SSL0503HC-1R2M-N
SSL0503HC-1R2M-N
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
SSL0503HC-1R2M-N 数据手册
Form No.: QF-1274 Edition: 2 RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL 各廠家 Customer: : Customer P/N: Drawing No: : Quantity: : 0 Pcs. Chilisin P/N: : Date : 2019/02/22 SSL0503HC-1R2M-N SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 東莞奇力新電子( 東莞奇力新電子(東莞廠) 東莞廠)有限公司 奇力新電子股份有限公司 Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL +86-769-8773-0251~3 FAX +86-769-8773-0232 E-mail cect@chilisin.com Chilisin Electronics Corp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com http //www.chilisin.com : : : : : : : 奇力新電子( 奇力新電子(越南廠) 越南廠)有限公司 奇力新電子( 奇力新電子(湖南廠) 湖南廠)有限公司 Chilisin Electronics (Vietnam) Limited No 143 - 145, Road No 10, VSIP Hai Phong, Lap Le Commune, Thuy Nguyen Dist, Haiphong City, Vietnam Tel 84-316 255 688 Fax 84-316 255 689 E-mail sales@chilisin.com : : Drawn by 陳瑞揚 ryan.chen : HuNan Chilisin Electronics Technology Co., Ltd No. 8, Shaziao Liangshuijing Town, Yuanling County, Huaihua City, Hunan Province 419601, China Tel 86-745-867-5882 E-mail cect@chilisin.com : : Checked by 吳振賢 lcn07 Approved by 陳瑞揚 ryan.chen YG19200758 SSL0503HC Series Specification 1 Scope: This specification applies to SMD Unshielded Power Choke 2 Part Numbering: 3 Rating: Operating Temperature: -40℃ ~ 125℃(Including self - temperature rise) Storage Temperature: 20℃ ~ 25℃ R.H.65%(In Tape & Reel Condition) 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35 ) Ordinary Humidity(25 to 85% RH) ℃ In case of doubt 20 to 30 50 to 80 %RH ℃ SSL0503HC Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Inductance (uH) Test Freq. RDC (Ω)Max. SSL0503HC-R33□-N 0.33 100 kHz,0.25 V 0.007 8.2 7 330 R33 SSL0503HC-R56□-N 0.56 100 kHz,0.25 V 0.01 7.7 6 200 R56 SSL0503HC-1R0□-N 1 100 kHz,0.25 V 0.017 5.3 4.4 140 1R0 SSL0503HC-1R2□-N 1.2 100 kHz,0.25 V 0.017 5.3 4.4 140 1R2 SSL0503HC-1R6□-N 1.6 100 kHz,0.25 V 0.022 4.5 4 100 1R6 SSL0503HC-2R2□-N 2.2 100 kHz,0.25 V 0.035 3.5 3.1 100 2R2 SSL0503HC-4R7□-N 4.7 100 kHz,0.25 V 0.054 2.6 2.2 50 4R7 SSL0503HC-6R8□-N 6.8 100 kHz,0.25 V 0.07 2 1.8 45 6R8 SSL0503HC-100□-N 10 100 kHz,0.25 V 0.111 1.9 1.5 40 100 SSL0503HC-150□-N 15 100 kHz,0.25 V 0.17 1.5 1.2 30 150 SSL0503HC-220□-N 22 100 kHz,0.25 V 0.25 1.2 1 25 220 SSL0503HC-270□-N 27 100 kHz,0.25 V 0.32 1 0.85 20 270 SSL0503HC-330□-N 33 100 kHz,0.25 V 0.35 0.99 0.82 20 330 SSL0503HC-470□-N 47 100 kHz,0.25 V 0.47 0.87 0.72 15 470 Part No. Isat (A) Irms (A) NOTE: □-tolerance M=±20% / T=±30% 1.Operating temperature range -40℃ ~ 125℃(Including self - temperature rise) 2.Isat for Inductance drop 30% from its value without current. ℃ temperature rise from 25℃ ambient. 3.Irms for a 40 "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SRF Marking (MHz)Typ. SSL0503HC Series Specification 8 SSL0503HC Series 8.1 Construction: 8.2 Material List: SSL0503HC Series Specification 9 Packaging: 9.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 130 grams in the arrow direction. 9.2 Packaging Quantity 9.3 Reel Dimensions SSL0503HC Series Specification 9 Packaging: 9.4 Tape Dimensions in mm 10 Recommended Land Pattern: 11 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5. The moisture sensitivity level (MSL) of products is classified as level 1. SSL0503HC Series Specification 12 Graph: SSL0503HC-1R2M-N
SSL0503HC-1R2M-N 价格&库存
很抱歉,暂时无法提供与“SSL0503HC-1R2M-N”相匹配的价格&库存,您可以联系我们找货
