GENERAL THICK FILM CHIP FIXED RESISTOR
Miniature and light weight
Suit for reflow and wave flow solder
Stable electrical capability,high reliability
Low assembly cost,suit for automatic SMT equipment
Superior mechanical and frequency characteristics
RoHS
Compliant with RoHS directive
Halogen f ree requirement
R
S
03
Product
Code
Rated Power
Code
Type Code
1003
F
T
Resistance Value Code
Resistance
Tolerance Code
Packaging
Style Code
K
T.C.R Code
(E-24
Code
Rated
Power
Series
Code Type
01
C
Normal
Power
Series
Upgraded
Power
Series
Three digits (E-24 series):The
B
300
L
250
W
200
U
400
01005
0201
0201
02
0402
03
0603
05
0805
06
S
Code
Type Code
005 01005
Thick
Film
Chip
Fixed
Resistor
Tolerance
Code Packaging
B
0.1%
denotes number of zeros.
(E-96
C
0.25%
Four digits(E-96 series):The
D
0.5%
F
1%
G
2%
J
5%
first two digits are significant
Style
figures and the third one
T
first three digits are Significant
C
0402
K
100
W
200
should be expressed by "R".
Example:
U
400
C
K
100
L
250
1206
1210 1210
10
2010
12
2512
0603
0805
1206
1210
2010
2512
figures and the four one
R
Decimal point
103 =10k
(E-24)
1003=100k (E-96)
1R0 =1.0
(E-24)
K
1
10%
C
Tape
Reel
Case
Ceramic Substrate
Bottom Electrode
Top Electrode
Resistor Layer
Primary Overcoat
Secondary Overcoat
Edge Electrode
Barrier Layer
External Electrode
Dimensions(mm)
Type
L
a
t
W
b
01005
0201
0.40
0.02
0.20
0.02
0.13
0.03
0.10
0.03
0.10
0.03
0.60
0.03
0.30
0.03
0.23
0.03
0.15
0.05
0.15
0.05
0402
1.00
0.10
0.50
0.10
0.30
0.10
0.20
0.10
0603
1.60
0.15
0.80
0.15
0.40
0.10
0.30
0.20
0.25 0.10
0.30 0.20
0805
2.00
0.20
1.25
0.15
0.50
0.10
0.30
0.20
0.40
0.20
1206
1210
3.20
3.20
0.20
0.20
1.60
2.50
0.15
0.20
0.55
0.55
0.10
0.10
0.50
0.50
0.20
0.20
0.50
0.50
0.20
0.20
2010
5.00
0.20
2.50
0.20
0.55
0.10
0.60
0.20
0.60
0.20
2512
6.40
0.20
3.20
0.20
0.55
0.10
0.60
0.20
0.60
0.20
100
-55
70
Operating
Temperature
Range:
-55 ~125
Operating
Temperature
Range:
-55 ~155
75
Percent Rated Load
50
25
-50
-25
75
50
100
Ambient temperature(
125
155
1
01005 0201
0402 0603 0805 1206 1210 2010 2512
Note 1 01005 0201 product be the same with curve
0402 0603 0805 1206 1210 2010 2512 be the same with curve .
2
70
Note 2 For resistors operated in ambient over 70 ,rated load (rated power) shall be derated in accordance with the above figure.
70
Rated Power at 70
Limiting Element Voltage
Max. Overload Voltage
(V)
(V)
(W)
Type
01005
0201
0402
0603
0805
1206
1210
2010
2512
Normal Power
Series
Upgraded Power
Series
Normal Power
Series
Upgraded Power
Series
Normal Power
Series
Upgraded Power
Series
1/32
1/20
1/16
1/16
1/10
1/8
1/4
1/2
1
1/10
1/8
1 /4
1/3
3 /4
15
25
50
50
100
200
200
200
200
50
150
200
200
200
30
50
100
100
200
400
400
400
400
100
300
400
400
400
1
2
Note
Voltage of DC or AC RMS value.
E=
E=
or Limiting element voltage whichever is lower.
