SQC453226T-4R7K-N
SQC453226T-4R7K-N
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
SQC453226T-4R7K-N 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BWQC Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors - SQC Series SQC Series The SQC Series is a type of miniature wire-wound chip inductor designed on a special ferrite core. They are excellent for use in DC power supply circuits. Features Applications  RoHS compliant  Personal computers  Low DC resistance, high current capacity, and high impedance  Disk drives and computer peripherals  Pagers, cordless phone characteristics  Excellent solder heat resistance  DC power supply circuit  Both flow and reflow soldering methods can be employed  Available in 4 sizes Product Identification  Packaging: T:Tape and Reel  Packaging: T:Tape and Reel Shape and Dimensions SQC322520 & SQC322520LT SQC322517 & SQC322517HP SQC453226 Dimensions in mm TYPE A B C D E F G SQC322517 3.2 ± 0.3 2.5 ± 0.2 1.55± 0.15 2.5 ± 0.2 2.5 ± 0.2 0.9 ± 0.3 1.3 ± 0.2 SQC322517HP 3.2 ± 0.3 2.5 ± 0.2 1.55± 0.15 2.5 ± 0.2 2.5 ± 0.2 0.95 ± 0.3 1.2 ± 0.2 SQC322520 3.2 ± 0.3 2.5 ± 0.2 2.0 ± 0.2 - - - - SQC322520LT 3.2 ± 0.3 2.5 ± 0.2 2.0 ± 0.2 - - - - SQC453226 4.5 ± 0.3 3.6 ± 0.2 2.6 ± 0.2 3.2 ± 0.2 3.2 ± 0.2 3.2 ± 0.2 - SMD Wire Wound Ferrite Chip Inductors - SQC Series Recommended Pattern SQC322517 & SQC322517HP SQC322520 & SQC322520LT & SQC453226 Dimensions in mm TYPE A B C D E SQC322517 5.5 1.0 1.3 1.0 2.0 SQC322517HP 5.5 1.0 1.3 1.0 2.0 SQC322520 5.5 1.0 1.3 1.0 2.0 SQC322520LT 5.5 1.0 1.3 1.0 2.0 SQC453226 7.5 1.5 1.5 1.5 3.0 SMD Wire Wound Ferrite Chip Inductors – SQC Series Electrical Characteristics Inductance Tolerance (uH) (±%) SQC322517T-2R2□-N 2.2 20 SQC322517T-3R3□-N 3.3 20 SQC322517T-6R8□-N 6.8 SQC322517T-100□-N 10 SQC322517T-220□-N 22 SQC322517T-101□-N 100 Part Number Test SRF RDC Rated current (MHz) Min (Ω±30%) (mA) 1 64 0.097 790 1 50 0.12 710 20 1 32 0.25 540 20 / 10 1 26 0.30 350 20 / 10 1 19 0.71 250 20 / 10 1 10 3.50 100 Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : K=±10% , M=±20%  Operating temperature range-25℃~125℃(Including self - temperature rise)  Rated Current for Inductance drop 10% from its value with current  Measure Equipment: L:Agilent HP4192A SRF:Agilent HP4287A RDC:Chroma 16502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – LS Series Electrical Characteristics Inductance Tolerance (uH) (±%) SQC322517HP-R47□-N 0.47 30 SQC322517HP-1R0□-N 1.0 30 SQC322517HP-1R5□-N 1.5 SQC322517HP-2R2□-N 2.2 SQC322517HP-3R3□-N 3.3 SQC322517HP-4R7□-N SQC322517HP-6R8□-N Test SRF RDC Rated current (MHz) Min (Ω±20%) (mA) Irms (mA) 1 100 