CRB 455E
CRB 455E
    YXC(扬兴科技)
    DIP
    陶瓷谐振器 DIP
CRB 455E 数据手册
DESIGN CHECK APPROVAL (设计) (审核) (批准) CUSTOMER: DATE: February 26, 2019 (日期) (客户) APPROVAL SHEET 承认书 PART NAME (产品名称) MODEL (型号) CUSTOM PART NO (客户部品号) CUSTOM MODEL (客户型号) APPROVED BY (承认印)  PLEASE RETURN ONE SET OF APPLICATION TO US AFTER SIGNING ON THE BELOWING SPACE FOR APPROVAL IF YOU APPROVE OUR SAMPLES AND APPLICATIONS (请于承认 签回此单) CERAMIC RES0NATOR CRB455E CRB455E REMARK (注记) . NO: GG-077 DATE: February 26, 2019 SPECIFICATION FOR CERAMIC RES0NATOR (陶瓷谐振器规格书) MODEL NAME:CRB455E Approved by (批准) Checked by (审核) Issued by (签发) Drawn by (制图) Issue Date (签发日期) 1999.8.25 1. SCOPE (范围) This specification is applied to the ceramics resonator used for communication. . (本规格书适用于通讯用陶瓷谐振器。 ) 2. MODEL NAME (产品名称) Part Name Customer’s Part Number (型号) Drawing No. (客户型号) ( 图号) CRB455E GG-077 3. DIMENSIONS (尺寸) A UNIT : MM CRB 455E B D C E F F G H A 7.0±0.3 B C 9.0±0.3 6.0±0.5 D E 0.9±0.1 0.7±0.1 F 2.5±0.2 G 0.15±0.03 H 3.5±0.3 4.TEST CIRCUIT (测试电路) Parts shall be measured under a condition (Temp.:3~35℃. Hum.:45~85%) unless any necessity to measure under a standard condition (Temp.:20 + 2℃. Humi.:65 + 5%) is occurred. (测量条件为温度 3-35℃,相对湿度 45~85%,必要时标准测量条件为温度 20 + 2℃, 相对湿度 65 + 5%) VDD IC IC (2) Output 1MΩ C1 C1=C2=100PF IC= 1/6CD4069UBE VDD=+5V C2 5. ELECTRICAL CHARACTERISTICS (电气性能) Item Requirements (项目) 5-1 Center Frequency (fo) (要求) 455KHZ (中心频率) 5-2 Frequency Accuracy (频率精度) 5-3 Resonator Impedance (谐振阻抗) 5-4 Operating Temperature Range Fc±2KHZ 20 Ώ max -20 TO +80 ˚C (使用温度) 5-5 Storage Temperature Range -30 TO +85 ˚C (储存温度) 5-6 Withstanding Voltage DC 100 V (耐电压) 5-8 Temperature Coefficient Of Center Frequency ±0.3% max (-20~+80℃) 5-9 Insulation Impedance 100 MΏ min (绝缘阻抗) 5-10 静电容 320 ± 20 %PF 6. PHYSICAL AND ENVIRONMENTAL CHARACTERISTICS (物理及环境特性) Test Item Condition of Test (试验项目) (试验条件) Requirements (要求) 6-1 Lead Strength Applied to vertical weight 1Kg along with (引脚强度) the direction of lead without any shock Lead Pulling for 5-10sec. No mechanical damage and the (引脚拉力) (沿引线方向加 10 牛顿静载荷 5-10 秒.) measured values Lead Bending Filter lead shall be subjected to withstand shall meet Item (引脚弯曲) against 90°bending its stem.This opration 5. shall be done toward both diretion. (无机械损伤,测量 (引脚折弯 90°,反方向同样。 ) 值足第 5 款要求.) 6-2 Solderability Dip the terminals of the filter no closer The solder shall (可焊性) than 1.5mm into a soldering bath(230+5℃) be for coat at for 5+1 sec . least 95% of the (refer to MIL-STD-202E-208C) terminal surface (端子至少 1.5mm 应浸没在(230+5℃)锡池内 5+1 秒。)