10CE470AX
10CE470AX
    SUNCON
    SMD,D8xL10.2mm
    贴片铝电解电容 SMD
10CE470AX 数据手册
Aluminum Electrolytic Type / Surface Mount Type Aluminum Electrolytic Capacitors Surface Mount Type CE-BD CE-AX 105℃ 1,000 to 2,000hours Solvent proof (within 2 minutes) ● AEC-Q200 ■ Specifications ● ● Items Condition Specifications Rated voltage (V) − 6.3 10 16 25 35 50 Surge voltage (V) Room temperature 8.0 13 20 32 44 63 Category temperature range (℃) − CE-BS Capacitance tolerance (%) 120Hz/20℃ CE-LD CE-FS CE-FS(High Voltage) CE-FH CE-AX CE-KX Dissipation Factor(tan δ) Leakage current (LC) CE-LX tanδ (max.) 120Hz/20℃ −55 to +105 M : ±20 φ4 to φ6.3 0.24 0.20 0.16 0.14 0.12 0.12 φ8 to φ16 0.28 0.24 0.20 0.16 0.14 0.14 Exceeding 1,000μF, +0.02 every 1,000μF The greater value of either 0.01CV or 3 μA/after 2minutes (max.) Impedance ratio at Iow temperature Based on the value at −40℃ Z/Z20℃ 120Hz, +20℃ −55℃ Z/Z20℃ Endurance 105℃ rated voltage applied (With the rated ripple current) CE-ZX CE-ZC Low Impedance Series CE-BSS CE-FSS RoHS compliance CE-GA 3 2 2 2 2 2 5 4 4 3 3 3 Test CE-LS φ4 to φ6.3, φ10 × 7.7 : 1,000hours, φ8 to φ16 : 2,000hours △C/C Within ±25% of the initial value tanδ Less than 200% of the specified value LC Less than the specified value CE-LH CE-PS CE-PF CE-TH CE-JX CE-NP CE-FN 50 Polarity (Cathode) 0D 470 16 A D±0.5 0.3max. Lot No. W Rated Capacitance Series Symbol Rated Voltage(6.3V→6) C CE-PC CE-PH (Unit : mm) [ φD≤10 ] (P) CE-LF ■ Marking, Dimensions H CE-LL φD CE-LH(High Voltage) [ φD≥12.5 ] Polarity (Cathode) 0DT 4700 10 A Lot No. Indicated Only φD=16 Rated Capacitance Series Symbol Rated Voltage(6.3V→6) L R (+) A pressure relief vent is provided for φD=8 or bigger (P)reference size L±0.3 W±0.2 H±0.2 C±0.2 R P 4 6.0 4.3 4.3 5.0 0.5 to 0.8 1.0 5 6.0 5.3 5.3 6.0 0.5 to 0.8 1.4 6.3 6.0 6.6 6.6 7.3 0.5 to 0.8 2.2 6.3 7.7 6.6 6.6 7.3 0.5 to 0.8 2.2 8 10.2 8.3 8.3 9.0 0.7 to 1.0 3.2 10 7.7 10.3 10.3 11.0 1.0 to 1.4 4.6 10 10.2 10.3 10.3 11.0 1.0 to 1.4 4.6 12.5 13.5±0.5 12.8 12.8 13.5 1.0 to 1.4 4.6 16 16.5±0.5 16.3 16.3 17.3 1.7 to 2.1 7.0 Aluminum Electrolytic Type / Surface Mount Type RoHS compliance ■ Size, Impedance, Rated Ripple Current 10 16 25 35 10 15 22 27 4×6.0 1.80 47 5×6.0 0.76 150 56 5×6.0 0.76 150 → 68 100 150 220 330 1.80 80 5×6.0 0.76 150 → 6.3×6.0 6.3×6.0 0.44 230 6.3×6.0 0.44 230 0.44 0.34 4×6.0 2.90 60 6.3×6.0 0.88 165 1.80 80 5×6.0 0.76 150 4×6.0 1.80 80 5×6.0 0.76 150 5×6.0 0.76 150 5×6.0 0.76 150 5×6.0 0.76 150 5×6.0 0.76 150 6.3×6.0 0.88 165 6.3×6.0 0.44 230 6.3×6.0 0.44 230 6.3×7.7 0.68 195 6.3×6.0 0.44 230 6.3×6.0 0.44 230 6.3×7.7 0.68 195 6.3×6.0 0.44 230 0.44 6.3×7.7 0.34 280 6.3×6.0 230 → 6.3×6.0 0.44 → 230 0.44 230 230 6.3×7.7 0.34 280 280 8×10.2 0.17 450 → 230 6.3×6.0 0.44 230 6.3×6.0 0.44 230 6.3×7.7 0.34 280 8×10.2 0.17 450 8×10.2 0.39 300 6.3×7.7 0.34 280 8×10.2 0.17 450 8×10.2 0.17 450 10×10.2 0.21 450 10×10.2 0.21 450 0.34 280 8×10.2 0.17 8×10.2 0.17 10×7.7 450 0.17 10×7.7 450 0.17 450 8×10.2 0.17 450 0.17 450 8×10.2 0.17 450 680 8×10.2 0.17 450 10×7.7 8×10.2 0.17 10×7.7 450 0.17 450 1000 8×10.2 0.17 450 1500 10×10.2 0.090 670 2200 3300 0.17 12.5×13.5 0.066 450 10×10.2 0.090 670 12.5×13.5 0.14 620 12.5×13.5 0.14 620 450 8×10.2 0.17 450 10×10.2 0.090 670 CE-FSS CE-FS CE-FS (High Voltage) CE-FH CE-KX CE-ZX CE-ZC 10×10.2 0.090 670 12.5×13.5 0.066 900 12.5×13.5 0.066 900 CE-LX CE-GA CE-LS 450 → CE-LH CE-LH (High Voltage) CE-LL 10×10.2 0.090 670 12.5×13.5 0.066 12.5×13.5 0.066 12.5×13.5 0.066 900 900 900 900 4700 6800 8×10.2 0.17 CE-LD CE-AX 390 470 CE-BS 0.44 6.3×7.7 CE-BD CE-BSS 6.3×6.0 10×7.7 6.3×7.7 80 4×6.0 → 6.3×6.0 1.80 80 → 33 4×6.0 50 4×6.0 16×16.5 0.078 16×16.5 0.052 1250 16×16.5 0.052 1250 CE-PC CE-PH CE-TH CE-JX 16×16.5 0.052 1250 CE-NP →Please use the higher voltage model in the next. Please refer to page 14 for ripple current frequency coefficients. Case size:φDxL(mm) 10×7.7:CE-AXA 16×16.5:CE-AXT AXA 10 CE 470 AXA Series code Rated capacitance Type code Rated voltage CE-LF CE-PF 16×16.5 0.052 1250 16 CE 470 AX 790 CE-PS 16×16.5 0.052 1250 ■ Part number AX Surface Mount Type 6.3 4.7 Aluminum Electrolytic Capacitors V μF Series code Rated capacitance Type code Rated voltage Rated ripple current mArms(100kHz, 105℃) CE-FN Impedance(Ω) max. at 100kHz, 20℃ AXT 10 CE 4700 AX T Sn plating terminal option Series code Rated capacitance Type code Rated voltage 51
10CE470AX 价格&库存
很抱歉,暂时无法提供与“10CE470AX”相匹配的价格&库存,您可以联系我们找货