0.030 3400 2550 1 100 0.045 2300 2050 30 1 70 0.057 1750 1750 30 / 20 1 70 0.076 1550 1600 30 / 20 1 50 0.120 1250 1200 4.7 30 / 20 1 40 0.180 1000 1000 6.8 30 / 20 1 40 0.240 850 850 SQC322517HP-100□-N 10 30 / 20 1 30 0.380 750 700 SQC322517HP-150□-N 15 30 / 20 1 25 0.700 550 500 SQC322517HP-220□-N 22 30 / 20 1 20 0.810 500 450 SQC322517HP-330□-N 33 30 / 20 1 14 1.050 360 320 SQC322517HP-470□-N 47 30 / 20 1 11 1.480 280 240 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : M=±20% , T=±30%  Operating temperature range-25℃~125℃(Including self - temperature rise)  Rated Current:Self temperature rise shall be limited to 40℃ Max Inductance drop 30% typ.  Measure Equipment: L:Agilent HP4192A SRF:Agilent HP4291A RDC:Chroma 16502 Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – SQC Series Electrical Characteristics Inductance Tolerance (uH) (±%) SQC322520T-R47□-N 0.47 20 SQC322520T-1R0□-N 1.0 20 SQC322520T-2R2□-N 2.2 SQC322520T-3R3□-N 3.3 SQC322520T-3R9□-N 3.9 SQC322520T-4R7□-N SQC322520T-6R8□-N Test SRF RDC Rated current (MHz) Min (Ω±30%) (mA) 1 150 0.042 1100 1 96 0.09 1000 20 1 64 0.13 600 20 / 10 1 60 0.15 600 20 1 50 0.16 500 4.7 20 1 43 0.20 450 6.8 20 1 30 0.26 400 SQC322520T-100□-N 10 20 / 10 1 26 0.44 300 SQC322520T-150□-N 15 20 / 10 1 22 0.55 350 SQC322520T-220□-N 22 20 / 10 1 19 0.71 250 SQC322520T-270□-N 27 20 / 10 1 15 0.90 230 SQC322520T-330□-N 33 20 / 10 1 15 1.10 200 SQC322520T-470□-N 47 20 / 10 1 15 1.30 170 SQC322520T-560□-N 56 20 / 10 1 12 2.30 150 SQC322520T-101□-N 100 20 / 10 1 10 3.50 100 SQC322520T-151□-N 150 20 / 10 / 5 1 7 6.00 80 SQC322520T-221□-N 220 20 / 10 / 5 1 6.8 8.40 70 SQC322520T-271□-N 270 20 / 10 1 6 10.0 65 SQC322520T-331□-N 330 20 / 10 / 5 1 5.6 10.0 60 SQC322520T-391□-N 390 20 / 10 1 5 17.0 60 SQC322520T-471□-N 470 20 / 10 0.001 5 19.0 60 SQC322520T-561□-N 560 20 / 10 0.001 5 22.0 60 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10% , M=±20%  Operating temperature range-25℃~125℃(Including self - temperature rise)  Rated Current:Self temperature rise shall be limited to 35℃ Max Inductance drop 10% typ.  Measure Equipment: L:Agilent HP4192A SRF:Agilent HP4291A RDC:Chroma 16502 Rate Current:HP4284A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – SQC Series Electrical Characteristics (LOW DCR Type) Inductance Tolerance (uH) (±%) SQC322520LT-R15□-N 0.15 20 SQC322520LT-R27□-N 0.27 20 SQC322520LT-R47□-N 0.47 SQC322520LT-1R0□-N 1.0 SQC322520LT-1R5□-N Test SRF RDC Rated current (MHz) Min (Ω±30%) (mA) 1 400 0.028 1450 1 250 0.034 1250 20 1 150 0.042 1100 20 1 100 0.060 1000 1.5 20 1 85 0.085 900 SQC322520LT-2R2□-N 2.2 20 1 64 0.097 790 SQC322520LT-3R3□-N 3.3 20 1 55 0.13 700 SQC322520LT-4R7□-N 4.7 20 / 10 1 43 0.15 650 SQC322520LT-6R8□-N 6.8 20 1 30 0.21 600 SQC322520LT-100□-N 10 20 / 10 1 26 0.30 450 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : K=±10% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Rated Current:Self temperature rise shall be limited to 35℃ Max Inductance drop 10% typ.  