CRW-Series Thick Film Wide Terminal
Chip Resistor Product Specifications
■Thick
Film Wide Terminal Chip Resistor— CRW Series
Application
— Navigation equipment
─ Power equipment: Power supply, Illumination equipment
─ Indoor lighting, Central door locking
文件編號/版本 S-10-12-19-02
製作日期
2019/01/14
頁次
1/1
Features
— Small size and light weight
— Reliability, high quality
— Chip resistor of the wide terminal type.
Document No. S-10-12-19-02
Released Date 2019/01/14
1/10
Page No.
Type Dimension
CRW0612/ CRW1020/ CRW1218/
CRW2030/ CRW1225
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
CRW0612
1.60 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.30 ± 0.20
0.50 ± 0.20
CRW1020
2.50 ± 0.20
5.00 ± 0.20
0.55 ± 0.10
0.40 ± 0.20
0.75 ± 0.20
CRW1218
3.10 ± 0.10
4.60 ± 0.10
0.55 ± 0.05
0.40 ± 0.20
0.50 ± 0.20
CRW1225
3.20 ± 0.20
6.50 ± 0.20
0.55 ± 0.20
0.40 ± 0.20
0.75 ± 0.20
CRW2030
5.10 ± 0.10
7.60 ± 0.10
1.20 ± 0.10
0.80 ± 0.20
0.80 ± 0.20
Standard Electrical Specifications
Item
Type
Resistance Range
Rated Power
at 70℃
Max Working
Voltage
Max Overload
Voltage
T.C.R.
(PPM/℃)
F(±1%)
±400
CRW0612
0.75 W
1Ω~9.9Ω
±200
10Ω~10MΩ
±100
10Ω~10MΩ
±400
CRW1020
1W
200V
CRW1218
1W
400V
1Ω~9.9Ω
±200
10Ω~10MΩ
±100
10Ω~10MΩ
±400
1Ω~9.9Ω
±200
10Ω~10MΩ
±100
10Ω~10MΩ
±400
CRW1225
CRW2030
2W
3W
J(±5%)
1Ω~9.9Ω
±200
10Ω~10MΩ
±100
10Ω~10MΩ
±100
1Ω~1KΩ
2/10
Page No.
Low Ohm Chip Resistor Electrical Specifications
Item
Type
Rated Power
at 70℃
Rated Voltage
Range
Max Overload
Voltage
T.C.R.
(PPM/℃)
±1800
CRW0612
CRW1020
CRW1218
CRW1225
CRW2030
0.75W
0.15~0.86V
1W
0.1~0.99V
1W
0.1~0.99V
2W
0.14~1.41V
3W
0.17~1.72V
2.154V
2.475V
2.475V
3.518 V
4.308V
Resistance Range
(mΩ)
F(±1%)、J±(5%)
30~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
±1800
10~50
±800
51~100
±600
101~990
Parts Number Explanation
■ Example:
CRW
0612
J
10K0
P
05
Z
Product Type
Size(Inch)
Resistor
Tolerance
Resistors
Value
Package
Quantity
Optional
CRW
0612
1020
1218
2030
1225
F:±1%
J:±5%
P、Q:Paper Taping
E:Embossed Taping
D:Packed in a Bag
01:1000PCS
04:4000PCS
05:5000PCS
3/10
Page No.
Appendix For SMD Chip Resistor
● Packaging Information
■ Dimension
Unit: mm
TYPE
SIZE
A
ψB
ψC
ψD
W
ψM
0612
7”
5K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
1020/1218/1225
7”
4K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
16.0±2.0
178±2.0
2030
7”
1K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
19.0±2.0
178±2.0
Tapping Specification
■ Dimension
Unit: mm
Packaging
Type
A
B
W
E
F
G
H
T
Paper Type
0612
1.90±0.2
3.50±0.2
8.0±0.2
1.75±0.1
3.5±0.05
4.0±0.1
2.0±0.05
0.75±0.1
ψD
P
4.0±0.1
4/10
Page No.
