CRA064RJ510RE04Z
CRA064RJ510RE04Z
    EVEROHMS(天二)
    RA_1206X4
    排阻/电阻网络 SMD-8P,5.1x3.1mm 510Ω ±5% 250mW ±200ppm/℃
CRA064RJ510RE04Z 数据手册
CRA-Series Thick Film Array Chip Resistor Product Specifications Thick Film Array Chip Resistor — CRA Series ■ ■ Application — Entertainment: Stereo, TV tuners, Tape recorder ─ Appliance: Air conditioner, Refrigerator ─ Computer & relative products: Main board, PDA ─ Communication equipment: Cell phone, Fax machine ─ Power equipment: Power supply, Illumination equipment ─ Measuring instrument: Electric meter, Navigation equipment ■ Features — Small size and light weight - Reduction of assembly costs and matching with placement machines - Reliability, high quality and fast delivery Document No. S-10-12-02-03 Released Date 2019/01/03 1/8 Page No. CRA-Series Thick Film Array Chip Resistor Product Specifications ■ Document No. S-10-12-02-03 Released Date 2019/01/03 2/8 Page No. Type Dimension ■ Dimension Unit: mm TYPE L W H l1 l2 P Q Q1 CRA022R 1.00±0.10 1.00±0.10 0.33±0.05 0.15±0.10 0.25±0.10 0.67±0.10 0.34±0.10 --- CRA024R 2.00±0.10 1.00±0.10 0.40±0.10 0.20±0.10 0.20±0.10 0.50±0.10 0.30±0.10 0.43±0.10 CRA034R 3.20±0.20 1.60±0.15 0.50±0.10 0.30±0.20 0.30±0.20 0.80±0.20 0.50±0.15 0.61±0.10 CRA064R 5.10±0.20 3.10±0.20 0.55±0.15 0.55±0.15 0.55±0.15 1.30±0.20 0.90±0.10 --- Document No. S-10-12-02-03 Released Date 2019/01/03 3/8 Page No. CRA-Series Thick Film Array Chip Resistor Product Specifications ■ Standard Electrical Specifications Item Rating Power at 70℃ Max Working Voltage Max Overload Voltage CRA022R 0.063 W 25V 50V CRA024R 0.063 W 25V 50V CRA034R 0.1 W 50V 100V Type CRA064R ● ● 0.25 W 200V Resistance Range T.C.R. (PPM/℃) 400V Operating Temperature F(±1%) J±(5%) ±400 ±200 ±400 ±200 ±400 1Ω~9.9Ω 10Ω~1MΩ 1Ω~9.9Ω 10Ω~1MΩ 1Ω~9.9Ω ±200 10Ω~1MΩ ±400 1Ω~9.9Ω ±200 10Ω~1MΩ -55℃ ~ +155℃ For non-standard parts, please contact our sales dept. Operating Temperature Range :−55℃〜+155℃. Type 022R 024R Jumper Rated Current 034R 064R 1A 2A Parts Number Explanation ■ Example: ■ CRA 024R J 10R0 Product Type Size (Inch) Resistor Tolerance Resistors Value CRA 022R(0402*2) 024R(0402*4) 034R(0603*4) 064R(1206*4) R:CONVEX F:±1% J:±5% Q 10 Package Quantity P、Q:Paper Taping E:Embossed Taping D:Packed in a Bag 04:4000PCS 05:5000PCS 10:10000PCS Z Optional Document No. S-10-12-02-03 Released Date 2019/01/03 4/8 Page No. CRA-Series Thick Film Array Chip Resistor Product Specifications ■ Appendix For SMD Chip Resistor ● Packaging Information ■ Dimension TYPE Unit: mm SIZE A ψB ψC ψD W ψM 022R/024R 7” 10K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 034R 7” 5K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 11.5±2.0 178±2.0 064R 7” 4K/Reel 2.0±0.5 13.5±1.0 21±1.0 60±1.0 16.0±2.0 178±2.0 ■ Tapping Specification ■ Dimension Packaging Paper Type Unit: mm ψD Type A B W E F G H T 022R 1.25±0.1 1.25±0.1 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.45±0.1 024R 1.20±0.1 2.20±0.1 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 034R 1.90±0.2 3.50±0.2 8.0±0.2 1.75±0.1 3.5±0.05 4.0±0.1 2.0±0.05 0.60±0.1 1.50 -0 0.75±0.1 +0.10 ■ Dimension Packaging 2.0±0.1 4.0±0.1 Unit: mm Type A B W E F G H T ψD ΨD1 064R 3.55±0.2 5.55±0.2 12±0.3 1.75±0.1 5.5±0.05 4.0±0.1 2.0±0.05 0.25±0.1 1.50 -0 T1 P +0.25 +0.10 Embossed Type P 1.50 -0 0.85±0.15 4.0±0.1 CRA-Series Thick Film Array Chip Resistor Product Specifications ■ Document No. S-10-12-02-03 Released Date 2019/01/03 5/8 Page No. Packing Material Data/Storage Data ■ Front & Back Lead Dimension ■ Top Adhesive Peel Off Strength:10~70g ■ Package Inner Box Size Reel Size H(mm) External Box Size Contain Length Width Height (Kpcs) (mm) (mm) (mm) 1 13 2 24 25K 180 180 60 3 36 50K 180 180 110 5 60 150K 430 200 200 10 113 300K 400 400 200 ■ Storage Data: Storage time at the environment temp: 25±5℃& humidity: 60±20% is valid for one year from the date of delivery. CRA-Series Thick Film Array Chip Resistor Product Specifications ● Document No. S-10-12-02-03 Released Date 2019/01/03 6/8 Page No. Reliability Test and Requirement Test Item Test Method Temperature JIS C 5201-1 Coefficient of clause 4.8 Resistance (T.C.R) Procedure Requirements -55℃ or +155℃, 25℃ is the reference temperature Refer to Ratings General:2.5 times RCWV or Max. Overload voltage whichever is less for 5 seconds. High Power:2.5 times RCWV or Max. Overload voltage whichever is less for 2 seconds. