VG039NCHXTB222
VG039NCHXTB222
    HOKURIKU(北陆电气)
    SMD
    可调电阻/电位器 2.2KΩ ±25% SMD
VG039NCHXTB222 数据手册
SPECIFICATION Product Name VARIABLE RESISTOR Model No. VG039NCHXT Control No. 412 Date January 9, 2007 HOKURIKU ELECTRIC INDUSTRY CO., LTD. COMPONENTS DIVISION ELECTRO-MECHANICAL COMPONENT FACTORY SALES DEPARTMENT Sales  Representative Approved ELECTRO-MECHANICAL COMPONENT FACTORY Drawn N.Kurata Checked M.Kanagawa Checked H.Takabayashi Approved T.Nakayama The contents of this specification may change without prior notice. For inquiries, please refer to product name, model No., and control No. written in the cover sheet of this specification. Because this specification is for reference only, for your actual use of this part please acknowledge and sign the formal specification for this part. 1. Scope This specification applies to 3 mm Chip trimmer potentiometer with Metal - Glaze - Resistor, used in electronic equipment. 2. Construction ② (Dimensions and Materials) and Rating 2.1. Dimension See attached Drawing. 2.2. Materiales See attached Material List 2.3. Operating Temperature Range -40 ℃∼+100 ℃ 2.4. Storage Temperature Range -10 ℃∼+40 ℃ 2.5. Nominal Total Resistance Range 100 Ω ∼ 1 MΩ (1・2・3・5 series , see attached Application List) 2.6. Total Resistance Tolerance ±25 % 2.7. Power Rating 0.1 5 W (∼+70 ℃) Power rating vs. ambient temperature shall be denoted on the following chart. 100 80 Power Rating ratio (%) 60 40 20 0 20 40 60 80 100 Ambient Temperature (℃) 2.8. Rated Voltage Rated Voltage E=√P・R Where P : Power Rating (W) R : Nominal Total Resistance (Ω) When the rated voltage exceeds the maximum operating voltage, the maximum operating voltage shall be the rated voltage. 2.9. Maximum Operating Voltage ③ ② ① 50 V Review Item 2.4, 3.3.2 2006.11.11 H.Takabayashi Add Item 5.4 and review Item 5. 2006.8.2 H.Takabayashi DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED APPROVALS H.Takabayashi M.Urayama Oct./11/’06 Oct./11/’06 DATE DATE Oct. ,11, 2006 ⑥ ⑤ ④ TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 1 7 3. Characteristics Standard atmospheric conditions Unless otherwise specified, the standard range of atmospheric conditions for making measurements and tests is as follows : Ambient temperature : 5 ℃ to 35 ℃ Relative humidity : 45 % to 85 % Air pressure : 860 hPa to 1 060 hPa If there is any doubt about the results, measurements shall be made within the following limits : Ambient temperature : 20 ℃±2 ℃ Relative humidity : 60 % to 70 % Air pressure : 860 hPa to 1 060 hPa 3.1. Mechanical characteristics Item Conditions Specifications 1 Total Mechanical Rotation 270 °±20 ° 2 Rotational Torque 0.98 mN・m ∼ 11.76 mN・m 3 End Stop Strength The following torsion moment of 14.7 mN・m shall be applied to the spindle for 5 seconds in any direction. Without distinct looseness or poor contact. 