3N28000G33YC
3N28000G33YC
    SJK(晶科鑫)
    SMD3225_4P
    有源晶振 28MHz 3.3V -40℃~+85℃ CMOS
3N28000G33YC 数据手册
SMD Crystal Oscillators Size: 3.2×2.5×1.00 mm 3N Series SMD Crystal Oscillators Features ● 3225 size, low profile of 1.0mm ● Frequency range from 1MHz to 125MHz ● Low voltage operation ● Low current consumption ● 3-state function ● Automatic mounting and reflow soldering ● Application for car, GPS, Bluetooth, PC IoT, PDA, Peripherals, DVC, etc. ● RoHS Compliant /Pb Free Standard Specification Item /Type Output Type Output Load Supply Voltage Frequency Range Supply Current Frequency Stability 3N (SMD 3225 Crystal Oscillators) CMOS 15pF, or specify 3.3V (1.8V, 2.5V available) 1~125 MHz 15mA Max. ±25ppm, ±50ppm Operating Temperature Storage Temperature Voltage Vol (Max.) /Voh (Min.) -40~+85℃, or specify -55~+125℃ 0.1 VDD /0.9 VDD Rise (Tr) /Fall (Tf) Time Period Jitter 5ns Max. 40 pSec Max. Duty Cycle Start-up Time Phase Jitter (12KHz~20MHz) Aging (at 25℃) Packing Units 45~55% 5ms Max. 1ps Max. ±3ppm /Year Max. 3000pcs. /Reel Dimensions [mm] 3.2±0.10 3 1 SJK 40.000 MHz Top View 2 1.0 ±0.10 ● 2.5 ±0.10 4 Side View Pin No. Connection 1 OE (Output Enable) 2 GND 3 Output 4 Vcc 1.4 1.2 0.8 1.4 2 0.5 1.2 1.0 1.2 1 Pin Connections 4 3 Buttom View Top View Suggested Layout
3N28000G33YC 价格&库存
很抱歉,暂时无法提供与“3N28000G33YC”相匹配的价格&库存,您可以联系我们找货
3N28000G33YC
库存:241
