MMF-25FRF3K9
MMF-25FRF3K9
    YAGEO(国巨)
    MELF_D2.2X5.9MM_SM
    贴片电阻 MELF_D2.2X5.9MM_SM 3.9KΩ ±1% 1/4W ±100ppm/℃
MMF-25FRF3K9 数据手册
Through-hole resistors Melf Metal Film Resistors General Type Normal & Miniature Style [ MMF Series ] FEATURES Power Rating 1/6W, 1/4W, 0.4W, 1/2W, 0.6W, 1W Resistance Tolerance ±0.1%, ±0.25%, ±0.5%, ±1%, ±2%, ±5% T.C.R. ±15ppm/°C, ±25ppm/°C, ±50ppm/°C, ±100ppm/°C DERATING CURVE For resistors operated in ambient temperatures above 70°C, power rating must be derated in accordance with the curve below. INTRODUCTION The MMF Series Melf Metal Film Resistors are manufactured using a vacuum sputtering system to deposit multiple layers of mixed metal alloys and passivative materials onto a carefully treated high grade ceramic substrate. SMD enabled structure. Rated Load (%) 70 155 °C 100 80 60 40 20 20 40 60 80 Ambient Temperature (°C) 100 120 140 160 DIMENSIONS Unit: mm STYLE D C L DIMENSION Normal Miniature L D C Min. MMF-12 MMF25S / MMF204 3.50±0.2 1.40±0.15 0.5 MMF-25 MMF50S / MMF207 5.90±0.2 2.20±0.1 0.5 MMF-50 MMF1WS 8.50±0.2 3.20±0.2 0.5 21 Note: ELECTRICAL CHARACTERISTICS STYLE MMF-12 MMF25S MMF204 MMF-25 MMF50S MMF207 MMF-50 MMF1WS Power Rating at 70°C 1/6W 1/4W 0.4W 1/4W 1/2W 0.6W 1/2W 1W Maximum Working Voltage 150V 200V 250V 350V Maximum Overload Voltage 300V 400V 500V 700V Voltage Proof on Insulation 300V 500V 700V Resistance Range 0.22Ω-3.9Ω for tol ±5%, E96 series value, 4Ω - 1MΩ for tol ±1% E24 + E96 series value Operating Temp. Range -55°C to +155°C Temperature Coefficient ±50ppm/°C for 4Ω - 1MΩ , ±100ppm/°C for 0.22Ω - 3.9Ω Note: Special value is available on request ENVIRONMENTAL CHARACTERISTICS PERFORMANCE TEST TEST METHOD APPRAISE Short Time Overload IEC 60115-1 4.13 2.5 times RCWV for 5 sec. (Not more than maximum Overload Voltage) ±0.5%+0.05Ω Voltage Proof on Insulation IEC 60115-1 4.7 In V-Block for 60 sec., test voltage as above table No Breakdown Temperature Coefficient IEC 60115-1 4.8 Between -55°C to +155°C By type Insulation Resistance IEC 60115-1 4.6 in V-block for 60 Sec. >10,000MΩ Solderability IEC 60115-1 4.17 245±5°C for 3±0.5 Sec. 95% Min. coverage Solvent Resistance of Marking IEC 60115-1 4.30 IPA for 5±0.5 Min. with ultrasonic No deterioration of coatings and markings Periodic-pulse Overload IEC 60115-1 4.39 4 times RCWV 10,000 cycles (1 Sec. on, 25 Sec. off) ±1.0%+0.05Ω Damp Heat Steady State IEC 60115-1 4.24 40±2°C, 90-95% RH for 56 days, loaded with 0.1 times RCWV ±2.0%+0.1Ω Endurance at 70°C IEC 60115-1 4.25 70±2°C at RCWV (or Umax., Whichever less) for 1,000 Hr. (1.5Hr.on, 0.5Hr. Off) ±2.0%+0.1Ω Temperature Cycling IEC 60115-1 4.19 -55°C  Room Temp.  +155°C  Room Temp. (5 cycles) ±0.75%+0.05Ω Resistance to Soldering Heat IEC 60115-1 4.18 260±3°C for 10±1 Sec., immersed to a point 3±0.5mm from the body ±0.5%+0.05Ω Note: RCWV(Rated Continuous Working Voltage) = Power Rating x Resistance Value or Max. working voltage listed above, whichever less. Revision: 2020
MMF-25FRF3K9
1. 物料型号:文档中提到了几种型号,例如MMF-12、MMF25S、MMF204、MMF-25、MMF50S、MMF207、MMF-50和MMFIWS。
2. 器件简介:Melf金属膜电阻器使用真空溅射系统在高级陶瓷基板上沉积多层混合金属合金和被动材料,支持SMD结构。
3. 引脚分配:文档中没有明确提到引脚分配,但通常这类电阻器是无引脚的表面贴装元件。
4. 参数特性:包括功率等级(1/6W, 1/4W, 0.4W, 1/2W, 0.6W, 1W)、电阻公差(±0.1%, ±0.25%, ±0.5%, ±1%, ±2%, ±5%)和温度系数(±15ppm/°C, ±25ppm/°C, ±50ppm/°C, ±100ppm/°C)。
5. 功能详解:文档提供了电阻器的降额曲线、尺寸信息、电气特性(如在70°C时的功率等级、最大工作电压、最大过载电压等)和环境特性(如短时间过载测试、绝缘耐压测试等)。
6. 应用信息:虽然文档没有直接提到应用信息,但从电气特性和环境特性可以推断这些电阻器适用于需要高精度和高稳定性的应用场合。
7. 封装信息:提供了不同型号的尺寸信息,例如MMF-12型号的尺寸为3.50±0.2mm x 1.40±0.15mm x 0.5mm。
MMF-25FRF3K9 价格&库存
很抱歉,暂时无法提供与“MMF-25FRF3K9”相匹配的价格&库存,您可以联系我们找货
