Aluminum Electrolytic Type / Surface Mount Type
Capacitors
Surface
Mount Type
CE-BD
CE-KX
10 to 20% less impedance than CE-AX series at hight frequencies.
105℃ 1,000 to 2,000hours ● Solvent proof (within 2 minutes)
● AEC-Q200
■ Specifications
Items
Condition
Specifications
Rated voltage
(V)
6.3
10
16
25
35
50
63
80
100
Surge voltage
(V)
Room temperature
8.0
13
44
63
79
100
125
Category temperature range (℃)
CE-BS
Capacitance tolerance (%)
120Hz/20℃
CE-LD
CE-FS
CE-FS(High Voltage)
CE-FH
CE-AX
CE-KX
Dissipation Factor(tan δ)
Leakage current
(LC)
CE-LX
tanδ
(max.)
120Hz/20℃
−55 to +105
M : ±20
φ4 to φ6.3
0.24
0.20
φ8 to φ16
0.28
0.24
0.14
0.12
0.12
0.10
0.08
0.07
0.20
0.16
0.14
0.14
0.12
0.10
0.08
The greater value of either 0.01CV or 3
Impedance ratio at
Iow temperature
Based on the value at −40℃ Z/Z20℃
120Hz, +20℃ −55℃ Z/Z20℃
Endurance
105℃
rated voltage applied
(With the rated
ripple current)
CE-GA
0.16
Exceeding 1,000μF, +0.02 every 1,000μF
μA/after 2minutes (max.)
CE-ZX
CE-ZC
Low Impedance
Series
CE-BSS
CE-FSS
RoHS compliance
3
2
2
2
2
2
2
2
2
5
4
4
3
3
3
3
3
3
Test
CE-LS
φ4 to φ6.3 : 1,000hours, φ8 to φ16 : 2,000hours
△C/C
Within ±25% of the initial value
tanδ
Less than 200% of the specified value
LC
Less than the specified value
CE-LH
CE-LH(High Voltage)
CE-PS
CE-PF
Polarity
(Cathode)
0D
470
16 K
CE-TH
CE-JX
CE-NP
CE-FN
52
0.3max.
W
Lot No.
Rated Capacitance
Series Symbol
Rated Voltage(6.3V→6)
[ φD≥12.5 ]
Polarity
(Cathode)
0DT
3300
16 K
(Unit : mm)
C
CE-PH
[ φD≤10 ]
(P)
CE-PC
■ Marking, Dimensions
H
CE-LF
φD
CE-LL
Lot No.
Indicated Only φD=16
Rated Capacitance
Series Symbol
L
R (+)
A pressure relief vent is provided
for φD=8 or bigger
(P)reference size
D±0.5
L±0.3
W±0.2
H±0.2
C±0.2
R
P
4
6.0
4.3
4.3
5.0
0.5 to 0.8
1.0
5
6.0
5.3
5.3
6.0
0.5 to 0.8
1.4
6.3
6.0
6.6
6.6
7.3
0.5 to 0.8
2.2
6.3
7.7
6.6
6.6
7.3
0.5 to 0.8
2.2
8
10.2
8.3
8.3
9.0
0.7 to 1.0
3.2
10
10.2
10.3
10.3
11.0
1.0 to 1.4
4.6
12.5
13.5±0.5
12.8
12.8
13.5
1.0 to 1.4
4.6
16
16.5±0.5
16.3
16.3
17.3
1.7 to 2.1
7.0
RoHS compliance
■ Size, Impedance, Rated Ripple Current
10
16
25
35
10
15
22
4×6.0
27
33
1.45
90
47
5×6.0
0.70
170
56
5×6.0
0.70
170
4×6.0
1.45
90
5×6.0
0.70
170
1.45
90
4×6.0
1.45
90
5×6.0
0.70
170
4×6.0
1.45
90
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
5×6.0
0.70
