9321315301
9321315301
    BETTER(贝特电子)
9321315301 数据手册
Document Record No. Date 1 2014.02.14 Modified Content Page Draft 6 D Runsong Zhong Lianghua Guo 6 B/0 Kings Luo Wenhua Yan 2 2014.04.08 Added TUV certification 3 2015.02.04 Add 125mA and 250mA CQC certification; 4,15,16 Add 200mA I-T Curve Edition Prepared/modified by B/1 Kings Luo Checked by Wenhua Yan 4 2015.02.09 Add 8A and 10A CQC certification; 19,20 B/2 Kings Luo Wenhua Yan 5 2015.06.18 The fuse high to change the 7.6mm 5 B/3 Jeffery Gem Guo B/4 Jeffery Gem Guo B/5 Jeffery Gem Guo B/6 Jeffery Lin Gao 9 2015.12.12 Update PSE certification B/7 Jeffery Lin Gao 10 2016.01.14 Update I2T value B/8 Jeffery Wenhua Yan 11 2016.04.15 Add the 0.16A~0.4A CQC certification B/9 Jeffery Helge B/10 Jeffery Wenqiang Luo C/0 J.Q. Fei Gao C/1 J.Q. Fei Gao 6 2015.08.04 Update UR certification 7 2015.09.09 Update CQC , TUV certification 8 2015.11.18 Update the tapping 9 3,7 12 2016.8.24 Change the construction 13 2017.12.08 Update BSI,SEMKO certification 14 2018.03.05 Update TUV certification 15 2018.10.08 Change of the innor core and material 4 C/2 Xiang Xiong Fei Gao 16 2019.02.25 Update UL certification 7 C/3 Xiang Xiong Fei Gao 17 2019.03.11 Add 6.3A PSE certification 7 C/4 Xiang Xiong Fei Gao Add 12A,12.5A,15A 18 2019.04.24 and16A IT curve 6 C/5 Xiang Xiong Fei Gao 19 2019.10.14 Change CQC to CCC D/0 YaLan Wang Fei Gao 20 2020.04.23 Update tape drawing D/1 YaLan Wang Fei Gao D/2 YaLan Wang Fei Gao 21 2020.04.24 Add 300V CQC certification TABLE OF CONTENTS 1. SCOPE AND DESCRIPTION............................................................................................................ 3 2. GENERAL INFORMATION................................................................................................................3 3. AGENCY APPROVALS......................................................................................................................3 4. PART NUMBERING SYSTEM.......................................................................................................... 4 5. CONSTRUCTION AND MECHANICAL CHARACTERISTICS.................................................... 5 6. ELECTRICAL SPECIFICATIONS.................................................................................................... 6 7. SOLDERING PARAMETERS........................................................................................................... 8 8. ORDERING INFORMATION..............................................................................................................8 9. PACKING INFORMATION.................................................................................................................9 10.APPENDIX..........................................................................................................................................10 2 932 / OC FUSE 1. SCOPE AND DESCRIPTION Following electronic product specifications apply to fuses of the 932 series. The 932 series is a sub miniature fuse links for overcurrent protection. Its main applications are for consumer electronics, LED drivers, power supplies, battery chargers and controllers for industrial use. 2. GENERAL INFORMATION General Description The 932 series provides protection for printed circuit boards used in a large variety of applications that need fuses with time-delay, low breaking capacity. The sub-miniature device is constructed of a plastic cap and base with a tin plated copper lead wire. It offers excellent mounting characteristics and is 100% tested for cold resistance. Detailed Features • Subminiature fuse with