RMCS1206FT1K69
RMCS1206FT1K69
    SEI
    贴片电阻 1206 1.69KΩ ±1% 1/4W ±100ppm/℃
RMCS1206FT1K69 数据手册
RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Features: • • • • • • Inner terminations engineered to deter sulfur contamination Non-standard resistance values available Zero ohm available (max resistance 0.05Ω) “-HP” denotes high power RoHS compliant and halogen free Also available RMCS-PD Series – High Sulfur Resistant Thick Film Chip Resistor Electrical Specifications Maximum Overload Type / Code Power Rating (W) @ 70ºC RMCS0201 0.05 Maximum Working Voltage (V)(1) 25 RMCS0402 0.063 50 100 1 RMCS0603 0.1 50 100 1 RMCS0805 0.125 150 300 2 RMCS1206 0.25 200 400 2 RMCS1210 0.33 200 400 2.5 RMCS2010 0.75 200 400 3.5 RMCS2512 1 250 500 4 Voltage (V)(2) 50 Maximum Current Jumper (A) 1 TCR (ppm/ºC) ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 ± 200 ± 100 ± 200 Ohmic Range (Ω) and Tolerance 0.5% - 1% 5% 1 - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M 1 - 9.76 10 - 1M 1.02M - 10M (1) Lesser of √ P*R or maximum working voltage, whichever is lower. (2) 2.5* √ P*R or Max. Overload Voltage listed above, whichever is lower. Electrical Specifications – High Power Type / Code Power Rating (W) Maximum Working Maximum Overload TCR (ppm/ºC) (1) (2) @ 70ºC Voltage (V) Voltage (V) RMCS0201_-HP 0.083 25 50 RMCS0402_-HP 0.1 50 100 RMCS0603_-HP 0.25 75 150 RMCS0805_-HP 0.33 150 300 RMCS1206_-HP 0.5 200 400 RMCS1210_-HP 0.75 200 400 RMCS2010_-HP 1 200 400 ± 200 ± 200 ± 100 ± 200 ± 100 ± 200 ± 100 ± 200 ± 100 ± 200 ± 100 ± 200 ± 100 Ohmic Range (Ω) and Tolerance 0.5%(3) 10 - 1M 10 - 1M 10 - 1M 10 - 1M 10 - 1M 10 - 1M 1% 5% 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M 1 - 9.76 10 - 1M (1) Lesser of √ P*R or maximum working voltage, whichever is lower. (2) 2.5* √ P*R or Max. Overload Voltage listed above, whichever is lower. (3) 0.5% tolerance for 0603 and 0805 requires lower power rating. Contact Stackpole for details. Rev Date: 2/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 1 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Mechanical Specifications Type / Code Weight (g) (1000 pieces) RMCS0201 0.15 RMCS0402 0.62 RMCS0603 2.042 RMCS0805 4.368 RMCS1206 8.947 RMCS1210 15.959 RMCS2010 24.241 RMCS2512 39.448 L Body Length 0.024 ± 0.001 0.60 ± 0.03 0.039 ± 0.006 1.00 ± 0.15 0.063 ± 0.008 1.60 ± 0.20 0.079 ± 0.008 2.00 ± 0.20 0.122 ± 0.006 3.10 ± 0.15 0.122 ± 0.006 3.10 ± 0.15 0.197 ± 0.008 5.00 ± 0.20 0.250 ± 0.004 6.35 ± 0.10 W Body Width 0.012 ± 0.001 0.30 ± 0.03 0.020 ± 0.002 0.50 ± 0.05 0.031 ± 0.004 0.80 ± 0.10 0.049 ± 0.006 1.25 ± 0.15 0.061 ± 0.010 1.55 ± 0.25 0.102 ± 0.012 2.60 ± 0.30 0.098 ± 0.008 2.50 ± 0.20 0.122 ± 0.006 3.10 ± 0.15 H Body Height 0.009 ± 0.001 0.23 ± 0.03 0.014 ± 0.004 0.35 ± 0.10 0.018 ± 0.006 0.45 ± 0.15 0.020 ± 0.006 0.50 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.006 0.55 ± 0.15 0.022 ± 0.004 0.55 ± 0.10 0.022 ± 0.006 0.55 ± 0.15 a Top Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.006 0.20 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.014 ± 0.008 0.35 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.010 0.50 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 0.024 ± 0.010 0.60 ± 0.25 b Bottom Termination 0.006 ± 0.002 0.15 ± 0.05 0.008 ± 0.006 0.20 ± 0.15 0.012 ± 0.008 0.30 ± 0.20 0.016 ± 0.008 0.40 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.008 0.50 ± 0.20 0.020 ± 0.012 0.50 ± 0.30 0.020 ± 0.008 0.50 ± 0.20 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Performance Characteristics Test Test Method Short Time Overload JIS-C-5201-1 4.13 