■ Thin Film Chip Resistor — TR Series
■ Application
— Medical equipments, Military equipments
— Converters
— Consumer products
— Communication devices
— Measurement instruments
— Printers
■ Features
— Tight tolerance from ±0.01%,±0.1%, ±0.25%, ±0.5%, ±1%
— Low T.C.R. ±10ppm, ±25ppm, ±50ppm
TEL: 886-7-8116611
FAX: 886-7-8115533
E-mail: service@everohms.com
http://www.everohms.com
■ Type Dimension
TR1218
TR0402 / TR0603 /TR0805 / TR1206 /
TR1210 / TR2010 / TR2512
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
TR0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.15 ± 0.10
0.20 ± 0.10
TR0603
1.60 ± 0.20
0.80 ± 0.15
0.40 ± 0.10
0.30 ± 0.20
0.30 ± 0.10
TR0805
2.00 ± 0.20
1.25 ± 0.15
0.50 ± 0.15
0.30 ± 0.15
0.40 ± 0.15
TR1206
3.05 ± 0.10
1.60 ± 0.20
0.55 ± 0.15
0.40 ± 0.20
0.50 ± 0.20
TR1210
3.05 ± 0.10
2.50 ± 0.20
0.55 ± 0.15
0.50 ± 0.20
0.50 ± 0.20
TR2010
5.00 ± 0.20
2.50 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
TR1218
3.10 ± 0.10
4.60 ± 0.10
0.55 ± 0.05
0.40 ± 0.20
0.50 ± 0.20
TR2512
6.30 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Standard Electrical Specifications
TYPE
Rated Power
at 70℃
Max
Working
Voltage
Max Overload T.C.R.
Voltage
(PPM/℃
Resistance Range
T(±
±0.01%)
W(±
±0.05%)
±10
TR0402
0.063W
25V
50V
75V
150V
40.2Ω~42K2Ω
10Ω~100KΩ
10Ω~100KΩ
10Ω~100KΩ
10Ω~1MΩ
10Ω~1MΩ
10Ω~1MΩ
10Ω~100KΩ
10Ω~100KΩ
10Ω~100KΩ
4.7Ω~332KΩ
4.7Ω~332KΩ
4.7Ω~332KΩ
4.7Ω~4M7Ω
4.7Ω~4M7Ω
1Ω~4M7Ω
10Ω~220KΩ
10Ω~220KΩ
10Ω~220KΩ
4.7Ω~3M32Ω
4.7Ω~3M32Ω
4.7Ω~3M32Ω
±50
4.7Ω~3M32Ω
4.7Ω~3M32Ω
1Ω~3M32Ω
±10
10Ω~220KΩ
10Ω~220KΩ
10Ω~220KΩ
4.7Ω~2M74Ω
4.7Ω~2M74Ω
4.7Ω~2M74Ω
±50
4.7Ω~2M74Ω
4.7Ω~2M74Ω
1Ω~2M74Ω
±10
10Ω~499KΩ
10Ω~499KΩ
10Ω~499KΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
±50
4.7Ω~1MΩ
4.7Ω~1MΩ
1Ω~1MΩ
±10
10Ω~499KΩ
10Ω~499KΩ
10Ω~499KΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
±50
4.7Ω~1MΩ
4.7Ω~1MΩ
1Ω~1MΩ
±10
10Ω~499KΩ
10Ω~499KΩ
10Ω~499KΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
±50
4.7Ω~1MΩ
4.7Ω~1MΩ
1Ω~1MΩ
±10
10Ω~499KΩ
10Ω~499KΩ
10Ω~499KΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
4.7Ω~1MΩ
1Ω~1MΩ
±25
±25
24.9Ω~100KΩ
±50
±10
TR0805
TR1206
TR1210
TR2010
TR1218
TR2512
0.125W
0.25W
0.25W
0.5W
0.5W
0.75W
150V
200V
200V
200V
200V
200V
300V
400V
400V
400V
400V
400V
±25
±25
±25
±25
±25
±25
±50
F(±
±1%)
40.2Ω~42K2Ω
±10
0.1W
C(±
±0.25%)
D(±
±0.5%)
40.2Ω~42K2Ω
±50
TR0603
B(±
±0.1%)
24.9Ω~100KΩ
24.9Ω~100KΩ
24.9Ω~100KΩ
24.9Ω~100KΩ
24.9Ω~100KΩ
24.9Ω~100KΩ
For non-standard parts, please contact our sales dept.
