■ High voltage Chip Resistor — HR Series
■ Application
─ Power supply
─ Automotive industry
─ Measurement instrument
─ Back light inverter
─ Medical or Military equipment
■ Features
─ Special material and design for high working voltage require
─ Compatible with flow and reflow soldering
─ Suitable for lead free soldering
─ High limiting voltage
TEL: 886-7-8116611
FAX: 886-7-8115533
E-mail: service@everohms.com
http://www.everohms.com
■ Type Dimension
■ Dimension
Unit: mm
TYPE
L
W
H
l1
l2
HR0402
1.00 ± 0.10
0.50 ± 0.05
0.30 ± 0.05
0.15 ± 0.10
0.20 ± 0.10
HR0603
1.60 ± 0.20
0.80 ± 0.15
0.40 ± 0.10
0.30 ± 0.20
0.30 ± 0.10
HR0805
2.00 ± 0.20
1.25 ± 0.15
0.50 ± 0.15
0.30 ± 0.15
0.40 ± 0.15
HR1206
3.05 ± 0.10
1.60 ± 0.20
0.55 ± 0.15
0.40 ± 0.20
0.50 ± 0.20
HR1210
3.05 ± 0.10
2.50 ± 0.20
0.55 ± 0.15
0.50 ± 0.20
0.50 ± 0.20
HR2010
5.00 ± 0.20
2.50 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
HR2512
6.30 ± 0.20
3.20 ± 0.20
0.55 ± 0.10
0.60 ± 0.20
0.60 ± 0.20
■ Standard Electrical Specifications
Item
Type
HR0402
HR0603
HR0805
HR1206
HR1210
HR2010
HR2512
Rated Power
at 70℃
Max Working Voltage
0.063W
100V
0.1W
0.125 W
0.25 W
0.33 W
0.5 W
1W
200 V
400 V
500V
500V
500V
800V
For non-standard parts, please contact our sales dept.
Operating Temperature Range :−55℃〜+155℃.
TEL: 886-7-8116611
FAX: 886-7-8115533
Max Overload Voltage
T.C.R.
(PPM/℃
Resistance Range
F(±
±1%) G(±
±2%) J±
±(5%)
±300
100Ω~990Ω
±200
1KΩ~10MΩ
±200
47Ω~98.8Ω
±100
100Ω~51MΩ
±200
47Ω~98.8Ω
±100
100Ω~51MΩ
±200
47Ω~98.8Ω
±100
100Ω~51MΩ
±200
47Ω~549Ω
±100
560Ω~51MΩ
±200
47Ω~549Ω
±100
560Ω~51MΩ
±500
47Ω~98.8Ω
±200
100Ω~549Ω
±100
560Ω~51MΩ
200V
400 V
800 V
1000 V
1000 V
1000 V
1600 V
■ Parts Number Explanation
■ Example:
HR
0603
J
100R
P
05
Product Type
Size
(Inch)
Resistor
Tolerance
Resistors
Value
Package
Quantity
0402
0603
0805
1206
2010
2512
TEL: 886-7-8116611
F:±1%
G:±2%
J:±5%
FAX: 886-7-8115533
P、Q:Paper Taping
E:Embossed Taping
D:Packed in a Bag
01:1000PCS
02:2000PCS
04:4000PCS
05:5000PCS
10:10000PCS
20:20000PCS
40:40000PCS
50:50000PCS
Appendix For SMD Chip Resistor
● Packaging Information
■ Dimension
Unit: mm
TYPE
0402
SIZE
A
ψB
ψC
ψD
W
ψM
7”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
13”
40K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
13”
50K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
0603
0805
1206
1210
7”
5K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
11.5±2.0
178±2.0
10”
10K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
254±2.0
13”
20K/Reel
2.0±0.5
13.5±1.0
21±1.0
100±1.0
11.5±2.0
330±2.0
2010
2512
7”
4K/Reel
2.0±0.5
13.5±1.0
21±1.0
60±1.0
16.0±2.0
178±2.0
TEL: 886-7-8116611
FAX: 886-7-8115533
Tapping Specification
■ Dimension
Packaging
Unit: mm
Type
A
B
W
E
F
G
H
ψD
T
0402
