www.jghcorp.com
【深圳市晶光华电子有限公司】
Small SMD seam sealed clock crystal oscillator units.
High precision characteristic covering up to wide frequency
range.
Designed for automatic mounting and reflow soldering.
Tri-State function available.
Supply voltage range : 1.8 V ~ 5.0 V.
High stability, low jitter, low power consumption.
Main application : wireless communication set, PDA, and
DSC.
Crystals specifications
ITEMS(项目)
PARAMETER(规格说明) O53
Output Type(输出模式)
CMOS
Output Load(输出负载条件)
15 pF , 30 pF
Oscillation Mode(振荡模式)
Fundamental / 3rd Overtone
Supply Voltage(电源电压)
1.8±10%V ;2.5±10%V ;2.8±10%V ;3.3±10%V;5±10%V;
Frequency Range(输出频率范围)
1 ~ 150 MHz
Frequency Stability
± 20 ppm , ± 25 ppm , ± 30 ppm , ± 50 ppm
Operating Temperature Range(工作温度)
- 10 ~ + 70 ℃ , - 40 ~ + 85 ℃
Storage Temperature Range(储存温度)
- 55 ~ + 125 ℃
Oscillating voltage(振荡电压)
Voltage Vol ( Max. )
10 % VCC Max.
Voltage Voh ( Min. )
90 % VCC Min
8 ns Max.
Rise ( Tr ) / Fall ( Tf ) Time:上升/下降时间
Current Consumption(功耗)
1-75 MHz
5 mA Max.
10 mA Max.
20 mA Max.
75-150 MHz
15 mA Max.
20 mA Max.
NA
Symmetry(占空比)
40 ~ 60 %
Start-up Time(振荡启动时间)
5 ms Max.
Phase Jitter ( 12 KHz ~ 20 MHz )
Dimensions
1 ps Max.
Aging ( at 25 ℃ )频率老化
± 3 ppm / year Max.
Packing Unit(包装单位)
1,000pcs/Reel
很抱歉,暂时无法提供与“O5325000153350”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.36960
- 10+2.66760
- 30+2.35440
- 100+1.97640
- 500+1.73880