E
Rated voltage(V)
P
Rated power(W)
R
Normal resistance( )
2
T.C.R(ppm/ )
Type
01005
10
100
1
0201
10
1M
1
0402
10
1M
0603 0805
1206 1210
2010 2512
Resistance Tolerance
Resistance
Range
1
10
1M
0.1%
0.25%
0.5%
1%
2%
5%
10%
300
300
300
R 100
300
R 1M
250
250
250
250
R 10
400
400
400
400
200
200
200
200
400
400
400
400
R 1M
R 10M
R 10
R 1M
100 or
R
400
400
400
400
10M
R 10
R 1M
100
R 10M
200
100 or
400
400
400
200
200
100 or
200
100 or
400
200
100 or
250
250
250
250
250
100
100
100
100
100
100
250
250
250
250
250
250
200
T.C.R(ppm/ )
Type
0402
0603 0805
1206 1210
2010 2512
Resistance
Range
100
10
1M
0.1%
R 1M
R 1M
R 10M
Solderability
95%
95% Cover Min
Resistance to
Soldering Heat
No mechanical damage
R
(1.0%R+0.05 )
Substrate
Bending Test
R
(1.0%R+0.05 )
Rapid Change of
Temperature
0.05
0.5% 1%
0.05 )
0.05
1%
(IEC 60115-1)
Test Methods (IEC 60115-1)
Specifications
01005:
R
(1.0%R
Others:
0.1% 0.25%
R
(0.5%R
2% 5% 10%
R
(1.0%R
0.5%
Item
Shear Test
0. 5%
IEC 60115-1 4.17
245
5
3s 0.3s.
Lead-free solder bath at 245
5
IEC 60115-1 4.18
270
5
10s 1s.
Lead-free solder bath at 270
5
IEC 60115-1 4.33
(Bending distance)
01005 3mm 0201 0402 0603
1206 1210 4mm
2010
(Duration):60s 5s.
for 3s 0.3s.
for 10s 1s.
0805 5mm
2512 2mm .
IEC 60115-1 4.32
(Applying force):0201:2N 0402
1206 1210 25N 2010 2512 45N.
(Duration):10s 1s.
0603: 5N
0805 9N
IEC 60115-1 4.19
01005 0201 -55 (30
(5
) 125 (30
) 300
01005 0201 -55 (30min) normal temperature(5min)
125 (30min),300 cycles;
0402 0603 0805 1206 1210 2010 2512 -55 (30
(5
) 155 (30
) 300
0402 0603 0805 1206 1210 2010 2512 -55 (30min)
normal temperature(5min) 155 (30min) 300cycles.
3
Continue
Item
(IEC 60115-1)
Specifications
IEC 60115-1 4.8
+20 /-55 /+20 /+125 /+20
Within specified T.C.R
T.C.R
Short Time
Overload
01005:
R
(2.0%R 0.05 )
Others:
0.1% 0.25% 0.5% 1%
R
(1.0%R 0.05 )
2% 5% 10%
R
(2.0%R 0.05 )
IEC 60115-1 4.13
2.5
5
2.5 times rated voltage or max. overload voltage whichever is
lower for 5 s.
IEC 60115-1 4.39
Intermittent
Overload
Damp Heat,
Steady State
Endurance
at 70
R
(5.0%R+0.05 )
01005: R
(3.0%R 0.05
Others:
lower for 1s ON/ 25s OFF 10000 cycles.
0.1% 0.25% 0.5% 1%
R
(1.0%R 0.05
2% 5% 10%
R
(2.0%R 0.05
40
2 ,93% 3%RH,1000h,rated voltage or limiting element voltage
whichever is lower for 1.5h ON/0.5h OFF.
01005: R
(3.0%R 0.05
Others:
IEC 60115-1 4.25.1
2
1000
1.5
0.5
70
2
1000h rated voltage or limiting element voltage
) 70
0.1% 0.25% 0.5% 1%
R
(1.0%R 0.05
2% 5% 10%
R
(2.0%R 0.05
IEC 60115-1 4.24
40
2
93% 3%RH 1000
Endurance
at Upper
Category
Temperature
01005: R
Others:
(3.0%R 0.05
) IEC 60115-1 4.25.3
01005 0201 125
2
1000h.
0402 0603 0805 1206 1210 2010 2512 155
0.1% 0.25% 0.5% 1%
R
(1.0%R
2% 5% 10%
R
(2.0%R
0.05
0.05
Operation at
Low
Temperature
01005: R
Others:
(2.0%R
0.05
0.1% 0.25% 0.5% 1%
R
(1.0%R 0.05
2% 5% 10%
R
(2.0%R 0.05
2
1000h.
IEC 60115-1 4.36
-55
5
-55
5 , 1h without load rated voltage or limiting element
voltage whichever is lower for 45min, 15min without load.
