160AVEA101M0606
160AVEA101M0606
    APAQ(钰邦)
    SMD,D6.3xL5.8mm
    贴片铝电解电容 SMD
160AVEA101M0606 数据手册
AP-CON Aluminum Solid Electrolytic Capacitor AVEA Series Standard   Standard SMD type Rated Voltage:2.5~25Vdc    Endurance 2000hrs at 105℃ Suitable for DC-DC converters, voltage regulators and decoupling applications RoHS Compliant Specification Category Temperature Range -55~+105℃ Rated Capacitance Range 15 to 1000 (μF) Rated Voltage Range 2.5 to 25Vdc Capacitance Tolerance ±20% (M) Surge Voltage Rated voltage X 1.15 (at 105°C) Dissipation Factor Leakage Current Shall not exceed values shown in standard ratings. 0.12 max. (at 20°C 120Hz) (at 20°C after 2 mins.) 105°C, 2000hrs, rated voltage applied Appearance No significant damage Endurance Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value ≦ The initial specified value 60℃, 90 to 95% RH, 1000hrs, No voltage applied Appearance No significant damage Leakage current Damp Heat (Steady State) Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value 1,000 cycles and each one includes charge with surge voltage specified at 105°C for 0.5min through a protective resistor (R=1kΩ) and discharge for 5.5min. Appearance No significant damage Surge Voltage Capacitance Change ≦ ±20% of the initial value DF(tanδ) ≦ 150% of the initial specified value ESR ≦ 150% of the initial specified value Leakage current ≦ The initial specified value Dimensions and Marking Series Date code Polarity Capacitance marking (-) Voltage Size code 0506 0645 0606 0610 0807 0810 ψD±0.5max (mm) 5.0 6.3 6.3 6.3 8.0 8.0 L (mm) 5.8 4.3 5.8 9.7 6.8 9.7 α (mm) E (mm) W±0.2 (mm) H±0.2 (mm) C±0.2 (mm) R (mm) P±0.3 (mm) 0.2 0.2 0.2 0.3 0.2 0.3 0.00~0.20 0.00~0.20 0.00~0.20 0.00~0.20 0.00~0.20 0.00~0.20 5.3 6.6 6.6 6.6 8.3 8.3 5.3 6.6 6.6 6.6 8.3 8.3 6 7.3 7.3 7.3 9 9 0.5~0.8 0.5~0.8 0.5~0.8 0.6~0.9 0.8~1.1 0.8~1.1 1.4 2.1 2.1 2.1 2.9 2.9 Product Specifications are subject to change without notice. AP-CON Aluminum Solid Electrolytic Capacitor AVEA Series Standard Standard Ratings WV/Vdc (SV) 2.5 (2.9) 6.3 (7.2) 16 (18.4) 25 (28.8) Cap Size (μF) Code 330 330 390 390 560 820 100 220 220 330 560 560 820 1000 47 68 100 100 180 270 270 330 15 22 27 47 0506 0645 0506 0606 0606 0610 0645 0645 0606 0606 0610 0810 0810 0810 0606 0606 0506 0606 0606 0807 0810 0810 0645 0645 0606 0606 Leakage ESR Current (mΩmax/20%, (μA) 100k to300kHz) 165 700 700 292 700 700 315 700 277 416 705 705 1,033 1,260 376 300 320 320 576 864 864 1,056 300 275 338 235 21 17 10 10 10 10 19 17 15 17 10 10 12 10 25 25 27 24 22 22 16 16 55 45 40 30 Product Specifications are subject to change without notice. Rated Ripple Current (mArms/ 105℃ /100kHz) Part No. 2,670 2,300 3,900 3,900 3,900 4,300 2,300 2,300 3,160 3,390 4,300 4,500 4,700 5,440 2,500 2,440 3,000 2,490 3,300 3,300 4,400 4,700 1,650 2,350 2,100 2,500 2R5AVEA331M0506 2R5AVEA331M0645 2R5AVEA391M0506 2R5AVEA391M0606 2R5AVEA561M0606 2R5AVEA821M0610 6R3AVEA101M0645 6R3AVEA221M0645 6R3AVEA221M0606 6R3AVEA331M0606 6R3AVEA561M0610 6R3AVEA561M0810 6R3AVEA821M0810 6R3AVEA102M0810 160AVEA470M0606 160AVEA680M0606 160AVEA101M0506 160AVEA101M0606 160AVEA181M0606 160AVEA271M0807 160AVEA271M0810 160AVEA331M0810 250AVEA150M0645 250AVEA220M0645 250AVEA270M0606 250AVEA470M0606
160AVEA101M0606 价格&库存
很抱歉,暂时无法提供与“160AVEA101M0606”相匹配的价格&库存,您可以联系我们找货
