RMC 0805 2M J N
RMC 0805 2M J N
    TYOHM(幸亚电阻)
    贴片电阻 0805
RMC 0805 2M J N 数据手册
RMC series THICK FILM CHIP RESISTORS Features 1. Miniature size can compact P.C. Board, 2. 8mm tape carrier packaging available for automatic surface mounting. 3. Excellent mechanical strength and electrical stability. 4. Reducing assembly costs. 1. 2. 8mm 3. 4. ELECTRICAL AND MECHANICAL PERFORMANCE Characteristics Resistance Tolerance Resistance Temp. Coeff. Power Rating Load Short Time Overload Dielectric Withstanding Voltage Insulation Resistance Test Methods Standards 5% ( J ) or - 1% ( F ) 1MÙ 200ppm/ Surface temp 155 Max. 155 , R/R -55 1% ~ 155 Rated voltage for 30 minutes / 30 2.5 times of rated voltage for 5 seconds. 2.5 /5 1% No evidence of mechanical damage or insulation breakdown. 1,000MÙ Max. Overload Voltage for 1 min. 1 DC 100V megger Minimum 95% coverage 95% No evidence of mechanical damage. Resistance to Soldering Heat , R/R 1% Solder-ability 245 5 for 2 seconds 270 5 for 10 1 seconds ENVIRONMENTAL CHARACTERISTICS Characteristics Standards Temp. Cycle R/R 0.5% Load Life R/R 1% Moisture-proof Load Life R/R 1% Reference Standards IEC 60115-8 JIS C 5201-8 5 Test Methods -55 ( 30 min.) Room Temp.( 3 min.) +155 ( 30 min.) Room Temp.( 3 min.) / ( 5 cycles) Rated power load 90 minutes ON 30 minutes OFF 70 1000 hours Rated power load 90 minutes ON 30 minutes OFF 40 95% RH 500 hours RMC series Dimensions Unit mm L c W t Dimension(mm) Rated Wattage CODE L 0.2 W 0.2 C 0.2 d 0.2 t 0.1 1.0 0.1 0.5 0.05 0.2 0.1 0.25 0.1 0.35 0.05 Max. Resistance Working Range(Ù) Voltage 50V 1~10M 0.45 50V 1~10M 0.4 0.5 150V 1~10M 0.5 0.5 0.6 200V 1~10M 2.5 0.6 0.5 0.6 200V 1~10M 3.2 0.6 0.5 0.6 200V 1~10M 0402(1005) 1/16W 0603(1608) 1/10W 1.6 0.8 0.3 0.3 0805(2012) 1/8W 2.0 1.25 0.4 1206(3216) 1/4W 3.2 1.6 2010(5025) 1/2W 5.0 2512(6332) 1W 6.3 d Note: 1. Max. Overload Voltag is 2 times of Max. Working Voltage 2. Zero ohm is also supplied ( 50 mÙ Max.) 3. Too low or too high ohmic values can be supplied only case by case. Rate Continuous Working Voltage ( RCWV ) shall be determined Rated Power X Resistance Value or Max. Working Voltage listed above, whichever less. Derating Curve Surface Temperature Rise For resistors operated in ambient temperatures above 70 , power rating must be derated in accordance with the curve below. -55 70 Surface Temperature Rise (OC) 100 Rated Load (%) 80 60 40 20 155 0 -40 0 40 80 120 150 160 200 100 50 240 0 Ambient Temp. (OC) 0 20 40 60 80 100 Rated Load (%) How to order It is composed by Type, Code Number, Nominal Resistance, Tolerance, Terminal Surface Material. e.g. RMC a. a. Type( 0603 b. 1K c. 5% d. N e. ): Thick Film Chip Resistors are called "RMC". b. Code Number( ): There are 0402, 0603, 0805, 1206, 2010, 2512. c. Nominal Resistance( d. Tolerance( ): ) : 1K. 5% . e. Terminal Surface Material( ) 6 N (RoHS Compliant)
RMC 0805 2M J N
1. 物料型号:RMC系列,包括多种尺寸,如0402(1005)、0603(1608)、0805(2012)、1206(3216)、2010(5025)和2512(6332)。
2. 器件简介:这些电阻器具有小型化尺寸,适合紧凑型PCB设计,并且支持8mm胶带载体包装,适用于自动表面贴装。
3. 引脚分配:文档中没有明确提到引脚分配,但通常这类电阻器是无引脚的表面贴装元件。
4. 参数特性: - 阻值容差:±5%(J)或±1%(F) - 温度系数:不同阻值范围有不同的温度系数 - 额定负载:最高表面温度155°C,额定电压30分钟 - 短时间过载:2.5倍额定电压5秒 - 耐电压:无机械性能损坏及绝缘击穿现象 - 绝缘电阻:1,000MΩ - 焊锡性:焊锡面积≥95% - 浸锡耐热性:无机械性能损坏现象,阻值变化≤±1%
5. 功能详解:文档中没有提供具体的功能详解,但根据参数特性可以推断这些电阻器具有优秀的机械强度和电气稳定性,有助于降低组装成本。
6. 应用信息:适用于需要小型化和自动化贴装的应用场景。
7. 封装信息:提供了不同尺寸的封装信息,包括额定功率、尺寸、最大工作电压和电阻范围。
RMC 0805 2M J N 价格&库存
很抱歉,暂时无法提供与“RMC 0805 2M J N”相匹配的价格&库存,您可以联系我们找货
