RAC104D103JCTH
RAC104D103JCTH
    KAMAYA(釜屋电机)
    RA_0402X4
    排阻/电阻网络 0402x4 10kΩ ±5% 63mW ±200ppm/℃
RAC104D103JCTH 数据手册
Spec. No.: Date: RAC-K-HTS-0001 2017. 1. 10 /14 Sp e c i f i c a t i o n Title: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE Style: RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RoHS COMPLIANCE ITEM Halogen and Antimony Free Product specification contained in this specification are subject to change at any time without notice If you have any questions or a Purchasing Specification for any quality Agreement is necessary, please contact our sales staff. Hokkaido Research Center Approval by: T. Sannomiya Drawing by: M. Shibuya Note: Stock conditions Temperature: +5°C ∼ +35°C Relative humidity: 25% ∼ 75% The period of guarantee: Within 2 year from shipmen t by the company. Solderability shall be satisfied. Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 1/12 1. Scope 1.1 This specification covers the detail requirements for fixed chip resistors networks; rectangular type, style of RAC06 2D, 06 4D, 10 2D, 10 4D, 16 4D, 16 8D. 1.2 Applicable documents JIS C 5201−1: 2011, JIS C 5201−9: 2006, JIS C 5201−9−1: 2006 IEC60115−1: 2008, IEC60115−9: 2003, IEC60115−9−1: 2004 EIAJ RC−2129−2000. 2. Classification Type designation shall be the following form. (Example) 1. RAC 16 D 103 J 4 2 3 4 5 6 1 Style 2. RAC 16 D JP 4 1 2 3 4 5 Style 1 Fixed chip resistors networks; rectangular type 2 Size Style 3 Number of element 4 Circuits 5 Rated resistance 103 E24 Series, 3 digit, Ex. 103--> 10kΩ, 1000 E96 Series, 4 digit, Ex. 1000-->100Ω 1022--> 10.2kΩ JP Chip jumper C 7 TP 8 C 7 TP 8 6 Tolerance on rated resistance F ±1% J ±5% 7 Terminal style C D E Convex Type With Corner Flat Type Flat Type Low profile 8 Packaging form B TH TP Bulk (loose package) Paper taping Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D Title: RAC−K−HTS−0001 Page: /14 2/12 3. Rating 3.1 The ratings shall be in accordance with Table−1. Table−1 Style Terminations style RAC06 2D D,E Rated element dissipation (W) Rated network dissipation (W) 0.063 0.031 RAC06 4D RAC10 2D D,E 0.125 C 0.125 0.063 RAC10 4D RAC16 4D 0.25 C 0.1 0.25 Temperature coefficient of resistance ( 10−6 / °C) ±200 ±350 ±200 ±200 ±350 ±200 ±400 ±300 ±200 ±100 ±200 +300~+500 RAC16 8D Style C 0.063 Limiting element voltage(V) 0.25 Max over load voltage(V) RAC06 2D 12.5 25 RAC06 4D RAC10 2D 25 50 RAC10 4D 50 100 RAC16 4D 50 100 RAC16 8D 25 100 Note. Rated current of chip jumper: 1(A) Note. Resistance value of chip jumper: 50mΩ max. ±200 Rated resistance range(Ω) 100~100k 10~27 30~1M 100~100k 10~27 30~1M 3~9.1 Preferred number series for resistors F(±1%) E24 J(±5%) F(±1%) E24 E24 10~1M Tolerance on rated resistance J(±5%) J(±5%) F(±1%) 10~1M 1~9.1 1.1M~10M 10~1M E24 E24 Number of element Circuit networks Category temperature range(°C) 2 4 2 4 4 8 D (Independence type) −55∼+125 J(±5%) J(±5%) 3.2 Derating The derated values of dissipation (or current rating in case