170
6.3×6.0
0.39
250
6.3×6.0
0.39
250
250
6.3×6.0
0.39
250
6.3×6.0
0.39
250
6.3×6.0
0.39
250
6.3×7.7
6.3×6.0
0.39
250
6.3×6.0
0.39
250
0.30
300
CE-BD
6.3×6.0
0.39
250
6.3×7.7
0.30
300
8×10.2 0.15
600
CE-BSS
250
6.3×7.7
0.30
300
8×10.2 0.15
600
8×10.2 0.15
600
CE-BS
0.30
300
6.3×7.7
0.30
300
8×10.2 0.15
600
8×10.2 0.15
600
CE-LD
300
8×10.2 0.15
600
8×10.2 0.15
600
8×10.2 0.15
600
10×10.2 0.080
850
CE-FSS
8×10.2 0.15
600
8×10.2 0.15
600
8×10.2 0.15
600
10×10.2 0.080
850
680
8×10.2 0.15
600
10×10.2 0.080
850
1000
8×10.2 0.15
600
1500
10×10.2 0.080
850
6.3×6.0
100
6.3×6.0
0.39
250
150
6.3×6.0
0.39
250
6.3×6.0
0.39
220
6.3×6.0
0.39
250
6.3×7.7
330
6.3×7.7
0.30
470
10×10.2 0.080
250
0.39
6.3×6.0
68
0.39
4×6.0
850
12.5×13.5 0.058 1150
3300
CE-FS
CE-FS
(High Voltage)
16×16.5 0.035 1800
CE-FH
16×16.5 0.035 1800
CE-AX
16×16.5 0.035 1800
2200
16×16.5 0.035 1800
CE-ZC
16×16.5 0.035 1800
6800
CE-KX
CE-ZX
16×16.5 0.035 1800
4700
Surface
Mount Type
6.3
4.7
Capacitors
V
μF
CE-LX
CE-GA
CE-LS
V
μF
50
63
80
CE-LH
100
2.2
6.3×6.0
2.70
42
6.3×6.0
2.40
45
4×6.0
2.55
64
5×6.0
2.00
55
6.3×6.0
2.40
45
6.3×6.0
2.40
45
10
6.3×6.0
0.52
215
6.3×6.0
1.00
90
6.3×7.7
2.00
65
6.3×7.7
2.00
65
22
6.3×6.0
0.52
215
6.3×7.7
0.80
135
8×10.2 0.90
140
8×10.2 0.90
140
33
6.3×7.7
0.44
243
8×10.2 0.35
280
8×10.2 0.90
140
10×10.2 0.50
220
47
6.3×7.7
0.44
243
8×10.2 0.35
280
10×10.2 0.50
220
12.5×13.5 0.24
500
8×10.2 0.35
280
12.5×13.5 0.24
500
12.5×13.5 0.24
500
10×10.2 0.20
480
12.5×13.5 0.24
500
16×16.5 0.14
800
12.5×13.5 0.24
500
16×16.5 0.14
800
16×16.5 0.14
800
3.3
4.7
68
100
8×10.2 0.22
400
150
220
10×10.2 0.13
585
330
12.5×13.5 0.10
800
800
CE-LF
CE-PC
CE-PH
CE-PS
CE-PF
CE-TH
CE-JX
CE-NP
CE-FN
16×16.5 0.065 1410
470
1000
12.5×13.5 0.14
CE-LH
(High Voltage)
CE-LL
16×16.5 0.060 1610
→Please use the higher voltage model in the next.
Please refer to page 14 for
ripple current frequency coefficients.
■ Part number KX
Case size:φDxL(mm)
16×16.5:CE-KXT
Rated ripple current
mArms(100kHz, 105℃)
Impedance(Ω)
max. at 100kHz, 20℃
KXT
16 CE 3300 KX T
16 CE 470 KX
Series code
Rated capacitance
Type code
Rated voltage
Sn plating terminal option
Series code
Rated capacitance
Type code
Rated voltage
53
很抱歉,暂时无法提供与“25CE100KX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.10916
- 10+0.88053
- 30+0.78257