Operating Temperature Range :−55℃〜+155℃.
TEL: 886-7-8116611
FAX: 886-7-8115533
■ Parts Number Explanation
■ Example:
TR
0603
B
10K
P
05
Product
Type
Size
(Inch)
Resistor
Tolerance
Resistors
Value
Package
Quantity
0402
0603
0805
1206
1210
2010
1218
2512
T:±0.01%
W:±0.05%
B:±0.1%
C:±0.25%
D:±0.5%
F:±1%
TEL: 886-7-8116611
FAX: 886-7-8115533
P、Q:Paper Taping
E:Embossed Taping
D:Packed in a Bag
01:1000PCS
02:2000PCS
04:4000PCS
05:5000PCS
10:10000PCS
20:20000PCS
40:40000PCS
50:50000PCS
TCR
Power
±10PPM
±25PPM
±50PPM
0.25W
0.5W
■ Appendix For SMD Chip Resistor
● Packaging Information
◆ For TR Series
■ Dimension
Unit: mm
7”
13”
13”
7”
10”
13”
7”
SIZE
10K/Reel
40K/Reel
50K/Reel
5K/Reel
10K/Reel
20K/Reel
5K/Reel
A
2.0±0.5
2.0±0.5
2.0±0.5
2.0±0.5
2.0±0.5
2.0±0.5
2.0±0.5
ψB
13.5±1.0
13.5±1.0
13.5±1.0
13.5±1.0
13.5±1.0
13.5±1.0
13.5±1.0
ψC
21±1.0
21±1.0
21±1.0
21±1.0
21±1.0
21±1.0
21±1.0
ψD
60±1.0
100±1.0
100±1.0
60±1.0
100±1.0
100±1.0
60±1.0
W
11.5±2.0
11.5±2.0
11.5±2.0
11.5±2.0
11.5±2.0
11.5±2.0
11.5±2.0
7”
4K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
16.0±2.0 178±2.0
TYPE
0402
0603
0805
1206
1210
2010/2512
1218
ψM
178±2.0
330±2.0
330±2.0
178±2.0
254±2.0
330±2.0
178±2.0
■ Tapping Specification
■ Dimension
Packaging
Paper Type
Unit: mm
Type
A
B
W
E
F
G
H
ψD
T
0402
0.70±0.10 1.20±0.10 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.45±0.10
0603
1.05±0.20 1.80±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.60±0.10
0805
1.55±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10 1.50
1206
1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10
1210
2.85±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10
2.0±0.1
+0.10
-0
■ Dimension
Packaging Type
4.0±0.1
Unit: mm
A
B
W
E
F
G
H
T
ψD
2010 2.80±0.20 5.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10
Embossed
Type
P
+0.10
2512 3.40±0.20 6.70±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50
1218 3.30±0.20 4.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10
TEL: 886-7-8116611
FAX: 886-7-8115533
-0
ΨD1
T1
P
1.50±0.10 0.85±0.15
1.50±0.10 0.85±0.15 4.0±0.1
1.50±0.10 0.85±0.15
■ Packing Material Data / Storage Data
■ Front & Back Lead Dimension
■ Top Adhesive Peel Off Strength:10~70g
■ Package
Inner Box Size
External Box Size
Reel
Size H(mm)
1
13
Contain
(Kpcs)
Length
(mm)
Width
(mm)
Height
(mm)
2
24
25K
180
180
60
3
36
50K
180
180
110
5
60
150K
430
200
200
10
113
300K
400
400
200
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
TEL: 886-7-8116611
FAX: 886-7-8115533
● Reliability Test and Requirement
◆ For TR Series
Test Item
Test Method
Temperature
JIS C 5201-1
Coefficient of
clause 4.8
Resistance (T.C.R)
Procedure
Requirements
TCR +155 ℃ , 25℃ is the reference temperature
Refer to Ratings
General:2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
High Power:2.5 times RCWV or Max. Overload
voltage whichever is less for 2 seconds.
