HCDS74T-470M-N
HCDS74T-470M-N
    CHILISIN(奇力新)
    SMD
    功率电感 SMD
HCDS74T-470M-N 数据手册
SMD POWER INDUCTORS HCDS SERIES FEATURES * RoHS compliant * Magnetic shieled surface mountinductor with hight curront rating low DC resistance * Ideal for DC – DC converter inductor applications * Packed in embossed carrier tape and can be vse by automatic mounting machine. 特性 *无铅. *具有磁屏蔽,低阻抗,大电流通过之特性. *DC-DC转换应用中理想的选择. *卷轴,编带包装,适用于表面贴装设备. ORDERING CODE(标志示例) HNR HCDS 3015 74 (1) (2) 100 M (3) (4) (1) Type 型号 (2) Dimensions 尺寸 (3) Inductance 电感量 (4) Inductance Tolerance J : ±5% K : ±10% L : ±15% M : ±20% Y : ±25% T : ±30% 电感量公差 XLVS30~80 Recommended Pattern HCDS73&74 Shape and Dimensions Dimensions in m m TYPE A B C HCDS73 7.3±0.2 7.3±0.2 3.4 HCDS74 7.3±0.2 7.3±0.2 4.5 D TYPE A B C +0 1.8 HCDS73 8.4 4.4 2.2 +0 1.8 HCDS74 8.4 4.4 2.2 SMD POWER INDUCTORS HCDS124&125&127&129 Shape and Dimensions Recommended Pattern Dimensions in m m TYPE A B C HCDS124 12.5 +0 12.5 HCDS125 12.5 +0 12.5 HCDS127 12.5 +0 12.5 HCDS129 12.5 +0 12.5 D E F A B C +0 1.2 5 7.6 13.0 7.0 5.4 +0 1.2 5 7.6 13.0 7.0 5.4 +0 1.2 5 7.6 13.0 7.0 5.4 1.2 5 7.6 13.0 7.0 5.4 +0 4.5 +0 6.0 +0 8.0 +0 10.0 +0 SMD POWER INDUCTORS HCDS 73 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS73T-1R5□ 1.5 1 kHz,1 V 0.03 4 M 1R5 HCDS73T-2R2□ 2.2 1 kHz,1 V 0.03 4 M 2R2 HCDS73T-3R3□ 3.3 1 kHz,1 V 0.04 3.7 M 3R3 HCDS73T-6R8□ 6.8 1 kHz,1 V 0.06 2 M 6R8 HCDS73T-100□ 10 1 kHz,1 V 0.072 1.68 M 100 HCDS73T-120□ 12 1 kHz,1 V 0.098 1.52 M 120 HCDS73T-150□ 15 1 kHz,1 V 0.13 1.33 M 150 HCDS73T-180□ 18 1 kHz,1 V 0.14 1.2 M 180 HCDS73T-220□ 22 1 kHz,1 V 0.19 1.07 M 220 HCDS73T-270□ 27 1 kHz,1 V 0.21 0.96 M 270 HCDS73T-330□ 33 1 kHz,1 V 0.24 0.91 M 330 HCDS73T-390□ 39 1 kHz,1 V 0.32 0.77 M 390 HCDS73T-470□ 47 1 kHz,1 V 0.36 0.76 M 470 HCDS73T-560□ 56 1 kHz,1 V 0.47 0.68 M 560 HCDS73T-680□ 68 1 kHz,1 V 0.52 0.61 M 680 HCDS73T-820□ 82 1 kHz,1 V 0.69 0.57 M 820 HCDS73T-101□ 100 1 kHz,1 V 0.79 0.5 M 101 HCDS73T-121□ 120 1 kHz,1 V 0.89 0.49 M 121 HCDS73T-151□ 150 1 kHz,1 V 1.27 0.43 M 151 HCDS73T-181□ 180 1 kHz,1 V 1.45 0.39 M 181 HCDS73T-221□ 220 1 kHz,1 V 1.65 0.35 M 221 HCDS73T-271□ 270 1 kHz,1 V 2.31 0.32 M 271 HCDS73T-331□ 330 1 kHz,1 V 2.62 0.28 M 331 HCDS73T-391□ 390 1 kHz,1 V 2.94 0.26 M 391 HCDS73T-471□ 470 1 kHz,1 V 4.18 0.24 M 471 HCDS73T-561□ 560 1 kHz,1 V 4.67 