4 Soldering Strength A static load shown in this figure shall be applied to terminals for 30 s after soldering. Without distinct looseness or poor contact. Solder 9.8 N 9.8 N 4.9 N 5 Push Load A push load of 9.8 N shall be applied to the axial direction for 30 seconds from upper part of the product. ③ ② ① Without distinct looseness or poor contact. Without board breaking. ⑥ ⑤ ④ DRAWN N.Kurata DATE Oct./11/’06 CHECKED APPROVALS H.Takabayashi M.Urayama DATE Oct./11/’06 DATE Oct./11/’06 TITLE VARIABLE RESISTOR DATE Oct. ,11, 2006 HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 2 7 3. Characteristics 3.2. Electrical characteristics Item 1 2 3 4 Resistance Law (Taper) Ineffective Rotation Residual Resistance Contact Resistance Conditions Output voltage ratio at the middle of total rotational angle. 40 %∼60 % ( Linear taper ) Ineffective rotation is the sum of all rotational distances in which resistance does not change and is calculated as a percentage of the total mechanical rotation. Total nominal The resistances at each resistance end of the mechanical 1 kΩ or less rotation between terminals Total nominal 1 and 2, or 2 and 3 resistance more than 1 kΩ shall be measured. 10 % or less of total mechanical rotation, at each end. The moving contact shall be rotated to a point where the resistance between terminals 1 and 2 is half of the total resistance. Contact resistance shall be calculated by the following formula : (R12+R23)−R13 Where Temperature Coefficient (T. C. R.) 20 Ω or less 2 % or less of total nominal resistance. 5 % or less of nominal total resistance. ×100(%) 2×R13 5 Specifications R12 : Resistance between R23 : Resistance between R13 : Resistance between terminals terminals terminals 1 2 1 and and and 2 3 3 The trimmer potentiometer shall be maintained in a thermostatic chamber at a temperature, according to the table as shown below. Step Temperature(℃) Initial +25±2 1 -40±3 2 +25±2 3 +100±3 Within ±250 ppm/ ℃ The mesurement shall be made, after the thermostatic chamber achieved the mark temperature and maintained for 30 min ∼ 45min. ③ ② ① ⑥ ⑤ ④ DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED APPROVALS H.Takabayashi M.Urayama Oct./11/’06 Oct./11/’06 DATE DATE Oct. ,11, 2006 TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 3 7 3.3. Endurance characteristics When the items in ★mark, the moving contact shall be rotated to a point where the resistance between 1 and 2 is half of the total resistance. Item ② Conditions Specifications 1 ★ Vibration The entire frequency range, from 10 Hz to 55 Hz and return to 10 Hz, shall be transversed in 1 min. Amplitude (total excursion) : 1.5 mm This motion shall be applied for a period of 2 h in each of 3 mutually perpendicular directions. (a total of 6 h) Change in resistance between 1 and 2 is relative to the value before test . Within ±5 % Without an instant open during the test. 2 ★ Resistance to Soldering Heat Re-flow soldering method Peak temperature : Within 260 ℃ 10 s Application time : more than 230 ℃, Within 40 s Within ±2 % of initial resistance. Soldering iron method Tip temperature : 400 ℃±10 ℃ Application time of soldering iron : 3 s +1 s /−0 s. 3 ★ High Temperature Storage The trimmer potentiometer shall be subjected in a thermostatic chamber at a temperature of 70 ℃±2 ℃ without electrical load for 1 