Measure Equipment: L:Agilent HP4192A SRF:Agilent HP4291A RDC:Chroma 16502 Rate Current:HP4284A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors – SQC Series Electrical Characteristics Inductance Tolerance (uH) (±%) SQC453226T-1R0□-N 1.0 20 SQC453226T-1R5□-N 1.5 20 SQC453226T-1R8□-N 1.8 SQC453226T-2R2□-N 2.2 SQC453226T-3R3□-N 3.3 SQC453226T-4R7□-N SQC453226T-6R8□-N Test SRF RDC Rated current (MHz) Min (Ω) Max (mA) 1 100 0.08 1080 1 85 0.09 1000 20 1 65 0.10 900 20 / 10 1 60 0.11 900 20 1 47 0.13 800 4.7 20 / 10 1 35 0.15 750 6.8 20 / 10 1 30 0.20 720 SQC453226T-100□-N 10 20 / 10 / 5 1 23 0.24 650 SQC453226T-150□-N 15 20 / 10 / 5 1 20 0.32 570 SQC453226T-220□-N 22 20 / 10 / 5 1 15 0.60 420 SQC453226T-330□-N 33 20 / 10 / 5 1 12 1.0 310 SQC453226T-470□-N 47 20 / 10 / 5 1 10 1.1 280 SQC453226T-680□-N 68 20 / 10 / 5 1 8.4 1.7 220 SQC453226T-101□-N 100 20 / 10 / 5 1 6.8 2.2 190 SQC453226T-151□-N 150 20 / 10 / 5 1 5.5 3.5 130 SQC453226T-221□-N 220 20 / 10 / 5 1 4.5 4.0 110 SQC453226T-331□-N 330 20 / 10 / 5 1 3.6 6.8 100 SQC453226T-471□-N 470 20 / 10 / 5 1 3.0 8.5 90 SQC453226T-561□-N 560 20 / 10 / 5 0.001 2.5 10.4 80 SQC453226T-681□-N 680 20 / 10 / 5 0.001 2.2 14.7 70 SQC453226T-821□-N 820 20 / 10 / 5 0.001 2.0 20.0 60 SQC453226T-102□-N 1000 20 / 10 / 5 0.001 2.0 27.9 50 SQC453226T-152□-N 1500 20 / 10 / 5 0.001 1.8 35.0 40 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance : J=±5% , K=±10% , M=±20%  Operating temperature range-40℃~125℃(Including self - temperature rise)  Rated Current:Self temperature rise shall be limited to 35℃ Max Inductance drop 10% typ.  Measure Equipment: L:Agilent HP4192A SRF:Agilent HP4291A RDC:Chroma 16502 Rate Current:HP4284A+HP42841A Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Wire Wound Ferrite Chip Inductors - SQC Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A0 B0 K0 D E W P P0 P2 A B C D PCS / REEL SQC322517 2.85 3.56 1.80 1.55 1.75 8 4 4 2 178 60 9 1.5 2000 SQC322517HP 2.85 3.56 1.80 1.55 1.75 8 4 4 2 178 60 9 1.5 2000 SQC322520 2.90 3.60 2.25 1.5 1.75 8 4 4 2 178 60 9 1.5 2000 SQC322520LT 2.90 3.60 2.25 1.5 1.75 8 4 4 2 178 60 9 1.5 2000 SQC453226 3.60 4.90 3.00 1.5 1.75 12 8 4 2 178 60 13.2 1.5 500
SQC453226T-4R7K-N 价格&库存
很抱歉,暂时无法提供与“SQC453226T-4R7K-N”相匹配的价格&库存,您可以联系我们找货
