CR2512J180KE04Z
CR2512J180KE04Z
    EVEROHMS(天二)
    贴片电阻 2512
CR2512J180KE04Z 数据手册
■ Thick Film Chip Resistor — CR Series ■ Application ■ Features ─ Consumer electrical ─ Small size and light weight ─ Home Appliance: Air conditioner, Refrigerator ─ Reliability, high quality ─ Computer & relative products: Main board ─ Communication equipment: Cell phone, Fax machine ─ Power equipment: Power supply,lllumination equipment ─ Measuring instrument: Electric meter, Navigation equipment ■ Type Dimension ■ Dimension Unit: mm TYPE L W H l1 l2 CR0201 0.60 ± 0.03 0.30 ± 0.03 0.23 ± 0.05 0.15 ± 0.05 0.15 ± 0.05 CR0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.15 ± 0.10 0.20 ± 0.10 CR0603 1.60 ± 0.20 0.80 ± 0.15 0.40 ± 0.10 0.30 ± 0.20 0.30 ± 0.10 CR0805 2.00 ± 0.20 1.25 ± 0.15 0.50 ± 0.15 0.30 ± 0.15 0.40 ± 0.15 CR1206 3.05 ± 0.10 1.60 ± 0.20 0.55 ± 0.15 0.40 ± 0.20 0.50 ± 0.20 CR1210 3.05 ± 0.10 2.50 ± 0.20 0.55 ± 0.15 0.50 ± 0.20 0.50 ± 0.20 CR1812 4.50 ± 0.10 3.10 ± 0.20 0.55 ± 0.05 0.55 ± 0.20 0.70 ± 0.20 CR2010 5.00 ± 0.20 2.50 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 CR2512 6.30 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Standard Electrical Specifications Item Type CR0201 Rated Power Max Working at 70℃ Voltage 0.05 W CR0402 0.063 W CR0603 0.1 W CR0805 0.125 W CR1206 Max Overload Voltage 25V T.C.R. (PPM/℃) 50V 100V 75V 150V 150V 300V 0.5 W - 1Ω~9.9Ω ±200 - 10Ω~10MΩ ±400 - 1Ω~9.9Ω ±300 - 10Ω~990Ω ±200 10Ω~1MΩ 1KΩ~10MΩ ±400 - 1Ω~9.9Ω ±200 - - 10Ω~10MΩ ±100 10Ω~1MΩ 10Ω~10MΩ - ±400 - ±200 - - 10Ω~10MΩ ±100 10Ω~1MΩ 10Ω~10MΩ - ±300 - ±200 - 200V 400V 0.75 W 1W 10.2Ω~1MΩ 10.2Ω~10MΩ 1Ω~10Ω ±200 - - 10.2Ω~10MΩ 10.2Ω~1MΩ 10.2Ω~10MΩ ±300 - ±200 - - 1Ω~10Ω 10.2Ω~10MΩ - 10.2Ω~1MΩ 10.2Ω~10MΩ ±300 - ±200 - - 1Ω~10Ω 10.2Ω~10MΩ - 10.2Ω~1MΩ 10.2Ω~10MΩ ±300 - ±200 - ±100 ● ● ● ● 10.2Ω~10MΩ 1Ω~10Ω ±100 CR2512 1Ω~10Ω - ±100 CR2010 1Ω~9.9Ω ±300 ±100 0.75 W J(±5%) -200/+400 ±100 CR1812 Resistance Range F(±1%) G(±2%) 50V 0.25 W CR1210 B(±0.1%) D(±0.5%) - 1Ω~10Ω 10.2Ω~10MΩ - 10.2Ω~1MΩ 10.2Ω~10MΩ - For non-standard parts, please contact our sales dept. Operating Temperature Range :−55℃〜+155℃. Type CR1210/1812/2010/2512 :1Ω~10Ω(Alloy Film) Type CR1210/1812/2010/2512 :>10Ω(Thick Film) Type 0201 0402 0603 Jumper Resistance Value Jumper Rated Current TEL: 886-7-8116611 0805 1206 1210 1812 2010 2512 50mΩMax 0.5A FAX: 886-7-8115533 1A E-mail: service@everohms.com 2A http://www.everohms.com ● Low Ohm Chip Resistor ■ Standard Electrical Specifications Item Resistance Range (mΩ) Rated Power at 70℃ Rated Voltage Range Max Overload Voltage T.C.R. (PPM/℃) CR0402 0.063 W 0.17~0.25V 0.624 V ±800 470~990 CR0603 0.1 W 0.1~0.31V 0.775 V ±800 100~330 ±600 331~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 ±1800 10~50 ±800 51~100 ±600 101~990 F(±1%)、J±(5%) Type CR0805 CR1206 CR1210 CR1812 CR2010 0.125 W 0.25 W 0.5 W 0.75 W 0.75 W CR2512 1W 0.04~0.35V 0.875 V 0.05~0.5V 1.25 V 0.07~0.7V 1.75 V 0.08~0.8V 2.15 V 0.08~0.8V 2.15 V 0.1~0.99V 2.475V ● For non-standard parts, please contact our sales dept. ● Operating Temperature Range :−55℃〜+155℃. ● High Ohm Chip Resistor ■Standard Electrical Specifications Item Rated Power at 70℃ Max Working Voltage Max Overload Voltage CR0402 0.063 W 50V 100V CR0603 0.1 W 75V 150V CR0805 0.125 W 150V 300V CR1206 0.25 W CR1210 0.5 W Type ±200 200V CR2010 0.75 W CR2512 1W T.C.R. (PPM/℃) 400V Resistance Range F(±1%) J(±5%) 10.1 MΩ 10.1 MΩ ~ ~ 54 MΩ 100 MΩ ● For non-standard parts, please contact our sales dept. ● Operating Temperature Range :−55℃〜+155℃. TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ● Trimmable Chip Resistor – TCR series ■ Standard Electrical Specifications Item Rated Power at 