HPPC06030-100M-Q8
HPPC06030-100M-Q8
    CHILISIN(奇力新)
    IND-2P_7X6.8MM_SM
    功率电感 SMD
HPPC06030-100M-Q8 数据手册
Cautions and Warnings Please be noted that this spec is only for reference if you have projects designed with the product number listed in. If you are looking for new project design-in, please find BMQx Series specification/datasheet on Chilisin website. Or you may find our sales contact for more information on old part number at your convenience. Appreciated your attention and understanding. Note: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. Molding Power Inductors – HPPC Series HPPC Series HPPC series is low profile molding power choke with low RDC and high Q factor, so the efficiency performance is also superior. Its molded magnetic shielded type is suitable for high-density mounting and ultra-low buzz noise. Soldering conditions can be easily confirmed when mounting onto the board. This series also provides customers with embossed carrier type packaging for automatic mounting machine. Features Applications          RoHS, Halogen Free and REACH Compliance Low RDC High Q High Efficiency Ultra-low buzz noise Laptops and PCs Switches and servers Base stations DC/DC converters Product Identification Shape and Dimensions Recommended Pattern Dimensions in mm Dimensions in mm TYPE A B C D F TYPE A B C 04010 4.1±0.2 4.6±0.2 1.0Max 1.5±0.3 1.0±0.3 04010 2.5 3.7 1.5 04011 4.1±0.2 4.6±0.2 1.1Max 1.5±0.3 1.0±0.3 04011 2.5 3.7 1.5 04020 4.2±0.2 4.8±0.2 1.8±0.2 1.5±0.3 1.1±0.3 04020 2.5 3.7 1.5 05011 5.5±0.2 5.7±0.2 1.1Max 2.0±0.3 1.5±0.3 05011 2.5 4.1 1.9 2.5 4.6 1.9 05030 5.5±0.25 5.85±0.25 2.8±0.2 2.0±0.25 1.5±0.25 05030 06011 6.6±0.2 6.95±0.35 1.1Max 3.0±0.3 1.6±0.3 06011 3.5 6.05 2.35 06020 6.8±0.2 6.95±0.35 1.8±0.2 3.0±0.3 1.6±0.3 06020 3.5 6.05 2.35 06030 6.8±0.2 7.3±0.2 2.8±0.2 3.0±0.3 1.6±0.3 06030 3.5 6.05 2.35 10040 10.2±0.3 11.3±0.3 3.8±0.2 3.0±0.5 2.5±0.5 10040 4.0 9.50 3.50 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC04010-R33M-A8 0.33 20 100 14(12) 9.0(11) 6.0(7.0) R33 HPPC04010-1R0M-A8 1.0 20 100 43(39) 4.0(5.0) 4.0(4.5) 1R0 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Tem perature Change v.s DC Current 160 1.4 140 1.2 120 1.0 100 △ T(℃ ) L(uH) Inductance v.s DC Current 1.6 0.8 1R0 0.6 0.4 1R0 R33 80 60 40 R33 0.2 20 0.0 0 0 2 4 6 8 DC Current(A) 10 12 14 0 2 4 6 8 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 10 12 14 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC04011-1R0M-A8 1.0 20 100 38.5(35) 5.4(6.0) 4.3(4.8) 1R0 HPPC04011-2R2M-A8 2.2 20 100 82(75) 3.5(4.0) 3.0(3.3) 2R2 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 3.0 140 1R0 120 2.5 2R2 100 1.5 △ T( ℃ ) L(uH) 2.0 2R2 80 60 1.0 40 1R0 0.5 20 0.0 0 0 1 2 3 4 DC Current(A) 5 6 7 8 0 1 2 3 4 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 5 6 7 8 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC04020-R22M-Q8 0.22 20 100 