AP-CON Aluminum Solid Electrolytic Capacitor
AVHA Series High voltage
Standard SMD type
Rated Voltage:25~100Vdc
Endurance 5000hrs at 105℃
Suitable for DC-DC converters, voltage regulators and decoupling applications
RoHS Compliant
Specification
Category Temperature Range -55~+105℃
Rated Capacitance Range
22 to 470 (μF)
Rated Voltage Range
25 to 100Vdc
Capacitance Tolerance
±20% (M)
Surge Voltage
Rated voltage X 1.15 (at 105°C) Dissipation Factor
Leakage Current
Shall not exceed values shown in standard ratings.
0.12 max. (at 20°C 120Hz)
(at 20°C after 2 mins.)
105°C, 5000hrs, rated voltage applied
Appearance
No significant damage
Endurance
Capacitance Change
≦ ±20% of the initial value
DF(tanδ)
≦ 150% of the initial specified value
ESR
≦ The initial specified value
60℃, 90 to 95% RH, 1000hrs, No voltage applied
Appearance
Leakage current
Damp Heat (Steady State)
Capacitance Change
DF(tanδ)
ESR
Leakage current
1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a
protective resistor (R=1kΩ) and discharge for 5.5min.
Appearance
Surge Voltage
Capacitance Change
DF(tanδ)
ESR
Leakage current
Dimensions and Marking
Series
Date code
Polarity
Capacitance
marking (-)
Voltage
Size code
0606
0807
0810
0812
1012
ψD±0.5max
(mm)
6.3
8.0
8.0
8.0
10.0
L
(mm)
α
(mm)
E
(mm)
W±0.2
(mm)
H±0.2
(mm)
C±0.2
(mm)
R
(mm)
P±0.3
(mm)
5.8
6.8
9.7
12.0
12.3
±0.2
±0.2
±0.3
±0.5
±0.2
0.00~0.20
0.00~0.20
0.00~0.20
0.00~0.20
0.00~0.20
6.6
8.3
8.3
8.3
10.3
6.6
8.3
8.3
8.3
10.3
7.3
9
9
9
11
0.5~0.8
0.8~1.1
0.8~1.1
0.8~1.1
0.8~1.1
2.1
2.9
2.9
3.2
4.6
Product Specifications are subject to change without notice.
AVHA Series Standard
Standard Ratings
WV/Vdc
(SV)
25
(28.8)
35
(40.3)
50
(57.5)
63
(72.5)
80
(92)
100
(115)
Cap Size
(μF) Code
47
56
100
180
220
330
470
47
68
100
150
220
330
47
68
120
220
47
56
68
22
47
68
22
47
0606
0606
0807
0810
0810
0812
0812
0606
0608
0810
0810
0812
1012
0810
0810
1012
1012
0810
1012
1012
0810
1012
1012
1012
1012
ESR
Leakage
(mΩmax/20℃,
Current
(μA)
100k to300kHz)
235
280
500
900
1,100
1,650
2,350
329
476
700
1,050
1,540
2,310
470
680
1,200
2,200
592
705
857
352
752
1,088
440
940
35
35
24
18
18
18
18
35
35
35
25
25
24
25
25
19
17
25
25
25
40
33
25
45
35
Rated Ripple
Current
(mArms/ 105℃
/100kHz)
Part No.
2,500
2,500
3,200
4,100
4,100
4,100
4,650
2,100
2,000
2,800
3,000
2,890
3,400
2,700
2,700
2,950
2,950
2,700
2,950
3,280
1,700
2,100
2,950
1,600
2,100
250AVHA470M0606
250AVHA560M0606
250AVHA101M0807
250AVHA181M0810
250AVHA221M0810
250AVHA331M0812
250AVHA471M0812
350AVHA470M0606
350AVHA680M0608
350AVHA101M0810
350AVHA151M0810
350AVHA221M0812
350AVHA331M1012
500AVHA470M0810
500AVHA680M0810
500AVHA121M1012
500AVHA221M1012
630AVHA470M0810
630AVHA560M1012
630AVHA680M1012
800AVHA220M0810
800AVHA470M1012
800AVHA680M1012
101AVHA220M1012
101AVHA470M1012
很抱歉,暂时无法提供与“250AVHA470M0606”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.93690
- 50+0.75417
- 150+0.66280
- 1200+0.59098
- 2400+0.53622
- 4800+0.50879