000 h± 12 h. Then the trimmer potentiometer shall be taken out from the chamber and maintained at standard atmospheric conditions for 1 h ∼ 2 h, after which measurements shall be made. Change in total resistance is relative to the value before test. Within ±5 % 4 ★ Load Life The trimmer potentiometer shall be subjected in a thermostatic chamber at a temperature of 70 ℃±2 ℃ with a DC rated voltage for 1.5 h between terminals 1 and 3 followed by a pause of 30 min for 1 000 h±12 h. Then the trimmer potentiometer shall be taken out from the chamber and maintained at standard atmospheric conditions for 1 h ∼ 2 h without electrical load, after which measurements shall be made. Change in total resistance is relative to the value before test. Within ±5 % 5 ★ Temperature Cycle The trimmer potentiometer shall be subjected in a thermostatic chamber at 5 successive change of temperature cycles, each as shown in table below. Then the trimmer potentiometer shall be taken out from the chamber and maintained at standard atmospheric conditions for 1 h ∼ 2 h, after which measurements shall be made. Change in total resistance is relative to the value before test. Within ±2 % Without distinct looseness or poor contact. Step Temperature 1 2 −40 ℃±3 ℃ 3 4 100 ℃±2 ℃ Duration Standard atmospheric conditions Standard atmospheric conditions ③ ② ① 30 min 10 min to 15 min 30 min 10 min to 15 min ⑥ ⑤ ④ DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED H.Takabayashi Oct./11/’06 DATE Oct. ,11, 2006 APPROVALS M.Urayama Oct./11/’06 DATE TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 4 7 Item Conditions Specifications 6 ★ Humidity The trimmer potentiometer shall be subjected in a thermostatic chamber at a temperature of 40 ℃± 2 ℃ with relative humidity of 90% to 95% without electrical load for 1 000 h±12 h. Then the trimmer potentiometer shall be taken out from the chamber and its surface moisture shall be removed. And then the trimmer potentiometer shall be maintained at standard atmospheric conditions for 1 h ∼ 2 h, after which measurement shall be made. Change in total resistance is relative to the value before test. Within ±5 % 7 ★ Humidity Load Life The trimmer potentiometer shall be subjected in a thermostatic chamber at a temperature of 40 ℃± 2 ℃ and a relative humidity of 90 % to 95 % with a DC rated voltage for 1.5 hours between terminals 1 and 3 followed by a pause of 30 minutes for 1 000 h±12 h. Then the trimmer potentiometer shall be taken out from the chamber and its surface moisture shall be removed. And then the trimmer potentiometer shall be maintained at standard atmospheric conditions for 1 h ∼ 2 h without electrical load, after wihch measurement shall be made. Change in total resistance is relative to the value before test. Within ±5 % 8 Rotational Life The moving contact shall be rotated without electrical load for 20 cycles±2 cycles at a rate of 10 min-1. (A cycle of operation is defined as the travel of the moving contact from one end of the resistance element to the other and back through 90 % of the total mechanical rotation .) Change