TR0805B26K7P0525
TR0805B26K7P0525
    EVEROHMS(天二)
    贴片电阻 0805
TR0805B26K7P0525 数据手册
■ Thin Film Chip Resistor — TR Series ■ Application — Medical equipments, Military equipments — Converters — Consumer products — Communication devices — Measurement instruments — Printers ■ Features — Tight tolerance from ±0.01%,±0.1%, ±0.25%, ±0.5%, ±1% — Low T.C.R. ±10ppm, ±25ppm, ±50ppm TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Type Dimension TR1218 TR0402 / TR0603 /TR0805 / TR1206 / TR1210 / TR2010 / TR2512 ■ Dimension Unit: mm TYPE L W H l1 l2 TR0402 1.00 ± 0.10 0.50 ± 0.05 0.30 ± 0.05 0.15 ± 0.10 0.20 ± 0.10 TR0603 1.60 ± 0.20 0.80 ± 0.15 0.40 ± 0.10 0.30 ± 0.20 0.30 ± 0.10 TR0805 2.00 ± 0.20 1.25 ± 0.15 0.50 ± 0.15 0.30 ± 0.15 0.40 ± 0.15 TR1206 3.05 ± 0.10 1.60 ± 0.20 0.55 ± 0.15 0.40 ± 0.20 0.50 ± 0.20 TR1210 3.05 ± 0.10 2.50 ± 0.20 0.55 ± 0.15 0.50 ± 0.20 0.50 ± 0.20 TR2010 5.00 ± 0.20 2.50 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 TR1218 3.10 ± 0.10 4.60 ± 0.10 0.55 ± 0.05 0.40 ± 0.20 0.50 ± 0.20 TR2512 6.30 ± 0.20 3.20 ± 0.20 0.55 ± 0.10 0.60 ± 0.20 0.60 ± 0.20 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Standard Electrical Specifications TYPE Rated Power at 70℃ ℃ Max Working Voltage Max Overload T.C.R. Voltage (PPM/℃ ℃) Resistance Range T(± ±0.01%) W(± ±0.05%) ±10 TR0402 0.063W 25V 50V 75V 150V 40.2Ω~42K2Ω 10Ω~100KΩ 10Ω~100KΩ 10Ω~100KΩ 10Ω~1MΩ 10Ω~1MΩ 10Ω~1MΩ 10Ω~100KΩ 10Ω~100KΩ 10Ω~100KΩ 4.7Ω~332KΩ 4.7Ω~332KΩ 4.7Ω~332KΩ 4.7Ω~4M7Ω 4.7Ω~4M7Ω 1Ω~4M7Ω 10Ω~220KΩ 10Ω~220KΩ 10Ω~220KΩ 4.7Ω~3M32Ω 4.7Ω~3M32Ω 4.7Ω~3M32Ω ±50 4.7Ω~3M32Ω 4.7Ω~3M32Ω 1Ω~3M32Ω ±10 10Ω~220KΩ 10Ω~220KΩ 10Ω~220KΩ 4.7Ω~2M74Ω 4.7Ω~2M74Ω 4.7Ω~2M74Ω ±50 4.7Ω~2M74Ω 4.7Ω~2M74Ω 1Ω~2M74Ω ±10 10Ω~499KΩ 10Ω~499KΩ 10Ω~499KΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ ±50 4.7Ω~1MΩ 4.7Ω~1MΩ 1Ω~1MΩ ±10 10Ω~499KΩ 10Ω~499KΩ 10Ω~499KΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ ±50 4.7Ω~1MΩ 4.7Ω~1MΩ 1Ω~1MΩ ±10 10Ω~499KΩ 10Ω~499KΩ 10Ω~499KΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ ±50 4.7Ω~1MΩ 4.7Ω~1MΩ 1Ω~1MΩ ±10 10Ω~499KΩ 10Ω~499KΩ 10Ω~499KΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 4.7Ω~1MΩ 1Ω~1MΩ ±25 ╴ ±25 24.9Ω~100KΩ ±50 ±10 TR0805 TR1206 TR1210 TR2010 TR1218 TR2512 0.125W 0.25W 0.25W 0.5W 0.5W 0.75W 150V 200V 200V 200V 200V 200V 300V 400V 400V 400V 400V 400V ±25 ±25 ±25 ±25 ±25 ±25 ±50 ● ● F(± ±1%) 40.2Ω~42K2Ω ±10 0.1W C(± ±0.25%) D(± ±0.5%) 40.2Ω~42K2Ω ±50 TR0603 B(± ±0.1%) 24.9Ω~100KΩ 24.9Ω~100KΩ 24.9Ω~100KΩ 24.9Ω~100KΩ 24.9Ω~100KΩ 24.9Ω~100KΩ For non-standard parts, please contact our sales dept. Operating Temperature Range :−55℃〜+155℃. TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Parts Number Explanation ■ Example: TR 0603 B 10K P 05 Product Type Size (Inch) Resistor Tolerance Resistors Value Package Quantity 0402 0603 0805 1206 1210 2010 1218 2512 T:±0.01% W:±0.05% B:±0.1% C:±0.25% D:±0.5% F:±1% TEL: 886-7-8116611 FAX: 886-7-8115533 P、Q:Paper Taping E:Embossed Taping D:Packed in a Bag E-mail: service@everohms.com 01:1000PCS 02:2000PCS 04:4000PCS 05:5000PCS 10:10000PCS 20:20000PCS 40:40000PCS 50:50000PCS TCR / Power ±10PPM ±25PPM ±50PPM 0.25W 0.5W http://www.everohms.com ■ Appendix For SMD Chip Resistor ● Packaging Information ◆ For TR Series ■ Dimension Unit: mm 7” 13” 13” 7” 10” 13” 7” SIZE 10K/Reel 40K/Reel 50K/Reel 5K/Reel 10K/Reel 20K/Reel 5K/Reel A 2.0±0.5 2.0±0.5 2.0±0.5 2.0±0.5 2.0±0.5 2.0±0.5 2.0±0.5 ψB 13.5±1.0 13.5±1.0 13.5±1.0 13.5±1.0 13.5±1.0 13.5±1.0 13.5±1.0 ψC 21±1.0 21±1.0 21±1.0 21±1.0 21±1.0 21±1.0 21±1.0 ψD 60±1.0 100±1.0 100±1.0 60±1.0 100±1.0 100±1.0 60±1.0 W 11.5±2.0 11.5±2.0 11.5±2.0 11.5±2.0 11.5±2.0 11.5±2.0 11.5±2.0 7” 4K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 16.0±2.0 178±2.0 TYPE 0402 0603 0805 1206 1210 2010/2512 1218 ψM 178±2.0 330±2.0 330±2.0 