IEC 60115-1 4.6
1000M
Insulation
Resistance
Min
Voltage Proof
No breakdown or
flashover
Component
Solvent
Resistance
R
(1.0%R 0.05 )
83
90
Apply DC 100V 15V between substrate and terminations for
1min, then check insulation resistance.
IEC 60115-1 4.7
Apply max. overload voltage of AC RMS at a rate of approximately
100V/s between substrate and terminations for 60s 5s.
IEC 60115-1 4.29
(IPA) 23
5
Iso-propyl alcohol (IPA)
Packaging see the 83-90 Page .
4
10
23
5
10h.
PACKAGING AND PRECAUTION OF CHIP RESISTOR
Chip fixed resistor
C
A
B
unit: mm
unit: mm
Thick Film Resistor and
Thin Film Resistor
Type
01005
0201
0402
0603
0805
1206
1210
2010
2512
A
0.17
0.23
0.45
0.80
1.05
1.90
2.00
3.50
4.80
B
0.60
0.84
1.45
2.50
3.25
4.50
4.60
6.50
7.80
Metal Foil Resistor
Type
C
0.22
0.38
0.60
0.95
1.40
1.75
2.70
2.70
3.40
0603
0805
1206
2010
2512
R003~R004
R005~R030
R003~R004
R005~R047
R003~R004
R005~R068
R003~R009
R010~R100
R002~R004
R005~R200
A
0.4
0.6
0.5
0.8
0.8
1.8
1.6
2.7
1.0
3.8
B
C
2.8
1.0
3.2
1.4
4.4
1.8
6.3
2.9
8.0
3.4
Thick film chip network resistor
A B
Q1
Q2
Q3
Q2
Q3
Q2
Q1
RCMY08 / RCMT08 / RCML08
unit: mm
A
B
Q1
Q2
Q3
RCMY08
0.30
0.90
0.20
0.20
0.20
RCMT08
0.38
1.60
0.40
0.20
0.30
RCML08
0.80
2.70
0.60
0.40
0.40
Type
83
Paper Taping
01005 0201 0402 RCMY08 RCMT08
For 01005 0201 0402 RCMY08 RCMT08
unit: mm
Type
A
B
W
F
E
01005
0.45 0.02
0.25 0.02
8.00 0.02
3.50 0.05
1.75 0.05
0201
0.70 0.10
0.40 0.10
8.00 0.20
3.50 0.05
1.75 0.10
0402
1.20 0.10
0.70 0.10
8.00 0.20
3.50 0.05
1.75 0.10
RCMY08
1.57 0.05
0.77 0.05
8.00 0.20
3.50 0.05
1.75 0.10
RCMT08
2.20 0.10
1.20 0.10
8.00 0.20
3.50 0.05
1.75 0.10
unit: mm
Type
P
P0
P1
D0
T1
T
01005
2.00 0.05
4.00 0.10
2.00 0.05
1.55 0.02
0.17 0.02
0.31 0.02
0201
2.00 0.05
4.00 0.10
2.00 0.05
1.50 0.10
0.28 0.04
0.42 0.05
0402
2.00 0.05
4.00 0.10
2.00 0.05
1.50 0.10
0.42 0.05
RCMY08
2.00 0.05
4.00 0.10
2.00 0.05
1.50 0.10
0.60 0.10
RCMT08
2.00 0.10
4.00 0.10
2.00 0.05
1.50 0.10
0.60 0.10
0603 0805 1206 1210 RCML08:
For 0603 0805 1206 1210 RCML08:
84
unit: mm
Type
B
A
W
F
E
0603
1.85 0.10
1.10 0.10
8.00 0.20
3.50 0.05
1.75 0.10
0805
2.35 0.10
1.65 0.10
8.00 0.20
3.50 0.05
1.75 0.10
1206
3.50 0.20
1.90 0.20
8.00 0.20
3.50 0.05
1.75 0.10
1210
3.50 0.20
2.80 0.20
8.00 0.20
3.50 0.05
1.75 0.10
RCML08
3.50 0.20
1.90 0.20
8.00 0.20
3.50 0.05
1.75 0.10
unit: mm
T
Type
P0
P
D0
P1
Thin Film Resistor
Metal Foil Resistor
0603
4.00
0.10
4.00
0.10
2.00
0.05
1.50
0.10
0.60
0.10
0.75
0.10
0805
4.00
0.10
4.00
0.10
2.00
0.05
1.50
0.10
0.75
0.10
0.95
0.10
1206
4.00
0.10
4.00
0.10
2.00
0.05
1.50
0.10
0.75
0.10
0.95
0.10
1210
4.00
0.10
4.00
0.10
2.00
0.05
1.50
0.10
0.75
0.10
RCML08
4.00
0.10
4.00
0.10
2.00
0.05
1.50
0.10
0.75
0.10
Embossed Taping
2010 2512
For 2010 2512
unit: mm
W
B0
A0
Type
t
E
F
2010
5.50
0.15
2.82
0.15
