CRYSTAL UNIT
HC-49SMD/SSMD
Applications
Features
‧Industrial Control
Consumers .
‧Dimensions:49SMD:11.5 x 4.80 x3.8 mm.
49SSMD:11.5 x 4.80 x3.0 mm.
‧Surface mount type crystal units.
‧A great number of standard frequencie
‧Frequency range:3.2768~64MHz
Specifications
Standard Frequency
3.2768~64 MHz
Vibration Mode
AT Fundamental
12pF,20pF,or specify
Load Capacitance
±10ppm,±20ppm,or specify
Frequency Tolerance (at 25 )
±20ppm,or specify
Frequency Versus Temperature Characteristics
-20~+70℃,-40~+85℃,or specify
Operating Temperature
-40~+85℃ or specify
Storage Temperature
7 pF Max.
Shunt Capacitance
1~500μWMax.(100uW typical)
Level of Drive
±3ppm/year Max.
Aging (at 25 ℃ )
Equivalent Series Resistance(ESR)
3.2768 ~ 4MHz
4 ~ 5MHz
5 ~ 6 MHz
180 Ω Max.
120 Ω Max.
100 Ω Max.
20 ~ 25 MHz
100 Ω Max.
Fundamental
3rd Overtone
6 ~ 17 MHz
7 ~ 10 MHz
10 ~ 27MHz
80 Ω Max.
60 Ω Max.
40 Ω Max.
25 ~ 64 MHz
80 Ω Max.
Dimensions and Patterns [unit:mm]
Package Size – Dimensions (Unit: mm)
www.yxc.hk
第1页共2页
CRYSTAL UNIT
HC-49SMD/SSMD
Reflow Soldering Profile
Temperature
Pre Heating Temperature
Tp1 ~ Tp2 = + 170 °C
Heating Temperature
TMlt = + 220 °C
Peek Temperature
TMax. = + 260 °C
+260℃
TMax.
+220℃
Tmlt
Point of measuring
In case of Solder ability
Terminal.
In case of Resistance to soldering heat
Surface.
Tp2
Tp1
35s
100s
t(time)
Taping Specification(Unit: mm)
Size
A
B
C
D
E
F
G
H
49SMD
330±2.0
24.0±0.3
11.90±0.1
5.00±0.1
8.0±0.1
4.25±0.2
100.0±1.0
24.5±1.0
49SSMD
330±2.0
24.0±0.3
11.80±0.1
5.00±0.1
8.0±0.1
3.50±0.2
100.0±1.0
24.5±1.0
1000 pcs per reel
www.yxc.hk
第2页共2页
很抱歉,暂时无法提供与“X49SM16MSD2SI”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.74315
- 50+0.59487
- 150+0.52078
- 1000+0.42974
- 2000+0.38524
- 国内价格
- 1+0.57324
- 50+0.38250
- 1000+0.34578