0.22 M 561 HCDS73T-681□ 680 1 kHz,1 V 5.73 0.19 M 681 HCDS73T-821□ 820 1 kHz,1 V 6.54 0.18 M 821 HCDS73T-102□ 1000 1 kHz,1 V 9.44 0.16 M 102 NOTE: □-tolerance M=±20% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS 74 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS74T-1R5□ 1.5 1 kHz,1 V 0.02 5 M 1R5 HCDS74T-1R8□ 1.8 1 kHz,1 V 0.025 4 M 1R8 HCDS74T-2R2□ 2.2 1 kHz,1 V 0.025 3.5 M,T 2R2 HCDS74T-2R7□ 2.7 1 kHz,1 V 0.03 3.5 M,T 2R7 HCDS74T-3R3□ 3.3 1 kHz,1 V 0.035 3.5 M,T 3R3 HCDS74T-3R6□ 3.6 1 kHz,1 V 0.035 3.2 M,T 3R6 HCDS74T-4R7□ 4.7 1 kHz,1 V 0.035 3 M,T 4R7 HCDS74T-6R8□ 6.8 1 kHz,1 V 0.045 2.5 M 6R8 HCDS74T-100□ 10 1 kHz,1 V 0.049 1.84 M 100 HCDS74T-120□ 12 1 kHz,1 V 0.058 1.71 M 120 HCDS74T-150□ 15 1 kHz,1 V 0.081 1.47 M 150 HCDS74T-180□ 18 1 kHz,1 V 0.091 1.31 M 180 HCDS74T-220□ 22 1 kHz,1 V 0.11 1.23 M 220 HCDS74T-270□ 27 1 kHz,1 V 0.15 1.12 M 270 HCDS74T-330□ 33 1 kHz,1 V 0.17 0.96 M 330 HCDS74T-390□ 39 1 kHz,1 V 0.23 0.91 M 390 HCDS74T-470□ 47 1 kHz,1 V 0.26 0.88 M 470 HCDS74T-560□ 56 1 kHz,1 V 0.35 0.75 M 560 HCDS74T-680□ 68 1 kHz,1 V 0.38 0.69 M 680 HCDS74T-820□ 82 1 kHz,1 V 0.43 0.61 M 820 HCDS74T-101□ 100 1 kHz,1 V 0.61 0.6 M 101 HCDS74T-121□ 120 1 kHz,1 V 0.66 0.52 M 121 HCDS74T-151□ 150 1 kHz,1 V 0.88 0.46 M 151 HCDS74T-181□ 180 1 kHz,1 V 0.98 0.42 M 181 HCDS74T-221□ 220 1 kHz,1 V 1.17 0.36 K,M 221 HCDS74T-271□ 270 1 kHz,1 V 1.64 0.34 K,M 271 HCDS74T-331□ 330 1 kHz,1 V 1.86 0.32 K,M 331 HCDS74T-391□ 390 1 kHz,1 V 2.85 0.29 K,M 391 HCDS74T-471□ 470 1 kHz,1 V 3.01 0.26 K,M 471 HCDS74T-561□ 560 1 kHz,1 V 3.62 0.23 K,M 561 HCDS74T-681□ 680 1 kHz,1 V 4.63 0.22 K,M 681 HCDS74T-821□ 820 1 kHz,1 V 5.2 0.2 K,M 821 HCDS74T-102□ 1000 1 kHz,1 V 6 0.18 K,M 102 NOTE: □-tolerance K=±10% / M=±20% / T=±30% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS 124 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS124T-3R3□ 3.3 100 kHz,1 V 0.015 6.5 M 3R3 HCDS124T-3R9□ 3.9 100 kHz,1 V 0.015 6.5 M 3R9 HCDS124T-4R7□ 4.7 100 kHz,1 V 0.018 5.7 M 4R7 HCDS124T-6R8□ 6.8 100 kHz,1 V 0.023 4.9 M 6R8 HCDS124T-100□ 10 100 kHz,1 V 0.028 4.5 M 100 HCDS124T-120□ 12 100 kHz,1 V 0.038 4 M 120 HCDS124T-150□ 15 100 kHz,1 V 0.05 3.2 M 150 HCDS124T-180□ 18 100 kHz,1 V 0.057 3.1 M 180 HCDS124T-220□ 22 100 kHz,1 V 0.066 2.9 M 220 HCDS124T-270□ 27 100 kHz,1 V 0.08 2.8 M 270 HCDS124T-330□ 33 100 kHz,1 V 0.097 