12.00
0.10
5.50
0.10
1.75
0.10
0.25
0.05
2512
6.78
0.15
3.45
0.15
12.00
0.10
5.50
0.10
1.75
0.10
0.25
0.05
unit: mm
K0
Type
P
P0
D0
P1
D1
Thin Film Resistor
Metal Foil
Resistor
2010
4.00 0.10
4.00
0.10
2.00
0.05
1.50+0.10/-0 1.50
0.10
0.84
0.10
0.84
0.10
2512
4.00 0.10
4.00
0.10
2.00
0.05
1.50+0.10/-0 1.50
0.10
0.81
0.10
1.00
0.10
85
Reel
unit: mm
M
W
01005 0201
0402 0603
0805 1206
1210 RCMY08
RCMT08 RCML08
178 2.0
9.5 1.0
2010 2512
178 2.0
13.0 0.5
Type
A
B
C
D
12.5 1.5
2.0 0.5
13.0 0.5
21.0 0.5
58.0 2.0
15.5 1.5
2.0 0.5
13.0 0.5
21.0 0.5
57.0 2.0
T
Packaging Quantity
Tape & reel
Packaging style
W
M
Type
Quantity(pcs)
178
178
01005
2.0
E-24
0201 0402
RCMY08
RCMT08
20000
10000
9.5
unit 0.001
1.0
1.1
2.0
1.2
1.3
g Quantity
0.01
0.1
2010
2512
5000
4000
12.5
1
10
100
2.2
1.6
0.52.7
2.0
A
0603 0805
1206
RCMY08 RCMT08
RCML08
01005
0201
0402
50000
10000
2.0
1.5
1210
2010
2512
4000
0.5
1
1.5
13.0
1.8
T
0603 0805
1206 1210
RCML08
1.0
E-24 series( 10 n
Case
2.4
1k
10k
100k
1M
3.3
15.53.6
1.5
3.9
3.0
4.3
86
10M
100M
4.7
5.1
5.6
6.2
1000M )
6.8
2.0
7.5
0.5
8.2
9.1
1
E-96
10 n
E-96 series (
unit 0.001
0.01
0.1
1
10
100
1k
10k
100k
1M
10M
100M
1000M )
1.00
1.33
1.78
2.37
3.16
4.22
5.62
7.50
1.02
1.37
1.82
2.43
3.24
4.32
5.76
7.68
1.05
1.40
1.87
2.49
3.32
4.42
5.90
7.87
1.07
1.43
1.91
2.55
3.40
4.53
6.04
8.06
1.10
1.47
1.96
2.61
3.48
4.64
6.19
8.25
1.13
1.50
2.00
2.67
3.57
4.75
6.34
8.45
1.15
1.54
2.05
2.74
3.65
4.87
6.49
8.66
1.18
1.58
2.10
2.80
3.74
4.99
6.65
8.87
1.21
1.62
2.15
2.87
3.83
5.11
6.81
9.09
9.31
1.24
1.65
2.21
2.94
3.92
5.23
6.98
1.27
1.69
2.26
3.01
4.02
5.36
7.15
9.53
1.30
1.74
2.32
3.09
4.12
5.49
7.32
9.76
E 96
0603
E-96 series(0603) multiplied Cross-reference List and Resistance Cross-reference List
multiplied
code
Code
10 0
10 1
10 2
10
A
B
C
D
E-96
E-96 resistance
3
10 4
10 5
10 6
10 7
10 -1
10 -2
10 -3
E
F
G
H
X
Y
Z
Code
E-96
E-96 resistance
Code
E-96
E-96 resistance
Code
E-96
E-96 resistance
01
100
25
178
49
316
73
02
102
26
182
50
324
74
576
03
105
27
187
51
332
75
590
562
04
107
28
191
52
340
76
604
05
110
29
196
53
348
77
619
06
113
30
200
54
357
78
634
07
115
31
205
55
365
79
649
08
118
32
210
56
374
80
665
09
121
33
215
57
383
81
681
10
124
34
221
58
392
82
698
11
127
35
226
59
402
83
715
12
130
36
232
60
412
84
732
13
133
37
237
61
422
85
750
14
137
38
243
62
432
86
768
15
140
39
249
63
442
87
787
16
143
40
255
64
453
88
806
17
147
41
261
65
464
89
825
18
150
42
267
66
475
90
845
19
154
43
274
67
487
91
866
44
280
68
499
92
887
21
162
45
287
69
511
93
909
22
165
46
294
70
523
94
931
23
169
47
301
71
536
95
953
24
174
48
309
72
549
96
976
87
Description for Resistance Value Code and Marking of Thick Film Chip Resistor
All the resistance value code of thick film chip resistor is corresponding with the marking .