time delay, low breaking capacity • Small, rectangular and leaded design minimizes board space and eliminates the need for additional mounting components • Plastic cap / brown thermoplastic fuse body. • 0.6mm lead wires made of tin plated copper. • Protection against harmful over-currents in primary and secondary applications. • Lead-free, Halogen-free, RoHS compliant • Designed according to IEC 60127-3 • TUV compliance to EN 60127-7: 2016 3. AGENCY APPROVALS Agency Agency File Number Voltage/ Current Rating 400/300/277/250/125V AC: 0.1A~16A; E300003 250V AC:125mA;160mA;200mA;250mA;315mA 400mA;500mA;630mA;800mA;1A;1.25A 1.6A;2A;2.5A;3.15A;4A;5A;6.3A;8A;10A 2019010207235037 PSE15020937 PSE19021462 250V AC: 1A, 1.25A, 1.6A, 2A, 2.5A, 3.15A, 4A, 5A, 250V AC: 6.3A 250V AC: 630mA, 800mA, 1A, 1.25A, 1.6A, 2A, 2.5A, 3.15A, 4A, 5A, 6.3A 40033369 SU05042-13003, SU05042-13002, SU05042-13001 250V AC: 500mA, 630mA, 800mA, 1A, 1.25A, 1.6A, 2A, 2.5A, 3.15A, 4A, 5A, 6.3A 300V AC:500mA;1A;1.25A;1.6A;2A;2.5A;3.15A;4A;5A; CQC20012242947 6.3A;8A;10A 3 932 / OC FUSE R 50279350 300V AC: 125mA, 160mA,200mA, 250mA, 315mA, 400mA, 500mA, 630mA, 800mA, 1A, 1.25A, 1.6A, 2A, 2.5A, 3.15A, 4A, 5A, 6.3A, 8A, 10A 250V AC: 125mA, 160mA,200mA, 250mA, 315mA, 400mA, 500mA, KM 677189 250V AC:3.15A;5A;8A;10A 1719061 250V AC:3.15A;5A;8A;10A 4. PART NUMBERING SYSTEM 4.1 Part Number Example: 9321315278 932 1315 2 78 1 2 3 4 1 .Product Series ………….................. 2 .Ampere Rating …………….............. 3 .Rated Voltage …………................... 932 3.15A (see table 4.2 below) 1– 125V 2– 250V 3– 300V K– 400V 4 .Supplementary Code ………........... Complement Code 4.2. Ampere / Voltage Rating Table AMP CODE CURRENT RATING VOLTAGE RATING 0100 100mA 125 / 250 / 277/ 300/ 400V AC 0125 125mA 125 / 250 / 277/ 300/ 400V AC 0160 160mA 125 / 250 / 277/ 300/ 400V AC 0200 200mA 125 / 250 / 277/ 300/ 400V AC 0250 250mA 125 / 250 / 277/ 300/ 400V AC 0315 315mA 125 / 250 / 277/ 300/ 400V AC 0400 400mA 125 / 250 / 277/ 300/ 400V AC 0500 500mA 0630 630mA 125 / 250 / 277/ 300/ 400V AC 125 / 250 / 277/ 300/ 400V AC 0800 800mA 1100 1.00A 125 / 250 / 277/ 300/ 400V AC 125 / 250 / 277/ 300/ 400V AC 1125 1.25A 125 / 250 / 277/ 300/ 400V AC 1160 1.60A 125 / 250 / 277/ 300/ 400V AC 1200 2.00A 125 / 250 / 277/ 300/ 400V AC 1250 2.50A 125 / 250 / 277/ 300/ 400V AC 1315 3.15A 1400 4.00A 125 / 250 / 277/ 300/ 400V AC 125 / 250 / 277/ 300/ 400V AC 1500 5.00A 125 / 250 / 277/ 300/ 400V AC 1630 6.30A 125 / 250 / 277/ 300/ 400V AC 1700 7.00A 125 / 250 / 277/ 300/ 400V AC 1800 8.00A 125 / 250 / 277/ 300/ 400V AC 4 932 / OC FUSE 2100 10.00A 125 / 250 / 277/ 300/ 400V AC 2120 12.00A 125 / 250 / 277/ 300/ 400V AC 2125 12.50A 125 / 250 / 277/ 300/ 400V AC 2150 15.00A 125 / 250 / 277/ 300/ 400V AC 2160 16.00A 125 / 250 / 277/ 300/ 400V AC 5. CONSTRUCTION AND MECHANICAL CHARACTERISTICS Construction (cross section) Melting Soldering Sand Inner Core Plastic shell Lead Dimensions (units: mm) 8.3±0.2 4.1±0.2 Operating Temperature: Storage Conditions: Min0.5 7.6±0.40 -55°C to +125°C +10℃ to +60℃ Relative humidity: ≤ 75% yearly average without dew, maximum 30 days at 95% Vibration Resistance: 18.8±1.5mm 0.60±0.1 24 cycles at 15 min. each (60068-6) 10-60Hz at 0.75mm amplitude 60-2000Hz at 10g acceleration 5.08±0.1 Long Leads: L=18.8±1.5mm Short Leads: L=4.3±0.3mm 5 932 / OC FUSE 6. ELECTRICAL SPECIFICATIONS Time vs Current Characteristics Table (measured with constant current power supply) Time vs Current Characteristics: IEC 60127-3/Ⅳ Rated Current 100mA~6.3A 150% >1h 210% 1h 1h
9321315301 价格&库存
很抱歉,暂时无法提供与“9321315301”相匹配的价格&库存,您可以联系我们找货