IEC-60115-1 4.13 Rapid change of Temperature JIS-C-5201-1 4.6 IEC-60115-1 4.6 JIS-C-5201-1 4.25 IEC-60115-1 4.25.1 JIS-C-5201-1 4.24 IEC-60115-1 4.24 JIS-C-5201-1 4.23 IEC-60115-1 4.23.2 JIS-C-5201-1 4.33 IEC-60115-1 4.33 JIS-C-5201-1 4.17 IEC-60115-1 4.17 JIS-C-5201-1 4.18 IEC-60115-1 4.18 JIS-C-5201-1 4.7 IEC-60115-1 4.7 JIS-C-5201-1 4.18 IEC-60068-2-58 8.2.1 JIS-C-5201-1 4.19 IEC-60115-1 4.19 Sulfur Test ASTM-B-809-95 Insulation Resistance Endurance Damp Heat with Load Dry Heat Bending Strength Solderability Resistance to Soldering Heat Voltage Proof Leaching Test Specification ±1% and below ±5% Jumper ± (1% + 0.05Ω) < 50mΩ ± (2% + 0.05Ω) Test Condition RCWV*2.5 or Max. Overload Voltage whichever is lower for 5 seconds, 2 seconds for high power series. ≥10G Max. Overload Voltage for 1 minute 70 ± 2ºC, RCWV for 1000 hours with 1.5 hours "ON" and 0.5 hour "OFF" 40 ± 2ºC, 90 ~ 95% R.H., RCWV for 1000 hours < 100mΩ with 1.5 hours "ON" and 0.5 hour "OFF" ± (2% + 0.1Ω) ± (3% + 0.1Ω) < 100mΩ ± (2% + 0.1Ω) ± (3% + 0.1Ω) ± (1% + 0.05Ω) ± (1.5% + 0.1Ω) < 50mΩ At +125 / +155ºC for 1000 hours ± (1% + 0.05Ω) ± (1% + 0.05Ω) < 50mΩ Bending once for 5 seconds 2010, 2512 sizes: 2 mm / Other sizes: 3 mm 95% minimum coverage ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) 245 ± 5ºC for 3 seconds < 50mΩ 260 ± 5ºC for 10 seconds No breakdown or flashover 1.42 times Max. Operating Voltage for 1 minute Individual leaching area ≤ 5% Total leaching area ≤ 10% 260 ± 5ºC for 30 seconds ± (0.5% + 0.05Ω) ± (1% + 0.05Ω) < 50mΩ -55 to +125ºC / +155ºC, 5 cycles ± (0.5% + 0.05Ω) ± (0.5% + 0.05Ω) < 50mΩ H2S, 50 ± 2ºC, 91 ~ 93% R.H., no power rating for 1000 hours RCWV (Rated Continuous Working Voltage) = √ P*Ror Max. Operating Voltage, whichever is lower. Storage Temperature: 15 ~ 28ºC. Humidity < 80% R.H. Operating temperature range is -55°C to +125°C for 0201, and -55°C to +155°C for all other sizes. Rev Date: 2/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 2 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Power Derating Curve: Percent Rated Power (%) 100 -55ºC 70ºC 80 0402, 0603, 0805, 1206, 1210, 2010, 2512 60 40 0201 20 155ºC 125ºC 0 0 20 40 60 100 80 120 140 160 Ambient Temperature (°C) Packaging Specifications – Paper Tape Type RMCS0201 RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 L 0.015 0.38 0.026 0.65 0.043 1.10 0.063 1.60 0.075 1.90 0.110 2.80 Type RMCS0201 RMCS0402 RMCS0603 RMCS0805 ± ± ± ± ± ± ± ± ± ± ± ± M 0.002 0.05 0.006 0.15 0.010 0.25 0.010 0.25 0.008 0.20 0.010 0.25 0.027 0.68 0.045 1.15 0.075 1.90 0.094 2.40 0.138 3.50 0.138 3.50 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.002 0.05 0.006 0.15 0.010 0.25 0.010 0.25 0.008 0.20 0.008 0.20 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.315 8.00 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± E 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.059 1.50 RMCS1210 0.157 ± 0.004 4.00 ± 0.10 0.157 ± 0.004 4.00 ± 0.10 0.079 ± 0.002 2.00 ± 0.05 0.059 1.50 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 3 F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 0.138 3.50 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 0.002 0.05 inches mm inches mm inches mm inches mm inches mm inches mm 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 inches mm inches mm inches mm inches mm 0.033 ± 0.008 0.85 ± 0.20 inches mm 0.030 ± 0.008 0.75 ± 0.20 inches mm ØD0 RMCS1206 Rev Date: 2/24/2021 ± ± ± ± ± ± ± ± ± ± ± ± K1 0.017 0.42 0.018 0.45 0.028 0.70 0.033 0.85 ± ± ± ± ± ± ± ± Unit www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Packaging