TR0603D62R0P0510Z
TR0603D62R0P0510Z
    EVEROHMS(天二)
    贴片电阻 0603
TR0603D62R0P0510Z 数据手册
Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 1/9 TR Series Thin Film Chip Resistor Product Specifications ■ Thin Film Chip Resistor Product Specifications — TR Series Top view Bottom view ■ Applications █ Features — Consumer electronics — Tolerance to ±0.1 % — Computer — Low TCR to ±10 ppm/℃ — Telecom — Halogen free and lead free — Measuring instrument — RoHS compliant — Printing equipment — Converter ■ Parts Number Explanation ■ Example: TR 1206 B 10K0 P 05 25 Z Product Type Size (Inch) Tolerance Resistance Package Quantity (PCS) TCR (ppm/℃) Optional TR Series Thin Film Chip Resistor 0402 0603 0805 1206 1210 2010 2512 B:±0.1% C:±0.25% D:±0.5% F:±1% 4 digits EX. 1R00 = 1 Ω 10R0 = 10 Ω 100R = 100 Ω 2K20 = 2.2 KΩ 332K = 332 KΩ 1M00 = 1 MΩ P、Q:Paper Taping E:Embossed Taping B:Bulk 04:4000 05:5000 10:10000 20:20000 40:40000 50:50000 10:±10 15:±15 25:±25 50:±50 Z : default code TR Series Thin Film Chip Resistor Product Specifications Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 2/9 ■ Standard Electrical Specifications 項目 Item 型別 Type TR0402 TR0603 TR0805 額定功率 Rated Power at 70℃ 0.063W 0.1W 0.125W TR1206 0.25W TR1210 0.25W 阻值範圍 最大工作電壓 Max Working Max Overload Voltage Voltage 25V 75V 150V 200V TR2010 TR2512 最大過負載電壓 50V 150V 300V 400V 0.5W 0.75W ● For non-standard parts, please contact our sales dept. ● Operating Temperature Range :−55℃〜+155℃. Resistance Range 溫度係數 T.C.R. (PPM/℃) ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 ±10 ±15 ±25 ±50 B (±0.1%) C (±0.25%) D (±0.5%) F (±1%) 10Ω ~ 10KΩ (10.1KΩ~68KΩ developing) 4.7Ω ~ 10KΩ 1Ω ~ 10KΩ (10.1KΩ~220KΩ developing) (10.1KΩ~220KΩ developing) 10Ω ~ 100KΩ (101KΩ~332KΩ developing) 4.7Ω ~ 100KΩ 1Ω ~ 100KΩ (101KΩ~680KΩ developing) (101KΩ~680KΩ developing) 10Ω ~ 100KΩ (101KΩ~680KΩ developing) 4.7Ω ~ 100KΩ (101KΩ~1MΩ developing) 1Ω ~ 100KΩ (101KΩ~1MΩ developing) 10Ω ~ 100KΩ (101KΩ~1MΩ developing) 4.7Ω ~ 100KΩ 1Ω ~ 100KΩ (101KΩ~1.5MΩ developing) (101KΩ~1.5MΩ developing) 10Ω ~ 100KΩ 4.7Ω ~ 100KΩ 1Ω ~ 100KΩ 10Ω ~ 100KΩ 4.7Ω ~ 100KΩ 1Ω ~ 100KΩ 10Ω ~ 100KΩ 4.7Ω ~ 100KΩ 1Ω ~ 100KΩ TR Series Thin Film Chip Resistor Product Specifications Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 3/9 ■ Construction ① Alumina Substrate ④ Bottom Inner Electrode ⑦ ② Resistive Layer ⑤ Protective Overcoat ⑧ Nickel Barrier ③ Top Inner Electrode ⑥ Marking ⑨ Side Inner Electrode Solder coating (Sn) ■ Dimensions Unit : mm TYPE L W H l1 l2 TR0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.15 ± 0.10 0.20 ± 0.10 TR0603 1.60 ± 0.20 0.80 ± 0.15 0.40 ± 0.10 0.20 ± 0.15 0.30 ± 0.10 TR0805 2.00 ± 0.20 1.25 ± 0.15 0.50 ± 0.15 0.20 ± 0.15 0.40 ± 0.15 TR1206 3.05 ± 0.10 1.60 ± 0.20 0.55 ± 0.15 0.30 ± 0.20 0.50 ± 0.20 TR1210 3.05 ± 0.10 2.50 ± 0.20 0.55 ± 0.15 0.30 ± 0.20 0.50 ± 0.20 TR2010 5.00 ± 0.20 2.50 ± 0.20 0.55 ± 0.10 0.30 ± 0.15 0.60 ± 0.20 TR2512 6.30 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.40 ± 0.20 0.60 ± 0.20 TR Series Thin Film Chip Resistor Product Specifications Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 4/9 ■ Performance Characteristics ■ Power Derating Curve The Operating Temperature Range: -55°C ~+155°C. Power rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. DERATING