RS3MA
RS3MA
    ZHIDE(志得)
    SMA(DO-214AC)
    耐压:1KV 电流:3A 反向恢复时间:500NS
RS3MA 数据手册
RS3AA~RS3MA Surface Mount Super Fast Recovery Rectifiers 表面安装超快速整流二极管 反向电压 50~1000 V 正向电流 3.0 A Reverse Voltage 50~1000 V Forward Current 3.0 A 特征 Features DO-214AC/SMA ● 反向漏电流低 Low reverse leakage ● 正向浪涌承受能力强 High forward surge capability ● 高信赖性 High reliability ● 高温焊接保证 High temperature soldering guaranteed: 260℃/10 秒 260℃/10seconds ● 引线和管体皆符合RoHS标准 Lead and body according with RoHS standard ● 型号后缀“-F”标记无卤素产品 Green compound with suffix "-F" on Marking 机械数据 Mechanical Data ● 封装外形:DO-214AC 塑封 Case:DO-214AC Molded plastic ● 环氧树脂:UL易燃等级:94V-0 Unit: inch (mm) Epoxy: UL 94V-0 rate flame retardant ● 引脚:镀锡,无铅 Lead: Pure tin plated, lead free 最大值和特性 TA = 25℃ 除非另有规定。 Maximum Ratings & Characteristics 参数 Parameter Ratings at 25℃ ambient temperature unless otherwise specified. 符号 Symbols 最大可重复峰值反向电压 Maximum repetitive peak reverse voltage 最大均方根电压 Maximum RMS voltage 最大直流阻断电压 Maximum DC blocking voltage 最大正向平均整流电流 Maximum average forward rectified current RS3AA RS3BA RS3DA RS3GA RS3JA RS3KA RS3MA 单位 Unit VRRM 50 100 200 400 600 800 1000 V VRMS 35 70 140 280 420 560 700 V VDC 50 100 200 400 600 800 1000 V IF(AV) 3.0 A IFSM 80 A VF 1.30 V 正向不重复浪涌电流 8.3 ms单一正弦半波 Non-repetitive peak forward surge current 8.3 ms singlehalf sine-wave 最大正向电压 @IF=3.0A Maximum forward voltage 最大反向电流 @VDC TA= 25℃ Maximum reverse current TA= 125℃ 最大反向恢复时间 IF=0.5A , IR=1.0A ,IRR=0.25A MAX. reverse recovery time 典型热阻 Typical thermal resistance (Note 1) 典型结电容 VR=4.0V,f=1MHz Type junction capacitance 工作结温和存储温度 Operating junction and storage temperature rang 5 IR TRR μA 100 150 250 500 nS RθJA 85 ℃/W CJ 45 pF TJ , TSTG -55 --- +150 ℃ 备注 Note: 1) 安装在PCB板上,从PN结到周围环境的热阻。 1) Thermal resistance from junction to ambient, PCB mounted. REV.1.1,2018-12 Changzhou zhide Electronics CO.,LTD www.cz-zhide.com RS3AA~RS3MA 特性曲线 Characteristic Curves 正向特性曲线(典型值) 正向电流降额曲线 IF(AV) (A) 10 1 Tj=25℃ 0.1 0.2 0.6 1 1.4 IF(A) Average Forward Rectified Current (A) FORWARD CURRENT DERATING CURVE 平均正向电流 IF Instantaneous Forward Current (A) 正向电流 IF(A) TYPICAL FORWARD CHARACTERISTIC 3.5 3 2.5 2 1.5 1 0.5 0 0 1.8 25 50 75 100 正向电压 VF(V) 引脚温度 Ta(°C) VF Instantaneous Forward Voltage (V) TL, Lead temperature (°C) 浪涌特性曲线(最大值) 125 150 175 反向特性曲线 MAXIMUM NON REPETITIVE Typical Reverse Characteristics PEAK FORWARD SURGE CURRENT 10 60 50 40 30 20 10 Reverse Current(uA) 70 反向电流IR(uA) IFSM Peak Forward Surge Current (A) 峰值正向浪涌电流 IFSM(A) 80 1 0.1 Tj=25℃ Tj=25℃ 0 0.01 1 10 100 0% 20% 40% 60% 80% 通过电流的周期 额定峰值反向电压% Number of Cycles at 60 Hz. Percent Of Rated Peak Reverse voltage % REV.1.1,2018-12 Changzhou zhide Electronics CO.,LTD 100% www.cz-zhide.com
RS3MA
1. 物料型号:型号为EL817,这是一款采用DIP封装的光耦器件,主要用于隔离输入和输出信号。
2. 器件简介:EL817是由Everlight Electronics Co., Ltd.生产的,它是一个六引脚的光电耦合器,具有高速响应和高隔离电压特性。
3. 引脚分配:EL817的引脚从左到右依次为:1. 输出,2. 集电极,3. 发射极,4. 地,5. 输入,6. Vcc。
4. 参数特性:主要参数包括输入电流范围为2mA至10mA,输出电流最大为100mA,隔离电压可达5000Vrms。
5. 功能详解:EL817通过内部的发光二极管和光敏晶体管实现信号的光电转换,具有抗干扰能力强和响应速度快的特点。
6. 应用信息:广泛用于数字通信、测量设备、医疗设备和工业控制系统中,作为信号隔离和接口转换的组件。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.8mm x 4.8mm,引脚间距为2.54mm。
RS3MA 价格&库存
很抱歉,暂时无法提供与“RS3MA”相匹配的价格&库存,您可以联系我们找货
RS3MA
  • 10+0.44064
  • 100+0.35770
  • 300+0.31623
  • 1000+0.28512
  • 5000+0.26028
  • 10000+0.24776
库存:2006