■ Dimension
Unit: mm
Packaging
Embossed
Type
Type
E
F
W
1020
2.80±0.2
5.60±0.2
12±0.1
1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.23±0.1
1.50±0.1 0.85±0.15
1225
3.40±0.2
6.70±0.2
12±0.1
1.50±0.1 0.85±0.15
1218
3.30±0.2
4.60±0.2
12±0.1
1.50±0.1 0.85±0.15
2030
5.50±0.2
7.90±0.2
16±0.1
1.75±0.1 7.5±0.05 4.0±0.1 2.0±0.05 0.25±0.1
1.50±0.1
Top Adhesive Peel Off Strength:10~70g
H
T
ψD1
B
Packing Material Data/Storage Data
■ Front & Back Lead Dimension
G
ψD
A
T1
1.30±0.1
P
4.0±0.1
8.0±0.2
5/10
Page No.
Package
Inner Box Size
Reel Size H(mm)
External Box Size
1
13
Contain
(Kpcs)
Length
(mm)
Width
(mm)
Height
(mm)
2
24
25K
180
180
60
3
36
50K
180
180
110
5
60
150K
430
200
200
10
113
300K
400
400
200
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
Reliability Test and Requirement
Test Item
Test Method
Procedure
Requirements
Temperature
Coefficient of
Resistance (T.C.R)
JIS C 5201-1
clause 4.8
-55℃ or +155℃, 25℃ is the reference temperature
Refer to Ratings
Short Time
Overload
JIS C 5201-1
clause 4.13
General:2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
1%:±(1.0%+0.05Ω)
5%:±(2.0%+0.1Ω)
IR Reflow
Sony SS-00254
Leaching
Sony
SS-00254-9
260±5℃ for 30 seconds.
>95% Coverage
Soldering Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
1%:±(0.5%+0.05Ω)
5%:±(1.0%+0.05Ω)
Temperature Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃,5 cycles
1%: ±(0.5%+0.05Ω)
5%: ±(1.0%+0.10Ω)
1%:±(1.0%+0.05Ω)
5%:±(1.0%+0.05Ω)
6/10
Page No.
Electric Iron
Sony
SS-00254-5
Preheating temperature:350±10℃
Electric iron preheating time:3+1/-0 sec
Resistance to
Solvent
JIS C 5201-1
clause 4.29
The tested resistor be immersed into isopropyl alcohol of
1%:±(0.5%+0.05Ω)
20~25℃ for 60 secs.
5%:±(0.5%+0.05Ω)
Then the resistor is left in the room for 48 hrs.
Load Life in Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. RCWV or Max. working voltage
whichever is less for 1000 hrs with 1.5 hrs〝ON〞and
0.5 hr〝OFF〞.
Load Life
(Endurance)
JIS C 5201-1
clause 4.25
70±2℃, RCWV or Max. working voltage whichever is less 1%: ±(1.0%+0.05Ω)
for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞.
5%:±(3.0%+0.10Ω)
Insulation
Resistance
JIS C 5201-1
clause 4.6
100V for 1 minute.
≧10GΩ
Terminal Bending
Strength
JIS C 5201-1
clause 4.33
Bending once for 5 seconds
D: 0612、1218、1020、1225、2030=2mm
1%:±(1.0%+0.05Ω)
5%:±(1.0%+0.05Ω)
1%:±(1.0%+0.05Ω)
5%:±(1.0%+0.05Ω)
1%:±(1.0%+0.05Ω)
5%:±(2.0%+0.05Ω)
General Information
Recommend Land Pattern Design
■ Dimension
Type
Unit: mm
0201
0402
0603
0805
1206
A
0.60
0.75
2.04
0.85
3.50
B
2.90
3.40
4.24
3.70
7.50
C
3.20
5.00
4.80
6.40
7.80
Item
■Performance
7/10
Page No.