2.7 M 330 HCDS124T-390□ 39 100 kHz,1 V 0.132 2.1 M 390 HCDS124T-470□ 47 100 kHz,1 V 0.15 1.9 M 470 HCDS124T-560□ 56 100 kHz,1 V 0.19 1.8 M 560 HCDS124T-680□ 68 100 kHz,1 V 0.22 1.5 M 680 HCDS124T-820□ 82 100 kHz,1 V 0.26 1.3 M 820 HCDS124T-101□ 100 100 kHz,1 V 0.308 1.2 M 101 HCDS124T-121□ 120 100 kHz,1 V 0.38 1.1 M 121 HCDS124T-151□ 150 100 kHz,1 V 0.53 0.95 M 151 HCDS124T-181□ 180 100 kHz,1 V 0.62 0.85 M 181 HCDS124T-221□ 220 100 kHz,1 V 0.7 0.8 M 221 HCDS124T-271□ 270 100 kHz,1 V 0.876 0.6 M 271 HCDS124T-331□ 330 100 kHz,1 V 0.99 0.5 M 331 NOTE: □-tolerance M=±20% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS 125 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS125T-3R3□ 3.3 1 kHz,1 V 0.015 8 M 3R3 HCDS125T-4R7□ 4.7 1 kHz,1 V 0.018 7.6 M 4R7 HCDS125T-6R4□ 6.4 1 kHz,1 V 0.018 5.8 M 6R4 HCDS125T-8R2□ 8.2 1 kHz,1 V 0.025 5 M 8R2 HCDS125T-100□ 10 1 kHz,1 V 0.025 4 M 100 HCDS125T-120□ 12 1 kHz,1 V 0.027 3.5 M 120 HCDS125T-150□ 15 1 kHz,1 V 0.03 3.3 M 150 HCDS125T-180□ 18 1 kHz,1 V 0.034 3 M 180 HCDS125T-220□ 22 1 kHz,1 V 0.036 2.8 M 220 HCDS125T-270□ 27 1 kHz,1 V 0.051 2.3 M 270 HCDS125T-330□ 33 1 kHz,1 V 0.057 2.1 M 330 HCDS125T-390□ 39 1 kHz,1 V 0.068 2 M 390 HCDS125T-470□ 47 1 kHz,1 V 0.075 1.8 M 470 HCDS125T-560□ 56 1 kHz,1 V 0.11 1.7 M 560 HCDS125T-680□ 68 1 kHz,1 V 0.12 1.5 M 680 HCDS125T-820□ 82 1 kHz,1 V 0.14 1.4 M 820 HCDS125T-101□ 100 1 kHz,1 V 0.16 1.3 M 101 HCDS125T-121□ 120 1 kHz,1 V 0.17 1.1 M 121 HCDS125T-151□ 150 1 kHz,1 V 0.23 1 M 151 HCDS125T-181□ 180 1 kHz,1 V 0.29 0.9 M 181 HCDS125T-221□ 220 1 kHz,1 V 0.4 0.8 M 221 HCDS125T-271□ 270 1 kHz,1 V 0.46 0.75 M 271 HCDS125T-331□ 330 1 kHz,1 V 0.51 0.68 M 331 HCDS125T-391□ 390 1 kHz,1 V 0.69 0.65 M 391 HCDS125T-471□ 470 1 kHz,1 V 0.77 0.58 M 471 HCDS125T-561□ 560 1 kHz,1 V 0.86 0.54 M 561 HCDS125T-681□ 680 1 kHz,1 V 1.2 0.48 M 681 HCDS125T-821□ 820 1 kHz,1 V 1.34 0.43 M 821 HCDS125T-102□ 1000 1 kHz,1 V 1.53 0.4 M 102 HCDS125T-302□ 3000 1 kHz,1 V 6 0.25 M 302 NOTE: □-tolerance M=±20% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS 127 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS127T-1R2□ 1.2 100 kHz,1 V 0.007 9.8 T 1R2 HCDS127T-1R5□ 1.5 100 kHz,1 V 0.008 9.5 T 1R5 HCDS127T-2R2□ 2.2 100 kHz,1 V 0.0115 8 M,T 2R2 HCDS127T-2R4□ 2.4 100 kHz,1 V 0.0115 8 M,T 2R4 HCDS127T-3R3□ 3.3 100 kHz,1 V 0.0135 7.5 T 3R3 