178±2.0 254±2.0 330±2.0 178±2.0 ■ Tapping Specification ■ Dimension Packaging Paper Type Unit: mm Type A B W E F G H ψD T 0402 0.70±0.10 1.20±0.10 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.45±0.10 0603 1.05±0.20 1.80±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.60±0.10 0805 1.55±0.20 2.30±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1.50 1206 1.90±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 1210 2.85±0.20 3.50±0.20 8.0±0.20 1.75±0.10 3.5±0.05 4.0±0.10 2.0±0.05 0.75±0.10 2.0±0.1 +0.10 -0 ■ Dimension Packaging Type 4.0±0.1 Unit: mm A B W E F G H T ψD 2010 2.80±0.20 5.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 Embossed Type P +0.10 2512 3.40±0.20 6.70±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 1.50 1218 3.30±0.20 4.60±0.20 12±0.10 1.75±0.10 5.5±0.05 4.0±0.10 2.0±0.05 0.23±0.10 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com -0 ΨD1 T1 P 1.50±0.10 0.85±0.15 1.50±0.10 0.85±0.15 4.0±0.1 1.50±0.10 0.85±0.15 http://www.everohms.com ■ Packing Material Data / Storage Data ■ Front & Back Lead Dimension ■ Top Adhesive Peel Off Strength:10~70g ■ Package Inner Box Size External Box Size Reel Size H(mm) 1 13 Contain (Kpcs) Length (mm) Width (mm) Height (mm) 2 24 25K 180 180 60 3 36 50K 180 180 110 5 60 150K 430 200 200 10 113 300K 400 400 200 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ● Reliability Test and Requirement ◆ For TR Series Test Item Test Method Temperature JIS C 5201-1 Coefficient of clause 4.8 Resistance (T.C.R) Procedure Requirements TCR +155 ℃ , 25℃ is the reference temperature Refer to Ratings General:2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. High Power:2.5 times RCWV or Max. Overload voltage whichever is less for 2 seconds. ±(0.5%+0.05Ω) Short Time Overload JIS C 5201-1 clause 4.13 IR Reflow Sony SS-00254 ±(0.5%+0.05Ω) Leaching Sony SS-00254-9 260±5℃ for 30 seconds. >95% Coverage Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. ±(0.5%+0.05Ω) Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃,5 cycles ±(0.5%+0.05Ω) Electric Iron Sony SS-00254-5 Preheating temperature:350±10℃ Electric iron preheating time:3+1/-0 sec ±(0.5%+0.05Ω) Resistance to Solvent JIS C 5201-1 clause 4.29 The tested resistor be immersed into isopropyl alcohol of 20~25℃ for 60 secs. Then the resistor is left in the room for 48 hrs. ±(0.5%+0.05Ω) Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. RCWV or Max. working voltage whichever is less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. ±(0.5%+0.05Ω) Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, RCWV or Max. working voltage whichever is ±(0.5%+0.05Ω) less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. Terminal Bending JIS C 5201-1 Strength clause 4.33 Insulation Resistance JIS C 5201-1 clause 4.6 Bending once for 5 seconds D: TR Series 0402、0603、0805=5mm TR Series 1206、1210 =3mm TR Series 1218、2010、2512、2030=2mm ±(0.5%+0.05Ω) 100V for 1 minute. ≧10GΩ ● Temperature Coefficient of Resistance test to - 55 ℃ is available on request TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ● General Information ■ Recommend Land Pattern Design ( For Reflow Soldering ) ■ Dimension Type Unit: mm 0402 0603 0805 1206 1210 2010 1218 2512 A 0.60 0.80 1.30 2.20 2.00 3.80 2.04 4.90 B 1.60 2.40 2.90 4.20 4.40 6.60 4.24 8.10 C 0.70 1.00 1.45 1.80 2.70 2.70 4.80 3.40 Item ■ Performance Characteristics ■ Power Derating Curve DERATING CURVE 100 Power Ratio(%) 80 60 40 155℃ ℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Ambient Temperature (℃) Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. ■ Voltage Rating or Current Rating Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: E(RCWV)=√ √P× ×R TEL: 886-7-8116611 E=Rated voltage(V) P=Power rating(W) R=Nominal