APSG160ETD102MJB5S
APSG160ETD102MJB5S
    NCC(贵弥功)
    插件,D10xL11mm
    直插铝电解电容 AEC_D10X11MM_TM
APSG160ETD102MJB5S 数据手册
CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSG - Series ・Super low ESR, high ripple current capability ・Endurance: 15,000 to 20,000 hours at 105℃ ・Rated voltage : 16 to 35Vdc ・RoHS2 Compliant ・Halogen Free PSG Downsized PSF ◆SPECIFICATIONS Items Characteristics Category Temperature Range Rated Voltage Capacitance Tolerance Leakage Current -55 to +105℃ 16 to 35Vdc ±20% (M) I=0.2CV or 500μA, whichever is greater Where, I : Leakage current (μA), C : Nominal capacitance (μF), V : Rated voltage (V) *Note Dissipation Factor (tanδ) Low Temperature Characteristics (Max.Impedance Ratio) Endurance Bias Humidity Test Surge Voltage Test (at 20℃, 120Hz) (at 20℃ after 2 minutes) 0.12 max. (at 20℃, 120Hz) Z(-25℃)/Z(+20℃)≦1.15 Z(-55℃)/Z(+20℃)≦1.25 (at 100kHz) The following specifications shall be satisfied when the capacitors are restored to 20℃ after the rated voltage is applied for 20,000 hours (20 to 35V : 15,000 hours) at 105℃. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦150% of the initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjecting them to DC voltage at 60℃, 90 to 95% RH for 1,000 hours. Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦The initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value The capacitors shall be subjected to 1,000 cycles each consisting of charge with the surge voltage specified at 105℃ for 30 seconds through a protective resistor(R=1kΩ) and discharge for 5 minutes 30 seconds. Rated voltage (Vdc) 16 20 25 35 Surge voltage (Vdc) 18 23 29 40 Appearance No significant damage Capacitance change ≦±20% of the initial value D.F. (tanδ) ≦The initial specified value ESR ≦150% of the initial specified value Leakage current ≦The initial specified value 0.5% per 1,000 hours maximum (Confidence level 60% at 105℃) Failure Rate *Note : If any doubt arises, measure the leakage current after the following voltage treatment. Voltage treatment : DC rated voltage is applied to the capacitors for 120 minutes at 105℃. ◆DIMENSIONS [mm] ●Terminal Code : E F05,F08,H08 φD' φd F±0.5 Coated Case Size code φD φd F φD' L' F05 F08 H08 HB5 6.3 H16 H20 JB5 8.0 0.45 0.6 3.5 φD+0.5max. 2.5 L+1.0max. (Note1) J16 10.0 J20 5.0 L+1.5max. Note1 : L+1.2 max. for 16V270μF (Rated ripple current 5,080mArms). L' 15min. 4min. ◆MARKING HB5,H16,H20,JB5,J16,J20 φD' φd F±0.5 Coated Case L' 15min. EX) 16V150µF G 6D6 150 16V 4min. Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U CONDUCTIVE POLYMER ALUMINUM SOLID CAPACITORS TM NPCAP Radial Lead PSGSeries - ◆PART NUMBERING SYSTEM 1 2 3 4 A PSG 5 6 7 8 E 9 10 11 12 13 14 M 15 16 17 18 Supplement code (Note2) Size code Capacitance tolerance code Capacitance code (ex. 150µF:151,1,000µF:102) Lead forming·Taping code Terminal code Voltage code (ex. 16V:160,20V:200) Series code Category (Note2) : ‌PSG series, 16V270μF (Rated ripple current 5,080mArms) ,16V470μF (Rated ripple current 5,400mArms) ,16V560μF (Rated ripple current 6,100mArms)have supplement code “J”. Terminal and terminal plating are the same as all other in PSG series. Please refer to “Product code guide (conductive polymer type)” ◆STANDARD RATINGS WV (Vdc) 16 20 25 35 Cap (µF) Case size φD×L (mm) ESR (mΩ max./20℃, 100k to 300kHz) Rated ripple current (mArms/105℃, 100kHz) Part No. 150 270 270 470 470 560 560 820 820 1,000 1,000 1,200 1,500 1,800 2,200 120 180 330 390 680 56 82 100 120 180 180 220 220 270 330 330 390 470 560 68 120 6.3×5 6.3 ×8 6.3×8 8×8 8×8 8×11.5 8×11.5 8×16 10×11.5 8 ×20 10× 11.5 8 ×20 10× 16 10× 20 10× 20 6.3 ×5 6.3× 8 8× 8 8 × 11.5 10× 11.5 6.3 ×5 6.3× 8 6.3×8 6.3×8 8×8 8× 11.5 8× 8 8 × 11.5 8 × 11.5 8 ×11.5 10× 11.5 10 ×11.5 10×11.5 10×11.5 8 ×11.5 10×11.5 20 10 15 8 16 8 14 8 12 8 12 8 8 8 8 20 18 17 14 12 30 28 28 28 18 16 18 16 16 16 14 14 14 14 18 16 3,200 5,080 3,800 5,400 4,000 6,100 4,970 7,000 5,400 7,500 5,400 7,500 7,700 8,100 8,100 3,200 3,460 3,880 4,970 5,400 2,600 2,780 2,780 2,780 3,770 4,650 3,770 4,650 4,650 4,650 5,000 5,000 5,000 5,000 4,380 4,670 APSG160E□□151MF05S APSG160E□□271MF08J APSG160E□□271MF08S APSG160E□□471MH08J APSG160E□□471MH08S APSG160E□□561MHB5J APSG160E□□561MHB5S APSG160E□□821MH16S APSG160E□□821MJB5S APSG160E□□102MH20S APSG160E□□102MJB5S APSG160E□□122MH20S APSG160E□□152MJ16S APSG160E□□182MJ20S APSG160E□□222MJ20S APSG200E□□121MF05S APSG200E□□181MF08S APSG200E□□331MH08S APSG200E□□391MHB5S APSG200E□□681MJB5S APSG250E□□560MF05S APSG250E□□820MF08S APSG250E□□101MF08S APSG250E□□121MF08S APSG250E□□181MH08S APSG250E□□181MHB5S APSG250E□□221MH08S APSG250E□□221MHB5S APSG250E□□271MHB5S APSG250E□□331MHB5S APSG250E□□331MJB5S APSG250E□□391MJB5S APSG250E□□471MJB5S APSG250E□□561MJB5S APSG350E□□680MHB5S APSG350E□□121MJB5S □□ : Enter the appropriate lead forming or taping code. ◆RATED RIPPLE CURRENT MULTIPLIERS ・Frequency Multipliers Frequency(Hz) Radial lead type 120 0.10 1k 0.35 10k 0.60 50k 0.80 100k to 500k 1.00 Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications. CAT. No. E1001U
APSG160ETD102MJB5S 价格&库存
很抱歉,暂时无法提供与“APSG160ETD102MJB5S”相匹配的价格&库存,您可以联系我们找货
APSG160ETD102MJB5S
    库存:2000
    APSG160ETD102MJB5S
      • 1+3.60720
      • 10+2.87280
      • 30+2.55960
      • 100+2.16000
      库存:441
