HR1206J100RP05Z
HR1206J100RP05Z
    EVEROHMS(天二)
    贴片电阻 1206
HR1206J100RP05Z 数据手册
HR-Series High Voltage Chip Resistor Product Specifications ■ High Voltage Chip Resistor — HR Series ■ Application — Power supply, Industrial control system ─ Measurement instrument ─ Back light inverter ─ Medical, Precision equipments ■ Features — Special material and design for high working voltage require Document No. S-10-12-22-02 Released Date 2019/02/13 1/10 Page No. HR-Series High Voltage Chip Resistor Product Specifications ■ Document No. S-10-12-22-02 Released Date 2019/02/13 2/10 Page No. Type Dimension HR0402 / HR0603 / HR0805 / HR1206 HR1210 /HR2010 / HR2512 TYPE-1 L W H l1 l2 HR0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.15 ± 0.10 0.20 ± 0.10 HR0603 1.60 ± 0.20 0.80 ± 0.15 0.40 ± 0.10 0.30 ± 0.20 0.30 ± 0.10 HR0805 2.00 ± 0.20 1.25 ± 0.15 0.50 ± 0.15 0.30 ± 0.15 0.40 ± 0.15 HR1206 3.05 ± 0.10 1.60 ± 0.20 0.55 ± 0.15 0.40 ± 0.20 0.50 ± 0.20 HR1210 3.05 ± 0.10 2.50 ± 0.20 0.55 ± 0.15 0.50 ± 0.20 0.50 ± 0.20 HR2010 5.00 ± 0.20 2.50 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 HR2512 6.30 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 TYPE-2 L W H l1 l2 HR2010 5.00 ± 0.20 2.50 ± 0.20 0.55 ± 0.10 0.40 ± 0.20 0.60 ± 0.20 HR2512 6.30 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.40 ± 0.20 0.60 ± 0.20 HR-Series High Voltage Chip Resistor Product Specifications ■ Document No. S-10-12-22-02 Released Date 2019/02/13 3/10 Page No. Standard Electrical Specifications TYPE-1 Rated Power At 70℃ Max. Working Voltage Max. Over Load Voltage HR0402 0.063W 100V 200V HR0603 HR0805 HR1206 HR1210 0.1W 0.125 W 200 V 400 V HR2512 800 V J : ±5% F : ±1% ±300 100Ω~990Ω ±200 1KΩ~10MΩ ±200 47Ω~98.8Ω ±100 100Ω~30MΩ ±200 47Ω~98.8Ω ±100 100Ω~30MΩ ±200 47Ω~98.8Ω ±100 100Ω~30MΩ ±200 47Ω~549Ω ±100 560Ω~30MΩ ±200 47Ω~549Ω ±100 560Ω~30MΩ ±500 47Ω~98.8Ω ±200 100Ω~549Ω ±100 560Ω~30MΩ 0.33 W 1000 V 0.5 W 1.0 W Rated Power At 70℃ Max. Working Voltage Max. Over Load Voltage T.C.R (ppm/℃) HR2010 0.5 W 2000 V 3000 V ±100 HR2512 1.0 W 3000 V 4000 V ±100 TYPE-2 Resistance (Ω) 0.25 W 500 V HR2010 400 V T.C.R (ppm/℃) Resistance (Ω) J : ±5% F : ±1% 100K ~ 10M ● For non-standard parts, please contact our sales dept. ● Operating Temperature Range :−55℃〜+155℃. HR-Series High Voltage Chip Resistor Product Specifications ■ Document No. S-10-12-22-02 Released Date 2019/02/13 4/10 Page No. Parts Number Explanation ■ Example: ■ HR 2010 F 1M00 E 04 Z Product Type Size(Inch) Resistor Tolerance Resistors Value Package Quantity Optional HR 0402 0603 0805 1206 1210 2010 2512 F:±1% J:±5% P、Q:Paper Taping E:Embossed Taping D:Packed in a Bag 04:4000PCS 05:5000PCS 10:10000PCS 40:40000PCS 50:50000PCS Z : Type-1 Normal Type U : Type-2 Super Type Appendix For SMD Chip Resistor ● Packaging Information ■ Dimension Unit: mm TYPE SIZE A ψB ψC ψD W ψM 7” 10K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 13” 40K/50K Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 330±2.0 7” 5K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 10” 10K/Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 254±2.0 13” 20K/Reel 2.0±0.5 13.5±1.0 21±1.0 100±1.0 11.5±2.0 330±2.0 7” 4K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 16.0±2.0 178±2.0 0402 0603/0805/1206/ 1210 0603/0805 /1206 2010/2512 Document No. S-10-12-22-02 Released Date 2019/02/13 5/10 Page No. HR-Series High Voltage Chip Resistor Product Specifications ■ Tapping Specification ■ Dimension Packaging Paper Type Unit: mm Type A B W E F G H T 0402 0.70±0.1 1.20±0.1 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.45±0.1 0603 1.05±0.2 1.80±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.60±0.1 0805 1.55±0.2 2.30±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 1206 1.90±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 1210 2.85±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.75±0.1 ψD P 2.0±0.1 4.0±0.1 ■ Dimension Packaging Embossed Type Type Unit: mm A B W E F G H T ψD ΨD1 T1 2010 2.80±0.20 5.