5.5(5.0) 18(20) 10(11) R22 HPPC04020-1R0M-Q8 1.0 20 100 17(16) 8.0(8.5) 5.5(6.0) 1R0 HPPC04020-2R2M-Q8 2.2 20 100 38.5(35) 6.0(6.5) 4.0(4.5) 2R2 HPPC04020-4R7M-Q8 4.7 20 100 85(77) 4.0(4.5) 2.5(2.8) 4R7 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 6 140 5 120 R22 2R2 4R7 1R0 100 4R7 △ T(℃ ) L(uH) 4 3 80 60 2 2R2 40 1 20 1R0 R22 0 0 0 5 10 15 DC Current(A) 20 25 0 2.5 5 7.5 10 12.5 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 15 17.5 20 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC05011-1R0M-A8 1.0 20 100 33(30) 7.0(7.5) 4.8(5.3) 1R0 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 160 1.2 140 1R0 1.0 0.8 △ T(℃ ) L(uH) 120 1R0 0.6 100 80 60 0.4 40 0.2 20 0 0.0 0 1 2 3 4 5 DC Current(A) 6 7 8 9 0 1 2 3 4 5 6 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 7 8 9 10 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC05030-R22M-Q8 0.22 20 100 3.90(3.5) 28(32) 18.0(20.0) R22 HPPC05030-R36M-Q8 0.36 20 100 4.95(4.5) 23(25) 12.5(13.5) R36 HPPC05030-R68M-Q8 0.68 20 100 6.30(5.7) 17(18) 11.0(12.0) R68 HPPC05030-1R0M-Q8 1.0 20 100 9.8(8.9) 16(18) 9.00(9.50) 1R0 HPPC05030-1R5M-Q8 1.5 20 100 15(13.5) 12.5(13.5) 7.50(8.0) 1R5 HPPC05030-2R2M-Q8 2.2 20 100 20(18) 11.5(12.5) 6.00(6.5) 2R2 HPPC05030-4R7M-Q8 4.7 20 100 40(37) 6.5(7.50) 4.50(5.0) 4R7 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 160 5.0 140 1R0 4.0 R36 R22 4R7 2R2 4R7 △ T(℃ ) L(uH) 120 3.0 2.0 1R5 R68 80 60 2R2 40 1R5 1.0 100 1R0 R68 R36 20 R22 0.0 0 0 5 10 15 20 25 DC Current(A) 30 35 40 0 5 10 15 20 25 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 30 35 40 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC06011-1R0M-A8 1.0 20 100 26(24.5) 7.0(7.8) 6.8(7.3) 1R0 HPPC06011-2R2M-A8 2.2 20 100 57(52) 5.0(6.0) 4.2(4.6) 2R2 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 160 3.0 140 2R2 2.5 1R0 2.0 1.5 △ T(℃ ) L(uH) 120 2R2 100 80 60 1.0 40 1R0 0.5 20 0.0 0 0 2 4 6 DC Current(A) 8 10 12 0 2 4 6 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 8 10 12 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC06020-4R7M-Q8 4.7 20 100 48(43.7) 6.0(6.8) 4.2(4.7) 4R7 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 160 10 4R7 140 120 △ T(℃ ) L(uH) 8 6 4 4R7 100 80 60 40 2 20 0 0 0 1 2 3 4 5 DC Current(A) 6 7 8 9 0 1 2 3 4 5 6 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 7 8 9 10 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC06030-R22M-Q8 0.22 20 100 2.0(1.8) 35(40) 25(27) R22 HPPC06030-R36M-Q8 0.36 20 100 2.6(2.3) 27(32) 23(25) R36 HPPC06030-R47M-Q8 0.47 20 100 3.3(2.9) 25(27) 19(20) R47 HPPC06030-R56M-Q8 0.56 20 100 3.9(3.5) 23(25) 17(18) R56 HPPC06030-R68M-Q8 0.68 20 100 4.2(3.8) 18(20) 16(17) R68 HPPC06030-1R0M-Q8 1.0 20 100 5.3(4.8) 17(19) 14(15) 1R0 HPPC06030-1R5M-Q8 1.5 20 100 7.7(7.0) 15(17) 11(11.5) 1R5 HPPC06030-2R2M-Q8 2.2 20 100 9.4(8.5) 12(12.5) 10.5(11) 2R2 HPPC06030-3R3M-Q8 3.3 20 100 15(13.5) 9.0(9.5) 8.0(8.5) 