resistance(Ω) FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com ■ Operation and Storage Temperature MIN MAX Operation temperature -55℃ 70℃ Storage temperature 20℃ 30℃ Storage humidity 40% 80% ■ Equipments Applicable: Our company’s products are produced under low temperature processing applicable to IR reflow surface mounting devices. It is comparatively not applicable to wave soldering which will possibly cause the risk ablating the element protection layer and the front conductor and cause the drift of the resistance value and ablation of the markings. ■ Product Testing Method: Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and customized-made production is available. ■ 0603 E-96 Multiplier Code Code A Multiplier 10 CODING XX B 0 10 C 1 10 D 2 10 E 3 10 F 4 10 G 5 10 H 6 10 X 7 10 Y -1 10 -2 Z 10 -3 FORMULA 2 Example: 10.2KΩ = 102 x 10 Ω =02C X Multiplier Code 02 C -1 33.2Ω = 332 x 10 Ω =51X Resistance Code 51 X ■ 0603 Standard E-96 Values and 0603 Resistance Codes R-Value Code R-Value Code R-Value Code R-Value Code 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 01 05 06 07 08 09 15 23 02 03 04 10 11 12 13 14 16 17 18 19 20 21 22 24 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 25 31 39 26 27 28 29 30 32 33 34 35 36 37 38 40 41 42 43 44 45 46 47 48 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 49 55 63 69 70 71 50 51 52 53 54 56 57 58 59 60 61 62 64 65 66 67 68 72 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 73 79 87 95 74 75 76 TEL: 886-7-8116611 77 78 80 81 FAX: 886-7-8115533 82 83 84 85 86 88 89 E-mail: service@everohms.com 90 91 92 93 94 96 http://www.everohms.com ■ Standard Resistance Values in a Decade Marking code: 1%: marking code, please refer to E96 and E24 data form as below Ex: 120K, The marking code is 1203 in E24 121K, The marking code is 1213 in E96 Note: 0402 series resistor has no marking code. Type: 0603 1% marking code, please refer to E-96 multiplier code. E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 E192 E96 E48 100 101 102 104 105 106 107 109 110 111 113 114 115 117 118 120 121 123 100 100 169 172 174 176 178 180 182 184 187 189 191 193 196 198 200 203 205 208 169 169 287 291 294 298 301 305 309 312 316 320 324 328 332 336 340 344 348 352 287 287 487 493 499 505 511 517 523 530 536 542 549 556 562 569 576 583 590 597 487 487 825 835 845 856 866 876 887 898 909 920 931 942 953 965 976 988 825 825 124 124 126 127 129 130 132 133 135 137 138 140 142 143 145 147 149 150 152 154 156 158 160 162 164 165 167 102 105 105 107 110 110 113 115 115 118 121 127 121 210 127 130 133 133 137 140 140 143 147 147 150 154 154 158 162 162 165 213 215 218 221 223 226 229 232 234 237 240 243 246 249 252 255 258 261 264 267 271 274 277 280 284 174 178 178 182 187 187 191 196 196 200 205 205 210 215 357 215 221 226 226 232 237 237 243 249 249 255 261 261 267 274 274 280 361 365 370 374 379 383 388 392 397 402 407 412 417 422 427 432 437 442 448 453 459 464 470 475 481 294 301 301 309 316 316 324 332 332 340 348 348 357 365 604 365 374 383 383 392 402 402 412 422 422 432 442 442 453 464 475 464 612 619 626 634 642 649 657 665 673 681 690 698 706 715 723 732 741 750 759 768 777 787 796 806 816 499 511 511 523 536 536 549 562 562 576 590 619 634 649 649 665 681 681 698 715 715 732 750 750 768 787 806 866 866 887 909 909 931 953 953 976 590 604 619 845 787 E24 E12 E6 E3 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 10 10 10 12 15 15 18 22 22 22 27 33 33 39 47 47 47 56 68 68 82 According to IEC publication 63 Revision: June 30, 2017 TEL: 886-7-8116611 FAX: 886-7-8115533 E-mail: service@everohms.com http://www.everohms.com
TR0805B26K7P0525 价格&库存
很抱歉,暂时无法提供与“TR0805B26K7P0525”相匹配的价格&库存,您可以联系我们找货
TR0805B26K7P0525
    • 10+0.32325
    • 100+0.25553
    • 300+0.22162
    • 1000+0.19624
    库存:3848