Specifications – Embossed Plastic Tape Type RMCS2010 RMCS2512 L 0.110 2.80 0.138 3.50 Type RMCS2010 RMCS2512 ± ± ± ± M 0.008 0.20 0.008 0.20 0.217 5.50 0.264 6.70 0.004 0.10 0.004 0.10 0.157 4.00 0.157 4.00 P0 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.472 12.00 0.472 12.00 0.004 0.10 0.004 0.10 0.079 2.00 0.079 2.00 P1 ± ± ± ± ± ± ± ± E 0.012 0.30 0.012 0.30 0.069 1.75 0.069 1.75 0.002 0.05 0.002 0.05 0.059 1.50 0.059 1.50 P2 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.217 5.50 0.217 5.50 ØD0 +0.004 / -0 +0.10 / -0 +0.004 / -0 +0.10 / -0 ± ± ± ± Unit 0.002 0.05 0.002 0.05 inches mm inches mm 0 0 0 0 inches mm inches mm K2 0.047 1.20 0.047 1.20 - Unit Recommended Pad Layout Type / Code a b c Unit RMCS0201 0.012 0.30 0.010 0.25 0.012 0.30 inches mm 0.024 0.60 0.035 0.90 0.051 1.30 0.087 2.20 0.079 2.00 0.150 3.80 0.193 4.90 0.020 0.50 0.031 0.80 0.031 0.80 0.039 1.00 0.035 0.90 0.035 0.90 0.063 1.60 0.028 0.70 0.039 1.00 0.055 1.40 0.067 1.70 0.110 2.80 0.110 2.80 0.138 3.50 inches mm inches mm inches mm inches mm inches mm inches mm inches mm RMCS0402 RMCS0603 RMCS0805 RMCS1206 RMCS1210 RMCS2010 RMCS2512 Rev Date: 2/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Soldering Condition (1) Time of IR reflow soldering at maximum temperature point 260°C: 10 seconds (2) Time of wave soldering at maximum temperature point 260°C: 10 seconds (3) Time of soldering iron at maximum temperature point 410°C: 5 seconds RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type Sulfur Resistant Thick Film SMD Surface Mount Chip Resistor Note (1): RoHS Compliant by means of exemption 7c-I. RMCS Standard Series RoHS Compliant Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) Lead-Free Effective Date Code (YY/WW) YES(1) 100% Matte Sn over Ni Always Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Rev Date: 2/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com RMCS Series Stackpole Electronics, Inc. Sulfur Resistant Thick Film Chip Resistor Resistive Product Solutions Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 R M C S 0 6 0 3 J T 4 K 7 0 - H P Product Series Sulfur Resistant RMCS Size 0201 0402 0603 0805 1206 1210 2010 2512 Power Rating (W) RMCS -HP 0.05 0.083 0.063 0.1 0.1 0.25 0.125 0.33 0.25 0.5 0.33 0.75 0.75 1 1 NA Tolerance Packaging Code Tol Value Code Description Size Quantity D 0.5% E96 10" Reel G 0201, 0402 15000 F 1% E96, E24 Paper Tape J 5% E24 0201, 0402 10000 7" Reel Z Jumper 0603, 0805 Paper Tape 5000 T 1206, 1210 7" Reel 2010, 2512 4000 Plastic Tape Rev Date: 2/24/2021 This specification may be changed at any time without prior notice Please confirm technical specifications before you order and/or use. 6 Resistance Value Four characters with the multiplier used as the decimal holder. 1 ohm = 1R00 100 Kohm = 100K 1.02 Mohm = 1M02 Zero ohm jumper = 0R00 Special Code Description -HP High Power www.seielect.com marketing@seielect.com
RMCS1206FT1K69
物料型号:RMCS系列,包括不同尺寸的型号,如RMCS0201、RMCS0402、RMCS0603等,以及高功率型号(后缀-HP)。
器件简介:RMCS系列是由Stackpole Electronics, Inc.生产的耐硫厚膜芯片电阻器,具有抗硫污染的特性,符合RoHS标准,无卤素,提供非标准电阻值,包括零欧姆电阻。
引脚分配:文档中提供了详细的机械规格,包括电阻器的重量、尺寸(长度、宽度、高度)以及端头尺寸。
参数特性:电气规格表列出了不同型号的功率等级、最大工作电压、最大过载电压、最大电流跳跃、温度系数(TCR)、欧姆范围和公差。
功能详解:文档详细描述了电阻器的测试方法和规格,包括短时间过载、绝缘电阻、耐久性、湿热带负载、干热、弯曲强度、焊接性、耐焊接热、电压证明、浸出、快速温度变化和硫测试。
应用信息:虽然文档中没有直接提到应用信息,但从其特性可以推断,这些电阻器适用于需要高功率和耐硫环境的电子设备。
封装信息:文档提供了详细的封装规格,包括纸带和塑料带的尺寸,以及推荐的焊盘布局。
RMCS1206FT1K69 价格&库存
很抱歉,暂时无法提供与“RMCS1206FT1K69”相匹配的价格&库存,您可以联系我们找货
RMCS1206FT1K69
  • 5000+0.136405000+0.01740
  • 10000+0.1283010000+0.01630
  • 25000+0.1189025000+0.01510
  • 50000+0.1108050000+0.01410