±(0.5%+0.05Ω)
Short Time
Overload
JIS C 5201-1
clause 4.13
IR Reflow
Sony SS-00254
±(0.5%+0.05Ω)
Leaching
Sony SS-00254-9 260±5℃ for 30 seconds.
>95% Coverage
Soldering Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
±(0.5%+0.05Ω)
Temperature
Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃,5 cycles
±(0.5%+0.05Ω)
Electric Iron
Sony SS-00254-5
Preheating temperature:350±10℃
Electric iron preheating time:3+1/-0 sec
±(0.5%+0.05Ω)
Resistance to
Solvent
JIS C 5201-1
clause 4.29
The tested resistor be immersed into isopropyl alcohol
of 20~25℃ for 60 secs.
Then the resistor is left in the room for 48 hrs.
±(0.5%+0.05Ω)
Load Life in
Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. RCWV or Max. working voltage
whichever is less for 1000 hrs with 1.5 hrs〝ON〞and
0.5 hr〝OFF〞.
±(0.5%+0.05Ω)
Load Life
(Endurance)
JIS C 5201-1
clause 4.25
70±2℃, RCWV or Max. working voltage whichever is
±(0.5%+0.05Ω)
less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞.
Terminal Bending JIS C 5201-1
Strength
clause 4.33
Insulation
Resistance
JIS C 5201-1
clause 4.6
Bending once for 5 seconds
D: TR Series 0402、0603、0805=5mm
TR Series 1206、1210 =3mm
TR Series 1218、2010、2512、2030=2mm
±(0.5%+0.05Ω)
100V for 1 minute.
≧10GΩ
● Temperature Coefficient of Resistance test to - 55 ℃ is available on request
TEL: 886-7-8116611
FAX: 886-7-8115533
● General Information
■ Recommend Land Pattern Design
( For Reflow Soldering )
■ Dimension
Type
Unit: mm
0402
0603
0805
1206
1210
2010
1218
2512
A
0.60
0.80
1.30
2.20
2.00
3.80
2.04
4.90
B
1.60
2.40
2.90
4.20
4.40
6.60
4.24
8.10
C
0.70
1.00
1.45
1.80
2.70
2.70
4.80
3.40
Item
■ Performance Characteristics
■ Power Derating Curve
DERATING CURVE
100
Power Ratio(%)
80
60
40
155℃
60
70
80 100 120 140 160
Ambient Temperature (℃)
Power rating or current rating is in the case based on continuous full-load at ambient temperature of
70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance
with figure of derating Curve.
■ Voltage Rating or Current Rating
Resistance Range: ≧1Ω
Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working
voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula
as following:
E(RCWV)=√
√P×
×R
TEL: 886-7-8116611
E=Rated voltage(V)
P=Power rating(W)
R=Nominal resistance(Ω)
FAX: 886-7-8115533
■ Operation and Storage Temperature
MIN
MAX
Operation temperature
-55℃
70℃
Storage temperature
20℃
30℃
Storage humidity
40%
80%
■ Equipments Applicable:
Our company’s products are produced under low temperature processing applicable to IR reflow surface
mounting devices. It is comparatively not applicable to wave soldering which will possibly cause the risk
ablating the element protection layer and the front conductor and cause the drift of the resistance value and
ablation of the markings.
■ Product Testing Method:
Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch
at the back of both electrodes. Supposed different testing points or methods are requested, please advise
beforehand and customized-made production is available.
