CMLO0630H100MTT
CMLO0630H100MTT
    CYBERMAX(思博)
    SMD,7x6.6mm
    功率电感 SMD
CMLO0630H100MTT 数据手册
CMLO0630H Series SMD Molding Power Inductor ◆ Features Pb 、Magnetically shielded construction, low DC resistance; 、The use of magnetic iron powder ensure capability for large current; 3、Low audible core noise; 4、Ideal for DC-DC converter applications in hand held personal computer and etc; 5、Frequency Range: up to 3.0MHz; 6、RoHS compliant。 1 2 ◆ Applications 、Smart phone、MID; 、Next-generation mobile devices with multifunction such as adding color TV and digital movie cameras; 3、Flat-screen TVs, blue-ray disc recorders, set top box; 4、Notebooks, desktop computers, servers, graphic cards; 5、Portable gaming devices, personal navigation systems, personal multimedia devices; 6、Automotive systems; 7、Telecomm base stations。 1 2 External Dimensions Unit(mm) ◆ Lead Free Part Numbering CMLO (1) 0630 (2) (1) (2) (3) (4) H (3) : : 100 M (4) (5) A Series Type Dimension A X C Material Code Inductance 2R2=2.2μH 100=10μH 101=100μH (5) Inductance Tolerance M= 20%, Y= 30% (6) Company Code (7) Packaging packed in embossed carrier tape ; ; : ± : C T T (6) (7) E B ± D Recommended Land Pattern(mm) ◆ Dimensions Series A±0.3 (mm) B±0.2 (mm) C (mm) D±0.3 (mm) E±0.3 (mm) a typ (mm) b typ (mm) c typ (mm) CMLO0630H 7.0 6.6 3.0 Max 1.6 3.0 3.7 8.4 3.5 Rev.02 Page 1 of 7 www.cybermaxtech.com CMLO0630H Series ◆ Specification Part Number Rdc (m ) Ω μ INDUCTANCE Lo( H) Max Test a condition HEAT RATING CURRENT(Idc) DC AMPS1 (Typ.) SATURATION CURRENT(Isat) DC AMPS2 (Typ.) CMLO0630H Series CMLO0630HR22MTT 0.22 3.0 100KHz/1V 24.0 34.0 CMLO0630HR33MTT 0.33 3.5 100KHz/1V 21.0 25.0 CMLO0630HR47MTT 0.47 4.1 100KHz/1V 18.0 20.0 CMLO0630HR56MTT 0.56 4.5 100KHz/1V 16.5 18.0 CMLO0630HR68MTT 0.68 5.3 100KHz/1V 16.0 17.0 CMLO0630HR82MTT 0.82 6.0 100KHz/1V 14.0 16.0 CMLO0630H1R0MTT 1.0 7.4 100KHz/1V 12.0 15.0 CMLO0630H1R5MTT 1.5 12.1 100KHz/1V 12.0 12.0 CMLO0630H2R2MTT 2.2 15.0 100KHz/1V 9.5 10.0 CMLO0630H3R3MTT 3.3 22.0 100KHz/1V 8.5 9.5 CMLO0630H4R7MTT 4.7 33.0 100KHz/1V 6.0 9.0 CMLO0630H5R6MTT 5.6 42.0 100KHz/1V 5.5 6.5 CMLO0630H6R8MTT 6.8 48.0 100KHz/1V 5.0 6.0 CMLO0630H8R2MTT 8.2 60.0 100KHz/1V 5.0 5.5 CMLO0630H100MTT 10 68.0 100KHz/1V 4.5 5.5 CMLO0630H150MTT 15 113 100KHz/1V 3.0 4.0 CMLO0630H220MTT 22 170 100KHz/1V 2.5 3.0 CMLO0630H330MTT 33 270 100KHz/1V 2.0 2.5 CMLO0630H470MTT 47 385 100KHz/1V 1.5 2.0 NOTES: △ ℃ 1. DC current (Idc) that will cause an approximate T of 40 2. DC current (Isat) that will cause Lo to drop approximately 20% 3. All test data is referenced to 25 ambient 4. Operating Temperature Range -55 to +150 5. The part temperature (ambient + temp rise) should not exceed 150 under the worst operating conditions. Circuit design, component placement, PWB trace size and thickness, airflow and other cooling provisions all affect ℃ Rev.02 ℃ ℃ Page 2 of 7 ℃ www.cybermaxtech.com CMLO0630H Series the part temperature. Part temperature should be verified in the end application. ◆ Wave Soldering ◆ Hand soldering Rev.03 Page 3 of 7 www.cybermaxtech.com CMLO0630H Series ◆ Reliability Mechanical ℃ ~+125℃ -45℃ ~ + 1 2 5 ℃ -55 Rev.02 Page 4 of 7 www.cybermaxtech.com CMLO0630H Series Packaging Information (1) Tape Packaging Dimensions(Unit:mm) P0 D0 W P D1 Type CMLO0630H Tape dimensions (mm) W P P0 P2 D0 16 ±0.3 12 ±0.1 4 ±0.1 2 ±0.1 1.5 ±0.1 D1 T A0 1.5 0.35 6.9 ±0.1 ±0.05 ±0.1 B0 K0 E F 7.5 ±0.1 3.3 ±0.1 1.75 ±0.1 7.5 ±0.1 Taping Drawings (UNIT:mm) Rev.02 Page 5 of 7 www.cybermaxtech.com CMLO0630H Series (2) Reel Dimensions(Unit:mm) B N A D W C A W N B C D 330+2.0 16.8+0.2 97+0.5 2.2+0.5 13.2±0.2 10.75±0.25 (3) Packaging Quantity(PCS) Standard Quantity Type CMLO0630H Reel Inner box 1500 pcs / reel 3Reel / box (4500 pcs) Carton box 4 Middle boxes, (18000 pcs) (4) Peel force of top cover tape The peel speed shall be about 300mm/minute The peel force of top cover tape shall be between 0.1 to 1.3 N Rev.02 Page 6 of 7 www.cybermaxtech.com CMLO0630H Series (5) Reel Label Label on the reel • Customer's part Number • Lot Number • Quantity • date code Shipping Label • Customer's part Number • Manufacturer's part Number • Quantity • date code (6) Inner Box (7) Carton A B C Rev.02 Page 7 of 7 www.cybermaxtech.com
CMLO0630H100MTT 价格&库存
很抱歉,暂时无法提供与“CMLO0630H100MTT”相匹配的价格&库存,您可以联系我们找货
