35CE100LXS
35CE100LXS
    SUNCON
    SMD,D6.3xL7.7mm
    贴片铝电解电容 AEC_D6.3X7.7MM_SM
35CE100LXS 数据手册
Aluminum Electrolytic Type / Surface Mount Type Aluminum Electrolytic Capacitors Surface Mount Type CE-BD CE-LX Low Impedance 105℃ 2,000 to 5,000hours Solvent proof (within 2 minutes) ● AEC-Q200 ■ Specifications ● ● Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 63 80 100 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 79 100 125 Category temperature range (℃) − CE-BS Capacitance tolerance (%) 120Hz/20℃ CE-LD CE-FS CE-FS(High Voltage) CE-FH CE-AX CE-KX Dissipation Factor(tan δ) Leakage current (LC) CE-LX tanδ (max.) 120Hz/20℃ −55 to +105 M : ±20 φ4 to φ6.3 0.26 0.20 φ8 to φ18 0.28 0.24 0.14 0.12 0.12 0.08 ー ー 0.22 0.16 0.14 0.14 0.08 0.08 0.07 The greater value of either 0.01CV or 3 Impedance ratio at Iow temperature Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) CE-GA 0.16 Exceeding 1,000μF, +0.02 every 1,000μF μA/after 2minutes (max.) CE-ZX CE-ZC Long Life Series CE-BSS CE-FSS RoHS compliance 3 3 3 3 3 3 2 2 2 4 4 4 3 3 3 3 3 3 Test CE-LS φ4 to φ6.3, φ10 × 7.7 : 2,000hours, φ8 to φ18 : 5,000hours △C/C Within ±30% of the initial value tanδ Less than 300% of the specified value LC Less than the specified value CE-LH CE-LH(High Voltage) CE-PS CE-PF CE-TH CE-JX CE-NP CE-FN 0.3max. Polarity (Cathode) 0D 470 16 L W Lot No. Rated Capacitance Series Symbol Rated Voltage(6.3V→6) L [ φD≥12.5 ] Polarity (Cathode) Lot No. Indicated φD=16, 18 0DT 3300 16 L (Unit : mm) D±0.5 C CE-PH [ φD≤10 ] (P) CE-PC ■ Marking, Dimensions H CE-LF φD CE-LL R (+) A pressure relief vent is provided for φD=8 or bigger Rated Capacitance (P)reference size Series Symbol Rated Voltage(6.3V→6) ■ Part number LX W±0.2 H±0.2 C±0.2 R P 4 6.0 4.3 4.3 5.0 0.5 to 0.8 1.0 5 6.0 5.3 5.3 6.0 0.5 to 0.8 1.4 6.3 6.0 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 7.7 6.6 6.6 7.3 0.5 to 0.8 2.2 8 10.2 8.3 8.3 9.0 0.7 to 1.0 3.2 10 7.7 10.3 10.3 11.0 1.0 to 1.4 4.6 10 10.2 10.3 10.3 11.0 1.0 to 1.4 4.6 10 13.5±0.5 10.3 10.3 11.0 1.0 to 1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0 to 1.4 4.6 16 16.5±0.5 16.3 16.3 17.3 1.7 to 2.1 7.0 18 16.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 18 21.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 LXA 16 CE 470 LX LXS 16 CE 330 LXA Series code Rated capacitance Type code Rated voltage LXC 35 CE 100 LXS Series code Rated capacitance Type code Rated voltage LXT 35 CE 470 LXC 16 CE 3300 LX T Series code Rated capacitance Type code Rated voltage 56 L±0.3 Sn plating terminal option Series code Rated capacitance Type code Rated voltage Series code Rated capacitance Type code Rated voltage Aluminum Electrolytic Type / Surface Mount Type RoHS compliance ■ Size, Impedance, Rated Ripple Current 10 16 25 35 10 1.45 90 4×6.0 1.45 90 5×6.0 0.70 170 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 5×6.0 0.70 170 15 22 4×6.0 27 4×6.0 1.45 90 5×6.0 0.70 170 