0.70±0.10 1.20±0.10 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.45±0.10
0603
1.05±0.20 1.80±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.60±0.10
P
2.0±0.1
+0.10
Paper Type
0805
1.55±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
1206
1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05
4.0±0.10
2.0±0.05 0.75±0.10 1.50
-0
2.0±0.05 0.75±0.10
1210
2.85±0.2 3.50±0.2
4.0±0.1
2.0±0.05 0.75±0.1
8.0±0.2
1.75±0.1 3.5±0.05
4.0±0.1
■ Dimension
Packaging
Embossed
Type
Type
2010
Unit: mm
A
B
2.80±0.20 5.60±0.20
W
12±0.10
E
F
1.75±0.10 5.5±0.05
G
4.0±0.10
H
T
ψD
ΨD1
T1
+0.10
1.50±0.10 0.85±0.15
-0
1.50±0.10 0.85±0.15
2.0±0.05 0.23±0.10
1.50
2512
3.40±0.20 6.70±0.20
TEL: 886-7-8116611
12±0.10
1.75±0.10 5.5±0.05
FAX: 886-7-8115533
4.0±0.10
2.0±0.05 0.23±0.10
P
4.0±0.1
Packing Material Data/Storage Data
■ Front & Back Lead Dimension
Top Adhesive Peel Off Strength:
:10~70g
Package
Inner Box Size
Reel Size H(mm)
External Box Size
Contain Length Width Height
(Kpcs)
(mm)
(mm) (mm)
1
13
2
24
25K
180
180
60
3
36
50K
180
180
110
5
60
150K
430
200
200
10
113
300K
400
400
200
■ Storage Data:
Storage time at the environment temp: 25±5℃& humidity:60±20% is valid for one year from the date of delivery.
TEL: 886-7-8116611
FAX: 886-7-8115533
Reliability Test and Requirement
Test Item
Test Method
Temperature
JIS C 5201-1
Coefficient of
clause 4.8
Resistance (T.C.R)
Procedure
Requirements
-55℃ or +155℃, 25℃ is the reference temperature
Refer to Ratings
General:2.5 times RCWV or Max. Overload voltage
whichever is less for 5 seconds.
High Power:2.5 times RCWV or Max. Overload
voltage whichever is less for 2 seconds.
±1:±(1.0%+0.05Ω)
±5:±(2.0%+0.10Ω)
Short Time
Overload
JIS C 5201-1
clause 4.13
IR Reflow
Sony SS-00254
±1:±(1.0%+0.05Ω)
±5:±(1.0%+0.05Ω)
Leaching
Sony SS-00254-9 260±5℃ for 30 seconds.
>95% Coverage
Soldering
Heat
JIS C 5201-1
clause 4.18
260±5℃ for 10 seconds.
±1:±(0.5%+0.05Ω)
±5:±(1.0%+0.05Ω)
Temperature
Cycling
JIS C 5201-1
clause 4.19
-55℃ to +155℃,5 cycles
0.1%、0.5%、1%: ±(0.5%+0.05Ω)
2%、5%:±(1.0%+0.10Ω)
Electric Iron
Sony SS-00254-5
Preheating temperature:350±10℃
Electric iron preheating time:3+1/-0 sec
±1:±(1.0%+0.05Ω)
±5:±(1.0%+0.05Ω)
Resistance to
Solvent
JIS C 5201-1
clause 4.29
The tested resistor be immersed into isopropyl alcohol
of 20~25℃ for 60 secs. Then the resistor is left in the
room for 48 hrs.
±1:±(0.5%+0.05Ω)
±5:±(0.5%+0.05Ω)
Load Life in
Humidity
JIS C 5201-1
clause 4.24
40±2℃, 90~95% R.H. RCWV or Max. working voltage
whichever is less for 1000 hrs with 1.5 hrs〝ON〞and
0.5 hr〝OFF〞.
0.1%、0.5%、1%:±(1.0%+0.05Ω)
2%、5%:±(2.0%+0.05Ω)
Value
很抱歉,暂时无法提供与“HR2512F240KE04Z”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83139
- 50+0.65729
- 150+0.57014
- 500+0.50480
- 2500+0.45252