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.10Ω) Short Time Overload JIS C 5201-1 clause 4.13 IR Reflow Sony SS-00254 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) Leaching Sony SS-00254-9 260±5℃ for 30 seconds. >95% Coverage Soldering Heat JIS C 5201-1 clause 4.18 260±5℃ for 10 seconds. 1%:±(0.5%+0.05Ω) 5%:±(1.0%+0.05Ω) Temperature Cycling JIS C 5201-1 clause 4.19 -55℃ to +155℃,5 cycles 1%: ±(0.5%+0.05Ω) 5%:±(1.0%+0.10Ω) Electric Iron Sony SS-00254-5 Preheating temperature:350±10℃ Electric iron preheating time:3+1/-0 sec 1%:±(1.0%+0.05Ω) 5%:±(1.0%+0.05Ω) Resistance to Solvent JIS C 5201-1 clause 4.29 The tested resistor be immersed into isopropyl alcohol of 20~25℃ for 60 secs. Then the resistor is left in the room for 48 hrs. 1%:±(0.5%+0.05Ω) 5%:±(0.5%+0.05Ω) Load Life in Humidity JIS C 5201-1 clause 4.24 40±2℃, 90~95% R.H. RCWV or Max. working voltage whichever is less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 1%:±(1.0%+0.05Ω) 5%:±(2.0%+0.05Ω) Load Life (Endurance) JIS C 5201-1 clause 4.25 70±2℃, RCWV or Max. working voltage whichever is 1%: ±(1.0%+0.05Ω) less for 1000 hrs with 1.5 hrs〝ON〞and 0.5 hr〝OFF〞. 5% :±(3.0%+0.10Ω) Insulation Resistance JIS C 5201-1 clause 4.6 100V for 1 minute. ≧10GΩ CRA-Series Thick Film Array Chip Resistor Product Specifications ● Document No. S-10-12-02-03 Released Date 2019/01/03 7/8 Page No. General Information ■ Recommend Land Pattern Design ( For Reflow Soldering ) 024R 034R 022R 064R Unit: mm ■ Dimension Type 022R 024R 034R 064R 0.50 2.00 0.67 0.33 0.34 0.50 2.00 0.50 0.28 0.22 1.00 2.60 0.80 0.40 0.40 2.00 4.75 1.30 0.90 0.375 Item A B P Q1 Q2 ■Performance ■ Characteristics Power Derating Curve DERATING CURVE 100 80 Power Ratio(%) 60 40 155℃ 20 -55 0 20 40 60 70 80 100 120 140 160 Ambient Temperature (℃) Power rating or current rating is in the case based on continuous full-load at ambient temperature of 70℃. For operation at ambient temperature in excess of 70℃, the load should be derated in accordance with figure of derating Curve. CRA-Series Thick Film Array Chip Resistor Product Specifications Document No. S-10-12-02-03 Released Date 2019/01/03 8/8 Page No. Voltage Rating or Current Rating ■ Resistance Range: ≧1Ω Rated Voltage: The resistor shall have a DC continuous working voltage or a RMS AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined formula as following: E(RCWV)=√P×R E=Rated voltage(V) P=Power rating(W) R=Nominal resistance(Ω) Equipments Applicable: ■ Our company’s products are produced under low temperature processing applicable to IR reflow surface mounting devices. It is comparatively not applicable to wave soldering which will possibly cause the risk ablating the element protection layer and the front conductor and cause the drift of the resistance value and ablation of the markings. Product Testing Method: ■ Our products are tested with our company’s tapping & testing equipments by using four-feet probe to touch at the back of both electrodes. Supposed different testing points or methods are requested, please advise beforehand and customized-made production is available. ■ Standard Resistance Values in a Decade Marking code: ● 5%: marking code, please refer to E24 data Ex: 120K, The marking code is 124 in E24 ●Note: Array resistors 1%&5% code is the same. ●Note: jumper zero ohm resistor marking code is one 「0」 (except type below 022R).
CRA064RJ510RE04Z 价格&库存
很抱歉,暂时无法提供与“CRA064RJ510RE04Z”相匹配的价格&库存,您可以联系我们找货