Characteristics
Power Derating Curve
DERATING CURVE
100
80
Power Ratio(%)
60
40
155℃
60
70
80 100 120 140 160
Ambient Temperature (℃)
Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃.
For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure
of derating Curve.
Voltage Rating or Current Rating
Resistance Range: ≧1Ω
Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working
voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula
as following:
E(RCWV)=√P×R
E=Rated voltage(V)
P=Power rating(W)
R=Nominal resistance(Ω)
Product Testing Method:
Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the
back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and
customized-made production is available.
8/10
Page No.
0603 E-96 Multiplier Code
Code
A
B
C
D
E
F
G
H
X
Y
Z
Multiplier
100
101
102
103
104
105
106
107
10-1
10-2
10-3
CODING
FORMULA
XX
X
2
Example: 10.2KΩ = 102 x 10 Ω =02C
Multiplier Code
02
33.2Ω = 332 x 10 Ω =51X
Resistance Code
51
C
-1
X
0603 Standard E-96 Values and 0603 Resistance Codes
R-Value 100 102 105 107 110
Code
01
02
03
04
05
113
115
118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174
06
07
08
09
10
11
12
13
14
15
16
17
18
19
22
23
24
R-Value 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309
Code
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
R-Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549
Code
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
R-Value 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976
Code
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
9/10
Page No.
Standard Resistance Values in a Decade
Marking code:
1%: marking code, please refer to E96 and E24 data form as below
Ex: 120K, The marking code is 1203 in E24
121K, The marking code is 1213 in E96
5%: marking code, please refer to E24 data form as below
Ex: 120K, The marking code is 124 in E24
Note: 0402 series resistor has no marking code.
Type: 0603 1% marking code, please refer to E-96 multiplier code.
Note: jumper zero ohm resistor marking code is one 「0」 (except type below 0402).
E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48
100
101
102
104
105
106
107
109
110
111
113
114
115
117
118
120
121
123
124
126
127
129
130
132
133
135
137
138
140
142
143
145
147
149
150
152
154
156
158
160
162
164
165
167
100
100
102
105
105
107
110
110
113
115
115
118
121
121
124
127
127
130
133
133
137
140
140
143
147
147
150
154
154
158
162
165
162
169
172
174
176
178
180
182
184
187
189
191
193
196
198
200
203
205
208
210
213
215
218
221
223
226
229
232
234
237
240
243
246
249
252
255
258
261
264
267
271
274
277
280
284
169
169
174
178
178
182
187
187
191
196
196
200
205
205
210
215
215
221
226
226
232
237
237
243
249
249
255
261
261
267
274
280
274
287
291
294
298
301
305
309
312
316
320
324
328
332
336
340
344
348
352
357
361
365
370
374
379
383
388
392
397
402
407
412
417
422
427
432
437
442
448
453
459
464
470
475
481
287
287
294
301
301
309
316
316
324
332
332
340
348
348
357
365
365
374
383
383
392
402
402
412
422
422
432
442
442
453
464
475
464
487
493
499
505
511
517
523
530
536
542
549
556
562
569
576
583
590
597
604
612
619
626
634
642
649
657
665
673
681
690
698
706
715
723
732
741
750
759
768
777
787
796
806
816
487
487
499
511
511
523
536
536
549
562
562
576
590
619
649
665
681
681
698
715
715
732
750
750
768
787
806
825
845
866
866
887
909
909
931
953
953
976
E24 E12 E6 E3
634
649
825
590
604
619
825
835
845
856
866
876
887
898
909
920
931
942
953
965
976
988
787
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
10
10
10
12
15
15
18
22
22
22
27
33
33
39
47
47
47
56
68
68
82
According to IEC publication 63
很抱歉,暂时无法提供与“CRW2030F39R0E01Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1.72628
- 10+1.39288
- 30+1.25000
