■ AEC-Q200 Chip Resistor— QR Series (Wide Terminal Type)
■ Application
■ Features
─ Automotive electronics
─ Small size and light weight
─ Navigation equipment
─ Reduction of assembly costs and matching with placement machines
─ Power supply , ECU etc.
─ Reliability, high quality and fast delivery
─ Indoor lighting, Central door locking, Wiper module
─ Chip resistor of the wide terminal type.
■ Standard Electrical Specifications
Item
Type
Rated Power
at 70℃
Max Working
Voltage
Max Overload
Voltage
0.75 W
200V
400V
QR0612
T.C.R.
(PPM/℃
Resistance Range
F(±
±1%)
J(±
±5%)
±100
10Ω~3.3KΩ
10Ω~3.3KΩ
±100
3.6KΩ~1MΩ
3.6KΩ~1MΩ
Operating Temperature Range :−55℃〜+155℃.
■ Type Dimension- Chip Resistor
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
QR0612
1.60 ± 0.15
3.20 ± 0.15
0.60 ± 0.10
0.30 ± 0.20
0.45 ± 0.15
TEL: 886-7-8116611
FAX: 886-7-8115533
E-mail: service@everohms.com
http://www.everohms.com
■ Parts Number Explanation
■ Example:
QR
Product Ty pe
QR
0612
J
10R
P
S iz e
R es is tor
Tole ra nc e
R es is tors
Pac ka ge
(Inch)
06 12
F: ±1%
Value
05
P:Pa per Tapi ng
Quantity
0 5:5 00 0PC S
Optiona l
0.7 5W
J: ±5%
■ Appendix For SMD Chip Resistor
● Packaging Information
◆ For All Series
■ Dimension
Unit: mm
TYPE
QR0612
TEL: 886-7-8116611
SIZE
7”
5K/Reel
FAX: 886-7-8115533
A
ψB
ψC
ψD
W
ψM
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
■ Tapping Specification
■ Dimension
Packaging
Unit: mm
Type
A
B
W
E
F
G
H
T
ψD
P
+0.10
Paper Type
QR0612
1.90±0.2
3.50±0.2
8.0±0.2
1.75±0.1
3.5±0.05
4.0±0.1
2.0±0.05
0.75±0.1 1.50
4.0±0.1
-0
■ Packing Material Data / Storage Data
■ Front & Back Lead Dimension
■ Top Adhesive Peel Off Strength:10~70g
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Package
External Box Size
Inner Box Size
Size H(mm)
Reel
Contain Length
(Kpcs) (mm)
Width
(mm)
Height
(mm)
1
13
25K
180
180
60
2
24
50K
180
180
110
3
36
150K
430
200
200
5
60
300K
400
400
200
10
113
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
● Reliability Test and Requirement
Test Item
Test Method
Temperature
JIS C 5201-1
Coefficient of
clause 4.8
Resistance (T.C.R)
Procedure
Requirements
-55℃ or +155℃, 25℃ is the reference temperature
Refer to Ratings
Short Time
Overload
JIS C 5201-1
clause 4.13
2.5 times RCWV or Max. Overload voltage whichever is
less for 5 seconds.
1%:±(1.0%+0.05Ω)
5%:±(2.0%+0.10Ω)
Soldering
Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
1%:±(0.5%+0.05Ω)
5%:±(1.0%+0.05Ω)
Temperature
Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃,5 cycles
1%:±(0.5%+0.05Ω)
5%:±(1.0%+0.10Ω)
Load Life in
Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. RCWV or Max. working voltage
for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞.
1%:±(0.5%+0.05Ω)
5%:±(2.0%+0.05Ω)
Load Life
(Endurance)
JIS C 5201-1
clause 4.25
70±2℃, RCWV or Max. working voltage for 1000 hrs
1%:±(1.0%+0.05Ω)
5%:±(3.0%+0.10Ω)
Bending once for 5 seconds
D: 0612 = 2mm
±1:±(1.0%+0.05Ω)
±5:±(1.0%+0.05Ω)
Terminal Bending JIS C 5201-1
Strength
clause 4.33
TEL: 886-7-8116611
FAX: 886-7-8115533
AEC-Q200 test
Test Item
Test Method
Procedure
Requirements
Temperature
Cycling
JESD22 Method
JA-104
1000 Cycles (-55℃ to +125℃) Measurement at 24± 1%:±(0.5%+0.05Ω)
4 hours after test conclusion.