of chip jumper) at temperature in excess of 70 °C shall be as indicated by the following curve. Percentage 100 of the rated Area of recommended operation dissipation (Current) (%) 0 −55 70 125 Ambient temperature (°C) Figure−1Derating curve Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D Title: RAC−K−HTS−0001 Page: /14 3/12 3.3 Rated voltage d. c. or a. c. r. m. s. voltage calculated from the square root of the product of the rated resistance and the rated dissipation. E : Rated voltage (V) E = P · R P : Rated dissipation (W) R : Rated resistance (Ω) Limiting element voltage can only be applied to resistors when the resistance value is equal to or higher than the critical resistance value. At high value of resistance, the rated voltage may not be applicable. 〔So called RCWV (Rated continuous working Voltag) is determined by 〕 4. Packaging form The standard packaging form shall be in accordance with Table−2. Table−2 Standard packaging Symbol Packaging form quantity / units B Bulk (loose package) 1,000 pcs. Application RAC06, 10,16 TH Paper taping 8mm width, 2mm pitches 10,000 pcs. RAC06 2D, 4D, RAC10 2D, 4D TP Paper taping 8mm width, 4mm pitches 5,000 pcs. RAC16 4D, 8D Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 4/12 5. Dimensions The resistor shall be of the design and physical dimensions in accordance with below. 5.1 Terminations style:E. 5.1.1 RAC06 2D 5.1.2 RAC06 4D a b W W a Q b P P Q H H L L Circuit Circuit R1 R2 R1 R2 R3 R4 R1=R2 R1=R2=R3=R4 Figure−2 Style RAC06 2D RAC06 4D Terminations style E E Figure−3 L 0.8±0.05 1.4±0.05 5.1.3 Net weight (Reference) Terminations style Style RAC06 2D E RAC06 4D E Table−3 W H 0.6±0.05 0.23±0.10 0.6±0.05 0.23±0.10 Unit: mm Q 0.2±0.1 0.2±0.1 a 0.2±0.1 0.2±0.1 b ∗P 0.2±0.1 0.5 0.2±0.1 0.4 ∗Reference Net weight(mg) 0.38 0.65 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D 5.2 Terminations style:D. 5.2.1 RAC06 2D RAC−K−HTS−0001 Page: /14 5/12 5.2.2 RAC06 4D P a Q b W W a P b Title: Q H Circuit Circuit R1 H L L R2 R1 R2 R3 R4 R1=R2 R1=R2=R3=R4 Figure−4 Style RAC06 2D RAC06 4D Terminations style D D Figure−5 L 0.8±0.1 1.4±0.1 5.2.3 Net weight (Reference) Terminations style Style RAC06 2D D RAC06 4D D Table−4 W H 0.6±0.1 0.35±0.10 0.6±0.1 0.35±0.10 Unit: mm Q 0.3±0.1 0.25±0.10 a 0.15±0.10 0.15±0.10 b ∗P 0.15±0.10 0.5 0.20±0.10 0.4 ∗Reference Net weight(mg) 0.56 0.98 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D 5.3 RAC10 2D RAC−K−HTS−0001 Page: /14 6/12 5.4 RAC10 4D P Q1 Q1 Q2 b a P W W a b Title: L H L Circuit R1 H Circuit R1 R2 R2 R3 R4 R1=R2 R1=R2=R3=R4 Figure−6 Style RAC10 2D RAC10 4D Style RAC10 2D RAC10 4D Terminations style C C a 0.2±0.15 0.2±0.1 L 1.0±0.1 2.0±0.1 b 0.25±0.17 0.25±0.10 5.5 Net weight (Reference) Terminations style Style RAC10 2D C RAC10 4D C ∗P 0.65 0.5 Table−5 W H 1.0±0.1 0.35±0.10 1.0±0.1 0.45±0.10 Figure−7 Unit: mm Q or Q1 ∗Q2 0.34±0.10 ----0.3±0.05 0.4±0.1 ∗Reference Net weight(mg) 1.1 2.1 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 