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50±0.10 0.85±0.15 2512 3.40±0.20 6.70±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50±0.10 0.85±0.15 P 4.0±0.1 HR-Series High Voltage Chip Resistor Product Specifications ■ Document No. S-10-12-22-02 Released Date 2019/02/13 6/10 Page No. Packing Material Data/Storage Data ■ Front & Back Lead Dimension ■ Top Adhesive Peel Off Strength:10~70g ■ Package Inner Box Size Reel Size H(mm) External Box Size 1 13 Contain (Kpcs) Length (mm) Width (mm) Height (mm) 2 24 25K 180 180 60 3 36 50K 180 180 110 5 60 150K 430 200 200 10 113 300K 400 400 200 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. HR-Series High Voltage Chip Resistor Product Specifications ● Document No. S-10-12-22-02 Released Date 2019/02/13 7/10 Page No. Reliability Test and Requirement Requirements Test Item Test Method Procedure TYPE-1 TYPE-2 Temperature Coefficient of Resistance (T.C.R) JIS C 5201-1 clause 4.8 -55℃ or +155℃, 25℃ is the reference temperature. Refer to Ratings Short Time Overload JIS C 5201-1 clause 4.13 2.5 times RCWV or Max. Overload for 5 seconds. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.1Ω) ±2.0% IR Reflow Sony SS-00254 Pre Heating : 150~180℃ / 60~120sec Peak : 230~250℃ / 20~40sec 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) ±1.0% Leaching Sony SS-00254-9 260±5℃ for 30 seconds. >95% Coverage Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.05Ω) ±1.0% Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃,5 cycles 1%: ±(0.5%+0.05Ω) 5%: ±(1.0%+0.10Ω) ±1.0% Electric Iron Sony SS-00254-5 Preheating temperature:350±10℃ Electric iron preheating time:3+1/-0 sec 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) ±1.0% The tested resistor be immersed into isopropyl alcohol JIS C 5201-1 clause of 20~25 ℃ for 60 secs. Then the resistor is left in the 4.29 room for 48 hrs. 1%:±(0.5%+0.05Ω) 5%:±(0.5%+0.05Ω) ±1.0% Resistance to Solvent Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. RCWV or Max. working voltage whichever is less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.05Ω) ±3.0% Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, RCWV or Max. working voltage whichever is 1%:±(1.0%+0.05Ω) less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 5%:±(3.0%+0.10Ω) ±3.0% Insulation Resistance JIS C 5201-1 clause 4.6 100V for 1 minute. ≧10GΩ Bending once for 5 seconds D: 0402、0603、0805=5mm 1206、1210 =3mm 2010、2512 =2mm 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) Terminal Bending Strength JIS C 5201-1 clause 4.33 ±1.0% HR-Series High Voltage Chip Resistor Product Specifications ● Document No. S-10-12-22-02 Released Date 2019/02/13 8/10 Page No. General Information Recommend Land Pattern Design ■ ■ Dimension Unit: mm Type 0402 0603 0805 1206 1210 2010 2512 A 0.60 1.00 1.20 2.20 2.20 3.80 4.80 B 1.90 3.05 4.10 5.10 5.10 6.90 8.20 C 0.70 1.20 1.70 2.00 2.90 2.90 3.65 Item ■Performance ■ Characteristics Power Derating Curve DERATING CURVE 100 80 Power Ratio(%) 60 40 155℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Ambient