■ 0603 E-96 Multiplier Code
Code
A
Multiplier
10
CODING
XX
B
C
1
10
D
2
10
E
3
10
F
4
10
G
5
10
H
6
10
X
7
10
Y
-1
10
-2
Z
10
-3
FORMULA
2
Example: 10.2KΩ = 102 x 10 Ω =02C
X
Multiplier Code
02
C
-1
33.2Ω = 332 x 10 Ω =51X
Resistance Code
51
X
■ 0603 Standard E-96 Values and 0603 Resistance Codes
R-Value
Code
R-Value
Code
R-Value
Code
R-Value
Code
100 102 105 107
110
113
115
118
121 124 127 130 133 137
140 143 147 150 154 158 162 165
169 174
01
05
06
07
08
09
15
23
02
03
04
10
11
12
13
14
16
17
18
19
22
24
178 182 187 191 196 200
205 210 215 221 226 232 237 243
249 255 261 267 274 280 287 294
301 309
25
31
39
26
27
28
29
30
32
33
34
35
36
37
38
40
41
42
43
44
45
46
47
48
316 324 332 340 348 357
365 374 383 392 402 412 422 432
442 453 464 475 487 499
511
523
536 549
49
55
63
69
70
71
50
51
52
53
54
56
57
58
59
60
61
62
64
65
66
67
68
72
562 576 590 604 619 634
649 665 681 698 715 732 750 768
787 806 825 845 866 887 909 931
953 976
73
79
87
95
74
75
76
TEL: 886-7-8116611
77
78
80
81
FAX: 886-7-8115533
82
83
84
85
86
88
89
90
91
92
93
94
96
■ Standard Resistance Values in a Decade
Marking code:
1%: marking code, please refer to E96 and E24 data form as below
Ex: 120K, The marking code is 1203 in E24
121K, The marking code is 1213 in E96
Note: 0402 series resistor has no marking code.
Type: 0603 1% marking code, please refer to E-96 multiplier code.
E192
E96
E48
E192
E96
E48
E192
E96
E48
E192
E96
E48
E192
E96
E48
100
101
102
104
105
106
107
109
110
111
113
114
115
117
118
120
121
123
100
100
169
172
174
176
178
180
182
184
187
189
191
193
196
198
200
203
205
208
169
169
287
291
294
298
301
305
309
312
316
320
324
328
332
336
340
344
348
352
287
287
487
493
499
505
511
517
523
530
536
542
549
556
562
569
576
583
590
597
487
487
825
835
845
856
866
876
887
898
909
920
931
942
953
965
976
988
825
825
124
124
126
127
129
130
132
133
135
137
138
140
142
143
145
147
149
150
152
154
156
158
160
162
164
165
167
102
105
105
107
110
110
113
115
115
118
121
127
121
210
127
130
133
133
137
140
140
143
147
147
150
154
154
158
162
162
165
213
215
218
221
223
226
229
232
234
237
240
243
246
249
252
255
258
261
264
267
271
274
277
280
284
174
178
178
182
187
187
191
196
196
200
205
205
210
215
357
215
221
226
226
232
237
237
243
249
249
255
261
261
267
274
274
280
361
365
370
374
379
383
388
392
397
402
407
412
417
422
427
432
437
442
448
453
459
464
470
475
481
294
301
301
309
316
316
324
332
332
340
348
348
357
365
604
365
374
383
383
392
402
402
412
422
422
432
442
442
453
464
475
464
612
619
626
634
642
649
657
665
673
681
690
698
706
715
723
732
741
750
759
768
777
787
796
806
816
499
511
511
523
536
536
549
562
562
576
590
619
634
649
649
665
681
681
698
715
715
732
750
750
768
787
806
866
866
887
909
909
931
953
953
976
590
604
619
845
787
E24
E12
E6
E3
10
11
12
13
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
10
10
10
12
15
15
18
22
22
22
27
33
33
39
47
47
47
56
68
68
82
According to IEC publication 63
Revision: June 30, 2017
TEL: 886-7-8116611
FAX: 886-7-8115533
很抱歉,暂时无法提供与“TR0603D226KP0525Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.27914
- 200+0.25988
- 500+0.24063
- 1000+0.22138
- 3000+0.21176
- 6000+0.19828
- 国内价格
- 20+0.21082
- 200+0.16654
- 600+0.14192