7/12 5.6 RAC16 4D P Q1 Q2 a b Circuit W R1 L R2 R3 R4 H R1=R2=R3=R4 Style RAC16 4D Style RAC16 4D Terminations style C b 0.3±0.2 L 3.2±0.1 ∗Q2 0.6±0.1 5.7 Net weight (Reference) Terminations style Style RAC16 4D C ∗P 0.8 Figure−8 Table−6 W H 1.6±0.1 0.5±0.1 Q1 0.4±0.1 Unit: mm a 0.3±0.1 ∗Reference Net weight(mg) 7 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D Title: RAC−K−HTS−0001 Page: /14 8/12 5.8 RAC16 8D P Q a b Circuit W R1 L Style RAC16 8D Style RAC16 8D H Terminations style C b 0.3±0.1 L 3.8±0.1 Figure−9 Table−7 W H 1.6±0.1 0.45±0.10 R2 R3 R4 R5 R6 R7 R8 R1=R2=R3=R4=R5=R6=R7=R8 Unit: mm Q a 0.3±0.1 0.3±0.1 ∗Reference *P 0.5 5.9 Net weight (Reference) Terminations style Style RAC16 8D C Net weight(mg) 8.3 6. Marking The Rated resistance of RAC06 2D, 4D, RAC10 2D should not be marked. 6.1 For the resistors The rated resistance shall be marked in 3 digits (E24) and marked on over coat side. Marking example Contents 3 123 12×10 [Ω] → 12 [kΩ] 6.2 For the Jumper Chip Marking example Contents 000 JP Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 9/12 7. Performance 7.1 The standard condition for tests shall be in accordance with Sub−clause 4. 2, JIS C 5201−1: 2011. 7.2 The performance shall be satisfied in Table−8. Table−8(1) No. Test items Performance requirements Condition of test (JIS C 5201−1) 1 Resistance As in 4.5.2 Sub−clause 4.5 The resistance value shall correspond with the rated resistance taking into account the specified tolerance. Chip jumper: 50mΩ max. 2 Temperature characteristic 4.8 See Table−1. of resistance Natural resistance change per change in degree centigrade. R2-R1 TCR(10-6/Ω)= x 106 R1(t2-t1) +5 +5 t1 : 20°C -1 °C, t2: 125°C -1 °C 3 Short time overload 4 Resistance to soldering heat 5 Solderability 6 Temperature cycling R1 : Resistance at t1 temperature R2 : Resistance at t2 temperature 4.13 Test voltage: 2.5 times RCWV Test period: 5s. Test potential should not exceed max. overload voltage as shown in Table-1. 4.18 Test by a piece. Temp. of solder bath:260±5°C Immersion time: 10±1s After immersion into solder leaving the room temp. for 1h or more, and then measure the resistance. 4.17 Test by a piece. Flax: Rosin-Methanol Temp. of solder bath: 235±5°C Immersion time: 2±0.5s 4.19 Test cycle: 5 cycles for duty cycle as specified below. Step 1 2 3 4 Temperature(°C) -55±3 20 +5 -1 +125±2 20 +5 -1 Resistor: ∆R/R: Within ±(2%+0.1Ω) Chip jumper: 50mΩ max. No visible damage Resistor: ∆R/R: Within ±(1%+0.05Ω) Chip jumper: 50mΩ max. No evidence of appearance damage. 