CURVE 100 Power Ratio(%) 80 60 40 155℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Ambient Temperature (℃) ■ Rated Voltage Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: V = √𝐏 × 𝐑 V = Rated voltage (V) P = Rated power (W) R = Nominal resistance (Ω) TR Series Thin Film Chip Resistor Product Specifications Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 5/9 ■ Reliability Tests and Requirements Test Item Test Method Procedure Requirements Temperature Coefficient of Resistance (T.C.R) JIS C 5201-1 clause 4.8 At +25℃/-55℃ and +25℃/+125℃. Refer to Standard Electrical Specifications Short Time Overload JIS C 5201-1 clause 4.13 2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. ±(0.5%+0.05Ω) No Visual damage Insulation Resistance JIS C 5201-1 clause 4.6 100V for 1 minute. ≧10GΩ Solderability JIS C 5201-1 clause 4.17 245±5°C for 3±0.5secs. >95% Coverage No Visual damage Resistance to Soldering Heat JIS-C5201-1 clause 4.18 260±5℃ for 10 seconds. ±(0.5%+0.05Ω) No Visual damage Leaching JIS-C5201-1 clause 4.18 260±5℃ for 30 seconds. >95% Coverage No Visual damage Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃, 300 cycles ±(0.5%+0.05Ω) No Visual damage High Temperature Exposure JIS-C5201-1 4.25 155±5℃ for 1000 +48/-0 hours. ±(0.5%+0.05Ω) Resistance to Solvent JIS C 5201-1 clause 4.29 The tested resistor be immersed into isopropyl alcohol of 20~25℃ for 60 secs. Then the resistor is left in the room for 48 hrs. ±(0.5%+0.05Ω) No Visual damage Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. , Rated power or Max. working current whichever is less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. ±(0.5%+0.05Ω) Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, Rated power, or Max. working current whichever is less for 1000 hrs with 1.5 hrs〝ON〞and ±(0.5%+0.05Ω) 0.5 hr〝OFF〞. Terminal Bending Strength JIS C 5201-1 clause 4.33 Bending once for 5 seconds D: 0402、0603、0805=5mm 1206、1210 =3mm 2010、2512 = 2mm ±(0.5%+0.05Ω) No Visual damage Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 6/9 TR Series Thin Film Chip Resistor Product Specifications ■ Recommended Customer Soldering Parameters ■ Wave solder Temperature condition ■ Solder reflow Temperature condition ■ Rework temperature(hot air equipment):350℃, 3~5seconds ■ Recommended reflow methods IR, vapor phase oven, hot air oven If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. ■ Recommend Land Pattern Design ( For Reflow Soldering ) Unit: mm Type 0402 0603 0805 1206 1210 2010 2512 A 0.60 0.80 1.30 2.20 2.00 3.80 4.90 B 1.60 2.40 2.90 4.20 4.40 6.60 8.10 C 0.70 1.00 1.40 1.70 2.70 2.70 3.40 Item Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 7/9 TR Series Thin Film Chip Resistor Product Specifications ■ Marking 0402: no marking ■ ■ 01C 1002 0603: 3 digits code 0805~2512: 4 digits code No marking on 0402 type 3 digits code for 0603 type  Standard E96 Values and 0603 Resistance Codes R-Value 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 Code 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 R-Value 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 Code 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 R-Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 Code 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 R-Value 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Code 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96  E96 Multiplier Code Code A Multiplier B 0 C 1 10 D 2 10 E 3 10 F 4 10 G 5 10 H 6 10 X 7 10 Y -1 10 Z -2 10 -3 10 10 1. 