Aluminum Electrolytic Type / Surface Mount Type
CE-LD
CE-FSS
CE-FS
CE-FS(High Voltage)
CE-FH
160 to 400V, 105℃ 1,000 to 2,000hours
Non solvent proof
● AEC-Q200
■ Specifications
Items
Condition
Rated voltage
(V)
160
200
250
400
Surge voltage
(V)
Room temperature
200
250
300
450
120Hz/20℃
Dissipation Factor(tan δ)
tanδ
(max.)120Hz/20℃
μA/after
2minutes (max.)
Leakage current
(LC)
CE-LH
CE-LH(High Voltage)
CE-PS
[ φD≤10 ]
Polarity
(Cathode)
0D
10
200 F
3
3
6
6
6
6
10
Test
φ8 : 1,000hours, φ10 to φ16 : 2,000hours
△C/C
Within ±25% of the initial value
tanδ
Less than 200% of the specified value
LC
Less than the specified value
CE-JX
D±0.5
W
Lot No.
Rated Capacitance
Series Symbol
Rated Voltage
Polarity
(Cathode)
0DT
47
200 F
(Unit : mm)
0.3max.
[ φD≥12.5 ]
CE-PF
CE-FN
0.02CV +25
3
■ Marking, Dimensions
CE-TH
CE-NP
CV > 1000
Endurance
CE-LF
CE-PH
0.25
0.03CV +15
105℃
rated voltage applied
(With the rated
ripple current)
CE-LL
CE-PC
CV ≤ 1000
Impedance ratio at
Iow temperature
φD
CE-LS
M : ±20
0.20
Based on the value at −25℃ Z/Z20℃
120Hz, +20℃ −40℃ Z/Z20℃
CE-ZC
CE-GA
−40 to +105
Capacitance tolerance (%)
CE-ZX
CE-LX
Category temperature range (℃)
CE-AX
CE-KX
Specifications
C
CE-BS
High Voltage
Series
(P)
CE-BSS
105℃ Standard
H
Capacitors
Surface
Mount Type
CE-BD
CE-FS
RoHS compliance
L
Lot No.
Indicated Only φD=16
pressure relief vent
L±0.3
W±0.2
H±0.2
C±0.2
P
8
10.5
8.3
8.3
9.0
0.7∼1.0
3.2
10
10.5
10.3
10.3
11.0
1.0∼1.4
4.6
12.5
13.5±0.5
12.8
12.8
13.5
1.0∼1.4
4.6
16
16.5±0.5
16.3
16.3
17.3
1.7∼2.1
7.0
R (+)
(P)reference size
Rated Capacitance
Series Symbol
Rated Voltage
■ Size, Rated Ripple Current
V
μF
160
200
250
400
2.2
8×10.5
25
3.3
8×10.5
31
10×10.5
36
4.7
8×10.5
37
10×10.5
38
6.8
8×10.5
44
12.5×13.5
47
10
8×10.5
57
10×10.5
64
10×10.5
64
12.5×13.5
57
22
12.5×13.5
112
12.5×13.5
112
12.5×13.5
112
16×16.5
115
33
12.5×13.5
137
12.5×13.5
137
16×16.5
150
47
16×16.5
180
16×16.5
180
16×16.5
180
68
16×16.5
215
16×16.5
215
82
16×16.5
235
Please refer to page 14 for
ripple current frequency coefficients.
■ Part number
Case size:φDxL(mm)
16×16.5:CE-FST
FS
Rated ripple current
mArms(120Hz, 105℃)
FST
200 CE 10 FS
200 CE 47 FS T
Series code
Rated capacitance
Type code
Rated voltage
48
R
Sn plating terminal option
Series code
Rated capacitance
Type code
Rated voltage
很抱歉,暂时无法提供与“400CE2R2FS”相匹配的价格&库存,您可以联系我们找货