HCDS127T-3R5□ 3.5 100 kHz,1 V 0.0135 7.5 M,T 3R5 HCDS127T-4R7□ 4.7 100 kHz,1 V 0.0158 6.8 M,T 4R7 HCDS127T-6R1□ 6.1 100 kHz,1 V 0.0176 6.6 M,T 6R1 HCDS127T-6R8□ 6.8 100 kHz,1 V 0.02 6.2 M,T 6R8 HCDS127T-7R6□ 7.6 100 kHz,1 V 0.02 5.9 M,T 7R6 HCDS127T-100□ 10 1 kHz,1 V 0.0216 5.4 M 100 HCDS127T-120□ 12 1 kHz,1 V 0.0243 4.9 M 120 HCDS127T-150□ 15 1 kHz,1 V 0.027 4.5 M 150 HCDS127T-180□ 18 1 kHz,1 V 0.0392 3.9 M 180 HCDS127T-220□ 22 1 kHz,1 V 0.0432 3.6 M 220 HCDS127T-270□ 27 1 kHz,1 V 0.0459 3.4 M 270 HCDS127T-330□ 33 1 kHz,1 V 0.0648 3 M 330 HCDS127T-390□ 39 1 kHz,1 V 0.0729 2.75 M 390 HCDS127T-470□ 47 1 kHz,1 V 0.1 2.5 M 470 HCDS127T-560□ 56 1 kHz,1 V 0.11 2.35 M 560 HCDS127T-680□ 68 1 kHz,1 V 0.14 2.1 M 680 HCDS127T-820□ 82 1 kHz,1 V 0.16 1.95 M 820 HCDS127T-101□ 100 1 kHz,1 V 0.22 1.7 M 101 HCDS127T-121□ 120 1 kHz,1 V 0.25 1.6 M 121 HCDS127T-151□ 150 1 kHz,1 V 0.28 1.42 M 151 HCDS127T-181□ 180 1 kHz,1 V 0.35 1.3 M 181 HCDS127T-221□ 220 1 kHz,1 V 0.39 1.16 M 221 HCDS127T-271□ 270 1 kHz,1 V 0.56 1.06 M 271 HCDS127T-331□ 330 1 kHz,1 V 0.64 0.95 M 331 HCDS127T-391□ 390 1 kHz,1 V 0.7 0.88 M 391 HCDS127T-471□ 470 1 kHz,1 V 0.98 0.79 M 471 HCDS127T-561□ 560 1 kHz,1 V 1.07 0.73 M 561 HCDS127T-681□ 680 1 kHz,1 V 1.46 0.67 M 681 HCDS127T-821□ 820 1 kHz,1 V 1.64 0.6 M 821 HCDS127T-102□ 1000 1 kHz,1 V 1.82 0.55 M 102 NOTE: □-tolerance M=±20% / T =±30% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS 129 series Standard Specifications Part No. Inductance (uH ) Test Freq. RDC (Ω)Max. Isat (A) Tolerance Marking HCDS129T-100□ 10 100 kHz,1 V 0.016 11.5 M 100 HCDS129T-150□ 15 100 kHz,1 V 0.022 9.5 M 150 HCDS129T-220□ 22 100 kHz,1 V 0.03 8.0 M 220 HCDS129T-330□ 33 100 kHz,1 V 0.039 6.2 M 330 HCDS129T-470□ 47 100 kHz,1 V 0.056 5.1 M 470 HCDS129T-680□ 68 100 kHz,1 V 0.08 4.3 M 680 HCDS129T-101□ 100 100 kHz,1 V 0.125 3.5 K 101 HCDS129T-121□ 120 100 kHz,1 V 0.135 3.1 K 121 HCDS129T-151□ 150 100 kHz,1 V 0.185 2.9 K 151 HCDS129T-181□ 180 100 kHz,1 V 0.203 2.5 K 181 HCDS129T-221□ 220 100 kHz,1 V 0.225 2.3 K 221 HCDS129T-331□ 330 100 kHz,1 V 0.34 2.0 K 331 HCDS129T-471□ 470 100 kHz,1 V 0.51 1.5 K 471 HCDS129T-681□ 680 100 kHz,1 V 0.63 1.3 K 681 HCDS129T-102□ 1000 100 kHz,1 V 0.96 1.1 K 102 NOTE: □-tolerance M=±20% / T =±30% 1.Operating temperature range -40℃~105℃(Including self - temperature rise) 2.Isat for Inductance