95% coverage min., good tinning and no visible damage. Resistor: ∆R/R: Within ±(1%+0.05Ω) Chip jumper: 50mΩ max. No visible damage Time(min.) 30 2~3 30 2~3 Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: No. 7 Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D Table−8(2) Condition of test (JIS C 5201−1) Test items Load life 4.25 Test temp.: 70±2°C Test voltage: Cycle of 1h 30min. “ON” and 30min. “OFF” at dc rated voltage. Test period: 1,000 +48 0 h 8 Load life in humidity 4.24 Test condition: 40±2°C & 90~95% R.H. Test voltage: Cycle of 1h 30min. “ON” and 30min. “OFF” at dc rated voltage. Test period: 1,000 +48 0 h 9 10 11 Adhesion 4.32 Pressurizing force: 5N ( RAC06: 3N) Test time: 10±1sec. Insulation resistance 4.6 Test voltage: Max. overload voltage (DC) Test period: 1min. Dielectric withstanding 4.7 voltage Test voltage: Max. overload voltage (AC) Test period: 1min. RAC−K−HTS−0001 Page: /14 10/12 Performance requirements Resistor: ∆R/R: Within ±(3%+0.1Ω) Chip jumper: 50mΩ max. No visible damage Resistor: ∆R/R: Within ±(3%+0.1Ω) Chip jumper: 50mΩ max. No visible damage No remarkable damage or removal of the terminations R≥1GΩ No flashover, fire and breakdown. Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 11/12 8. Taping 8.1 Applicable documents JIS C 0806−3: 2014, EIAJ ET−7200C: 2010 8.2 Taping dimensions 8.2.1 RAC06 2D,RAC06 4D,RAC10 2D, RAC10 4D (Paper taping, 8mm width, 2mm pitches) Taping dimensions shall be in accordance with Figure−10 and Table−9. Unit: mm 4±0.1 Sprock et hole φ1.5 +0 0.1 .1 0 1.75±0.1 B 8±0.3 A t 2±0.05 Carrier cavity 3. 5±0.05 Direction of unreeling Style RAC06 2D RAC06 4D RAC10 2D RAC10 4D Figure−10 Table−9 A Unit: mm t B 0.9±0.1 1.5±0.1 1.15±0.1 2.2±0.2 0.7±0.1 1.15±0.1 1.2±0.2 0.5±0.1 0.5max. 0.6max. 8.2.2 RAC16 4D, RAC16 8D (Paper taping, 8mm width, 4mm pitches) Taping dimensions shall be in accordance with Figure−11 and Table−10. Unit: mm 4±0.1 φ1.5 Sprocket hole + 0.1 0 2±0.05 1.75±0.1 B C A t Carrier cavity 4±0.1 3.5±0.05 Direction of unreeling Style RAC16 4D RAC16 8D Figure−11 Table−10 A B 2.0±0.2 3.6±0.2 1.9±0.15 4.1±0.15 C 8.0±0.3 Unit: mm t 1.0max. 0.85max. Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10 Title: Drawing No: FIXED CHIP RESISTOR NETWORKS; RECTANGULAR TYPE RAC06 2D, RAC06 4D, RAC10 2D, RAC10 4D, RAC16 4D, RAC16 8D RAC−K−HTS−0001 Page: /14 12/12 8.3 Reel dimension Reel dimensions shall be in accordance with the following Figure−12 and Table−11. Unit: mm Marking φ178±2 φ60±1 φ13±0.2 2±0.5 A Figure−12 Table−11 Unit: mm A Style RAC06,10,16 9±0.5 Note: Marking label shall be marked on a place of Marking A or two place of marking A and B. 9. Marking on package The label of a minimum package shall be legibly marked with follows. 9.1 Marking A (1) Classification (Style, Rated resistance, Tolerance on rated resistance, Terminal style, Packaging form) (2) Quantity (3) Lot number (4) Manufacturer’s name or trade mark (5) Others 9.2 Marking B (KAMAYA Control label) Product specification contained in this specification are subject to change at any time without notice. If you have any questions or a Purchasing Specification for any quality agreement is necessary, please contact our sales staff. Issue: KAMAYA ELECTRIC CO., LTD. Research & Development Department HOKKAIDO Research center Last update: 2017.1.10
RAC104D103JCTH 价格&库存
很抱歉,暂时无法提供与“RAC104D103JCTH”相匹配的价格&库存,您可以联系我们找货
