400CE4R7LH
400CE4R7LH
    SUNCON
    SMD,D10xL10.5mm
    贴片铝电解电容 AEC_D10X10.5MM_SM
400CE4R7LH 数据手册
Aluminum Electrolytic Type / Surface Mount Type 105℃ Long Life 160 to 400V, 105℃ 5,000hours Non solvent proof ● AEC-Q200 ■ Specifications ● ● Items Condition Specifications Rated voltage (V) − 160 200 400 Surge voltage (V) Room temperature 200 250 450 Category temperature range (℃) − −40 to +105 Capacitance tolerance (%) 120Hz/20℃ M : ±20 Dissipation Factor(tan δ) tanδ (max.)120Hz/20℃ μA/after 2minutes (max.) Leakage current (LC) 0.20 CE-BS CV > 1,000 0.02CV +25 Endurance 105℃, 5,000hours rated voltage applied (With the rated ripple current) CE-LD 0.25 0.03CV +15 Based on the value at −25℃ Z/Z20℃ 120Hz, +20℃ −40℃ Z/Z20℃ CE-BD CE-BSS 0.20 CV ≤ 1,000 Impedance ratio at Iow temperature Surface Mount Type High Voltage Series Aluminum Electrolytic Capacitors CE-LH RoHS compliance CE-FSS CE-FS 3 3 6 6 6 10 CE-FS (High Voltage) CE-FH CE-AX △C/C Within ±30% of the initial value CE-KX tanδ Less than 300% of the specified value CE-ZX LC Less than the specified value CE-ZC CE-LX CE-GA CE-LS ■ Marking, Dimensions [ φD≤10 ] 0.3max. Polarity (Cathode) C H Series Symbol (P) Rated Capacitance Rated Voltage★ L [ φD≥12.5 ] Polarity (Cathode) 0DT 47 2D L W Lot No. φD 0D 10 2C L (Unit : mm) R (+) pressure relief vent (P)reference size Lot No. Indicated φD=16, 18 D±0.5 L W±0.2 H±0.2 C±0.2 8 10.5±0.3 8.3 8.3 10 10.5±0.3 10.3 12.5 13.5±0.5 12.8 16 16.5±0.5 18 18 CE-LH R P 9.0 0.7 to 1.0 3.2 CE-LL 10.3 11.0 1.0 to 1.4 4.6 CE-LF 12.8 13.5 1.0 to 1.4 4.6 CE-PC 16.3 16.3 17.3 1.7 to 2.1 7.0 CE-PH 16.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 CE-PS 21.5±1.0 19.0 19.0 20.0 1.7 to 2.1 7.0 CE-PF CE-LH (High Voltage) CE-TH Rated Capacitance Series Symbol CE-JX CE-NP Rated Voltage★ ★(160V : 2C, 200V : 2D, 400V : 2G) CE-FN ■ Size, Rated Ripple Current V μF 160 200 400 2.2 8×10.5 25 3.3 8×10.5 31 10×10.5 36 4.7 8×10.5 37 10×10.5 38 10 10×10.5 43 10×10.5 43 12.5×13.5 57 22 12.5×13.5 112 12.5×13.5 112 16×16.5 115 18×16.5 125 33 12.5×13.5 137 12.5×13.5 137 18×21.5 160 47 16×16.5 180 16×16.5 180 16×16.5 215 16×16.5 215 18×16.5 ★ 270 18×21.5 330 27 68 82 16×16.5 235 100 18×16.5 320 120 18×21.5 340 Please refer to page 14 for ripple current frequency coefficients. ★LHV ■ Part number LH Case size:φDxL(mm) φ16, φ18:CE-LHT LHV 160 CE 10 LH 200 CE 68 LHV T Series code Rated capacitance Type code Rated voltage Rated ripple current mArms(120Hz, 105℃) LHT Sn plating terminal option Series code Rated capacitance Type code Rated voltage 200 CE 47 LH T Sn plating terminal option Series code Rated capacitance Type code Rated voltage 61
400CE4R7LH 价格&库存
很抱歉,暂时无法提供与“400CE4R7LH”相匹配的价格&库存,您可以联系我们找货