3R3 HPPC06030-4R7M-Q8 4.7 20 100 22.0(20) 6.5(7.0) 6.0(6.5) 4R7 HPPC06030-6R8M-Q8 6.8 20 100 38.5(35) 6.0(6.5) 5.3(5.8) 6R8 HPPC06030-8R2M-Q8 8.2 20 100 47.0(43) 5.5(6.0) 5.0(5.4) 8R2 HPPC06030-100M-Q8 10 20 100 47.0(43) 5.0(5.5) 4.8(5.3) 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Tem perature Change v.s DC Current Inductance v.s DC Current 10 140 100 8R2 4R7 6R8 120 8 R36 1R0 R56 R22 R47 1R5 100 3R3 △ T( ℃ ) L(uH) 100 2R2 6 8R2 6R8 4 4R7 R68 80 60 40 3R3 2 2R2 1R5 1R0 R68 R56 R47 20 R36 R22 0 0 0 5 10 15 20 25 30 DC Current(A) 35 40 45 50 0 5 10 15 20 25 30 DC Current(A) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 35 40 45 50 Molding Power Inductors – HPPC Series Electrical Characteristics Part Number Inductance (uH) Tolerance (±%) Test Frequency (kHz) RDC(mΩ) Max(Typ.) Isat(A) Max(Typ.) Irms(A) Max(Typ.) Marking HPPC10040-R22M-Q8 0.22 20 100 0.54(0.45) 55(60) 40(42) R22 HPPC10040-R33M-Q8 0.33 20 100 0.68(0.62) 45(50) 32(35) R33 HPPC10040-R56M-Q8 0.56 20 100 1.2(1.0) 40(45) 28(30) R56 HPPC10040-R68M-Q8 0.68 20 100 1.5(1.3) 32(37) 25(27) R68 HPPC10040-1R0M-Q8 1.0 20 100 2.4(2.2) 26(30) 23(25) 1R0 HPPC10040-2R2M-Q8 2.2 20 100 4.7(4.3) 17(20) 15(15.6) 2R2 HPPC10040-3R3M-Q8 3.3 20 100 7.9(7.2) 16(18) 12(12.5) 3R3 HPPC10040-4R7M-Q8 4.7 20 100 10.5(9.5) 13(14) 10.5(11) 4R7 HPPC10040-6R8M-Q8 6.8 20 100 16.5(15) 9.0(10) 8.5(9.0) 6R8 HPPC10040-100M-Q8 10 20 100 24(22) 8.5(9.0) 8.0(8.5) 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-55℃~125℃(Including self - temperature rise)  Isat for Inductance drop 30% from its value without current  Irms for a 40℃ temperature rise from 25℃ ambient with current  Absolute maximum voltage 30VDC  Measure Equipment: L:WK 3260B or WK 6500P, 100kHz 0.5V RDC:CHEN HWA 502 or CHEN HWA 46502B Irms:CHROMA 1810 Test Instruments:WK3260B Impedance / Material Analyzer Inductance v.s DC Current Tem perature Change v.s DC Current 10 140 1R0 120 R68 100 R56 3R3 R22 4R7 100 6R8 R33 100 6 △ T(℃ ) L(uH) 8 6R8 4 4R7 2R2 80 60 40 3R3 2 20 2R2 1R0 R68 R56 R33 R22 0 0 0 10 20 30 40 DC CurrentA) 50 60 70 0 5 10 15 20 25 30 35 40 DC CurrentA) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 45 50 55 60 65 Molding Power Inductors – HPPC Series Packaging Specifications Tape Dimensions Tape Material Reel Dimensions Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A0 B0 K0 D E W P P0 P2 A B C D PCS / REEL 04010 4.4 4.9 1.4 1.55 1.75 12 8 4 2 330 100 13 13.4 2000 04011 4.4 4.9 1.5 1.55 1.75 12 8 4 2 330 100 13 13.4 2000 04020 4.5 5.1 2.4 1.55 1.75 12 8 4 2 330 100 13 13.4 2000 05011 5.9 6.2 1.5 1.55 1.75 16 12 4 2 330 100 13 16 2000 05030 5.9 6.25 3.4 1.55 1.75 16 12 4 2 330 100 13 16 1000 06011 6.9 7.4 1.5 1.55 1.75 16 12 4 2 330 100 13 16 1000 06020 7.05 7.6 2.4 1.55 1.75 16 12 4 2 330 100 13 16 1000 06030 7.0 7.6 3.4 1.55 1.75 16 12 4 2 330 100 13 16 1000 10040 10.6 11.7 4.25 1.55 1.75 24 16 4 2 330 100 13 24.4 500