Temperature (℃) Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. ■ Voltage Rating or Current Rating Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: E(RCWV)=√P×R E=Rated voltage(V) P=Power rating(W) R=Nominal resistance(Ω) Document No. S-10-12-22-02 Released Date 2019/02/13 9/10 Page No. HR-Series High Voltage Chip Resistor Product Specifications ■ Product Testing Method: Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and customized-made production is available. ■ 0603 E-96 Multiplier Code Code A B 0 Multiplier C 1 10 10 CODING FORMULA XX X D 2 E 3 10 F 4 10 G 5 10 10 X 7 10 Y -1 10 Z -2 10 10-3 10 2 Example: 10.2KΩ = 102 x 10 Ω =02C Multiplier Code 02 C -1 33.2Ω = 332 x 10 Ω =51X Resistance Code 51 ■ H 6 X 0603 Standard E-96 Values and 0603 Resistance Codes R-Value 100 102 105 107 110 Code 01 02 03 04 05 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 R-Value 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 Code 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 R-Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 Code 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 R-Value 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Code 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 HR-Series High Voltage Chip Resistor Product Specifications ■     Document No. S-10-12-22-02 Released Date 2019/02/13 10/10 Page No. Standard Resistance Values in a Decade Marking code: 1%: marking code, please refer to E96 and E24 data form as below Ex: 120K, The marking code is 1203 in E24 121K, The marking code is 1213 in E96 5%: marking code, please refer to E24 data form as below Ex: 120K, The marking code is 124 in E24 Note: 0402 series resistor has no marking code. Type: 0603 1% marking code, please refer to E-96 multiplier code. Note: jumper zero ohm resistor marking code is one 「0」 (except type below 0402). E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 100 101 102 104 105 106 107 109 110 111 113 114 115 117 118 120 121 123 124 126 127 129 130 132 133 135 137 138 140 142 143 145 147 149 150 152 154 156 158 160 162 164 165 167 100 100 102 105 105 107 110 110 113 115 115 118 121 121 124 127 127 130 133 133 137 140 140 143 147 147 150 154 154 158 162 165 162 169 172 174 176 178 180 182 184 187 189 191 193 196 198 200 203 205 208 210 213 215 218 221 223 226 229 232 234 237 240 243 246 249 252 255 258 261 264 267 271 274 277 280 284 169 169 174 178 178 182 187 187 191 196 196 200 205 205 210 215 215 221 226 226 232 237 237 243 249 249 255 261 261 267 274 280 274 287 291 294 298 301 305 309 312 316 320 324 328 332 336 340 344 348 352 357 361 365 370 374 379 383 388 392 397 402 407 412 417 422 427 432 437 442 448 453 459 464 470 475 481 287 287 294 301 301 309 316 316 324 332 332 340 348 348 357 365 365 374 383 383 392 402 402 412 422 422 432 442 442 453 464 475 464 487 493 499 505 511 517 523 530 536 542 549 556 562 569 576 583 590 597 604 612 619 626 634 642 649 657 665 673 681 690 698 706 715 723 732 741 750 759 768 777 787 796 806 816 487 487 499 511 511 523 536 536 549 562 562 576 590 619 649 665 681 681 698 715 715 732 750 750 768 787 806 825 845 866 866 887 909 909 931 953 953 976 E24 E12 E6 E3 634 649 825 590 604 619 825 835 845 856 866 876 887 898 909 920 931 942 953 965 976 988 787 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 10 10 10 12 15 15 18 22 22 22 27 33 33 39 47 47 47 56 68 68 82 According to IEC publication 63
HR1206J100RP05Z 价格&库存
很抱歉,暂时无法提供与“HR1206J100RP05Z”相匹配的价格&库存,您可以联系我们找货