Marking
E-24
(0603
5%)
10
E-24 series: Express resistance value on the glass side with three digits, the first tow digits
should be significant and the third one denote number of zeros.
10K
For example:
33
E-24
(0603
1%& 0.5%)
E-24 series(0603
1%& 0.5%): One short bar under marking letter.
For example:
E-96
E24
1%&
0.5%
0805 1206 1210 2010 2512 4R02 4R03
E-96 series & E-24 series:For the dimension type of 0805 1206 1210 2010 2512 4R02
4R03 express the resistance value with four digits, the first three digits are significant figures
and the fourth de notes the number of zeros.
For example:
133
100K
E-96
0603
E-96
For the dimension type of 0603, express the resistance value with three code, the first two digit
code denote the resistance of E-96 series, and the third code of letter denote the multiplier
(see the table three and four ).
For example:
R
2M
The decimal point should be expressed by R
For example:
5.6
The jumper should be expressed by
For example:
01005 0201 0402
on the glass side.
For the dimension type of 01005 0201
0402 there is no mark
For example:
IEC
IEC E24
For the resistance which don't belong to IEC serial, use the resistance of IEC serial which is most
close to the required resistance of non-IEC serial for replacement.
To get agreement by both party if there special requirement for the marking.
88
Description for Resistance Value Code and Marking of Thin Film Chip Resistor
0201 0402 0603 0805 1206 1210 2010 2512
All resistance value code of thin film chip resistor,including 0201
0402 0603 0805 1206
1210 2010 2512 size used four digits.
Example
TD03G4701BT
4701=4.7K
1R50=1.5
To use four digits code represent resistance value ,
Example 4701=4.7K
1R50=1.5
Marking
E24 E96
E96
When resistance value belongs to E24 as well as E96 series, we suggest preferentially use E96 series.
Example 10K=1002,
103
Marking for 0805 1206 1210 2010 2512 Size Resistor
For 0805 1206 1210 2010 2512 size resistor , express the resistance value with four digits code;
Example
100K
0603
Marking for 0603 Size Resistor
0603-E96
For resistance value belongs to E96 series, express the resistance value with three digits code.
Example
2M
0603-E24
For resistance value belongs to E24 series, express the resistance value with three digits code.
Example
10K
The decimal point should be expressed by "R" .
Example
5.6
0201 0402
For the dimension type of 0201 0402 there is no mark on the glass side.
Example
89
1
2
3
4
5
6
7
1 Use in various types of liquid, including water, oils, chemicals, and organic solvents.
2 Use outdoors where the products are exposed to direct sunlight, or in dusty places.
3 Use in places where the products are exposed to sea winds or corrosive gases, including Cl2, H2S, Nh3,
SO2, and No2 etc.
4 Use in places where the products are exposed to static electricity or electromagnetic waves.
5 Use in proximity to heat-producing components, plastic cords, or other flammable items.
6 Use involving sealing or coating the products with resin or other coating materials.
7 Use involving unclean solder or use of water or water-soluble cleaning agents for cleaning after soldering.
1
2
3
4
5
30
30%
70%
1 Avoid applying power exceeding normal rated power, exceeding the power rating under steady-state
loading condition may negatively affect product performance and reliability.
2 Be careful when pick up the products with tweezers. There may be a care that the overcoat and / or
the body
can be chipped.
3 Soldering tip shall not touch the product when install product manually.
4 Storage conditions: T 5
30
, RH 30%
70%.
Recommended wave solder profile
Recommended reflow profile
Recommended solder alloy
96.5Sn/3.0Ag/0.5Cu
90
很抱歉,暂时无法提供与“RC-01W430JT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.00454
- 1000+0.00346
- 3000+0.00292
- 国内价格
- 100+0.00416
- 3000+0.00267
- 6000+0.00264
- 15000+0.00259