70℃ Max Working Voltage Max Overload Voltage TCR0402 0.063 W 50V 100V TCR0603 0.1 W 75V 150V TCR0805 0.125 W 150V 300V TCR1206 0.25 W TCR1210 0.5 W TCR1812 0.75 W Type 0.75 W TCR1218 1W TCR2512 1W Resistance Tolerance Resistance Range ±15% ±200 200V TCR2010 T.C.R. (PPM/℃) ±20% 10Ω~1MΩ ±30% 400V ● For non-standard parts, please contact our sales dept. ● Operating Temperature Range :−55℃〜+155℃. ■ Parts Number Explanation ■ Example: CR 0603 J 10R P 05 Product Type Size(Inch) Resistor Tolerance Resistors Value Package Quantity CR TCR 0201 0402 0603 0805 1206 1210 1812 2010 2512 TEL: 886-7-8116611 B:±0.1% D:±0.5% F:±1% G:±2% J:±5% K:±10% L:±15% M:±20% N:±30% FAX: 886-7-8115533 P、Q:Paper Taping E:Embossed Taping D:Packed in a Bag E-mail: service@everohms.com Optional 04:4000PCS 05:5000PCS 10:10000PCS 40:40000PCS 50:50000PCS http://www.everohms.com ■ Appendix For SMD Chip Resistor ● Packaging Information ■ Dimension Unit: mm TYPE SIZE A ψB ψC ψD W ψM 0201/0402 7” 10K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 0402 13” 40K/50K Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 330±2.0 0603/0805/1206/ 1210 7” 5K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 10” 10K/Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 254±2.0 13” 20K/Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 330±2.0 7” 4K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 16.0±2.0 178±2.0 0603/0805 /1206 2010/2512/1812 ■ Tapping Specification ■ Dimension Unit: mm Packaging Type A B W E F G H T 0201 0.45±0.1 0.75±0.1 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.35±0.1 0402 0.70±0.1 1.20±0.1 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.45±0.1 0603 1.05±0.2 1.80±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.60±0.1 0805 1.55±0.2 2.30±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 1206 1.90±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 1210 2.85±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 ψD P 2.0±0.1 Paper Type 4.0±0.1 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Dimension Unit: mm Packaging Type Embossed Type A B W E F G H T ψD ψD1 T1 P 2010 2.80±0.2 5.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 2512 3.40±0.2 6.70±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 4.0±0.1 1812 3.30±0.2 4.60±0.2 12±0.1 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1 1.50±0.1 0.85±0.15 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Packing Material Data / Storage Data ■ Front & Back Lead Dimension ■ Top Adhesive Peel Off Strength:10~70g ■ Package External Box Size Contain Length Width Height (Kpcs) (mm) (mm) (mm) Inner Box Size Reel Size H(mm) 1 13 2 24 3 36 5 60 10 113 25K 180 180 60 50K 180 180 110 150K 430 200 200 300K 400 400 200 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ● Reliability Test and Requirement Test Item Test Method Temperature Coefficient of Resistance (T.C.R) JIS C 5201-1 clause 4.8 -55℃ or +155℃, 25℃ is the reference temperature Refer to Ratings Short Time Overload JIS C 5201-1 clause 4.13 General:2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. ±1:±(1.0%+0.05Ω) ±5:±(2.0%+0.1Ω) Value 95% Coverage Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. ±1:±(0.5%+0.05Ω) ±5:±(1.0%+0.05Ω) Value
CR2512J180KE04Z
1. 物料型号:文档列出了不同尺寸的芯片电阻型号,如CR0201、CR0402、CR0603等。 2. 器件简介:芯片电阻器以其小尺寸、轻重量、高可靠性和高质量而广泛应用于消费电子、家用电器、计算机及关联产品、通信设备、电源设备和测量仪器等。 3. 引脚分配:文档提供了不同型号的芯片电阻的尺寸数据,包括长度、宽度和高度。 4. 参数特性:包括额定功率、最大工作电压、最大过载电压、温度系数(T.C.R.)、电阻范围和公差等级。 5. 功能详解:文档详细描述了电阻器的电气特性,如额定功率、最大工作电压、最大过载电压和温度系数。 6. 应用信息:芯片电阻器适用于多种电子设备,包括手机、传真机、电源、照明设备、电表和导航设备等。 7. 封装信息:提供了不同型号的封装尺寸和包装信息,如卷带包装和纸带包装的尺寸规格。
CR2512J180KE04Z 价格&库存
很抱歉,暂时无法提供与“CR2512J180KE04Z”相匹配的价格&库存,您可以联系我们找货