0603 3 digits coding formula for E96 values as following: CODING XX FORMULA 2 Example: 10.2KΩ = 102 x 10 Ω = 02C X Multiplier Code 02 C -1 33.2Ω = 332 x 10 Ω = 51X Resistance Code 51 X EX.: 1Ω=01Y ; 7.5Ω=85Y ; 11Ω=05X ; 130Ω=12A ; 2KΩ= 30B ; 10KΩ=01C ; 150KΩ=18D 2. 0603 3 digits for E24 values E24 12 16 18 22 24 27 30 33 36 39 43 47 51 56 62 68 82 91 Examples: Resistance 3 digits code 2.2Ω 2R2 33Ω 330 470Ω 471 5.6KΩ 562 62KΩ 680KΩ 623 684 ("R"= decimal point) 3. 0603 E192 values are no marking. ■ 4 digits code for 0805 ~ 2512 type First 3 digits are the significant figures, the 4th digit is the multiplier. "R"= decimal point. Examples: Resistance 1Ω 5.6Ω 10Ω 22.6Ω 100Ω 1.1KΩ 4 digits code 1R00 5R60 10R0 22R6 1000 1101 10KΩ 332KΩ 1MΩ 1002 1004 3323 Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 8/9 TR Series Thin Film Chip Resistor Product Specifications ■ Packaging Information ■ Reel Dimensions TYPE 0402 0402 0603/0805/1206/ 1210 0603/0805 /1206 2010/2512 ■ 60±1.0 100±1.0 W 11.5±2.0 11.5±2.0 Unit: mm t ψM 178±2.0 330±2.0 21±1.0 60±1.0 11.5±2.0 178±2.0 21±1.0 21±1.0 21±1.0 100±1.0 100±1.0 60±1.0 11.5±2.0 11.5±2.0 16.0±2.0 254±2.0 330±2.0 178±2.0 A 2.0±0.5 2.0±0.5 ψB ψC ψD 7” 13” SIZE 10K/Reel 40K/50K Reel 13.5±1.0 13.5±1.0 21±1.0 21±1.0 7” 5K/Reel 2.0±0.5 13.5±1.0 10” 13” 7” 10K/Reel 20K/Reel 4K/Reel 2.0±0.5 2.0±0.5 2.0±0.5 13.5±1.0 13.5±1.0 13.5±1.0 Paper Tape Dimensions Paper Carrier Unit: mm Type W E F G H T 0402 0.70±0.10 1.20±0.10 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.45±0.10 0603 1.05±0.20 1.80±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.60±0.10 0805 1.55±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1206 1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1210 2.85±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 ■ A B ψD P 2.0±0.10 4.0±0.10 Plastic Embossed Tape Dimensions Unit: mm Type A B W E F G H T ψD ΨD1 T1 2010 2.80±0.20 5.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50±0.10 0.85±0.15 2512 3.40±0.20 6.70±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50±0.10 0.85±0.15 P 4.0±0.10 Document No. S-10-12-03-03 Released Date 2019/01/29 Page No. 9/9 TR Series Thin Film Chip Resistor Product Specifications ■ Front & Back Lead Dimensions ■ Top Adhesive Peel Off Strength:10~70g ■ Package Inner Box Size External Box Size Contain Length (Kpcs) (mm) Width (mm) Width (mm) 180 180 60 50K 180 180 110 150K 430 200 200 300K 400 400 200 Reel Size H(mm) 1 13 25K 2 24 3 36 5 60 10 113 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery.
TR0603D62R0P0510Z
物料型号:TR系列薄膜芯片电阻,包括多种尺寸如0402、0603、0805、1206、1210、2010和2512。
器件简介:这些电阻具有高精度和高稳定性,适用于计算机、电信、消费电子、测量仪器、打印设备和转换器等多种应用。
引脚分配:文档中没有明确提到引脚分配,但提供了电阻的尺寸信息。
参数特性:电阻的公差范围从±0.1%到±1%,温度系数(T.C.R.)从±10 ppm/℃到±50 ppm/℃,额定功率从0.063W到0.75W,最大工作电压从50V到400V。
功能详解:文档详细描述了电阻的构造,包括氧化铝基板、内外电极、电阻层、保护层和镍屏障等。
应用信息:适用于多种电子设备,强调了无卤素和无铅的特性,符合RoHS标准。
封装信息:提供了不同尺寸的电阻的详细尺寸数据,以及卷装和纸带封装的尺寸信息。
TR0603D62R0P0510Z 价格&库存
很抱歉,暂时无法提供与“TR0603D62R0P0510Z”相匹配的价格&库存,您可以联系我们找货
TR0603D62R0P0510Z
    • 10+0.38535
    • 100+0.30942
    • 300+0.27152
    库存:36