in total resistance is relative to the value before test. Within ±10 % 4. Marking Nominal total resistance ・・・・・ First number shows significant figures and the other shows quantity of zero. ex. 1 kΩ ・・・・ 13 10 kΩ ・・・・ 14 100 kΩ ・・・・ 15 Significant figures Quantity of zero 13 (1 kΩ) ③ ② ① ⑥ ⑤ ④ DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED APPROVALS H.Takabayashi M.Urayama Oct./11/’06 Oct./11/’06 DATE DATE Oct. ,11, 2006 TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 5 7 ① 5. The others 5.1. Preset Position The moving contact set half position of total rotation angle (50 %±15 % of total rotation angle) on delivery. 5.2. Application Notes ・ The soldering for this product should be reflow soldering. Please note that this product is not applicable to flow soldering. ・ Be careful with flying flux in soldering. ・ If flux was stuck on the resistance, please wash it out thoroughly by alcoholic solvent. ・ Handle the trimmer potentiometer with care. ・ This product is not what meant the use to affect the human body life which needs advanced safety and reliability, and the use of nuclear relation, and carried out design manufacture. ・ Please refer to EIAJ RCR-2191A "notes guideline(safe application guide of a potentiometer) of the potentiometer for electric devices" about notes on other use. ・ In a case where there is a wiring pattern right under this product after mounting. Please be sure to do some insuration measures on the pattern with a resist or some other materials. 5.3. The wish matter of the consideration to the safety of a product Although we are exerting our best effects to maintain the quality of this product, we cannot guarantee that they will never cause short circuiting and open circuitry. Therefore, when designing an equipment or device with which the priority is given to the safety, you will please carefully study the influences to the whole equipment of a single function failure of potentiometer in advance to make out a fail-safe design providing. 5.4. Industrial Proprietorship If the trouble on industrial proprietorship (related on delivered product s design and production) happens, we solves it on own responsibility. 5.5. Nation of products CHINA ③ ② ① ⑥ ⑤ ④ DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED H.Takabayashi Oct./11/’06 DATE Oct. ,11, 2006 APPROVALS M.Urayama Oct./11/’06 DATE TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 6 7 6. Taping Specification 6.1. 6.2. 6.3. 6.4. 6.5. Dimension ................................................ Taping direction ....................................... Peeling strength of cover tape................. Taping method......................................... Taping quantity ........................................ Dwg. No.F-362.022 Dwg. No.F-362.022 0.1 N∼0.7 N Fig.1 2 500 pcs./reel and Fig.2 Leading position 150 mm min. Vacant position 100 mm min. Non sealing 20 mm min. Chip component Vacant position 100 mm min. Fig.1 Feed direction Fig2 ③ ② ① ⑥ ⑤ ④ DRAWN N.Kurata Oct./11/’06 DATE DATE CHECKED H.Takabayashi Oct./11/’06 DATE Oct. ,11, 2006 APPROVALS M.Urayama Oct./11/’06 DATE TITLE VARIABLE RESISTOR HDK TYPE VG039NCH HDK. DWG. NO. HOKURIKU ELECTRIC INDUSTRY CO.,LTD. W-6522 REV. B 7 7 ① ⑤ ⑦ ② ⑧ ③ ⑥ ④ No. PART NAME 部品名 BASE MATERIAL 材  質 1 BOARD 基  板 CERAMIC Al2O3 セラミック (アルミナ) 2 RESISTOR 抵抗体 METAL GLAZE COATING メタルグレーズ皮膜 3 ELECTRODE 電  極 AgPd 銀パラジウム 4 1st, 3rd TERMINAL 1番, 3番 端 子 STEEL 鋼 板 ⑥ ⑤ ④ ③ ② ① UNDER PLATING Ni : 0.5∼2 μm 下地メッキ UNDER PLATING Ni : 0.5∼2 μm 下地メッキ STEEL 鋼 板 6 TERMINAL JOINT 端子接合部 SOLDER (Sn-3Ag-0.5Cu) 鉛フリー半田 7 MOVING CONTACT 摺動子 STAINLESS STEEL ステンレス 8 SEALING RESIN 封止樹脂 ACRYL アクリル系 2007.1.9 2006.12.21 訂正日/Date 浦山 M. Urayama 作成日 / Original Date 2006/8/26 高林 高林 訂 正 理 由 / Reason of Correction 高林 H. Takabayashi 写図/Drawn ② SURFACE PLATING Sn : 2 μm ∼ 4 μm 表面メッキ 下地メッキ厚変更 Correction Under Plating Thickness No.8 部品名変更 Correction Part Name No.8 承認/Approved 検図/Checked 設計/Designed ② SURFACE PLATING Sn : 2 μm ∼ 4 μm 表面メッキ 2nd TERMINAL 2番 端 子 5 ① PLATING 処  理 訂正者/Corrector 記 事 / Account 文書名 / Title 種別 / HDK TYPE 版/Rev. 使用材料表 / Material List VG039NCH B 仕様書番号 / DWG.NO. SHEET 北陸電気工業 株式会社 HOKURIKU ELECTRIC INDUSTRY CO., LTD. FF No. 3026A W-6502 1/1 適 用 品 一 覧 表 /Apprication List (適用外形寸法図/Drawing : F-362.021,F-362.022 ) 残留抵抗値/Residual Resistance Rev. 公称全抵抗値 Nominal Total Resistance B100 Ω B200 Ω B220 Ω B300 Ω B330 Ω B470 Ω B500 Ω B680 Ω B1 kΩ B2 kΩ B2.2 kΩ B3 kΩ B3.3 kΩ B4.7 kΩ B5 kΩ B6.8 kΩ B10 kΩ B20 kΩ B22 kΩ B30 kΩ B33 kΩ B47 kΩ B50 kΩ B68 kΩ B100 kΩ B200 kΩ B220 kΩ B300 kΩ B330 kΩ B470 kΩ B500 kΩ B680 kΩ B1 MΩ 抵抗値 許容差 1-2 間 2-3 間 Between Between Tolerance Terminal #1& #2 Terminal #2& #3 ±25 % 品  番 Part Number 20 Ωmax 20 Ωmax 40 Ωmax 44 Ωmax 60 Ωmax 66 Ωmax 94 Ωmax 100 Ωmax 136 Ωmax 200 Ωmax 400 Ωmax 440 Ωmax 600 Ωmax 660 Ωmax 940 Ωmax 1 kΩmax 40 Ωmax 44 Ωmax 60 Ωmax 66 Ωmax 94 Ωmax 100 Ωmax 136 Ωmax 200 Ωmax 400 Ωmax 440 Ωmax 600 Ωmax 660 Ωmax 940 Ωmax 1 kΩmax 1.36 kΩmax 1.36 kΩmax 2 4 4.4 6 6.6 9.4 10 kΩmax kΩmax kΩmax kΩmax kΩmax kΩmax kΩmax 2 kΩmax 4 kΩmax 4.4 kΩmax 6 kΩmax 6.6 kΩmax 9.4 kΩmax 10 kΩmax 13.6 kΩmax 13.6 kΩmax 20 kΩmax 20 kΩmax 備  考 Remark VG039NCHXT B101 B201 B221 B301 B331 B471 B501 B681 B102 B202 B222 B302 B332 B472 B502 B682 B103 B203 B223 B303 B333 B473 B503 B683 B104 B204 B224 B304 B334 B474 B504 B684 B105 ⑥ ⑤ ④ ③ ② ① 訂 正 理 由 / Reason of Correction 承認/Approved 検図/Checked 設計/Designed 写図/Drawn 文書名 / Title 訂正日/Date 浦山 M. Urayama 作成日 / Original Date 2006/8/28 高林 H. Takabayashi 製品規格 / Variable resistor 北陸電気工業 株式会社 HOKURIKU ELECTRIC INDUSTRY CO., LTD. FF No. 3026A 記 事 / Account 種別 / HDK TYPE 版/Rev. VG039NCHXT 仕様書番号 / DWG.NO. W-6500 SHEET 1/1 4 3 Φ3.6 D 1 2 摺動子回転範囲 Wiper Rotating Area 1.2 3 2.1 D 1.5 0.75 裏面樹脂封止 TERM.2 3.8 ( 1 ) 0.5 1.75 Resin C 0.95 2 C 0.8 TERM.3 0.65 TERM.1 2.7 B B 推奨ランドパターン寸法 (10/1) 回路図 PATTERN APPLICATION EXAMPLE (Scale 10/1) CIRCUIT C.W. TERM.1 A TERM.3 ③ ② ① 訂正箇所 TERM.2 訂 REVISION PLACE REVISION DATE 図法/ DRAWING 単位/ UNIT 第三角法 TRIGONOMETRY 1.2 1.2 訂正年月日 尺度/ SCALE mm REASON 訂正者 由 REVISION BY 処理/ DISPOSAL 材料/ MATERIAL 一般公差 0.8 1.2 3 A 種別・型名/ MODEL NAME 20/1 VG039NCH H.Takabayashi Aug.