drop 35% from its value without current. "-N" FOR COMPLETELY LEAD FREE TYPE(INCLUDING FERRITE BODY & SOLDER) SMD POWER INDUCTORS HCDS series Reliability specification 1-1.Mechanical Performance No 1-1-1 Item Vibration Specificatio n Test Method Appearance: NoTest damage device shall be soldered on the substrate Inductance:within±10% Oscillation of Frequency: 10 to 55 to 10Hz for 1min initial value Amplitude: 1.5mm Time: 2hrs for each axis (X, Y & Z), total 6hrs 1-1-2 damage 150℃, 1min Resistance to Appearance: NoPre-heating: Soldering Heat Solder Composition: Sn/Ag3.0/Cu0.5 Solder Temperature: 260±5℃ Immersion Time: 10±1sec 1-1-3 Solder ability be at 150℃, 1min The electrodes shall Pre-heating: least 95% covered Solder withComposition: new Sn/Ag3.0/Cu0.5 solder coating Solder Temperature: 245±3℃ Immersion Time:≦3sec 1-1-4 Resistance to solvent There must be Inductors must withstand 6 minutes of alcohol or water. no change in appearance or obliteration of marking. 1-2.Environmental Performance No 1-2-1 Item Temperature Cycle Specificatio n Appearance: No damage Inductance:wit hin±10% of initial value Test Method One cycle: Step Temperature (℃) Time (min) 1 -55±3 30 2 25±2 3 3 125±3 30 4 25±2 3 Total: 100cycles Measured after exposure in the room condition for 24hrs 1-2-2 Humidity Resistance 1-2-3 High Temperature Resistance Temperature: 40±2℃ Relative Humidity: 90 ~ 95% Time: 1000hrs Measured after exposure in the room condition for 24hrs Temperature: 125±3℃ Relative Humidity: 0% Applied Current: Rated Current Time: 1000hrs Measured after exposure in the room condition for 24hrs 1-2-4 Low Temperature Resistance Temperature: -55±3℃ Relative Humidity: 0% Time: 1000hrs Measured after exposure in the room condition for 24hrs SMD POWER INDUCTORS Packaging Specifications dimensions in mm Tape Dimensions Reel Dimensions Quantity PCS/REEL TYPE A0 B0 K0 D E W P P0 P2 A B C D HCDS73 7.6 7.6 3.6 1.55 1.75 16 12 4 2 330 100 13 16 1500 HCDS74 7.6 7.6 5 1.55 1.75 16 12 4 2 330 100 13 16 1000 HCDS124 12.6 12.6 5.1 1.55 1.75 24 16 4 2 330 100 13 24.4 500 HCDS125 12.6 12.6 6.7 1.55 1.75 24 16 4 2 330 100 13 24.4 500 HCDS127 12.6 12.6 8.7 1.55 1.75 24 16 4 2 330 100 13 24.4 500 HCDS129 12.6 12.6 10.7 1.55 1.75 24 16 4 2 330 100 13 24.4 400
HCDS74T-470M-N 价格&库存
很抱歉,暂时无法提供与“HCDS74T-470M-N”相匹配的价格&库存,您可以联系我们找货