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 33 5×6.0 0.70 170 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 47 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 56 5×6.0 0.70 170 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 68 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 CE-BD 5×6.0 ★2 0.70 170 6.3×7.7 ★2 0.30 300 CE-BSS 100 150 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×6.0 0.39 250 6.3×7.7 0.30 300 6.3×6.0 220 6.3×7.7 330 8×10.2 470 0.30 0.17 250 300 600 0.17 600 10×7.7 ★1 0.17 600 8×10.2 680 0.39 0.30 6.3×7.7 8×10.2 8×10.2 0.17 300 600 0.17 600 10×7.7 ★1 0.17 600 10×10.2 850 0.090 6.3×7.7 0.30 300 8×10.2 0.17 600 0.090 10×13.5 ★3 0.070 1500 10×10.2 2200 12.5×13.5 0.090 850 12.5×13.5 0.060 1100 12.5×13.5 850 12.5×13.5 CE-BS 0.17 600 8×10.2 0.17 600 CE-LD 10×7.7 ★1 0.17 600 CE-FSS 0.17 600 CE-FS 10×10.2 0.090 850 0.090 850 10×13.5 ★3 0.070 950 CE-KX 12.5×13.5 0.060 1100 CE-ZX 0.060 1100 12.5×13.5 0.060 1100 0.060 1100 12.5×13.5 0.060 1100 16×16.5 0.035 1800 0.060 1100 16×16.5 0.035 1800 16×16.5 0.035 1800 CE-LH (High Voltage) 16×16.5 0.035 1800 18×16.5 0.033 2060 CE-LL 18×21.5 0.028 2260 CE-LF 18×16.5 0.033 2060 CE-PC 18×21.5 0.028 2260 CE-PH 600 0.17 0.090 850 10×13.5 ★3 0.070 950 950 0.060 1100 16×16.5 0.035 1800 3900 5600 CE-LX CE-GA CE-LS CE-LH 0.060 1100 12.5×13.5 0.035 1800 CE-FH CE-ZC 950 3300 16×16.5 CE-FS (High Voltage) CE-AX 10×10.2 2700 4700 8×10.2 600 8×10.2 12.5×13.5 10×10.2 600 0.17 10×13.5 ★3 0.070 1000 0.17 600 600 10×10.2 8×10.2 10×7.7 ★1 0.17 10×7.7 ★1 0.17 8×10.2 300 600 600 8×10.2 8×10.2 0.30 0.17 0.17 8×10.2 6.3×7.7 18×16.5 0.033 2060 CE-PS 18×21.5 0.028 2260 CE-PF 6800 16×16.5 0.035 1800 18×16.5 0.033 2060 CE-TH 8200 18×16.5 0.033 2060 18×21.5 0.028 2260 CE-JX 10000 18×16.5 0.033 2060 CE-NP 12000 18×21.5 0.028 2260 CE-FN V μF 50 63 80 4×6.0 2.90 60 10 6.3×6.0 0.88 165 6.3×6.0 1.50 80 22 6.3×6.0 0.88 165 6.3×7.7 1.20 120 27 6.3×7.7 0.68 195 33 6.3×7.7 0.68 195 47 6.3×7.7 0.68 195 10×7.7 ★1 0.70 200 4.7 56 8×10.2 0.34 350 68 8×10.2 0.34 350 8×10.2 0.34 350 12.5×13.5 100 10×7.7 ★1 0.34 100 10×10.2 0.65 200 10×10.2 0.65 200 12.5×13.5 0.32 500 12.5×13.5 0.32 500 0.16 800 12.5×13.5 0.32 500 16×16.5 0.17 793 0.32 500 16×16.5 0.17 793 18×16.5 0.153 917 18×21.5 0.083 1230 330 150 10×10.2 0.18 670 12.5×13.5 0.16 800 12.5×13.5 220 10×10.2 0.18 670 12.5×13.5 0.16 800 330 12.5×13.5 0.12 900 16×16.5 0.082 1410 16×16.5 0.17 793 470 16×16.5 0.073 1610 16×16.5 0.082 1410 18×16.5 0.153 917 680 16×16.5 0.073 1610 18×16.5 0.080 1690 1000 16×16.5 0.073 1610 18×21.5 0.055 1960 1200 18×16.5 0.068 1900 1500 18×21.5 0.042 2180 Please refer to page 14 for ripple current frequency coefficients. ★1 LXA ★2 LXS ★3 LXC Surface Mount Type 6.3 4.7 Aluminum Electrolytic Capacitors V μF Case size:φDxL(mm) φ16, φ18:CE-LXT Impedance(Ω) max. at 100kHz, 20℃ Rated ripple current mArms(100kHz, 105℃) 57
35CE100LXS 价格&库存
很抱歉,暂时无法提供与“35CE100LXS”相匹配的价格&库存,您可以联系我们找货