-28-'06 4 理 承認/APPROVED BY 検図/ CHECKED BY 設計/ DESIGNED BY 写図/ TRACED BY 図名/ DESCRIPTION M.Urayama 1.2 正 記事/ REMARK 1.5 0.7 1.6 Aug.-28-'06 ± 0.3 mm GENERAL TOLERANCE 作成年月日 DRAWING DATE Aug./28/ '06 2 外観図 Drawing 北 陸 電 気 工 業 株 式 会 社 HOKURIKU ELECTRIC INDUSTRY CO.,LTD. FF No.4006B 半固定可変抵抗器 Variable Resistor 図番/ DRAWING No. 版/ REV. F-362.021 1 3 4±0.1 D 4±0.1 φ1.55±0.05 1 数量:2500 個/リール 1.7 D QUANTITY:2500 pcs/REEL 0.25 4±0.1 C 4±0.1 4±0.1 3.5±0.05 (2.75) 5.5 8 2±0.1 2 1.75±0.1 4 0.07 11.4±1 C φ60 -0/+1 φ13 0.2 5. 0± 0± φ180 -3/+0 4. 0.2 9±1 B 2 B 3.0±0.2 尺度 SCALE 1/2 A ③ ② ① A 訂 正 検図 CHECKED 承認 APPROVED 浦山 M.Urayama DATE Aug.-28-'06 DATE 一般公差 GENERAL TOLERANCE ± 0.3 R E V I S I O N S 設計 DESIGNED 単位:UNIT 尺度 SCALE 高林 H.Takabayashi mm 5 1 DATE Aug.-28-'06 タイトル TITLE テーピングリール TAPING REEL 北陸電気工業株式会社 HOKURIKU ELECTRIC INDUSTRY CO.,LTD. 種別/HDK TYPE VG039NCHXT HDK 図面番号 DWG No. F-362.022 版 REV. 4 3 nner i e h to t n i el e re h t Put D ① PART No. HDK TYPE VG039NCHXT ② VALUE ohms QUANTITY ③ 2500pcs ④RoHS ⑤ DATE ⑥ Lot.No. HOLKURIKU ELECTRIC INDUSTRY CO.,LTD. PART No. HDK TYPE VG039NCHXT VALUE ohms QUANTITY 2500pcs RoHS DATE Lot.No. HOLKURIKU ELECTRIC INDUSTRY CO.,LTD. Label (The pasting place of the label shall be per the above drawing) Inner box A (A max.of 2 reels) 1 box. (2 500 pcs) C 2 Inner box B (A max.of 6 reels) Type name, Resistance value and quantity are filled in. Note 4. Outer Outer Outer Outer Outer B ①PART No. : Per customer's directions ②VALUE : Indication of the resistance value (Ex. 100) ③QUANTITY : Label for the reel ④LEADLESS SOLDER : "RoHS" ⑤Date : Indication of taping date(Ex. 02.4.18) ⑥Lot.No. : Indication of HDK manufacturing lot No.(Ex. Q-16-5-1) Packaging Specification box box box box box a b c d e D C Number of the reels put in A max of 2 reels A max of 6 reels Inner box A Inner box B Inner box Label description Number of the reels put in A max of 6 reels A max of 12 reels A max of 24 reels A max of 48 reels A max of 30 reels Total Quantity of the products 5 000 pcs. max. 15 000 pcs. max. Total Quantity of the products 15 000 pcs.max. 30 000 pcs.max. 60 000 pcs.max. 120 000 pcs.max. 75 000 pcs.max. Size (W*L*H) (Unit : mm) 290*210*90 505*210*90 400*220*180 400*220*330 390*210*225 B Note 1- Glue the label on the reel (The gluing position is per the drawing.) Note 2- Cushion material is to be put in to fill the empty space when the number of the reels in an inner box does not reach 2 or 6 respectively. Put the inner box into the outer box. Note 3- Cushion material is to be put in to fill the empty space when the total quantity in the outer box does not reach 15 000 , 30 000 , 60 000, 75 000, or 120 000 pcs. respectively. Note 4- Type name, resistance value and quantity shall be written on a inner box. Example : VG039NCHXT B 1 k ohm 15 000 ③ ② ① A H W A DRAWN CHECKED N.Kurata DATE Oct.11,2006 DATE L 4 Outer box TOLERANCE UNLESS OTHERWISE SPECIFIED ± 3 REVISIONS TITLE UNIT SCALE H.Takabayashi mm 5 1 VARIABLE RESISTOR Oct.11,2006 APPROVED DATE HOKURIKU ELECTRIC INDUSTRY CO.,LTD. 2 HDK VG039NCHXT HDK DWG No. R-2832 1 TYPE REV.
VG039NCHXTB222 价格&库存
很抱歉,暂时无法提供与“VG039NCHXTB222”相匹配的价格&库存,您可以联系我们找货
