X206017734475MSD2SC
X206017734475MSD2SC
    YXC(扬兴科技)
    DT-26
    无源晶振 206
X206017734475MSD2SC 数据手册
YT-26M Features .External dimensions: 2.0 x 6.0 mm. .Frequency range: 6 ~ 27MHZ Y X C 12 X .Frequency tolerance(standard): ±20ppm. .Excellent Reliability Performance. .Applications: clock and Microcomputer. X Electrical Specifications Item / Type YT-26M Nominal Frequency Range 6 ~ 27 MHz Vibration Mode AT Fundamental Load Capacitance 20 pF , or specify Frequency Tolerance (at 25 ℃) ± 10 ppm, ± 20 ppm, or specify Frequency Versus Temperature Characteristics ± 20 ppm, or s pecif y Operating Temperature - 20 ~ + 70 ℃ , - 40 ~ + 85 ℃ , or specify Storage Temperature ℃ , or specify -40~+85 Shunt Capacitance 7 pF Max. Level Of Drive 1 ~ 100 μW ( 1.0 μW Tvp ) Insulation Resistance More Than 500MΩ at DC 100V Frequency Aging (at 25 ℃) ± 3 ppm / year Max. Equivalent Series Resistance(ESR) Fundamental 6.000-9.999MHz 120 Ω Max. 10.000-19.999MHz 100 Ω Max. 20.000MHz-27.000MHz 80 Ω Max. φ1.92 max φ0.20 0. 70 Dimensions YXC12XXX 6.01 max 5.93 min Units: mm( ±0.1mm) 1/1 YT-26M ★ PART NUMBER GUIDE 部件号示例 e.g. X206012MSD2SC Quartz Crystal Resonator Dimensions Frequency Load Capacitance (Hz) (Pf) X Load Capacitance (Pf) S 20pF G 12.5pF 2060 12M S ×6.0 SMD SEAM TYPE YT-26M =2.0 Frequency Stability Pin Overall (ppm) D Frequency tolerance B ±10PPM D ±20PPM 2 Material Operating Temp. Range S C Operating temperature C -20~ +70 ℃ -40~ +85 ℃ I 1/1
X206017734475MSD2SC 价格&库存
很抱歉,暂时无法提供与“X206017734475MSD2SC”相匹配的价格&库存,您可以联系我们找货
