tolerance
Performance
-40℃ ~ +125℃
±20%
I = 0.03CV or 4 (µA) whichever is greater (after 1 minutes)
Where, C = rated capacitance in µF
V = rated DC working voltage in V
Leakage Current (at 20℃)
Dissipation Factor
(Tanδ at 120Hz, 20℃)
Rated Voltage
Tanδ(max)
10
0.32
16
0.24
25
0.21
(at 120Hz, 20℃)
35
0.18
50
0.15
Impedance ratio shall not exceed the values given in the table below.
Rated Voltage
10
16
25
35
Impedance Z(-25℃)/Z(+20℃)
6
5
4
3
Z(-40℃)/Z(+20℃)
Ratio
12
8
6
4
Low Temperature
Characteristics (at 120Hz)
50
3
4
1,000 Hrs for φD ≦ 8 × 6.5mm
2,000 Hrs for φD ≧ 8 × 10mm
Capacitance Change
Within ±30% of initial value
Dissipation Factor
Less than 300% of specified value
Leakage Current
Within specified value
* The above specifications shall be satisfied when the capacitors are restored to 20℃after the rated voltage applied for
1,000 / 2,000 hours at 125℃.
Test Time
Endurance
Test Time
1,000 Hrs
Capacitance Change
Dissipation Factor
Leakage Current
* The above specifications shall be satisfied when the capacitors are restored to 20℃after exposing them for 1,000
hours at 125℃ without voltage applied.
Shelf Life Test
Freq.(Hz)
Cap.(μ F )
Under 330
300 < C ≦ 1,000
Ripple Current &
Frequency Multipliers
50
120
1k
10k up
0.80
0.85
1.0
1.0
1.25
1.20
1.40
1.30
DIAGRAM OF DIMENSIONS
Fig. 1
φD±0.5
Vent≧8φ×10L
LEAD SPACING AND DIAMETER
B± 0.2
W
L
0.3 Max
A±0.2
0.4 max
P
C±0.2
φD±0.5
Fig. 2
Vent
B±0.2
W
0.4 Max
L
A±0.2
1.0 Max
P
C±0.2
2011 Version
φD
6.3
6.3
8
8
10
12.5
12.5
16
18
L
5.7± 0.3
7.7 ± 0.3
6.5 ± 0.3
10 ± 0.5
10 ± 0.5
13.5 ± 0.5
16 ± 0.5
16.5 ± 0.5
16.5 ± 0.5
A
6.6
6.6
8.4
8.4
10.4
13.0
13.0
17.0
19.0
B
6.6
6.6
8.4
8.4
10.4
13.0
13.0
17.0
19.0
C
7.4
7.4
9.2
9.2
11.2
15.0
15.0
19.0
21.0
Unit: mm
P ± 0.2 Fig. No.
W
0.5 ~ 0.8
2.0
1
0.5 ~ 0.8
2.0
1
0.5 ~ 0.8
2.3
1
0.7 ~ 1.1
3.1
1
0.7 ~ 1.1
4.7
1
1.1 ~ 1.4
4.4
2
1.1 ~ 1.4
4.4
2
1.1 ~ 1.4
6.4
2
1.1 ~ 1.4
6.4
2
VUA
MARKING
φD = 6.3 mm
Negative
polarity
φD = 8 ~ 10 mm
Date code
a1
10
16u
Negative
polarity
Rated cap.
Rated voltage
& Series code
φD ≧ 12.5mm
Date code
a1
VUA
470
6.3V
Rated cap.
Rated voltage
µF
Contents
10V (1A)
mA
φD×L
22
220
33
330
47
470
68
680
6.3×5.7
50
100
101
8×6.5
220
221
330
16V (1C)
mA
φD×L
25V (1E)
mA
φD×L
a1
VUA
2200
6.3V
Date
code
Series
name
Rated
cap.
Rated
voltage
Dimension: φD × L(mm)
Ripple Current: mA/rms at 120 Hz, 125°C
DIMENSION & PERMISSIBLE RIPPLE CURRENT
V. DC
Negative
polarity
Series name
35V (1V)
mA
φD×L
50V (1H)
mA
φD×L
6.3×5.7
50
8×6.5
75
6.3×5.7
50
6.3×5.7
50
6.3×7.7
70
8×10
130
6.3×7.7
70
6.3×7.7
70
8×6.5
75
8×10
130
8×6.5
75
8×6.5
75
8×10
130
10×10
180
75
8×6.5
75
8×10
130
10×10
180
12.5×13.5
357
8×10
130
10×10
180
10×10
180
12.5×13.5
357
12.5×16
400
331
8×10
130
12.5×13.5
480
12.5×13.5
480
16×16.5
650
16×16.5
650
470
471
12.5×13.5
480
12.5×13.5
480
12.5×13.5
480
16×16.5
650
16×16.5
650
680
681
12.5×13.5
480
12.5×13.5
480
12.5×16
585
16×16.5
650
18×16.5
855
1,000
102
12.5×16
585
12.5×16
585
16×16.5
650
18×16.5
855
1,500
152
12.5×16
585
16×16.5
650
18×16.5
855
2,200
222
16×16.5
650
18×16.5
855
3,300
332
18×16.5
855
4,700
472
18×16.5
855
2011 Verison
很抱歉,暂时无法提供与“VUA101M1ATR-0806L”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.46494
- 50+0.45274
- 150+0.44464
- 500+0.43654