(端子表面 95%被浸润) 6-3 Vibration (振动) Filter shall be measured after being applied vibration as below (在下面条件下振动后测试) Vibration Freq: 10-55HZ (振动频率) Amplitude (幅度) Directions (方向) Time (时间) 6-4 Random Drop : 1.5 mm : 3 axial directions (3 轴向) : 1 hour/each direction No visible damage and the measured value shall meet table 1 (无可见损伤且测量值 满足表1) (1 小时/各方向) Filter shall be measured after 3 times (任意跌落) random dropping from the height of 76cm. concrete floor. (3 次 76cm高度跌落到水泥地板后测试) 6-5 Resistance to Filter immersing the terminals up to 1.5 Soldering Heat mm to filter’s body in soldering bath (耐焊接热) (350 +10℃) for 3 sec., filter shall be measure after being placed in natural condition for 1 hour. (端子在(350+10℃)锡池内浸没到器件根部 1.5mm, , 时间 3 秒,自然条件放置 1 小时后测试。 ) The measured value shall meet table 1. (测量值满足表 1) 6. PHYSICAL AND ENVIRONMENTAL CHARACTERISTICS(续上页) (物理及环境特性) Test Item (试验项目) after 6-6 Humidity (湿度) Condition of Test (试验条件) Requirements (要求) After being placed in a chamber (Humi, :90-95% RH Temp.:40 + 2℃) for 100 hours filter shall be measured after placed in natural condition for 1 hour (相对湿度 90-95% 温度 40 + 2℃容器中放置 100 小时, 自然条件放置 1 小时后测试。) 6-7 Life Test After being placed in a chamber 85+2℃ (High for 100 hours ,filter shall be temperature) measured after being placed in natural condition for 1 hour. (寿命试验) (高温) 6-8 (温度 85+ 2℃容器中放置 100 小时,自然条件放置 1 小时后测试。 ) Life Test Placed in a chamber (Temp:-55+ 2℃) for (Low 100 hours,filter shall be measured placed temperature) in natural condition for 1 hour . (寿命试验) (低温) (温度-55±2℃容器中放置 100 小时,自然条件放置 1 小时后测试。 ) After temperature cycling of -55℃(30 6-9 Thermal Shock minutes ) to +85℃ ( 30 minutes ) was (温度冲击) performed 5 times with a transfer time15 min filter shall be measured after being placed in natural condition for 1 hour. (温度-55℃(30 分钟)至+85℃(30 分钟)循环 5 次, 15 分钟 1 次,自然条件放置 1 小时后测试。 ) The measured value shall meet Table 1. (测量值应满足表 1) 6. PHYSICAL AND ENVIRONMENTAL CHARACTERISTICS(续上页) (物理及环境特性) Item (项目) ※ Center Frequency (中心频率) Limit Value (极限值) + 1.0 kHz max ※ Note: The limits in the above table are referenced to the initial Measurements.(表中的限值参照初始测量值) 7. NOTICE (注意) 7.1 Ceremic filter should be stored in storeroom .And the surrouding atmosphere is acidless,alkali-free and no other harmful impurity. 7.2 7.3 (器件应贮藏在贮藏室,周围环境无酸、碱性腐蚀或其它有害气体.) The package for ceramic filter should be avoid the hit by rain and Snow,also the mechanical damage. (包装应避免风雪、雨水的侵袭以及机械伤害。) This specification limits the quality of the component as a single unit .Please make sure that the component is evaluated and confirmed the drawing When it is mounted to your product. (本规格书只规定了部件本身的质量。应用于您的产品时。请确认图纸该部件是否等效.)
CRB 455E 价格&库存
很抱歉,暂时无法提供与“CRB 455E”相匹配的价格&库存,您可以联系我们找货