5%:±(1.0%+0.10Ω)
Resistance to
Solvent
MIL-STD-202
Method 215
Add Aqueous wash chemical-OKEM clean or
equivalent.
1%:±(0.5%+0.05Ω)
5%:±(0.5%+0.05Ω)
Biased Humidity
MIL-STD-202
Method 103
1000 hours 85℃/85%RH.
1%:±(0.5%+0.05Ω)
5%:±(2.0%+0.05Ω)
1000 hrs. @ T=125℃.
1%:±(0.5%+0.05Ω)
5%:±(2.0%+0.05Ω)
High Temperature MIL-STD-202
Exposure (Storage) Method 108
Operation Life
MIL-STD-202
Method 108
125℃,or Max.working voltage for 1000 hrs with 1.5 1%:±(1.0%+0.05Ω)
hrs"ON" and 0.5hr "OFF"
5%:±(3.0%+0.10Ω)
External Visual
MIL-STD-883
Method 2009
Electrical test not required.
Inspect device construction, marking and
workmanship.
MIL-STD-202
Mechanical Shock
Method 213
Impact acceleration:1500g
Pulse duration:0.5ms
Number of shocks:30 shocks(5 shocks for each
face)
1%:±(1.0%+0.05Ω)
5%:±(2.0%+0.10Ω)
MIL-STD-202
Method 204
5 g’s for 20min., 12 cycles each of 3 orientations.
1%:±(1.0%+0.05Ω)
5%:±(2.0%+0.10Ω)
Vibration
ESD
Solderability
Board Flex
TEL: 886-7-8116611
ACE-Q200- 002
0612:1KV
or ISO/DIS 10605
For the product %
J-STD-002
(1) 4 hrs 155℃ dry heat
(2) 260±5℃ 10 sec.
1%:±(0.5%+0.05Ω)
5%:±(1.0%+0.05Ω)
AEC Q200-005
Beading once for 60 seconds
1%:±(1.0%+0.05Ω)
5%:±(1.0%+0.05Ω)
FAX: 886-7-8115533
● General Information
■ Recommend Land Pattern Design
( For Reflow Soldering )
■ Dimension
Type
Item
Unit: mm
0612
A
0.70
B
2.30
C
3.20
■ Performance Characteristics
■ Power Derating Curve
DERATING CURVE
100
Power Ratio(%)
80
60
40
155℃
60
70
80 100 120 140 160
Power rating or current rating is in the
case based on continuous full-load at
ambient temperature of 70℃.
For operation at ambient temperature
in excess of 70℃, the load should be
derated in accordance with figure of
derating Curve.
Ambient Temperature (℃)
■ Voltage Rating or Current Rating
Resistance Range: ≧1Ω
Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working
voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula
as following:
E(RCWV)=√
√P×
×R
E=Rated voltage(V)
P=Power rating(W)
R=Nominal resistance(Ω)
■ Soldering Profile
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Equipments Applicable:
Our company’s products are produced under low temperature processing applicable to IR reflow
surface mounting devices. It is comparatively not applicable to wave soldering which will possibly
cause the risk ablating the element protection layer and the front conductor and cause the drift of the
resistance value and ablation of the markings.
■ Product Testing Method:
Our products are tested with our company’s tapping & testing equipments by using four-feet probe to
touch at the back of both electrodes. Supposed different testing points or methods are requested,
please advise beforehand and customized-made production is available.
Mar 2017
TEL: 886-7-8116611
FAX: 886-7-8115533
很抱歉,暂时无法提供与“QR0612J180RP05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.03821
- 500+0.02065
- 1500+0.00898
